Afterburner
- Location: It's... Classified Yeeeeeeeeeeaaaaaaah........
- Ribbons : 110
Re: Who's going 1080Ti on water? Founder's + EK block or HydroCopper?
2017/03/30 04:56:32
warrior10
Afterburner I have decided to wait for EVGA's Hydro Copper.
Liar, i bet you probably have all of your Hardware including even your HDD in an over-soaked fish tank lol. J/k Good luck waiting, because i can't, i've had some bad Gpu's years ago from the reference editions, and i don't OC. :/
My situation is different. I crunch (Fight cancer, look for planets etc.) 27/7. The fan on these FE's require to be at 4200RPM in order to keep the GPU at a steady 72f. That is just to much noise. Having WC'd for 10 years ish now. I just think it is easier to order new fans for the 360RAD and new fittings/tubing this time around than introduce another form of cooling to the system.
TheWizardMan
2017/03/30 07:39:17
Afterburner
warrior10
Right, but why do you need to wait for the HC? You can watercool a FE right now if you want. Sincerely curious.
| Asus Maximus IX Formula | Intel 6700K @ 4.8GHz | EVGA 1080 Ti w/ EKWB WBs (x2) | Phanteks Luxe TG | Custom Loop | | 32GB G.Skill Trident Z 3733 MHz | Samsung 960 EVO 500 GB M.2 Drive | Samsung 850 EVO 1 TB SSD | Cablemods Sleeved Cable Kit |
GTXMan
trawetSluaP
2017/03/30 13:16:47
All set up now: Few points - can't add more than a 100MHz to the core otherwise I crash, bit of a disappointment. I get a load of coilwhine when rendering high frames such as in Heaven etc but in real applications such as gaming I don't. Lastly, little bit disappointed with EK (although I ordered with OcUK) as my backplate didn't come with a logo... They must've forgot it at the factory.
Case: Phanteks Enthoo Elite CPU: i9-7900X Motherboard: Rampage VI Extreme RAM: Corsair Dominator Platinum 32GB 3200 MHz GPU: RTX 2080 FE Storage: 960 Pro 512GB, 2 x 840 Evo 250GB PSU: EVGA SuperNOVA 1200 P2 Monitor: HP Omen 27i, MX27AW Custom Watercooling LoopAquaero 6 XT
bloodhawk1989
2017/03/30 13:55:14
TheWizardMan
Afterburner
warrior10
I think one of the reasons why im also waiting for the Classified (unlike the HC) is that i want something with a better TDP. Maybe im jut on the edge because my current is a lemon xD
Desktop - 5900X / CH VIII Dark Hero / 3080 FTW3 (WC) / 2080Ti Strix OC (WC) / 64Gb Gskill 3200Mhz CL14 / 2 x 1 TB 960 Pro's EVOC P870DM3-G - 8700k @ 4.8Ghz / 2 x GTX 1080 / 64Gb Gskill 3000Mhz CL18 / 2 x 512GB 950 Pro
Afterburner
- Ribbons : 110
2017/04/01 06:07:29
TheWizardMan Right, but why do you need to wait for the HC? You can watercool a FE right now if you want. Sincerely curious.
A couple of reasons. - I have had a few unhappy situations with EK's.
- Even though Koolance is just a quick drive for me to their store/manufacturing facility, I have had a couple product failures.
- I simply am not liking the look of the HK's for the 1080's.
- I have had more drama free experiences with th HC's from EVGA.
- Most of the blocks I have seen thus far are frankly not that attractive to me. Although I have been looking at Phanteks blocks the last few days...
zswickliffe
2017/04/01 06:14:56
Finally took the plunge!
i7-4790k @ 4.6GHz 1080 Ti @ 2050MHz
- Ribbons : 282
2017/04/03 22:06:42
Removed for GTXJackBauer The Stalker of the Forums.
post edited by bcavnaugh - 2017/05/11 21:20:11
GTXJackBauer
- Ribbons : 48
2017/04/04 03:31:42
bcavnaugh I installed my EK Water Blocks today and I would rate them as only being 98% Compatible with the GTX 1080 Ti FE Graphics Cards.
What's with the 2%?
the_Scarlet_one
formerly Scarlet-tech
- Ribbons : 79
2017/04/04 04:23:40
GTXJackBauer
What's with the 2%?
You asked before I could.. the 2% is probably because they say Titan X, since they are 100% compatible. 1% per Titan X engraving ;-) Am I close BCav?
TheWizardMan
2017/04/04 08:23:06
I'm thinking I'll do the phanteks waterblocks with the EK backplates when they are released (don't like the stock backplates that much). I don't know why phanteks doesn't release a backplate with their waterblock?
- Ribbons : 282
2017/04/04 11:19:31
post edited by bcavnaugh - 2017/05/11 21:20:25
- Ribbons : 282
2017/04/04 11:29:20
post edited by bcavnaugh - 2017/05/11 21:20:34
the_Scarlet_one
- Ribbons : 79
2017/04/04 11:34:26
bcavnaugh My Dry Run Leak Testing Click on Image Twice for a Larger View.
Beautiful! Also, I see what you mean now. Ek may have determined, along with nvidia, that they didnt need extra cooling.
- Ribbons : 282
2017/04/04 11:45:45
post edited by bcavnaugh - 2017/05/11 21:20:47
the_Scarlet_one
- Ribbons : 79
2017/04/04 11:54:43
bcavnaugh Thanks, Someone asked me sometime ago how do you Dry Run being that water is wet. I do not think it should impact the Cooling as well or I would have not done the second card. EK Really Sucks because the do not provide the Needed O-Rings (OR 15x1mm Gasket)* for the SLI Block and Not for the EK-FC Terminal BLANK Serial Block. The Black Bar in the Middle of the SLI Block. Also they do not provide any cover for the Center of the Block as well so you need one EK-FC Terminal BLANK Serial another $10 for that. *The install O-Rings are not easy to remove nor put back on.
You mean the oblong orings for the terminals? No, they are not easy to remove and replace at all.. they are all a little pain in the butt. I tossed my plexi terminals, and picked up all acetal terminals because the plexi cracks fairly easy if you slightly overtighten the plug. Be aware, this isnt common, i had this terminal for 2 years, and this just recently appeared: You dont need a lot of pressure when tightening the plugs, and I definitely over tightened this one.
- Ribbons : 282
2017/04/04 12:13:52
post edited by bcavnaugh - 2017/05/11 21:20:59
GTXJackBauer
- Ribbons : 48
2017/04/04 13:08:55
Scarlet-Tech
Reason why I stay away from plexi and acrylic like the plague.
- Ribbons : 282
2017/04/04 16:51:28
post edited by bcavnaugh - 2017/05/11 21:21:12
bloodhawk1989
2017/04/04 17:25:56
bcavnaugh I knew someone would ask. *Nothing to do with the "Titan X Engraving" Mute Point for me. (And I thought Scarlet-Tech Knew me) What the Arrows are pointing to are covered with a Thermal Pad on the Blower Cooler but 2 are not covered at all with the Water Block and 4 are only half covered AND are not part of the Thermal Pads that come with the EK Water Block that is for the Titan X (Pascal) I did add a strip at the edge to at least cover half the them. Click on Image Twice for a Larger View. The Missing 2% Also remember that there are some other Thermal Pads on the Air Cooler that are NOT part of the water block so compare and add where needed. 3 that I recall, sorry I did not take a photo. Looking for that Photo of the GTX 1080 Ti Card so I can point them out...... I did install the EK Back Plates and did add some extra Thermal Pads and note that their is ONE Thermal Pad on the Stock Back Plate as well.
Those caps are not covered even on the 1080Ti blocks that EK is releasing soon. Till the MOSFETs are covered, we are all good.
post edited by bloodhawk1989 - 2017/04/04 17:28:15
- Ribbons : 282
2017/04/04 17:38:28
post edited by bcavnaugh - 2017/05/11 21:21:25
bloodhawk1989
2017/04/04 17:41:37
bloodhawk1989
bcavnaugh I knew someone would ask. *Nothing to do with the "Titan X Engraving" Mute Point for me. (And I thought Scarlet-Tech Knew me) What the Arrows are pointing to are covered with a Thermal Pad on the Blower Cooler but 2 are not covered at all with the Water Block and 4 are only half covered AND are not part of the Thermal Pads that come with the EK Water Block that is for the Titan X (Pascal) I did add a strip at the edge to at least cover half the them. Cck on Image Twice for a Larger View. The Missing 2% Also remember that there are some other Thermal Pads on the Air Cooler that are NOT part of the water block so compare and add where needed. 3 that I recall, sorry I did not take a photo. Looking for that Photo of the GTX 1080 Ti Card so I can point them out...... I did install the EK Back Plates and did add some extra Thermal Pads and note that their is ONE Thermal Pad on the Stock Back Plate as well.
Maybe so, but they are with the FE Cooler, maybe EK needs to review what they are doing and not only change the name on the Block.
True that. But from the temps that i measured around that area they dont really get as warm. Only the ones super close to the MOSFETs. Also the pads that NVIDIA has on them are some of the ****tiest pads i have seen lol. They crumble faster than dried chocolate brownies. I even dumped EK's pads once i found out they are only 3 W/mK. Replaced em with 11 W/mK fujipoly's.
joder
2017/04/04 18:21:29
bloodhawk1989 True that. But from the temps that i measured around that area they dont really get as warm. Only the ones super close to the MOSFETs. Also the pads that NVIDIA has on them are some of the ****tiest pads i have seen lol. They crumble faster than dried chocolate brownies. I even dumped EK's pads once i found out they are only 3 W/mK. Replaced em with 11 W/mK fujipoly's.
How many did you end up needing, what size (thickness and WxH), and where did you get them?
bloodhawk1989
2017/04/04 18:32:45
joder
Well i have a pretty retarded collection - http://i.imgur.com/xMIVGXF.jpg (There are more strips at the back of those Modright/FujiPoly packs) (I think i have issues xD) But for the 1080Ti , i used - 1 x 0.5mm 11 W/mK 60mmx50mm sheet OR 2 x 0.5mm 11 W/mK 100mm x 15mm sheet (for VRAM chips) (The 60mmx50mm sheet was initially for the chokes and to cut a few extra pads for the remaining VRAM chips since a single 100x15mm doesnt cover all of them) 1 x 1mm 11 W/mK 100 x 15mm sheet ( for Chokes) 1 x 1mm 11 W/mK 60mmx50mm sheet (for mosfets, cut in 2 x 18mm wide strips and then lines up along their length on the Mosfets). Also do note that EK included a 0.5mm strip for the chokes, but that made NO contact all with the block, that is why the 1mm. I got mine from Frozen CPU, but because i usually buy the large sheets. For smaller sheets you can grab them from amazon with either Same day or next day delivery if you are Prime member. They are available on PerformancePCS as well, but i couldn't find the sheet sizes i needed. Also if the FujiPoly pads are too expensive for your taste, you can always grab the Arctic thermal pads for a fraction of the price. They are however 6 W/mK. But that will only matter for the VRMs/MOSFETs. Do note that these will not help you get better over clocks. Just that the clocks are more stable than normal. In certain cases you might get a few Mhz extra.
post edited by bloodhawk1989 - 2017/04/05 09:27:39
joder
2017/04/04 19:50:04
bloodhawk1989 Well i have a pretty retarded collection - http://i.imgur.com/xMIVGXF.jpg (There are more strips at the back of those Modright/FujiPoly packs) (I think i have issues xD)
You weren't kidding lol. I am willing to spend a few extra bucks to get a stable overclock. I got some artifacting when boosting my memory at +600 so I think heat might have played an issue. Granted I am still on air waiting for the EK blocks. I am a bit hesitant now as their blocks aren't covering everything as someone pointed out earlier. Thanks for posting this. I want to buy just the right amount and not too much as they are pricey.
- Ribbons : 282
2017/04/04 19:52:27
post edited by bcavnaugh - 2017/05/11 21:21:41
bloodhawk1989
2017/04/04 19:57:28
bcavnaugh Still have some Bleeding to do,
I think i just finished a whole roll of paper towels wiping off all the drool. I really need to order my darn QDC's and overhaul my loops. bcavnaugh Any Listing?
https://www.amazon.com/s/...amp;crid=33GXEZNIELR7Z :P joder
Yeah i would only suggest using these with a waterblock. Also if you can wait until this week and shoot me a reminder on Firday/Saturday ill be taking apart my block. So i can take a few pictures for you guys. I went ahead and edited the important sizing bit with bold letters so that its easier to spot.
- Ribbons : 282
2017/04/04 20:04:29
post edited by bcavnaugh - 2017/05/11 21:21:51
- Ribbons : 282
2017/04/04 20:07:09
post edited by bcavnaugh - 2017/05/11 21:22:01
bloodhawk1989
2017/04/04 20:11:03
bcavnaugh Thanks
Ah my apologies i misunderstood. I really dont have a list per se tbh :( bcavnaugh
joder I am a bit hesitant now as their blocks aren't covering everything as someone pointed out earlier.
I am running at 2138MHz & 2126MHz Temps with Low Fans 44C with Fans High 38C.
Damn you are freaking lucky to be able to hit those clocks. Mine cant go anywhere over 2050Mhz that too is sometimes unstable. 2038 though is rock solid.
