wildwill
Re:Corsair 800D Water Cooling Build Thread
2012/10/25 11:52:58
Few more fittings arrived today so i can re arrange a few runs of tubing -
Asus Maximus Gene VI Intel 4770K Intel 520 Series 240GB SSD WD Caviar Black 2TB Asus 980 Matrix Platinum Hyper X Savage 8GB 2400MHz Silverstone Strider Gold 850 Watt Asus ROG Swift Corsair Vengeance K60 Gaming Keyboard Corsair Vengeance M60 Gaming Mouse Windows 8.1 64 Bit
wildwill
2012/10/27 21:09:17
New memory arrived today Corsair Vengeance LP 8GB 1866MHz - I previously had 16GB of Corsair Vengeance but i was going to water cool them then i decided not 2 so they are useless now in Bitspower water block shrouds. 8GB is more then enough and i may upgrade to 16GB again down the road. I wanted a low profile and clean look and this ram def provides that!
wildwill
2012/10/30 09:53:55
I was originally going to use a OCZ Agility SSD to replace my Intel 520 series SSD that is re located in to the interior of my case but - I stumbled upon this SSD and it just might be that much sexier. This is mainly for show but i will load it up with music and pics to get some use out of it.
Angrychair420
- Ribbons : 5
2012/10/30 13:22:18
hurry up with your build, you started before me, and I had to RMA 2 video cards
wildwill
2012/10/30 17:24:05
nookie420 hurry up with your build, you started before me, and I had to RMA 2 video cards LOL i should be done soon and i just ordered a Koolance dual pump bay res as well to help clean things up in the case a little.
buggyruth
2012/10/30 18:01:21
Looks good! Sometimes cleaning up the case & cabling is the hard part.
+1 If you like my Mods-Rig http://www.heatware.com/eval.php?id=78759 COOLER MASTER HAF X RC-942-KKN1 / EVGA Z77-FTW / Intel I7-3770K / 2 X Corsair Force Series GT 240GB. SSD Raid-0 / Western Digital Caviar Black WD2002FAEX / G.SKILL Trident X Series F3-2400C10D-16GTX / 2 X EVGA GeForce GTX 670-FTW+4GB. (04G-P4-3673-KR) with EK GeForce 680 GTX VGA Liquid Cooling Blocks - Acetal CSQ (EK-FC680 GTX - Acetal CSQ) / Swiftech Maelstrom 51/4" dual bay reservoir with dual MCP35X pumps / RayStorm CPU WaterBlock (Intel) Copper / XSPC RX360 Rad & XSPC EX140
wildwill
2012/10/30 18:18:27
After months of changing hardware out,testing the computer,and just trying to make any improvements i can i have come up with some final changes - Ordered - Koolance RP-452X2 Dual 5.25in Reservoir Rev.2.0 - This will allow me to eliminate my internal tube res,pump bracket,pump out of view completely. Swiftech MCP655 With Speed Control - I will be installing this in edition to my current D5 pump in the Koolance bay res for maximum pumping power. Corsair Air Series AF140 Quiet Edition High Airflow 140mm Fan - This will replace the Apevia 140mm UV green led fan installed in the mid panel.
wildwill
2012/10/30 18:19:46
buggyruth Looks good! Sometimes cleaning up the case & cabling is the hard part. TY sir and after these new additions the interior of the case should be as tidy as possible.
buggyruth
2012/10/30 18:22:50
Those should work nicely. I put in a Swiftech dual bay dual pump 35x in mine real happy with it! You can see it in my Mods rig page.
wildwill
2012/10/30 18:29:20
Very nice sir and i had a Maelstrom but after having some plasticizer issues the internals of the res has a coating on the walls i can't remove so i just have it sitting here.
wildwill
2012/10/30 18:31:21
buggyruth
2012/10/30 18:33:04
Thank you! The plasticizer problem is a bummer. Your updates are looking great, post us some final pics!
wildwill
2012/10/30 19:27:41
I will be adding a Coldzero Bay Side Plate as well to cover all the latching mechanisms and i have 2 options - Hexx - Or Open Frame ? -
wildwill
2012/11/05 11:53:40
wildwill
2012/11/06 11:33:56
Vlada011
- Ribbons : 11
2012/11/06 12:40:28
Koolance make fantastic things.
wildwill
2012/11/07 10:26:56
Finally decided and placed my for a Coldzero Bay Side Cover (Open Frame) - This will cover up all the 5.25'' bay latching mechanisms and give a real clean look when ever i remove the side panel. Like this - Decided on the following MDPC sleeving for my 8 pin power,24 pin power,4X 6 pin pci-e power connectors - TOXIC GREEN - AQUAMARINE-BLUE MKII - I chose these blue because it comes close to matching the rings on all the Corsair SP fans in this build. The Toxic Green will be the main sleeving but i may incorporate some of the Aqua Blue as well.
wildwill
2012/11/08 20:18:28
I changed the name of the build thread because over the course of the Winter i will be having custom air brushing done to this case. Because of the coolant i will be using(Mayhems Pastel Mint Green) i will be going with a Teenage Mutant Ninja Turtles II: The Secret of the Ooze theme - I have plans so far just to air brush the front and rear panels but things may change as time goes on. I also should have some renders tomorrow of my custom 670 ftw VGA back plates so i look foward to sharing those.
wildwill
2012/11/12 18:47:44
Ordered a few things tonight so i can make some changes and get closer to finishing this build - Durelene PVC Tubing Clear 1/2in. ID x 3/4in. OD - 30' I have a long tube run from my top GPU right port to the Koolance bay res so i figured a Koolance quick disconnect would come in handy along this run. Koolance QDC (High Flow) No-Spill Shutoff, Female Koolance QDC (High Flow) No-Spill Shutoff, Male Mayhems Pastel Mint Green Concentrate 250ML - Corsair Air Series AF140 Quiet Edition High Airflow 140mm Fan - I need this for the HD cage 140mm mount since i re located the AF140mm that was there to the mid panel 140mm mount. I also ordered my custom 670 FTW back plates as well from Coldzero but i won't show them until they arrive!
Simba123
- Ribbons : 14
2012/11/12 23:43:12
Props for an awesome build. Love reading through the evolution of this build. Keep up the great work! +1
wildwill
2012/11/13 09:30:04
Installed the Koolance res to check for leaks and function - I have the pump at level 3 right now and i get vibration noise so i will work on that issue when i install the 2cd D5 pump.
wildwill
2012/11/13 09:32:14
Simba123 Props for an awesome build. Love reading through the evolution of this build. Keep up the great work! +1 TY for following sir and i will continue to make quality improvements.
wildwill
2012/11/14 23:12:27
Going to replace all the 6MM Phillips head screws on the internal EX360 rad with these - I love the look of these oppose to a Phillips head and should add more of a premium look. I would like to replace the exterior 30MM Phillips head screws holding the rad to the case but Frozencpu does not carry that size in the above style.
post edited by wildwill - 2012/11/16 10:08:43
wildwill
2012/11/16 10:02:46
30' of Durelene for the next phase of this build -
Dejahboi
2012/11/18 22:50:16
Aren't you over at OCN as well? lol
Case: Corsair 800D Mobo: Asrock P67 Extreme 4 Gen 3 CPU: I5-3750K GPU: EVGA GTX 680 PSU: XFX Platinum PRO 1000W OS: Windows 8 Pro 64-bit
wildwill
2012/11/19 15:42:52
Yes lol I have been a member here for much longer though.
wildwill
2012/11/19 16:24:03
Small update for now - I installed a few of the Blue screws on the mobo already and they fit perfect and look great.I will install the rest of them once i break down the loop again in a week or 2 and take pics. The stock screws the EX360 came with have a wider head so they did chip some paint off but i do like this style of screw better -
Angrychair420
- Ribbons : 5
2012/11/19 21:54:12
me to on those screw heads.
wildwill
2012/11/21 10:09:06
I received the render for the custom GPU back plates i was working on with Coldzero - Should have them with in 2 weeks then i can start another overhaul on this build.
eternitykh
2012/11/21 12:12:06
coldzero plates and covers are so awesome looking! and those custom ones reflecting the actual 670 FTW is just badass. i was tempted many times to go their route, but... i dont want to give up those shiny polished heatkiller plates.... decisions, decisions.....
Core i7-3770k De-Lidded @ 4.8ghz // Asus Sabertooth z77 // Corsair Vengeance Black 1866mhz 9-10-9-27 4x4GB DDR3 2x EVGA GTX 670 FTW+ 4GB SLI // 3x Asus VH238H Monitor in Surround // Asus Xonar DX7.1 Sound Card Corsair Obsidian 700D Chassis // Corsair AX850 PSU // Corsair Neutron 240 SSD Corsair Individually sleeved Modular Cables // Custom Black Rigid 2-way SLI bridge XSPC RASA Black CPU Water Block // XSPC RS360 Radiator // XSPC X2O 750 Dual 5.25” Bay Reservoir Pump 2x Watercool Heatkiller GPU-X³ Hole Edition Waterblock Nickel/Black // 2x Watercool Heatkiller GPU-X³ Polished Backplate Corsair Vengeance K70 Keyboard // Corsair Vengeance M95 Mouse // Corsair Vengeance 1500 HeadsetCorsair Vengeance MM400 Compact Mouse Pad // Corsair Link Commander // Corsair Link Cooling and Lighting node
