1080Ti FTW3 Upgraded with the Hybrid Kit - Problem!
Page: << < ..1112131415.. > >> Showing page 11 of 18
PietroBR
  • Ribbons : 7
Re: 1080Ti FTW3 Upgraded with the Hybrid Kit - Problem! Tuesday, February 27, 2018 1:55 PM (permalink)
mark_thaddeus
Okidoki, I've been trying to figure one more thing about the hybrid kit. How the heck do you turn off the white rectangular bar led near the GPM leds? Very annoying and I'm hoping I don't have to use electrical tape on it.
You don't, as far as I know.
Case: Asus Z370-G Box / MB: Asus Z370-G / CPU: Intel I7 8700K / Mem.: 16GB (2x8) 3000Mhz Corsair Dominator Platinum DDR4 / GPU: GTX 1080TI FTW3 / A.I.O. W.C: EVGA CLC280 / PSU: EVGA SuperNOVA G3 750W
mark_thaddeus
Re: 1080Ti FTW3 Upgraded with the Hybrid Kit - Problem! Tuesday, February 27, 2018 8:31 PM (permalink)
Ugggghhhh! I guess it's time to use electrical tape on that hideous bar of light!
4.6 Ghz 4790k - Z97I Plus - 1080 Ti FTW3 Hybrid - 16 GB HyperX Savage 2133 DDR3 -  Crucial MX500 1 TB - Seasonic SS 660XP Platinum
dual109
Re: 1080Ti FTW3 Upgraded with the Hybrid Kit - Problem! Tuesday, February 27, 2018 10:15 PM (permalink)
PietroBR
mark_thaddeus
Hi,  I was reading in another post which i can't recall now in this forum once you install the kit to get full control of LEDS its best to flash card with the EVGA factory Hybrid Bios so its identified correctly by PXOC allowing you to control LEDs and fans correctly.   The bios is available from techpowerup. Think Sajin was the poster with the link.
mark_thaddeus
Re: 1080Ti FTW3 Upgraded with the Hybrid Kit - Problem! Wednesday, February 28, 2018 3:58 PM (permalink)
dual109
Not too sure I want to flash another bios considering the great clocks I can get with my card right now. Then again, if I get annoyed enough, I just might.
gregts
Re: 1080Ti FTW3 Upgraded with the Hybrid Kit - Problem! Wednesday, March 07, 2018 4:54 PM (permalink)
Same problem here with my kit, clocks don't go above 1569Mhz and when first installed it was locking my whole PC up.
I had come across this post before ordering (boy do I feel dumb now) but I went through with the order hoping to get a new batch...
To cut a long story short, I tried all kinds of configs with the screws in case it was something I had done (overtightened it), same results.
Then I tried it without the shroud off and it worked normally, it still worked with the shroud on but only the 2 front screw in.
Then re-read the whole post here and decided to apply some black electrical tape to the metallic side of the shroud as one of the clips already had tape on top of it.
I also added tape to the point noted in silentmarket's post on page 3 of this post as on the side of the led connectors on the pcb, photos here
Everything works as it should now with all the screws in.
And silentmarket was right, you should double check that the metallic edge is locked inside the shroud, it does get loose.
You have to check that they have clipped in.
My only problem now is the amazingly loud buzzing noise coming from the sound, but that's on another thread hahahaha
If I had known that I was trading a steadier overclock (not higher/that's down to the silicon lottery) due to lower temps to the silence of my air-cooled FTW3 in idle, I might not have purchased this kit...
pics here http s://imgur.com/gallery/pAY2A
post edited by gregts - Thursday, March 08, 2018 6:01 AM
ROG STRIX Z270E GAMING  | 7700K | EVGA 1080ti FTW3 Hybrid | 16GB Gskill 3200 | 960 EVO 512GB | 850 PRO 512GB
PietroBR
  • Ribbons : 7
Re: 1080Ti FTW3 Upgraded with the Hybrid Kit - Problem! Wednesday, March 07, 2018 11:55 PM (permalink)
gregts
For some reason, I cant post the photo of the build and the tape from imgur...
You need a minimun of 10 posts before being able to post links / photos.
You can post it on imgur.com a paste the link with a space on it (like http s://www.imgur.com)
gregts
Re: 1080Ti FTW3 Upgraded with the Hybrid Kit - Problem! Thursday, March 08, 2018 6:00 AM (permalink)
PietroBR
Thanks for the info Pietro!
PietroBR
  • Ribbons : 7
Re: 1080Ti FTW3 Upgraded with the Hybrid Kit - Problem! Thursday, March 08, 2018 10:10 AM (permalink)
gregts
PietroBR
No problem
Oxide36
Re: 1080Ti FTW3 Upgraded with the Hybrid Kit - Problem! Monday, March 12, 2018 8:25 PM (permalink)
Has anyone had success RMA'ing their card without the air cooler? I have this exact issue but no longer have the air cooler (a shop built the system for me and didn't give me the air cooler back). Evga will not accept the RMA without it. This seems absurd as they even said it's a known issue with their own product being defective! And I have the hybrid cooler which essentially makes this a FTW3 Hybrid series card.
I've heard great things about evga and their support but right now I have a $1200 brick and their middle finger.
PietroBR
  • Ribbons : 7
Re: 1080Ti FTW3 Upgraded with the Hybrid Kit - Problem! Monday, March 12, 2018 10:24 PM (permalink)
Oxide36
Sorry to say, but the fault is on the shop that build it to you.
EVGA is pretty clear about their RMA conditions:
Product Warranty Replacement:
  • EVGA CORPORATION reserves the right to check the validity of your warranty and your request for warranty service upon receiving the product.
  • EVGA reserves the right to claim for shipping fees, hold your warranty as well as a service charge from you for any incomplete, damaged or modified product that is returned and requires repair or replacement, or when you are not entitled to any coverage under EVGA's warranty. Service charges are variable based upon the actual material and labor cost to replace missing or modified parts back to their original factory condition.
https://www.evga.com/support/warranty/graphics-cards/
They might charge you a fee for the Heatsink, and later or you can try to get a refund from the store you bought.
It's not EVGA fault the store threw away (or maybe not) the original heatsink.
Doesn't hurt to ask for it also.
mark_thaddeus
Re: 1080Ti FTW3 Upgraded with the Hybrid Kit - Problem! Tuesday, March 13, 2018 11:24 PM (permalink)
Oxide36
You should call that shop and ask for your cooler back. All manufacturer's require that when you RMA a GPU that it should be brought back to it's original state / condition. That's the same for all the Galaxy, MSI and Asus, etc. cards I've RMA'd in the past.
gregts
Re: 1080Ti FTW3 Upgraded with the Hybrid Kit - Problem! Wednesday, March 14, 2018 1:44 PM (permalink)
Hope I don't need to RMA mine (already gone through one of those) but does that mean that I have to find the heatpads that were under the original cooler too?
They pretty much broke in pieces when I remove them (I did the mistake of disassembling the card just after use so they were quite soft...)
PietroBR
  • Ribbons : 7
Re: 1080Ti FTW3 Upgraded with the Hybrid Kit - Problem! Wednesday, March 14, 2018 11:06 PM (permalink)
gregts
you mean the thermal pads?
You can always buy some and put there to replace it.
If I'm not mistaken, those are 1.5mm thermal pads.
TahoeDust
Re: 1080Ti FTW3 Upgraded with the Hybrid Kit - Problem! Wednesday, March 14, 2018 11:47 PM (permalink)
So, I am gathering this kit should be avoided?  I was finally ready to pull the trigger, then read all the problems.  Are any of the other AIO options out there any good?
post edited by TahoeDust - Wednesday, March 14, 2018 11:51 PM
AHowes
  • Ribbons : 27
Re: 1080Ti FTW3 Upgraded with the Hybrid Kit - Problem! Thursday, March 15, 2018 0:05 PM (permalink)
Go for it.. not like evga won't replace it if it brakes your card.
Asus Z390 ROG Extreme XI MB
TahoeDust
Re: 1080Ti FTW3 Upgraded with the Hybrid Kit - Problem! Thursday, March 15, 2018 0:19 PM (permalink)
AHowes
Hmmm...So, if I do "Go for it", anyone care to give me the cliffs on steps to take to decrease the chances of issues?
AHowes
  • Ribbons : 27
Re: 1080Ti FTW3 Upgraded with the Hybrid Kit - Problem! Thursday, March 15, 2018 0:23 PM (permalink)
Seems like it's just the metal outer shroud. The end part can be loose and make sure it's snapped into place before attaching the shroud.
dual109
Re: 1080Ti FTW3 Upgraded with the Hybrid Kit - Problem! Thursday, March 15, 2018 2:14 AM (permalink)
TahoeDust
AHowes
Read this thread there are many pointers regarding the installation of the kit as the instructions are vague.   There's one at the top of this page.  "Make sure you card is cool before ripping off heatsink if you want to retain your thermal pads"   I've had my kit in a box since december and I'm glad I have and I'm still in two minds about installing it with all the other reports of pump noise and the minimal cooling benefits I've been hearing.
TahoeDust
Re: 1080Ti FTW3 Upgraded with the Hybrid Kit - Problem! Thursday, March 15, 2018 2:21 AM (permalink)
dual109
I read through the thread and just ordered it.  Buy once cry once, no guts no glory, it's only money, etc....
gregts
Re: 1080Ti FTW3 Upgraded with the Hybrid Kit - Problem! Thursday, March 15, 2018 8:32 AM (permalink)
TahoeDustI read through the thread and just ordered it.  Buy once cry once, no guts no glory, it's only money, etc....
Good luck mate. I hope you get the most out of it!
My experience has been mixed as I got the batch with the wonky metal shroud and a very loud pump.
1. Make sure your card is cool before ripping off heatsink if you want to retain your thermal pads as dual109 pointed out. I didn't and they turned into putty.
2. When removing the shroud be very careful when prying out the top led cable (the short one next to the power connectors). It can be a bugger to unclip.
I chipped the header & cut one of the cables. I will have to solder it back in should I ever need to use the stock cooler again.
3. Check that the metal shroud is clipped in properly as shown by silentmarket in this post. His whole post is a lifesaver.
Not checking his post can result to anything from no boost on the card all the way up to complete system lockups. I experienced all of it.
As I had already RMA'ed my new FTW3, I could be bothered to go through all that again, so I ended up taping both the shroud and the PCB contacts he proposes.
pics here.
4. As for the pump...I guess that's just down to luck.
I am sure a lot of folks here are enjoying their purchase but in hindsight, I could easily say that I would never buy a kit again, just too much hassle for me.
I would deffo buy a watercooled GPU but AFTER reading around about the pump noise.
The pump noise is very annoying in my dead silent case and I ended up having to customize my card to alleviate this - which is crazy after spending so much money.
Temp differences are substantial (depending on your case/fan setup) but you will have to run your fan at a high speed for that and the fan provided is loud.
I am running both the radiator fan (using a 4pin Silent Wings 3 fan) and the pump (with a cable extension) from my mobo headers (after flashing the slave vbios with an Asus fw) to be able to control everything through AI Suite.
Pics here https://imgur.com/a/wJoCk
Now, everything runs dead silent when idle and the card temps run around 55C when gaming. Bear in mind that I am getting these temps while undervolting (0,900) and running my card at 1860mhz..
If I OC my card, I have to crank up my fan speeds and it still runs around 60-65C. Hoping for better all around temps when I switch from my Fractal Meshify C to a Fractal R6 TG next month.
And since I wrote all this, I just want to add that I wish EVGA includes pump speed controls in XOC next time around and a better fan or at least a 4pin header allowing us to connect a custom pwm fan that can be controlled via XOC...
Their support team has been uber helpful and I love the brand (this is my second ftw card) but if these are not included, I think I will be buying an asus card. Aura and control via Ai suite are an unbeatable combo for me.
post edited by gregts - Thursday, March 15, 2018 10:32 AM
dual109
Re: 1080Ti FTW3 Upgraded with the Hybrid Kit - Problem! Thursday, March 15, 2018 11:11 AM (permalink)
gregts
pics here.
Great pointers, just like to add that in the manual it asks you to remove the back plate although I haven't installed my kit yet I've read a couple of posts saying its unnecessary.
Icarus2
Re: 1080Ti FTW3 Upgraded with the Hybrid Kit - Problem! Friday, March 16, 2018 9:03 AM (permalink)
New user here. This problem has happened to me TWICE now :( I recently bought a gaming PC off craigslist (I know, I know...) and it had a FTW3 and Hybrid kit already installed. Guy said the computer worked great and a quick inspection with the device manager looked good - but when I got it home, I immediately noticed the card was under-performing. After some benchmarks and tests, I came across this forum - contacted EVGA and was approved for Cross-Ship RMA's on both items because it was "a known issue". Today - I received both the new FTW3 and Hybrid Kit. First, I threw the FTW3 into the computer (stock air cooler) and was super happy because I finally had a card that was working properly, getting GREAT benchmark scores. Then, I verrrrrrry carefully installed the new hybrid kit and....the same problem happened again :((( VVDC during benchmarks stays at 0.7810 voltage - Card is locked at 1569Mhz and EVGA Precision crashes if I touch ANYTHING.
I'm completely defeated at this point. Going to bed now - will contact EVGA to see what can be done but I'm not feeling hopeful at his point...
PietroBR
  • Ribbons : 7
Re: 1080Ti FTW3 Upgraded with the Hybrid Kit - Problem! Friday, March 16, 2018 11:14 AM (permalink)
Icarus2
The hybrid kit itself was correct before installing? (The back grill was loose or locked up?)
I remember someone here saying that the grill might not be the issue alone. If I wasn't mistaken, looks like it was a power surge on the pump/VRM Fan that was damaging the Voltage controller on the card. Something like that a EVGA representant said to him.
gregts
Re: 1080Ti FTW3 Upgraded with the Hybrid Kit - Problem! Friday, March 16, 2018 11:43 AM (permalink)
Icarus2
Welcome to the forums Icarus.
Sounds like you have the problems everyone is having with this batch of kits (myself included).
To me, you have 2 options. Either RMA the kit and hope that the one that you receive fits perfectly or you just remove the kit, read my post and follow the steps pointed out by everybody here.
As I wrote, if you make sure that the metal shroud is clipped in properly and you tape the areas pointed out in silentmarket's post, the card should work perfectly...
AHowes
  • Ribbons : 27
Re: 1080Ti FTW3 Upgraded with the Hybrid Kit - Problem! Friday, March 16, 2018 5:04 PM (permalink)
Remove the kit and install the stock cooler back on and test the card..
Also inspect the hybrid cooler shroud and see if the metal end on it is snapped into place or loose.
If it's loose and you can snap it back into place then try installing the hybrid cooler again. That's all if the card is performing correctly before hand.
TahoeDust
Re: 1080Ti FTW3 Upgraded with the Hybrid Kit - Problem! Monday, March 19, 2018 5:26 PM (permalink)
Well....I just got done installing the kit on the card.  I have not installed it into my machine yet.  It seems like I have an awful lot of hardware left.  Should that be the case?
gregts
Re: 1080Ti FTW3 Upgraded with the Hybrid Kit - Problem! Monday, March 19, 2018 5:31 PM (permalink)
What kind of kit. Other than the fan cooler and the screws, no. Not that I know of anyway.
TahoeDust
Re: 1080Ti FTW3 Upgraded with the Hybrid Kit - Problem! Monday, March 19, 2018 7:43 PM (permalink)
Yep...the extra hardware were the screws and washers for the radiator install.  I swapped the stock fan for one of my static pressure Phanteks and am controlling it with my NZXT Grid+.  Very very awesome.  Completely silent and am 5 minutes into Unigine stress test at 2025MHz and the high temp is un 60c.
What is the best way to control the pump speed?
gregts
Re: 1080Ti FTW3 Upgraded with the Hybrid Kit - Problem! Monday, March 19, 2018 9:56 PM (permalink)
Good to hear man, enjoy it.
Read my previous posts, also check these pics.
The pump noise was driving me crazy...
I bought an adaptor and I am running the pump cable coming out the back of the card, going to a mobo header, so I can control it through Argus (read more on why I am using Argus Monitor over AI Suite here)
TahoeDust
Re: 1080Ti FTW3 Upgraded with the Hybrid Kit - Problem! Monday, March 19, 2018 10:12 PM (permalink)
gregts
Thanks.  I checked out the pictures.  I guess I got lucky because I do not have any audible pump noise.  By default is the pump running at max?  With it running off one of the fan headers, I thought maybe I could adjust pump speed with PrecisionX.  Also, is there any reason to flash the bios of the card to the FTW3 Hybrid bios?  I thought I read somewhere that some have done that.  Sorry for the newbish questions.  I promise I kind of know what I am doing...haha.
Also, thanks to everyone who has contributed to this thread.  It helped save me from some of the same issues others had.
