1080Ti FTW3 Upgraded with the Hybrid Kit - Problem!
Page: 12345.. > >> Showing page 1 of 18
TimStoll
2017/10/10 06:19:37 (permalink)
Hey Guys, I have a problem with the Hybrid Kit for the FTW3. I recently upgraded my FTW3 with the Hybrid Kit and since that, the Precision Software from EVGA is going Crazy... I installed the Kit properly and everything works fine technically but Precision doesn't recognize my Card as a Hybrid. It says it's a FTW3 and when I try to OC the Card to +60 Core the Screen Freeze for about 10-30 seconds and after that the Clock speeds don't get higher as 1569Mhz... I tried both Master and Slave and I have absolutely no clue... the german Support told me to untighten the screws from the Card 'cause this solves about 98% the problems people have. I didn't tighten the screws that hard in the first place... Hope you guys can help me in some way... sry for my german english :D
511 Replies Related Threads
    DeathAngel74
    • Ribbons : 10
    Re: 1080Ti FTW3 Upgraded with the Hybrid Kit - Problem! 2017/10/10 06:55:05 (permalink)
    Has this ever happened before you installed the Hybrid kit?
    Carnage specs:
    Motherboard: ASUS ROG STRIX X299-E GAMING | Processor: Intel® Core™ i7-7820x | Memory Channels#1 and #3: Corsair Vengeance RGB 4x8GB DDR4 DRAM 3200MHz | Memory Channels#2 and #4: Corsair Vengeance LPX Black 4x8GB DDR4 DRAM 3200 MHz | GPU: eVGA 1080 TI FTW3 Hybrid | PhysX: eVGA 1070 SC2 | SSD#1: Samsung 960 EVO 256GB m.2 nVME(Windows/boot) | SSD#2&3: OCZ TRION 150 480GB SATAx2(RAID0-Games) | SSD#4: ADATA Premier SP550 480GB SATA(Storage) | CPU Cooler: Thermaltake Water 3.0 RGB 360mm AIO LCS | Case: Thermaltake X31 RGB | Power Supply: Thermaltake Toughpower DPS G RGB 1000W Titanium | Keyboard: Razer Ornato Chroma | Mouse: Razer DeathAdder Elite Chroma | Mousepad: Razer Firefly Chroma | Operating System#1: Windows 7 SP1 Ultimate X64 | Operating System#2: Linux Mint 18.2 Sonya (3DS Homebrew/Build Environment)
    TimStoll
    Re: 1080Ti FTW3 Upgraded with the Hybrid Kit - Problem! 2017/10/10 06:57:17 (permalink)
    Nope... its the first Time ever :/
    • Ribbons : 282
    Re: 1080Ti FTW3 Upgraded with the Hybrid Kit - Problem! 2017/10/10 09:49:31 (permalink)
    Remove PXOC and NVIDIA Drivers and Delete the Profile Folder.
    Run DDU in Safe Mode and then Install the NVIDIA Driver you want to use restart your PC and Install PXOC and see how they run.
    Re: 1080Ti FTW3 Upgraded with the Hybrid Kit - Problem! 2017/10/10 11:03:43 (permalink)
    Precision isn't going to recognize your ftw3 card as a ftw3 hybrid card as your current card doesn't have the hybrid vbios loaded to it. I bet your driver crashed and recovered when the screen froze.
    When the graphics driver crashes & recovers during a 3d load clocks will get locked to a lower value until you close the 3d app & let the card return to idle clocks (139/405). Sometimes you'll need to reboot the machine to restore normal clocks.
    A unstable overclock can cause the screen to freeze up & the driver to crash & recover. +60 seems to be too high of an overclock for your card. Start with +20 and work your way up in +20 increments.
    post edited by Sajin - 2017/10/10 11:05:45
    Tiffo60
    Re: 1080Ti FTW3 Upgraded with the Hybrid Kit - Problem! 2017/10/10 12:17:38 (permalink)
    I agree with this guy. My FTW3 will boost to 2025 with just a +25 on the core clock while the temps are below 40c which that lasts about 10 seconds lol.
    Thermaltake Core X9
    Evga X99
    I7-5930K
    Evga GTX 1080ti FTW3
    Corsair Dominator Platinum C15 32Gb 3000mhz
    EVGA SuperNova 1600 P2
    DeathAngel74
    • Ribbons : 10
    Re: 1080Ti FTW3 Upgraded with the Hybrid Kit - Problem! 2017/10/10 12:21:46 (permalink)
    My hybrid boosts to 2037 (+50) @1.093v. 1070 sc2 boosts to 2037 +(72) @ 1.081v.
    Carnage specs:
    Ranmacanada
    Re: 1080Ti FTW3 Upgraded with the Hybrid Kit - Problem! 2017/10/10 12:36:22 (permalink)
    I agree with Sajin.  Your card will NEVER be recognized as a Hybrid because it's not a factory Hybrid.  Period.  As for your clocks, when the driver crashes, all hell breaks loose.  Just because you installed a Hybrid kit doesn't mean you will automagically get a better overclock.  It still comes down to the silicon lottery.  FTW3 is a pretty high clocked card to begin with and is almost at it's max out of the box.  I myself have a 1080Ti Hybrid that is a serious lottery winner as it can run at 2133 stable all day everyday while folding, but when the driver crashes, it gets locked at 1974 and I need to reboot the entire system to get it back to overlcocked values again.  I now run it at only 2075 and since then the driver hasn't crashed in over a month, so it is now truly stable.
    ASUS TUF GAMING X570-PLUS (WI-FI)
    AMD Ryzen 2700
    Fold for the CURE!
    EVGA 1080 FTW
    EVGA 1080Ti Hybrid
    TimStoll
    Re: 1080Ti FTW3 Upgraded with the Hybrid Kit - Problem! 2017/10/12 06:05:00 (permalink)
    Thanks for your Help guys! It's not about overclocking the Card, it's about PrecisionX. Without ANY changes to the Clocks my Card will not get any higher as 1569Mhz. I have no clue what to do. And when I make only one change with the Tool like +1Mhz to the Core Clock, the Cursor is stuttering and it seems to be a massive input Lag -.-
    TimStoll
    Re: 1080Ti FTW3 Upgraded with the Hybrid Kit - Problem! 2017/10/12 07:33:02 (permalink)
    Ok so every time I make a Change in the Tool for example only setting the Temp Target to 89° Celsius, the program freezes, black screen, some green and black dots (lol) and then I'm back at my desktop but the highest possible Clocks are 1569Mhz... I also deleted and installed the Nvidia Driver in a complete way (delete folders, registry etc.)... I also switched the PCIe Lane on my MB, but nothing seems to solve the problem -.-
    • Ribbons : 123
    Re: 1080Ti FTW3 Upgraded with the Hybrid Kit - Problem! 2017/10/12 07:42:18 (permalink)
    GPU Temperature ?
    CPU Temperature ?
    MB Temperature ?
    Room Temperature ?
    OS ?
    Nvidia driver # ?
    Nvidia Control Panel settings ?
    Windows device Manager -- issues ? (yellow circles)
    What benchmark software are you running to test GPU ?  GPU will Only OC if needed
    CPU, MB, RAM and ANY overclocking ?
    Test GPU with Stock (no OC) on your CPU & RAM
    Can Also be a sign of Unstable Power - check
    Card fully seated ?
    Wall outlet / source
    PSU
    Power cable from PSU to card - (swap with spare cable and different PSU output if possible)
    TimStoll
    Re: 1080Ti FTW3 Upgraded with the Hybrid Kit - Problem! 2017/10/12 07:52:17 (permalink)
    -Windwos 10 64Bit
    -Nvidia Driver 387.92
    -PrecisionX Version 6.1.16
    -Nope, no yellow circles. everything is fine
    -I'm running FurMark GPU Stress Test Version 1.19.0.0
    -Yes I resetted every change I made in the Bios to default
    -Temperatures:
    MB 29°
    CPU 40°
    GPU 24°
    Room 21°
    I will check the Cables! thx
    post edited by TimStoll - 2017/10/12 07:55:01
    TimStoll
    Re: 1080Ti FTW3 Upgraded with the Hybrid Kit - Problem! 2017/10/12 08:11:18 (permalink)
    Update: I changed the PSU Cables but it didn't helped... my PSU is a Corsair AX1200i from a previous build I had, so the Power must be enough for this Card :D
    My Build is a:
    -i7 4770k
    -Asus Maximus VI Formula
    -32GB G.Skill Ripjaw 2400Mhz DDR3
    post edited by TimStoll - 2017/10/12 08:13:50
    • Ribbons : 123
    Re: 1080Ti FTW3 Upgraded with the Hybrid Kit - Problem! 2017/10/12 08:12:29 (permalink)
    Did you check this thread ? Basic troubleshooting steps. Windows clean boot, clean driver install, debug mode, etc.
    What other GPUs have been in this PC ?
    Other thoughts:
    - Download the Newest Nvidia driver -- direct from Nvidia
    - Download Precision XOX 6.1.14
     Uninstall Precision XOC
         1) Make sure when you remove Precision XOC, you then reboot
         2) then you Manually remove the Precision Folder off your drive - look in Program Files (x86), then reboot
    2B) After removing Precision
         Run DDU in default (safe mod with reboot) to remove all traces of old GPU driver
         Go offline, stop all background software - Including Security Software
         NOW --use the Custom install Nvidia driver with Clean install --ONLY install GPU driver & PhysX   ---> DO NOT install anything else (3D, Sound ....)
         3) Now Reinstall Precision, with nothing else running - pull the internet connection - kill security and any other item that's running - Reboot again
    Note: on newer GPU cards, After you install XOC, shutdown PC, remove the power cord from wall, Remove All Powered accessories (monitor, USB hub ...) press and hold power button on PC 30 seconds - discharge all capacitors, plug everything back in & Restart your PC
    post edited by Cool GTX - 2017/10/12 08:49:03
    TimStoll
    Re: 1080Ti FTW3 Upgraded with the Hybrid Kit - Problem! 2017/10/12 08:39:14 (permalink)
    ok so I did all the steps with the DDU and followed everything step by step and checked twice... but nothing is working... Still one change in Precision -> Freeze -> Black -> Desktop -> not higher than 1569Mhz...
    I don't think I broke something because technically everything works fine and I was super careful as I always been in my four previous custom Watercooled PC's :/
    I hope this is not gonna be a RMA
    The LED's are working, the Pump is quite, the Temps are low... the only thing that doesn't work is that the clocks don't get over 1569Mhz... I'm so confused
    Re: 1080Ti FTW3 Upgraded with the Hybrid Kit - Problem! 2017/10/12 08:47:21 (permalink)
    Completely uninstall precision x, reboot pc, retest furmark without precision x installed.
    TimStoll
    Re: 1080Ti FTW3 Upgraded with the Hybrid Kit - Problem! 2017/10/12 11:57:30 (permalink)
    Tested it, same Clockspeed :/ I will run it for the next hour to see if something happen...
    http://www.bilder-upload....=0b0466-1507834632.jpg
    Re: 1080Ti FTW3 Upgraded with the Hybrid Kit - Problem! 2017/10/12 12:01:44 (permalink)
    Do you experience the issue on both vbioses?
    TimStoll
    Re: 1080Ti FTW3 Upgraded with the Hybrid Kit - Problem! 2017/10/12 12:08:19 (permalink)
    Nope, ever since I upgraded to the Hybrid.
    There is also no difference between Master and Slave Bios relating to my problem
    Re: 1080Ti FTW3 Upgraded with the Hybrid Kit - Problem! 2017/10/12 12:13:55 (permalink)
    Does the issue only occur in furmark, or does it occur in all applications as well? If all applications...
    Reinstall the stock cooler to see if it helps make the issue go away. If the issue presists after installing the stock cooler test the card in another pc (family, freind, or local pc shop), or just rma the card.
    joao.pl.vicente
    Re: 1080Ti FTW3 Upgraded with the Hybrid Kit - Problem! 2018/01/02 14:30:53 (permalink)
    Hi guys,
    I am having the same issue...
    Followed all possible guides to fix it but still no progress! After installed Hybrid Kit, everytime I open the PXOC the computer freezes, black screen until I restart it again... small increments like +1 Mhz is enought to crash.
    Stock speeds everything is fine, bench without crash or artifacts, plays well...
    DO you guys have any other info regards this topic?
    Cheers
    p.s - I used Afterburn and Nvidia Inspector but also crashed every small OC.
    post edited by joao.pl.vicente - 2018/01/02 14:33:44
    Zaruchen
    Re: 1080Ti FTW3 Upgraded with the Hybrid Kit - Problem! 2018/01/02 17:52:44 (permalink)
    I had this issue with one of my RMAd cards where it refused to run more than 780 mv and anything changed to the card like fans or clocks will freeze
    Processor: Intel® Core™ i9-9900K CPU @ 5GHz
    Memory: 32GB @ 3600Mhz
    Hard Drive: 2x Samsung Evo 850 1TB, Samsung 970 Pro 1TB NVME
    Video Card: NVIDIA GeForce GTX 3090 Ti FTW3 + Hybrid Kit
    Motherboard: Asus ROG MAXIMUS XII HERO (WI-FI AC)
    Computer Case: Corsair 570x
    hopk2621
    Re: 1080Ti FTW3 Upgraded with the Hybrid Kit - Problem! 2018/01/05 12:08:51 (permalink)
    Hey guys,
    I am having the exact same issues. Just installed the hybrid kit yesterday. Uninstalled and reinstalled all drivers. Core clock is stuck at the exact speed mentioned by the poster and any attempt to OC will cause a freeze or crash. I can OC memory, but not core clock. Stock it is fine and works with any of the games I'm playing, but maxes out at 1569Mhz. Any advice? RMA?
    Thanks
    #23
    • Ribbons : 135
    Re: 1080Ti FTW3 Upgraded with the Hybrid Kit - Problem! 2018/01/05 12:23:15 (permalink)
    hopk2621
    Hey guys,
    Thanks
    Did you reinstall the stock cooler and the GPU operates correctly?
    #24
    hopk2621
    Re: 1080Ti FTW3 Upgraded with the Hybrid Kit - Problem! 2018/01/05 12:35:23 (permalink)
    Not yet. I just discovered this issue after installing the kit last night. That would be the next logical step to determine whether anything was damaged during the installation. I'll do that and see if it still works as well as it did before.
    #25
    • Ribbons : 135
    Re: 1080Ti FTW3 Upgraded with the Hybrid Kit - Problem! 2018/01/05 15:32:33 (permalink)
    hopk2621
    It could be coincidence...but nearly identical issues when installing the same mod on the same product makes one wonder if there isn't a fitment problem where something is making electrical contact where it should not.
    #26
    AHowes
    • Ribbons : 27
    Re: 1080Ti FTW3 Upgraded with the Hybrid Kit - Problem! 2018/01/05 20:29:32 (permalink)
    hopk2621
    You totally right.. someone screwed up on the design. Something is touching something it shouldn't.
    Asus Z390 ROG Extreme XI MB
    #27
    hopk2621
    Re: 1080Ti FTW3 Upgraded with the Hybrid Kit - Problem! 2018/01/07 10:55:19 (permalink)
    hopk2621
    Could the voltage be the problem? Here is a screenshot taken from GPU-Z while running the Heaven benchmark and it shows the 1569 MHz limit mentioned above.
    #28
    • Ribbons : 135
    Re: 1080Ti FTW3 Upgraded with the Hybrid Kit - Problem! 2018/01/07 11:03:01 (permalink)
    hopk2621
    hopk2621
    Yes, your VDDC (essentially GPU core voltage) should be ~1v or higher under load.
    #29
    greekie
    Re: 1080Ti FTW3 Upgraded with the Hybrid Kit - Problem! 2018/01/09 21:26:36 (permalink)
    Same thing is happening with me.
    I reinstalled the shroud three times, as well as the back plate. Temps are great, games run great, but as soon as I load up PXOC or Afterburner, system locks up.
    I installed the original heatsink and still suffering the same symptoms.
    I guess its just time to RMA :(
    #30
