atomicvai
Re: 1080Ti FTW3 Upgraded with the Hybrid Kit - Problem!
Monday, February 05, 2018 11:03 PM
The issue is apparently with the shroud contacting the card. My replacement is on the way and they said the same thing to me "we do not believe you will have any issues". I'm not sure if there's a change, but they said they did not experience the issue with their new units in testing. I will install it without the shroud and test before I put the shroud on.
dual109
Tuesday, February 06, 2018 4:03 AM
atomicvai The issue is apparently with the shroud contacting the card. My replacement is on the way and they said the same thing to me "we do not believe you will have any issues". I'm not sure if there's a change, but they said they did not experience the issue with their new units in testing. I will install it without the shroud and test before I put the shroud on.
Great let us know and how it performs as I'm sitting on fence if I'm going to install it or even sell it. I'm no so much concerned about stuffing the card as an RMA will be honoured worst case it's that I'm in Australia and don't want to be hit for shipping and be without a card for 2 weeks especially if gains are minimal.
atomicvai
Tuesday, February 06, 2018 4:05 AM
dual109
I'll take a good look at the new shroud vs. the old and let you know if I can actually see any difference.
mark_thaddeus
Wednesday, February 07, 2018 3:45 PM
atomicvai I'll take a good look at the new shroud vs. the old and let you know if I can actually see any difference.
Thank you very much! I have my hybrid kit sitting unopened on my desk and I'll wait on your update good sir before I do anything!
4.6 Ghz 4790k - Z97I Plus - 1080 Ti FTW3 Hybrid - 16 GB HyperX Savage 2133 DDR3 - Crucial MX500 1 TB - Seasonic SS 660XP Platinum
atomicvai
Wednesday, February 07, 2018 10:59 PM
It was supposed to arrive today, but delayed due to weather. Should get it tomorrow.
dual109
Thursday, February 08, 2018 0:09 PM
atomicvai
dual109
Yes Please let us know thanks. EVGA haven't been forthcoming with any info. I mean if we have many reports of the same problem happening it's either has to be a issue with the kit or problem with the installation. At least there replacing the cooler and cards if they fail.
corpsejockey
Thursday, February 08, 2018 5:11 PM
Yup... exact same issue. Problem persists after reinstalling stock cooler. Time to get the rma ball rolling.
atomicvai
Thursday, February 08, 2018 6:19 PM
Ok, my replacement cooler just showed up at work, so I'll do the install a little later today. Looking at the shroud though, I don't see any difference. Still metal in the same places etc, so I'm a little nervous. I'll have a closer look when I can get home and compare directly. So far though, looks the same.
AHowes
- Ribbons : 27
Thursday, February 08, 2018 6:23 PM
atomicvai Ok, my replacement cooler just showed up at work, so I'll do the install a little later today. Looking at the shroud though, I don't see any difference. Still metal in the same places etc, so I'm a little nervous. I'll have a closer look when I can get home and compare directly. So far though, looks the same.
Could be a difference in the height of contact of the memory plate as well. May be hard to tell. Just thinking of that as others have said it could be something with tightening the screws too much putting too much pressure on the memory or pcb.
atomicvai
Thursday, February 08, 2018 9:52 PM
Alright, the new cooler is installed and working as it should. The only thing I haven't done yet is install the shroud. I could see absolutely no difference between the new and the old one, but maybe it's extremely minor. I'll throw the shroud on tomorrow. Temps are great. The replacement card actually clocks a little better than my original one. I did look at the memory plate and it appeared identical to the old one, but once again it could be a matter of such a small degree of difference that it's not perceptible. As far as tightening, I tightened everything as tight as I did the first time.
AHowes
- Ribbons : 27
Thursday, February 08, 2018 9:56 PM
The cooling should be better for the power area once you put the shroud one but good idea for testing purposes!
dual109
Thursday, February 08, 2018 10:01 PM
atomicvai Alright, the new cooler is installed and working as it should. The only thing I haven't done yet is install the shroud. I could see absolutely no difference between the new and the old one, but maybe it's extremely minor. I'll throw the shroud on tomorrow. Temps are great. The replacement card actually clocks a little better than my original one. I did look at the memory plate and it appeared identical to the old one, but once again it could be a matter of such a small degree of difference that it's not perceptible. As far as tightening, I tightened everything as tight as I did the first time.
Awesome great please do report back. Cheers
mark_thaddeus
Friday, February 09, 2018 2:36 AM
I just opened up my hybrid kit and inspected the shroud and noticed that the metal grill near the blower fan is loose. Upon further inspection, I noticed that the metal part (with 4 tabs) that connects to the shroud is not properly seated/connected and has come loose. A picture (post #62 - page 3) of this was shown earlier in the thread so I didn't bother posting another pic. I've fixed the loose part and made sure that it all went back into the tabs of the shroud (Need to be careful when doing this as it is a bit tight and there is a possibility to break the tabs). I'm getting antsy so I will try and install the hybrid kit and video tape the whole thing for posterity. I'll do what @atomicvai did and test without the shroud first and then test with shroud on.
post edited by mark_thaddeus - Friday, February 09, 2018 4:39 AM
atomicvai
Friday, February 09, 2018 3:18 AM
mark_thaddeus I just opened up my hybrid kit and inspected the shroud and noticed that the metal grill near the blower fan is is loose. Upon further inspection, I noticed that the metal part (with 4 tabs) that connects to the shroud is not properly seated/connected and has come loose. A picture (post #62 - page 3) of this was shown earlier in the thread so I didn't bother posting another pic. I've fixed the loose part and made sure that it all went back into the tabs of the shroud (Need to be careful when doing this as it is a bit tight and there is a possibility to break the tabs). I'm getting antsy so I will try and install the hybrid kit and video tape the whole thing for posterity. I'll do what @atomicvai did and test without the shroud first and then test with shroud on.
Both of mine were really loose as well. I didn't think about it on the first install but seated my new one properly. Tomorrow I'll do the install of the shroud. Sure loving these max 45 degree temps on the GPU. I'll cry if the shroud dummies my card.
bisu0728
Friday, February 09, 2018 3:25 AM
Did you noticed those four spring screws are still too tight? I wonder if too much pressure on core is the root cause.
atomicvai
Friday, February 09, 2018 3:47 AM
bisu0728
I still found them tight, no more or less than the first kit.
mark_thaddeus
Friday, February 09, 2018 4:49 AM
atomicvai Both of mine were really loose as well. I didn't think about it on the first install but seated my new one properly. Tomorrow I'll do the install of the shroud. Sure loving these max 45 degree temps on the GPU. I'll cry if the shroud dummies my card.
I'm thinking of leaving the shroud off once I install the cooler, since I will have a fan blowing air directly onto the card. I'll check to see temps then decide or maybe I'll decide with how your install goes!
dual109
atomicvai
Hi just curious did you remove the thermal pad on the block and put paste on instead????
atomicvai
Friday, February 09, 2018 1:50 PM
dual109
atomicvai
No, just used what came with it.
shaolinn
Saturday, February 10, 2018 1:01 PM
atomicvai
dual109
atomicvai
And any update on the shroud install?
atomicvai
Saturday, February 10, 2018 7:25 PM
Just finished installing the shroud. Everything is working perfectly. Make sure you clip the metal pieces at the end tight on to the shroud. When the unit arrived that metal grate was loose and flopping around, so it needs to be clipped in to the shroud properly. I can't say if I noticed that on the last one, and it's on it's way back to EVGA, so can't confirm. Thanks to mark_thaddeus for pointing that out on his. Considering it's really the only metal on the shroud that could have contacted anything, I can't help but wonder if that was the cause. Finally up and running and happy. I will say that EVGA really came through for me as far as dealing with the shipping both ways on the card and the kit. You really can't ask for better customer service. This isn't the first time I've had to RMA a card with EVGA, but the experience in dealing with them is best in the business. I wanted to say a thanks to all on here as well that contributed their experiences and suggestions. Great community!
post edited by atomicvai - Saturday, February 10, 2018 7:27 PM
shaolinn
Saturday, February 10, 2018 7:51 PM
atomicvai Just finished installing the shroud. Everything is working perfectly. Make sure you clip the metal pieces at the end tight on to the shroud. When the unit arrived that metal grate was loose and flopping around, so it needs to be clipped in to the shroud properly. I can't say if I noticed that on the last one, and it's on it's way back to EVGA, so can't confirm. Thanks to mark_thaddeus for pointing that out on his. Considering it's really the only metal on the shroud that could have contacted anything, I can't help but wonder if that was the cause. Finally up and running and happy. I will say that EVGA really came through for me as far as dealing with the shipping both ways on the card and the kit. You really can't ask for better customer service. This isn't the first time I've had to RMA a card with EVGA, but the experience in dealing with them is best in the business. I wanted to say a thanks to all on here as well that contributed their experiences and suggestions. Great community!
So was it user error or did they actually change the shroud? Good to hear it works. Now if only they would get stock in EU.
atomicvai
Saturday, February 10, 2018 7:58 PM
shaolinn
As I said, I didn't see any difference in the shrouds, so who knows. As far as user error, I installed this unit exactly as I installed the first one. The loose metal grate is a QC issue, not user error.
bisu0728
Saturday, February 10, 2018 8:28 PM
atomicvai
shaolinn
Mine also have the loose metal grate. I don't know why it happened that commonly!! I don't think that loose metal grate is the cause of our damage. I do clip the metal piece back before installing the shroud and my card still damaged in the way that same as other.
bisu0728
Saturday, February 10, 2018 8:36 PM
atomicvai
shaolinn
Interestingly, new kit just delivered. The metal grate was loosen too...... why this becomes a such common issue!
brian91292
Saturday, February 10, 2018 9:49 PM
Just finished installing my FTW3 hybrid kit and everything went great :D No issues with boost clocks, nice and quiet, and temps are insanely low compared to air. The kit wasn't hard to install either... anyone complaining about stripping screws probably just didn't have the right tools for the job. The instructions were also just fine in my opinion. Edit: These lower temps have also opened the door to a previously unreachable overclock, any core clock increase would cause my PC to blackscreen/crash in games very quickly (with an average temp of ~70c), now with the hybrid kit under load I've seen no higher than ~50c and I'm able to push core +75 and memory +750.
post edited by brian91292 - Saturday, February 10, 2018 9:59 PM
AHowes
- Ribbons : 27
Saturday, February 10, 2018 11:48 PM
You should max out the voltage slider as well and see if you can get more.
brian91292
Sunday, February 11, 2018 0:07 PM
AHowes You should max out the voltage slider as well and see if you can get more.
Yeah I tried that after posting the screenshot, decided to switch to afterburner for the voltage/frequency curve now (as I hit some instability when gaming with the OC in PXOC), but I'm finding that the power fan isn't ever firing up now. Anyone know a workaround for this? I've flashed the actual FTW3 Hybrid bios thinking this might allow the power fan to be controlled via afterburner, but I guess not.
post edited by brian91292 - Sunday, February 11, 2018 0:10 PM
mark_thaddeus
Sunday, February 11, 2018 0:40 PM
Reporting in and I'm happy to say that the card is running fine without the shroud so far! I ran heaven benchmark and the card ran 2050 Mhz (I didn't try to push it further though I could have, it feels to have even more room for that!) at 1.063v (auto setting though and didn't set it manually) and it ran perfect. Almost no fluctuation on the clocks as it kept running and only hit 50C. Good to see that a couple of folks had success installing the shroud! I'll probably do that after letting this run a day and then enjoy it! Also it seems the issues do stem from the shroud as the installation of the memory base plate / pump bracket and mosfet heat sink were very straightforward and personally idiot proof IMHO. Pro tip, people need to get a nice #0 and #1 Phillips screwdriver so there is no stripping of screws! So happy with the Hybrid Kit! I'm glad I got one! EDIT: (I'll report back once the shroud is installed)
post edited by mark_thaddeus - Sunday, February 11, 2018 0:51 PM
mark_thaddeus
Sunday, February 11, 2018 0:56 PM
shaolinn So was it user error or did they actually change the shroud? Good to hear it works. Now if only they would get stock in EU.
It's hard to say if it was user error because I really had to pay attention and check the shroud to even notice the clip come off the shroud. It's a QC error and will lead to a lot of bricked cards. Aside from improving QC, EVGA should include a warning on the manual or a separate piece of paper in the kit (Just like you have for the proper mounting of the radiator) as redundancy.
