It will be a few weeks before i can make any significant changes while i wait for some custom stuff to arrive but i will continue to improve while i wait -
I have placed an order for the following items -
I ordered a XSPC 120mm rad a few weeks ago and never used it so because of that i have an extra Corsair SP120mm fan left over. I am going to put it to good use by going with a XSPC 480 rad in place of my current XSPC multiport 360 rad.
XSPC EX480 Copper Quad-Fan Radiator
![](http://www.performance-pcs.com/catalog/images/xspc/ex480.jpg)
I currently have a Swifttech radbox supporting my rear 360 rad/3 fans and although i like the looks of it i desire something with more flexibility and strength.
As you can see here the radbox bolts to the top section of the 360 rad -
![](http://farm8.staticflickr.com/7132/7702881838_a28500137e.jpg)
With the Koolance rad bracket i can bolt it to the 2cd section of the rad to even out the weight load. I will raise the rad up in the process but i will be using 2 45 degree rotary fittings to fix that issue.
Koolance Radiator Mounting Bracket with Quick-Release
![](http://www.performance-pcs.com/catalog/images/products/bkt-hx001p.jpg)
I currently have 1 MCP655/D5 bolted to a Koolance RP-452X2 dual bay res. I want close to total silence with this build but unfortunately i am getting some vibration noise with the pump on setting 2 or higher. I recently lowered the pump speed setting to 1 and although i hear no vibration now my temps have suffered up 2 10c under certain loads. I will be purchasing an additional Swifttech D5 pump so i can run them both at speed 1 and hopefully solve this issue.
Swiftech MCP655 Series 12 VDC Water Pump - With Speed Control
![](http://www.performance-pcs.com/catalog/images/products/MCP655.jpg)
These leds will be used to light both individual Koolance bay res chambers -
Mod/Smart Dual LED 3mm - Green with black sleeving.
![](http://www.performance-pcs.com/catalog/images/modsmart/led-3d2-g.jpg)
Since this build is now being themed after the ninja turtles "secret of the ooze" movie,i will be using Mayhems Pastel Mint Green which is the closest match to this -
![](http://24.media.tumblr.com/tumblr_mdenjxaq4K1rbgp20o1_250.gif)
![](http://24.media.tumblr.com/tumblr_m5zzg5UkTl1ro8ysbo1_1280.jpg)
Mayhems Pastel Mint Green Concentrate -
