my monitor has dp1.2 and my gpu has dp 1.4 what cable should i use dp 1.2 or dp 1.4
hawad
2020/03/25 23:03:27 (permalink)
Hey there.
My monitor has dp1.2 and  my gpu has dp 1.4.
  what cable should i use dp 1.2 or dp 1.4 ?
8 Replies Related Threads
    • Ribbons : 86
    Re: my monitor has dp1.2 and my gpu has dp 1.4 what cable should i use dp 1.2 or dp 1.4 2020/03/26 00:13:44 (permalink)
    For future proofing I suggest using an approved 1.4 DP cable
    hawad
    Re: my monitor has dp1.2 and my gpu has dp 1.4 what cable should i use dp 1.2 or dp 1.4 2020/03/26 00:40:27 (permalink)
    but will not get advantages of 1.4   because my monitor support dp 1.2  is this right ? or I misunderstood?
    tdkid1
    Re: my monitor has dp1.2 and my gpu has dp 1.4 what cable should i use dp 1.2 or dp 1.4 2020/03/26 04:34:58 (permalink)
    there is no such thing as this or that type cable. its just cable whether you bought it today of 15 years ago its just an electrical signal to your monitor to tell it what it needs to display. with this being said you are limited to what your monitor can do. mine for example is a TV in which I am stuck at 56hz which is fine for me as I don't hardcore game that requires a 240hz monitor.
    a good teacher will not give you the answer you seek, they will help you learn as to why you had that problem and will guide you to the solution that works for it so you can pass the knowledge on.
    Associate Code: RJVGCE38ZNYRH45
    Rewards Program Code is: ISWBJCPO8X
    • Ribbons : 123
    Re: my monitor has dp1.2 and my gpu has dp 1.4 what cable should i use dp 1.2 or dp 1.4 2020/03/26 07:30:25 (permalink)
    You do not need an expensive DP cable   You DO Need a Certified cable
    How to Choose a DisplayPort Cable, and Not Get a Bad One! - DisplayPort
    Products Database - DisplayPort
    Re: my monitor has dp1.2 and my gpu has dp 1.4 what cable should i use dp 1.2 or dp 1.4 2020/03/26 08:08:03 (permalink)
    https://www.amazon.com/gp/product/B0767F5DNR
    1.4 cables are backwards compatible with 1.2 devices.
    aka_STEVE_b
    EGC Admin
    • Ribbons : 69
    Re: my monitor has dp1.2 and my gpu has dp 1.4 what cable should i use dp 1.2 or dp 1.4 2020/03/26 08:29:03 (permalink)
    Exactly what I was going to recommend.  Newer cables are almost always backward compatible, so get that.
    AMD RYZEN 9 5900X  12-core cpu~ ASUS ROG Crosshair VIII Dark Hero ~ EVGA RTX 3080 Ti FTW3~ G.SKILL Trident Z NEO 32GB DDR4-3600 ~ Phanteks Eclipse P400s red case ~ EVGA SuperNOVA 1000 G+ PSU ~ Intel 660p M.2 drive~ Crucial MX300 275 GB SSD ~WD 2TB SSD ~CORSAIR H115i RGB Pro XT 280mm cooler ~ CORSAIR Dark Core RGB Pro mouse ~ CORSAIR K68 Mech keyboard ~ HGST 4TB Hd.~ AOC AGON 32" monitor 1440p @ 144Hz ~ Win 10 x64
    • Ribbons : 86
    Re: my monitor has dp1.2 and my gpu has dp 1.4 what cable should i use dp 1.2 or dp 1.4 2020/03/26 08:32:19 (permalink)
    Yes and as suggested above get a certified cable. Otherwise you're stuck with a cheap quality cable which may not work well.
    Hoggle
    Re: my monitor has dp1.2 and my gpu has dp 1.4 what cable should i use dp 1.2 or dp 1.4 2020/03/26 09:57:37 (permalink)
    Now days the cables are being made to be more and more universally backwards compatible so think of it more like USB.
