wildwill
Re:Corsair 800D Water Cooling Build Thread
2012/10/05 10:18:55
Few more items arrived today - EX120mm rad that will mount to the rear 120mm exhaust section - Danger Den tube cutter because scissors aren't cutting it lol - Additional Enzotech stop plug i needed, Bitspower premium 3/4'' OD tube clamps(No Zip Ties) - Bitspower Flow Indicator Plexi/Matte Black - UN 140mm fan bracket(1 part of the puzzle to mount the D5 pump) - UN 3G bracket(2cd part of the puzzle to mount the D5 bracket) - Bitspower Plexi UV Green filtered 120mm rad grill - Bitspower Plexi UV Green filtered 360mm rad grill - This thing pops like a mofo under UV light and i love the quality on it.
Asus Maximus Gene VI Intel 4770K Intel 520 Series 240GB SSD WD Caviar Black 2TB Asus 980 Matrix Platinum Hyper X Savage 8GB 2400MHz Silverstone Strider Gold 850 Watt Asus ROG Swift Corsair Vengeance K60 Gaming Keyboard Corsair Vengeance M60 Gaming Mouse Windows 8.1 64 Bit
wildwill
2012/10/05 15:15:55
I managed to bolt the 120mm rad to the Swiftech rad box with ease i just needed to add an additional small washer to shorting the screw up some so i wouldn't puncture the rad - The iphone is terrible in low light so this is just is a quick example of how it is set up. ![](http://farm9.staticflickr.com/8452/8057821955_f90f13080c.jpg) I also need to figure out how to integrate this 120mm in to the loop since i am already using 2 360 rads!
Angrychair420
- Ribbons : 5
![](//www.evga.com/community/modsRigs/images/sm_mods_off.gif)
2012/10/05 18:06:19
what screws did you use to mount the fans and rad to the top of the case?
wildwill
2012/10/05 20:38:44
It should have come with 2 sets!
1 short to directly mount the rad then a longer set to mount the fans to the rad.
wildwill
2012/10/06 20:17:48
I will be changing this UN 140mm bracket out for a black 1 but this is the cleanest and most balanced way i could mount the pump given the 2 brackets i had - ![](http://farm9.staticflickr.com/8453/8061462136_b1ed9cb803.jpg) XSPC EX120 rad mounted to the rear exhaust -
wildwill
2012/10/08 12:14:29
I am once again changing my mind on what reservoir i will be using on this build! I bought a Bitspower Water Tank Z-Multi 150 - POM a while back so i have decided to mount it to the top of my D5 pump. ![](http://www.performance-pcs.com/catalog/images/products/BP-WTZM150P-BK.jpg) I will be using this fitting to connect it to the top inlet port on the Bitspower pump top - ![](http://www.performance-pcs.com/catalog/images/enzotech/bmm_g14.jpg) This res has 3 ports on the bottom and 1 on top so it seems like the best way to configure it is the following - Use the single port side to connect the res to the pump. Use the 3 ported side for a return line from my top 360 rad and also use a port to fill the res. Does this all make sense ?
wildwill
2012/10/09 13:28:26
The best place to mount the Bitspower flow indicator seems to be above the top gpu left output. I did a few dry fits with different lengths of tubing but i don't like the way the tubing leans back due to the weight so i found a solution - I can mount this to the top left gpu port then thread the Bitspower flow indicator right in for much added stability.
wildwill
2012/10/10 12:18:03
I re located my Intel 520 series 240 gig SSD to this location a few weeks ago but i am going to move it back to the hot swap HD bay and replace it with this SSD - It will provide an additional 240 gigs of space for future games and match the UV light show that will be going on.
post edited by wildwill - 2012/10/10 12:25:08
eternitykh
2012/10/10 17:49:40
¬_¬ you are giving me um...... inspiration about the ssd placement.... lol..... agility 4 huh, pretty nice drive, i was gonna say samsung 840 if you haven't ordered the new drive yet but, the agility's color scheme fits nicely with your setup.
Core i7-3770k De-Lidded @ 4.8ghz // Asus Sabertooth z77 // Corsair Vengeance Black 1866mhz 9-10-9-27 4x4GB DDR3 2x EVGA GTX 670 FTW+ 4GB SLI // 3x Asus VH238H Monitor in Surround // Asus Xonar DX7.1 Sound Card Corsair Obsidian 700D Chassis // Corsair AX850 PSU // Corsair Neutron 240 SSD Corsair Individually sleeved Modular Cables // Custom Black Rigid 2-way SLI bridge XSPC RASA Black CPU Water Block // XSPC RS360 Radiator // XSPC X2O 750 Dual 5.25” Bay Reservoir Pump 2x Watercool Heatkiller GPU-X³ Hole Edition Waterblock Nickel/Black // 2x Watercool Heatkiller GPU-X³ Polished Backplate Corsair Vengeance K70 Keyboard // Corsair Vengeance M95 Mouse // Corsair Vengeance 1500 HeadsetCorsair Vengeance MM400 Compact Mouse Pad // Corsair Link Commander // Corsair Link Cooling and Lighting node
wildwill
2012/10/10 21:03:35
Thanks bro i was hoping i could inspire some else to maybe place there SSD there.
As far as the SSD it will be plenty fast with just games to load on it + the color scheme is just what i was looking for.
wildwill
2012/10/11 10:23:44
Ordered my custom PSU plate cover and here is how it works - http://www.youtube.com/wa...ed&v=mMEEVpRgLjA#!Tons of other things ordered as well(some for function and some for flash) - Bitspower Premium Male G1/4" Matt Black Aqua-Pipe I Fitting - This will replace the silver aqua pipe that comes stock in the Bitspower 150 Z-Multi water tank. ![](http://www.performance-pcs.com/catalog/images/products/BP-MBWP-C17.jpg) Bitspower G1/4" Anti-Cyclone Adapter - Black Matte Finish - This will replace the silver anti-cyclone adapter that comes stock in the Bitspower 150 Z-Multi water tank. ![](http://www.performance-pcs.com/catalog/images/products/BP-MBWP-C46.jpg) Bitspower UV Mesh Radguard 120 (1 x 120mm) - UV Green X3 - These will cover and protect my 360 interior mounted roof radiator and also add a nice visual effect. (UN)Designs Pump Z3-Bracket (for Laing D4/D5/DDC Pumps) & 140mm Fans - Black - I currently have the deep blue version but i feel the black version will blend it better. ![](http://www.performance-pcs.com/catalog/images/products/Z3-Bracket-BK.jpg) Enzotech Male to Male G 1/4 Threaded Coupler - Matte Black X2 - I need 1 to mount the Bitspower water tank to the pump and 1 to thread the Bitspower flow indicator in to a Enzotech thread adapter. ![](http://www.performance-pcs.com/catalog/images/enzotech/bmm_g14.jpg) Enzotech Male to Female G 1/4 Threaded Adapter - Matte Black - This will thread directly in to 1 of my top GPU ports to add some stability to the Bitspower flow indicator that will be threaded in to it. Enzotech Male to Female G 1/4 Threaded Extender - Matte Black - I am using this because the discharge OUT port i am using on the pump will sit to close to the Bitspower water tank when mounted. I will have more space to work with now after i thread a 90 degree rotary barb in to this. ![](http://www.performance-pcs.com/catalog/images/enzotech/bmf_g14.jpg) ENZOTECH BSLI-1 Fittings Package for SLI Setups - This will add another bridge to the video cards for added stability and flow. ![](http://www.performance-pcs.com/catalog/images/enzotech/bsli.jpg) 8-Pin (EPS12V) Extension Cable 12 Inches - Sleeved in UV green and the female connecter will be UV green as well. 24-Pin (EPS12V) Extension Cable 12 Inches - Sleeved in UV green and the female connecter will be UV green as well. BitFenix 3-pin to 3 x 3-pin Fan Adapter Cable 60cm - Black Sleeve X2 - I needed a 3 pin set so i can send all my 3 pin fan cable extensions directly to the fan controller for a cleaner look. Mayhems Dye - 10ml UV Yellow/Green - I plan on adding a few drops to enhance the Mayhems UV green concentrate i will be using. ![](http://www.performance-pcs.com/catalog/images/mayhem/10ml-mayhems-dye-uv-yellow-green.jpg) Mod/Smart Dual LED - Pre-wired with 4-Pin Connector 3mm - Blue X2 - This will be sleeved in UV green and replace the current LED's plugged in to my Raystorm cpu block.
wildwill
2012/10/12 11:41:09
A few more items arrived today - ![](http://farm9.staticflickr.com/8467/8080461542_b95a3bf072.jpg) ![](http://farm9.staticflickr.com/8184/8080462250_f6fb0a5764.jpg) All blacked out now -
Angrychair420
- Ribbons : 5
2012/10/12 12:09:55
yeah, my hotswap bay doesn't read my SSD either, it's a real freakin shame. I was gonna try and mount it in the bottom bay.
wildwill
2012/10/12 13:58:37
UN Designs 140mm fan bracket all blacked out - ![](http://farm9.staticflickr.com/8049/8080787096_ee9055c219.jpg) Both Enzotech sli bridges on - ![](http://farm9.staticflickr.com/8185/8080792439_20a191afd5.jpg) All 3 Bitspower UV green mesh rad guard's on -
wildwill
2012/10/13 19:41:05
Here is how i have it set up and i love how well i was able to integrate the Bitspower flow indicator. The Enzotech threaded adapter worked so well to stabilize it. ![](http://farm9.staticflickr.com/8194/8084749121_c4cc0a5b9a.jpg) ![](http://farm9.staticflickr.com/8054/8084748407_f6f60ed791.jpg) Going to flush the res up and make a few changes tonight.
loveha
- Ribbons : 65
2012/10/13 19:54:40
Looks great, never understood the spinney thing's though. If you have good flow, you will see it in the reservoir as the flow pushes to the top.
Case - Phanteks Enthoo Evolv XMobo - EVGA X570 FTWCPU - AMD Ryzen 9 5900XRAM - 32GB Trident Z Royal 3600MHz 14-14-14-34GPU - EVGA RTX 3080 Ti FTW3 Ultra GamingPSU - Seasonic Prime TX-1000Heatkiller IV CPU Waterblock / Heatkiller V GPU WaterblockHeatkiller V EBC Active Backplate / Two Heatkiller Rad 360 L Six Noctua NF-A12x25 / Heatkiller D5 Pump
ChrisS
2012/10/13 22:08:38
Looks awesome, excellent job!
wildwill
2012/10/14 10:02:08
The flow indicator is more of a visual thing.
This build is a combination of performance and looks!
TY Chris I appreciate it!
eternitykh
2012/10/14 12:55:45
im really digging those UV green bracket/pieces/wuteveritscalled, it DOES make your parts pop a lot.
wildwill
2012/10/14 20:40:36
TY sir that was the affect i was going for.
wildwill
2012/10/15 01:49:25
I don't like the angle of the feed coming from the pump discharge to the top right GPU port but there is a slight issue - I have a spare Enzotech 90 degree compression fitting but when i try to thread it in that port it hits the GPU back plate so i have to raise the fitting up some with 1 of these. Enzotech Male to Female G 1/4 Threaded Extender - Matte Black ![](http://www.performance-pcs.com/catalog/images/enzotech/bmf_g14.jpg) ![](http://www.performance-pcs.com/catalog/images/enzotech/brcfs-id12-od34.jpg) This will give me enough space so the fitting won't hit the back plate and i can match the angle of the tubing to flow with the angle of the drain plug feed.
wildwill
2012/10/15 12:53:27
Few more small items arrived today for some touch ups - 24 Pin power extension sleeved in UV green/UV green female connector. ![](http://farm9.staticflickr.com/8044/8091293241_27f8fda064.jpg) Mod/Smart 3mm twin blue led sleeved in UV green for the XSPC Raystorm water block, BitFenix 3-pin to 3 x 3-pin Fan Adapter Cable 60cm - Black Sleeve,Mayhems UV yellow/green dye. ![](http://farm9.staticflickr.com/8468/8091294243_827babb730.jpg) The quality of the sleeving on these Bitfenix extensions is amazing and feels so good in your hands lol.
wildwill
2012/10/16 11:33:55
I recently ordered a PSU plate cover from Coldzero.com which makes all kinds of custom parts for the Corsair 800D/700D so i was inclined to look in to another custom part from them - Front panel with 120mm fan. This is a stealth DVD-RW version which i will not be using but it gives an idea of the design and craftsmanship. I already have a Sunbeamtech 6 channel fan controller mounted to the bottom of my front panel so this will be a custom part. It needs to take up 4 slots only and still offer the capabilities to mount a 120mm fan. I emailed them about this and i am confident it can be done so this will be 1 of the final editions to this build.
post edited by wildwill - 2012/10/16 11:41:21
wildwill
2012/10/17 13:24:42
wildwill
2012/10/20 20:43:04
Front page updated with -
Accessory list, current and removed hardware, updated total cost.
wildwill
2012/10/22 14:24:42
My Coldzero custom PSU cover arrived today from Portugal - ![](http://farm9.staticflickr.com/8470/8113844426_d0104395b3.jpg) The quality and fitment are top notch!
wildwill
2012/10/22 22:16:47
I ordered a few more fittings so i can re locate 2 separate tubes in my loop and also raise the tube res up a little bit - Enzotech 45 Degree Rotary Fitting Male/Female - Matte Black X3 ![](http://www.performance-pcs.com/catalog/images/enzotech/BRMF-G14-45.jpg) Enzotech Male to Female Threaded Adapter - Matte Black ![](http://www.performance-pcs.com/catalog/images/enzotech/bmfl_g14.jpg) Enzotech Male to Female Threaded Extender - Matte Black ![](http://www.performance-pcs.com/catalog/images/enzotech/bmf_g14.jpg) I have also decided on new Ram finally since my previous Corsair Vengeance 16 gig set is useless now covered in Bitspower water block shrouds - Corsair Vengeance LP(Low Profile) In Blue
n00btastica
2012/10/23 03:00:49
Affiliate Code : COFF917OY0.
wildwill
2012/10/24 11:54:51
Thanks i should be done with in a few weeks i just need to make some adjustments and install a few more items.
wildwill
2012/10/24 13:54:46
Emailed Mnpctech.com about cutting 2 holes out of my front window panel so i can see both Corsair air series fans 140mm/120mm in action.
Hopefully it can be done with ease because i would really love to see this mod incorporated in to this build.
Both cut outs will feature a Matte black grill + i already have high powered Blue leds on the interior of the case so it should look good.
