RTX 2070 Super FTW3 Gaming Ultra Fan Problem
FlopperBTW
2023/02/04 20:56:44 (permalink)
Hey y'all, I just recently (2 days ago) picked up a 2070 Super FTW3, and I'm curious about the fan stop function, well, more of, I have a problem with it. The card absolutely refuses to stop "fan1" no matter what, even when set to zero in X1, is this fixable?
2 Replies Related Threads
    Thekelz
    Re: RTX 2070 Super FTW3 Gaming Ultra Fan Problem 2023/02/05 01:11:32 (permalink)
    FlopperBTW
    Pins in the header that controls fan and RGB connections could be bent or the fan itself might not be connected to it's own header fully. Recently had an issue where my fan would work at 100% no matter what, it was fixed by the technician. He found a bent pin in the header, but the fan itself was also not connected properly. You might wanna check it out.
    bob16314
    • Ribbons : 761
    Re: RTX 2070 Super FTW3 Gaming Ultra Fan Problem 2023/02/05 05:32:41 (permalink)
    That card has Dual-BIOS..If the BIOS is in the "OC" position, fan 1 will never stop..Slide the BIOS switch to "Normal" which will allow for Zero-Fan operation..Switch to the "Normal" BIOS and restart your PC, roll from there.
