Corsair 800D Water Cooling Build Thread
Page: 12345.. > >> Showing page 1 of 6
wildwill
2012/07/26 00:58:00 (permalink)
I have decided to ditch my Corsair C70 case because i needed something much larger and more water cooling friendly so i felt this was the best route for me.
Case -
Corsair 800D
Intel DZ77GA-70K
Intel 3770K
Corsair Vengeance 16GB
Intel 520 series 240 gig SSD
WD Caviar Green 2TB
Evga GTX 670 FTW X2
Corsair AX850
Corsair SP2500 2.1 Gaming Speakers
Corsair Vengeance K60 Gaming Keyboard
Corsair Vengeance M60 Gaming Mouse
Corsair Vengeance 2000 7.1 Gaming Headset
Windows 7 64 Bit
Creative Sound Blaster Recon 3D
Samsung TOC 27'' 1920x1080
Sony Optical Drive
Water Cooling Hardware List -
XSPC RayStorm High Performance Acetal CPU Liquid Cooling Block
XSPC EX360 Crossflow Triple 120mm Low Profile Split Fin Radiator
XSPC EX360 Multiport Triple 120mm Low Profile Split Fin Radiator
XSPC Razor Nvidia GTX 680 Full Coverage VGA Block X2
(UN)Designs D5 Pump Z3 140mm Fan Bracket - Black
Enzotech SLI Bridge Kit X2
Bitspower Premium Male G1/4" Matt Black Aqua-Pipe I Fitting
Bitspower G1/4" Anti-Cyclone Adapter - Black Matte Finish
Swiftech MCB-120™ Revision 2 "Radbox" Radiator/Fan Housing
Swiftech MCP655 Special Edition 12 VDC Pump With Speed Controller
Bitspower  Water Tank Z-Multi 150 - POM  - Current
EK Spin Reservoir Acrylic - Removed
XSPC Dual 5.25" Bay Reservoir (Alu Front)  - Removed
Swiftech Maelstrom 5 1/4" Dual Bay Basic Reservoir - Removed
Tubing -
Feser - 1/2" ID/3/4"OD - UV Acid Green 30'
Fan Controller & Fans -
Sunbeamtech Rheosmart 6 Channel Fan Controller
Fans -
Corsair SP120 High performance High Static Pressure X6
Corsair AF120 Quiet Edition X1
Corsair AF140 Quiet Edition X1
Apevia 140mm UV Green
Fittings -
Enzotech 90 Degree Rotary Compression Fitting Matte Black 1/2"x3/4"  X6
Enzotech Compression Fitting Matte Black 1/2"/3/4" X6
Enzotech 1/4 Threaded Stop Plug X16
Enzotech Male to Male G 1/4 Threaded Coupler - Matte Black X2
Enzotech Male to Female G 1/4 Threaded Adapter - Matte Black X2
Enzotech Male to Female G 1/4 Threaded Extender - Matte Black
Enzotech Drain Plug G 1/4 Threaded Cap - 1/2" Barb - Matte Black
Fluid & Accessories - Mayhems UV Green/Mayhems UV Yellow/Green dye
Accessories -
Cold Zero PSU Cover Plate - Matte Black
Bitspower UV Mesh Radguard 120mm  - UV Green X4
8-Pin (EPS12V) Extension Cable 12 Inches - Sleeved In UV Green
Mod/Smart Dual LED - Pre-wired with 4-Pin Connector 3mm - Blue - Sleeved In UV Green X2
2 x BitFenix 3-pin to 3 x 3-pin Fan Adapter Cable - 60cm - Black Sleeved
Bitspower Flow Indicator - Clear/Black/Matte Black
Bitspower Single Luxury Tube Clamp For Tube OD 3/4in. - Black X4
Bitspower - D5 Mod Pump Top V2 (POM Version)
Bitspower D5 / MCP655 Mod Kit - Matte Black Finish
OKGEAR 36'' inch SATA 3.0 Cable - Straight to Straight - UV Green
OKGEAR 24'' SATA 3.0 Cable - Straight to Right Angle - UV Green
Serial ATA Power Cable 12" - Sleeved In UV Green
XSPC LCD Display Temperature Sensor - Green
XSPC 5.25" Drive Bay Temperature Sensor Display Frame
Molex Extension Cable 36" Black Sleeved X6
MaxFinder Triple Braided 3-Pin Fan Extension Cable 3 Pack 60cm - Black X4
Bitfenix Alchemy Connect 30 LED Light Strip 600mm - Blue X2
Corsair Individually Sleeved Modular Cable upgrade kit for the Professional Series AX850 PSU - Blue
Water Cooling Upgrade Total Cost -
$1,979 - This is minus all shipping and includes hardware Ive have bought and since removed and replaced.
post edited by wildwill - 2012/10/20 20:47:33
Asus Maximus Gene VI
Intel 4770K
Intel 520 Series 240GB SSD
WD Caviar Black 2TB
Asus 980 Matrix Platinum
Hyper X Savage 8GB 2400MHz
Silverstone Strider Gold 850 Watt
Asus ROG Swift
Windows 8.1 64 Bit
160 Replies Related Threads
    wildwill
    Re:Corsair 800D Water Cooling Build Thread 2012/07/28 20:59:38 (permalink)
    Applied a sheet of sound deadening to the rear panel
    My Tuniq TX-4 Arrived today so i decided to mount 1 of my XSPC 680 blocks to make a little progress -
    Thermal Pads Applied -
    Water Block On -
    post edited by wildwill - 2012/08/21 18:56:00
    Intel 4770K
    WD Caviar Black 2TB
    Asus ROG Swift
    Windows 8.1 64 Bit
    yellow__fever
    • Ribbons : 14
    Re:Corsair 800D Water Cooling Build Thread 2012/07/28 21:53:53 (permalink)
    Nice!
    "Sang Noir"
    -Silverstone TJ07-BW
    -Intel Core i7 920 @4.209GHz 1.343VCore + EK Supreme HF Rev2 Acetal Copper
    -OCZ XTC Platinum 6GB DDR3-1600 [7-7-7-20]
    -Asus Republic of Gamers Rampage III Extreme
    -EVGA GTX 560Ti 448 Classified [900/1800/2100] + EK-FC480 Copper Waterblock
    -2x Corsair Force GT 120GB SSD + 1x WD 1TB Black
    -Corsair AX1200 PSU + Laing D5 (EK D5 XTop Rev2) + Feser Quad XChanger
    -Razer Mamba + Razer Blackwidow + Sennheiser PC 320
    -46" Samsung LED TV 1920x1080p
    Pics in Mod Rigs!
    MexicanPlumber
    Re:Corsair 800D Water Cooling Build Thread 2012/07/29 10:51:30 (permalink)
    Very nice. Where are you putting that second 3x 120 radiator?
    wildwill
    Re:Corsair 800D Water Cooling Build Thread 2012/07/29 20:30:08 (permalink)
    Mr.MattyV
    Its being installed on the back of the case sir.
    I can mount the radiator to the swiftech radbox then use 2 90 degree fittings and come in through the supplied grommets on the back of the case.
    Intel 4770K
    WD Caviar Black 2TB
    Asus ROG Swift
    Windows 8.1 64 Bit
    MexicanPlumber
    Re:Corsair 800D Water Cooling Build Thread 2012/07/29 22:09:53 (permalink)
    ah ok, cool. This is going to look awesome
    wildwill
    Re:Corsair 800D Water Cooling Build Thread 2012/07/29 22:49:16 (permalink)
    Ordered a few more things tonight -
    Bitspower D5 / MCP655 Pump Mod Kit In Matte Black
    Various Enzotech fittings in Matte Black
    PrimoChill PrimoFlex PRO LRT Tubing 1/2"ID 3/4"OD In Clear 12'
    Mayhems Aurora Extinction Green Dye
    So more updates coming this week!
    Intel 4770K
    WD Caviar Black 2TB
    Asus ROG Swift
    Windows 8.1 64 Bit
    direraptor22
    • Ribbons : 16
    Re:Corsair 800D Water Cooling Build Thread 2012/07/30 04:06:44 (permalink)
    “The fascination of flight can't be expressed with words. But it really lies beyond the capabilities of human endeavor. Once you've experienced it, you'll never be able to forget it.” - Friedrich Oblessor
    Afterburner
    • Ribbons : 110
    Re:Corsair 800D Water Cooling Build Thread 2012/07/30 06:42:28 (permalink)
    Looking forward to the finished product. I have two of these 800D builds. Both Watercooled...
    May I make a suggestion? I found that replacing two of the factory 140's is required. They are HORRIBLE.
    I now use this one for the bottom fan that pulls the air from the bottom of the case (By the PSU) http://www.performance-pcs.com/catalog/index.php?main_page=product_info&cPath=36_316_849&products_id=28570&zenid=72b2c13dc8156fb24019441f204f0a92
    And I use this one for the rear exhaust http://www.performance-pcs.com/catalog/index.php?main_page=product_info&cPath=36_316_849&products_id=28571&zenid=72b2c13dc8156fb24019441f204f0a92
    Finally I just installed this Corsair unit (There are two versions, the one I got is the one required ad there is almost no clearance from the case where it mounts) to pull air from the seems in the front of the case. So it pushes air towards the door/cover that the black fan can use in addition to the bottom screened air. http://www.performance-pcs.com/catalog/index.php?main_page=product_info&cPath=36_49_1050&products_id=34312&zenid=72b2c13dc8156fb24019441f204f0a92
    I am extremely pleased with the results. My temps dropped 7c by doing this.
    wildwill
    Re:Corsair 800D Water Cooling Build Thread 2012/07/30 14:07:19 (permalink)
    I dry fitted the Swiftech radbox today and everything is looking good so far. I had to remove the stock rear 140mm fan and mount a Corsair AF120 Quiet Edition i had sitting here from my previous build to mount the radbox as it was intended.
    I plan on coming in from the top of the rad with 2 Enzotech 90 degree fittings -
    Intel 4770K
    WD Caviar Black 2TB
    Asus ROG Swift
    Windows 8.1 64 Bit
    MexicanPlumber
    Re:Corsair 800D Water Cooling Build Thread 2012/07/30 15:47:05 (permalink)
    ooh, that looks nice.  How far down does the rad go on the case?
    wildwill
    Re:Corsair 800D Water Cooling Build Thread 2012/07/30 19:59:31 (permalink)
    Mr.MattyV
    The bottom sits right around where the PSU is installed so it is long but i still have room to work back there.
    Afterburner
    I appreciate your input and i do plan on changing them out.
    I already replaced the rear exhaust with a Corsair AF120 Quiet Edition and i will prob do 2 140mm Corsair Quiet's or perhaps those fans you recommended.
    Intel 4770K
    WD Caviar Black 2TB
    Asus ROG Swift
    Windows 8.1 64 Bit
    wildwill
    Re:Corsair 800D Water Cooling Build Thread 2012/08/02 20:35:23 (permalink)
    A few more things arrived today but unfortunately my Enzotech fittings are being dropped shipped from the manufacturer so i wont have them until next week -
    Mayhems Aurora Extinction Green Coolant Concentrate -
    XSPC Daul 5.25'' Bay Res & 12' of Primochill 1/2''x3/4'' Clear tubing -
    Side Note -
    I had trouble as expected sliding the bay res in because the slots on each side of the 5.25'' bay are a little 2 wide so i need to Dremel them down a bit tomorrow.
    All fans and swifttech radbox mounted on the rear rad -
    Mounted Permanently -
    post edited by wildwill - 2012/08/03 00:22:41
    Intel 4770K
    WD Caviar Black 2TB
    Asus ROG Swift
    Windows 8.1 64 Bit
    wildwill
    Re:Corsair 800D Water Cooling Build Thread 2012/08/05 23:20:55 (permalink)
    I mounted the XSPC cpu block tonight and i can honestly say it was not the easiest install. I had to had to apply a lot of pressure on the screw heads just to catch any threads on the cpu back plate because they use a spring/washer combination. I ended up re applying TIM 3 different times because i wasn't content with the cpu block spreading the tim around while i struggled to mount it properly.
    After it was all said and done i was happy with the finished look though -
    Intel 4770K
    WD Caviar Black 2TB
    Asus ROG Swift
    Windows 8.1 64 Bit
    Sleinous
    • Ribbons : 32
    Re:Corsair 800D Water Cooling Build Thread 2012/08/06 01:19:19 (permalink)
    This is looking very nice! I've move dit to mods rigs as it's now more suited to that part of the forums.
    My Affiliate Code: GL1IAAFWJF
    wildwill
    Re:Corsair 800D Water Cooling Build Thread 2012/08/06 14:52:16 (permalink)
    Sleinous
    TY sir and that's np i appreciate it.
    Intel 4770K
    WD Caviar Black 2TB
    Asus ROG Swift
    Windows 8.1 64 Bit
    wildwill
    Re:Corsair 800D Water Cooling Build Thread 2012/08/06 14:54:02 (permalink)
    I dry fitted some tubing today to get an idea of how to route everything off the rear mounted rad -
    I can bring another feed to the top video card and that will complete the loop from the rear rad but if any 1 else has a better idea then feel free to share it.
    Intel 4770K
    WD Caviar Black 2TB
    Asus ROG Swift
    Windows 8.1 64 Bit
    zophar
    • Ribbons : 26
    Re:Corsair 800D Water Cooling Build Thread 2012/08/06 16:06:58 (permalink)
    Very nice build so far. I loved my 800D case. It's awesome for a water cooled build.
    wildwill
    Re:Corsair 800D Water Cooling Build Thread 2012/08/06 23:39:47 (permalink)
    zophar
    TY sir hopefully i won't disappoint.
    Intel 4770K
    WD Caviar Black 2TB
    Asus ROG Swift
    Windows 8.1 64 Bit
    wildwill
    Re:Corsair 800D Water Cooling Build Thread 2012/08/06 23:49:58 (permalink)
    Placed an order tonight since i have finally figured out how i want to run my loop. This will allow me to dry fit the entire loop this week and get closer to the finished product -
    8 x Enzotech G 1/4 Threaded Stop Plug - Matte Black
    4 x Enzotech Compression Fitting G 1/4 Thread 1/2" ID and 3/4" OD - Matte Black
    1 x Enzotech 90 Degree Rotary Compression Fitting G 1/4 Thread 1/2' ID 3/4" OD - Matte Black
    Enzotech sli bridge kit
    Mayhems X1 UV Green Concentrate - 250ml
    2 x Enzotech High Flow 1/2" Barb Fitting G 1/4 Thread - Matte
    Black
    IandH Silver KillCoil
    Intel 4770K
    WD Caviar Black 2TB
    Asus ROG Swift
    Windows 8.1 64 Bit
    Sleinous
    • Ribbons : 32
    Re:Corsair 800D Water Cooling Build Thread 2012/08/07 02:24:48 (permalink)
    Tasty hardware incoming!
    Centricus
    Re:Corsair 800D Water Cooling Build Thread 2012/08/07 08:49:30 (permalink)
    By far my favorite case.
    wildwill
    Re:Corsair 800D Water Cooling Build Thread 2012/08/07 19:43:43 (permalink)
    I have decided on a lighting scheme that will be low profile but still have a strong impact so with that said -
    Bitfenix Alchemy Connect 30 LED Light Strip - Blue X2
    4-Pin Molex Powe Adapter Cable w/ Remote On/Off Toggle Switch - 36" - To have full control of both LED strips
    Few others items that are being purchased tonight to help finish this build up -
    Corsair Air Series AF140 Quiet Edition High Airflow 140mm Fan - To replace the fan that blows air in to the HD cage
    PrimoChill Anti-Kink Coils - Gloss Blue - Just in case i need some
    I am still trying to decide if i want to go with a single bay fan controller or just order another Corsair link cooling node so i can control everything from the desktop.
    Intel 4770K
    WD Caviar Black 2TB
    Asus ROG Swift
    Windows 8.1 64 Bit
    #23
    nvidia3
    Re:Corsair 800D Water Cooling Build Thread 2012/08/07 23:51:17 (permalink)
    Looks great!
    #24
    wildwill
    Re:Corsair 800D Water Cooling Build Thread 2012/08/09 23:19:56 (permalink)
    A few more items arrived today -
    Enzotech SLI Bridge Kit  & KillCoil -
    Tons of Enzotech Fittings -
    Mayhems UV Green Fluid -
    3 Pin Sleeved Extension Cables For The Rear rad Fans -
    Bitspower MCP655 Mod Kit In Matte Black -
    Test Fit With 2 Enzotech Matte Black Compression Fittings -
    I have a bunch more stuff coming next week so i can get closer to getting this thing running again so stay tuned!
    Intel 4770K
    WD Caviar Black 2TB
    Asus ROG Swift
    Windows 8.1 64 Bit
    #25
    wildwill
    Re:Corsair 800D Water Cooling Build Thread 2012/08/13 14:07:39 (permalink)
    Few more items arrived today -
    Lamptron inverter less UV tube which is not as bright as i thought it would be, 2 30 LED Bitfenix strips which are high quality and very bright and a 4 pin molex power switch to control the led strips -
    Corsair AF140mm for the HD cage fan -
    Intel 4770K
    WD Caviar Black 2TB
    Asus ROG Swift
    Windows 8.1 64 Bit
    #26
    dipzy_v
    Re:Corsair 800D Water Cooling Build Thread 2012/08/13 15:12:21 (permalink)
    This build is coming along very nicely
     Heatware: dipzy_v
    Threadripper 1950x|Asus Zenith Extreme|32GB Gskill DDR4 C14|TITAN Xp|512GB x2 NVME SSD|Corsair AX1500i|LG 32UD99|Corsair K95 Platinum Speed|Corsair M65|
    #27
    wildwill
    Re:Corsair 800D Water Cooling Build Thread 2012/08/13 20:06:50 (permalink)
    Ordered a Enzotech Quad Block,2 1/2' barbs,2 stop plugs so i can set up a drain port at the bottom of the loop -
    Intel 4770K
    WD Caviar Black 2TB
    Asus ROG Swift
    Windows 8.1 64 Bit
    #28
    tester300
    Re:Corsair 800D Water Cooling Build Thread 2012/08/13 20:39:57 (permalink)
    Hey
    Would you recommend the Lamptron Inverterless?
    How bright is it from a scale of 1-10?
    Thanks
    #29
    wildwill
    Re:Corsair 800D Water Cooling Build Thread 2012/08/13 21:03:15 (permalink)
    tester300
    Hey
    Thanks
    Build quality is nice but as far as brightness i would give it a 7 out of 10.
    The cover on it is not clear so there is def more brightness 2 be had but i can't determine if it will suit my needs until i get all the tubing in.
    Intel 4770K
    WD Caviar Black 2TB
    Asus ROG Swift
    Windows 8.1 64 Bit
    #30
