unclenode
Re: 1080Ti FTW3 Upgraded with the Hybrid Kit - Problem!
Friday, February 16, 2018 4:54 AM
I think it was my attention to small detail that puzzled me when the instructions said two #12 rubber pads, yet only one existed, due to lack of any explanation of them being attached and the need to separate them. Either way, this certainly is an issue, and as I stated to Brendan on the support line, think of how many of these cards are clock locked and the user has no clue, because things still work, albeit slower. The lay person would be none the wiser, or EVGA would have a mutiny on their hands. Yes, a better topic heading might help, this is costly and time-consuming for many of us.
_____________________________
PietroBR
- Ribbons : 7
Friday, February 16, 2018 1:35 PM
atomicvai
PietroBR God dammit. I'm in the club as well Didn't saw this post before. Gotta install the Air cooler back tomorrow to see if the card will work fine.
Was your metal grate loose or clipped in properly?
Nope. It was loose. But never though it was an issue. I'm going to install the original heatsink and pray that the card works as before.
atomicvai
Friday, February 16, 2018 4:17 PM
PietroBR
atomicvai
Yeah, really looks like that's the underlying issue (only metal on the shroud that could possibly contact the card). I'm surprised EVGA hasn't properly dealt with this. Even my replacement from them was loose. I would have possibly pooched a second card if I hadn't seen it mentioned on here to clip it properly to the shroud. As great as their customer service was in replacing my card and cooler, they are failing at communicating what the issue is and what to look for to new customers or existing ones that have had theirs replaced. Here is what I did differently from my first install to my second install: 1. Left the shroud off for the first test, to confirm working before installing the shroud. 2. Ensured the metal grate was properly clipped in to the shroud (not mentioned anywhere by EVGA). 3. Did NOT remove the backplate, just the screws (there is zero reason to remove the backplate for the installation). Beyond that, I did everything exactly the same between the two installs. As far as I could tell, there was no difference between my first kit and the replacement. I think EVGA just crossed their fingers and hoped it would work. I tightened all the screws the same both times. I didn't install the two microscopic rubber pads either time. The second install works perfectly. Hope that helps for anyone reading this in the future before installing the kit.
post edited by atomicvai - Friday, February 16, 2018 4:20 PM
PietroBR
- Ribbons : 7
Friday, February 16, 2018 7:57 PM
Man Something definetly went wrong with my card. I have installed the aircooler back. Used DDU to make a clean install of Nvidia drivers. Did a clean install of PXOC 6.1.3 Did a full power down on the computer (took the pc out of wall plug and holded the power button for 30 seconds for full discharge). Now, with the GPU in full stock, it is O.Cing to 1886Mhz, on GPU Boost 3.0 (before, it was boosting to 1987). Now, adding power target to 127% and Voltage slider to max, it O.C. to about 1900Mhz. Funny thing now is, I can O.C. higher than I was able before. Example, my card would't let me O.C. over 2000Mhz and it would crash. Now, I did a few custom runs (windowed mode) on Firestrike Ultra, and I was able to get 2025Mhz without crashs on it. I still will do some more testing, but something is wrong with the GPU Boost and voltage control on the card, for sure. Edit: Played a little bit of Far Cry 4, and got stable 2012Mhz without crashes (1440p with everything on ultra).
post edited by PietroBR - Friday, February 16, 2018 8:21 PM
unclenode
Saturday, February 17, 2018 6:10 AM
Consider yourself extremely fortunate, you broke yours the opposite way! Many of us put the air cooler on and came back to the same clock locked 1569 core. Now, figure out what you did so we can all get higher clocks ;)
PietroBR
- Ribbons : 7
Saturday, February 17, 2018 9:38 AM
unclenode Consider yourself extremely fortunate, you broke yours the opposite way! Many of us put the air cooler on and came back to the same clock locked 1569 core. Now, figure out what you did so we can all get higher clocks ;)
Kind of. I did some runs on Timespy extreme, and in the graphic run, despite having higher clocks, it's scoring less (wth?). Something went wrong with the card. I think the hybrid kit, somehow is shorted the gpu boost voltage controller, if it exist in anyway. I'm saying this because my cars now is oscillating a lot the clocks (it never did this before). Well I will rma the kit soon, but it will take some time to get the rma here in Brazil. I will keep it posted if I discover something new.
PietroBR
- Ribbons : 7
Saturday, February 17, 2018 4:54 PM
- Ribbons : 135
Saturday, February 17, 2018 5:04 PM
PietroBR
- Ribbons : 7
Saturday, February 17, 2018 5:12 PM
HeavyHemi You didn't accidentally leave some sort of vsync enabled did you?
Not at all (neither on the firestrike, or nvidia Control panel).
- Ribbons : 135
Saturday, February 17, 2018 5:21 PM
PietroBR
Okay...but, that is what your results look like....very strange. How about a Superposition run?
PietroBR
- Ribbons : 7
Saturday, February 17, 2018 9:11 PM
PietroBR
I did not completed the run, but I did monitored the Power Consumption, and it won't past 60% (same for all 1080p extreme / 1440p / 8K optimized). Also, I wasn't able to reach even 2000Mhz on Superposition (3DMark runs would hit over this frequency). This is all very confusing. Incredible how a bad batch of hybrid kit manage to kill a GPU in this way. EDIT: I did 1 run at 1080p extreme on Superposition. Comparison with a run I did in December 2017  Clock was around 2075Mhz now, but look at the FPS on both runs. Almost 20fps in average of diference, despite having higher clocks.
post edited by PietroBR - Saturday, February 17, 2018 9:23 PM
- Ribbons : 271
Saturday, February 17, 2018 10:40 PM
Give up; it's toast. That's not the first time I have seen a video card function properly in every measurable way but still unexplainably not perform as it should. Sometimes there is just something messed up in an immeasurable way; or it is throttling rapidly but briefly, fluctuating so fast that you can't measure it but the overall performance makes it obvious.
PietroBR
- Ribbons : 7
Sunday, February 18, 2018 1:29 AM
ty_ger07 Give up; it's toast. That's not the first time I have seen a video card function properly in every measurable way but still unexplainably not perform as it should. Sometimes there is just something messed up in an immeasurable way; or it is throttling rapidly but briefly, fluctuating so fast that you can't measure it but the overall performance makes it obvious.
Yeah. I already convinced myself that the card toasted. I was just trying to find the root of the issue. Either way, RMA will be the way..
evgapcbuilds
Sunday, February 18, 2018 1:35 AM
They still do RMAs for that?
- Ribbons : 271
Sunday, February 18, 2018 2:05 AM
evgapcbuilds They still do RMAs for that?
Why wouldn't they? Are you human or robot?
evgapcbuilds
Sunday, February 18, 2018 2:12 AM
Oh I thought you broke the card somehow since you said “toasted” lol
- Ribbons : 271
Sunday, February 18, 2018 2:19 AM
evgapcbuilds
Feel free to read any part of the thread next time before commenting. You seem to be trying real hard for 100 posts. Just so you know, there aren't any Elite video cards available; there haven't been any for weeks.
unclenode
Monday, February 19, 2018 4:57 AM
Yes, you are seeing the other effect of this failed installation. No boost clock (so locked at 1569) AND more importantly the VDC voltage is not allowing past a certain voltage, which is causing the real world performance loss of around 30%+. That is how I actually found out I had a problem, I was watching a YouTube video of the Superposition benchmark and an EVGA guy talking about Precision and overclocking. He was hitting 70-90 fps on 4k Optimized with his FTW3 and hybrid cooler while I was hitting 42fps with the same card. That's a huge hit.
PietroBR
- Ribbons : 7
Monday, February 19, 2018 10:17 AM
unclenode Yes, you are seeing the other effect of this failed installation. No boost clock (so locked at 1569) AND more importantly the VDC voltage is not allowing past a certain voltage, which is causing the real world performance loss of around 30%+. That is how I actually found out I had a problem, I was watching a YouTube video of the Superposition benchmark and an EVGA guy talking about Precision and overclocking. He was hitting 70-90 fps on 4k Optimized with his FTW3 and hybrid cooler while I was hitting 42fps with the same card. That's a huge hit.
Yup. In my case I won't past 0.950V and 60% of Power Limit, limiting the card on the 1860ish Mhz if full stock. I recorded two runs on Superposition via GPU-Z Log. I will try to upload the Excel sheet here out of curiosity.
TheWereCat
Monday, February 19, 2018 2:12 PM
So I bought the Hybrid kit in december and after I mounted it my 1080ti FTW3 Gaming was stuck at 1569MHz. So I took it apart, assembled again and it worked... for 5 minutes. Then black screen and I was unable to get the card display image even after mounting the original cooler back. I RMAd the card and I got a replacement one in January. I mounted the Hybrid cooler and the card worked fine until today. This morning I turn on PC and the card is stuck at 1569MHz and every change in Precision XOC results in freeze. DDU and new drivers did not helped. Changing between Master and Slave BIOS seems to not do anything. GPU-Z still reports the same BIOS version. I removed the card, loosened the cooler and then tried to mount it back with as equal pressure as possible. I removed the entire shroud (yes, the grill is loose on it). Still, the card wont go past 1569MHz and 0,800V. I have not tried to mount the air cooler back yet but I have a feeling that it will not do anything. Do I seriously have to do another RMA now? :-( I have not seen this forum post back then. EDIT: So I mounted the air cooler back aaaand... 1569MHz :-(
post edited by TheWereCat - Monday, February 19, 2018 3:36 PM
hasler74
Monday, February 19, 2018 4:35 PM
I wish I would have read this before using a gift card to order a hybrid kit. Is the consensus that the grill is shorting the power delivery? If so what exactly am I looking for to ensure this is safe to install? I saw in an earlier post that there should be some electrical tape some where, but I am not exactly sure where that should be. Any help before I risk my card would be appreciated.
AHowes
- Ribbons : 27
Monday, February 19, 2018 4:48 PM
I don't think anyone knows yet forsure what's going on with these kits.
If your going to go for it at least make sure the shroud edge is snapped in before putting it on.. the metal edge I think at the end.
At least know evga will have your back if the card ends up bad afterwards.
Maybe contact thrm first and ask if they have any current info on what the problem is first. Maybe they fixed the issue and can see by the aerial number if yours is a newer revision kit or what.
chefmattyp
Monday, February 19, 2018 4:51 PM
hope this isn't a problem that is too common
- Ribbons : 271
Monday, February 19, 2018 5:19 PM
chefmattyp hope this isn't a problem that is too common
After 9 pages, I think it is safe to assume that it is.
hasler74
Monday, February 19, 2018 5:21 PM
Just dropped a line to customer service. We will see what they say.
unclenode
Monday, February 19, 2018 6:59 PM
They will issue an RMA, for both the card and hybrid cooler if need be, but the guys I've spoken to act like they've never heard of the issue. I had to direct them to this thread as proof that there were numerous people with the exact same issue. I have a FTW3 Hybrid (already assembled) coming today, that sucker had better work out of the box.
AHowes
- Ribbons : 27
Monday, February 19, 2018 7:02 PM
unclenode They will issue an RMA, for both the card and hybrid cooler if need be, but the guys I've spoken to act like they've never heard of the issue. I had to direct them to this thread as proof that there were numerous people with the exact same issue. I have a FTW3 Hybrid (already assembled) coming today, that sucker had better work out of the box.
Prob told to say that I'm guessing since this has been going on for a while now. I got the ftw3 hybrid in my son's rig and it's awesome!
dual109
Monday, February 19, 2018 9:55 PM
AHowes I don't think anyone knows yet forsure what's going on with these kits.
I contacted EVGA about 2 weeks ago and there was no recall on the Kit. I posted this a few pages back. Cheers
mark_thaddeus
Monday, February 19, 2018 10:43 PM
dual109 I contacted EVGA about 2 weeks ago and there was no recall on the Kit. I posted this a few pages back. Cheers
Agreed, I sent an email to EVGA and they specifically mentioned that there was no recall or version 2 of the hybrid kit for the FTW3. They told me to install it first and if something happens then they will RMA both if need be. I also directed them to this thread and got no response back. I also haven't installed the shroud on my hybrid kit and it's running great. Lol! Too busy at work at the moment to bother with it!
post edited by mark_thaddeus - Monday, February 19, 2018 10:52 PM
4.6 Ghz 4790k - Z97I Plus - 1080 Ti FTW3 Hybrid - 16 GB HyperX Savage 2133 DDR3 - Crucial MX500 1 TB - Seasonic SS 660XP Platinum
PietroBR
- Ribbons : 7
Tuesday, February 20, 2018 10:22 AM
I have started the RMA process of my Hybrid Kit. And soon enought will do on my card as well.
Did you guys, who RMAed the Kit, needed to upload photos of the S/N and the product itself to EVGA? (might be a procedure specific for EVGA Brazil, but who knows..)
