the_Scarlet_one
formerly Scarlet-tech
- Ribbons : 79
Re: Who's going 1080Ti on water? Founder's + EK block or HydroCopper?
2017/03/23 11:37:42
MiguelEVGAfan if i wanted to go ek etc and just wanted to cool off the gpu only what single kit can i get? cannot seem to find a single kit just for gpu
You would want to piece together the system yourself. I think they only do CPU full kits, and you purchase the GPU block separate. You should make an account and email them and see if they will make you a kit with the GPU only.
the1320god68
2017/03/23 15:38:36
El-Dubya Hmmm, wonder when/if EK will release back plates that say "1080 Ti" instead of Titan X (would prefer they were just plain actually).
Cant even see it...
the_Scarlet_one
- Ribbons : 79
2017/03/24 04:03:54
I guess I am a complete idiot. The stand offs under the stock nvidia backplate mount to the EK water block. I didnt even think about the standoffs. Another user posted a thread where he used the stand offs and kept the stock backplate. Sadly, noone thinks to say they used the stand offs, they just say they used the screws. https://forums.evga.com/P...terblock-m2635322.aspx
post edited by Scarlet-Tech - 2017/03/24 04:07:33
GTXMan
2017/03/28 07:59:53
Anyone here get the EK nickel-plated TXP block? If so, what biocide/anti-corrosive are you using? I ask because I emailed EK yesterday asking if they still do not recommend the use of PT Nuke and they said yes, they still do not recommend it for their nickel-plated blocks. Also no kill coils. I'm now looking at PrimoChill Liquid Utopia which they said they have not tested but didn't think it'd be an issue. So what are you guys using?
Current rig: DCS4VR 3.0Thermaltake Core P5 || 7700k + Aquacomputer Kuplex Cryos NEXT w/ VISION || EVGA XC Gaming 2080Ti + EK Vector block/backplate || G-Skill Trident Z 32GBs DDR4-4000 || ASUS Maximus IX Code || LG 38GL950G-B|| Logitech G900 || Sony WH1000-XM4 || VIVE Pro
- Ribbons : 282
2017/03/28 10:14:17
Removed for GTXJackBauer The Stalker of the Forums.
post edited by bcavnaugh - 2017/05/11 21:19:14
Zeeflyboy
2017/03/28 13:46:48
How long do we think it'll be before a 1080Ti hydrocopper appears? Really tempted to change from my 2 x 980Ti hydrocoppers, haven't really seen any aftermarket water-cooling jackets that look quite as smart as the HC's normally do, plus I prefer buying with the blocks pre-installed for convenience. I saw MSI have a seahawk announced already but again doesn't look as classy as the HC offerings imo...
GTXJackBauer
- Ribbons : 48
2017/03/28 13:57:41
GTXMan Anyone here get the EK nickel-plated TXP block? If so, what biocide/anti-corrosive are you using? I ask because I emailed EK yesterday asking if they still do not recommend the use of PT Nuke and they said yes, they still do not recommend it for their nickel-plated blocks. Also no kill coils. I'm now looking at PrimoChill Liquid Utopia which they said they have not tested but didn't think it'd be an issue. So what are you guys using?
I have seen what DYI fluids with coils can do to EK's nickle. Let's just say it's not pretty. I've since left distilled and silver to Aquacomputer's Clear DP Ultra fluid. So far it's working like a charm. Zeeflyboy How long do we think it'll be before a 1080Ti hydrocopper appears?
I surely hope they do especially the Classified HCs.
the_Scarlet_one
- Ribbons : 79
2017/03/28 14:01:50
I use the EKWB fluids, specifically the clear fluid: https://www.ekwb.com/shop...vo-concentrate-coolantI have used their pastels, but will never put any pastel in any computer I own again. They leave disgusting residue behind, even when you change the fluid constantly.
GTXJackBauer
- Ribbons : 48
2017/03/28 14:05:31
Scarlet-Tech
Color fluids have a tendency to stain at the least. I know it looks all pretty and stuff but the colors eventually break down and get absorbed. Some might argue this but again, I've seen it over the years. Colored tubing and LED lighting should take care of the color fluid's absence imo. I agree, clear balanced fluid is the best way to go from reputed custom water cooling companies period.
- Ribbons : 282
2017/03/28 14:12:21
post edited by bcavnaugh - 2017/05/11 21:19:26
GTXJackBauer
- Ribbons : 48
2017/03/28 14:16:09
GTXJackBauer
Scarlet-Tech
I have been using Koolance Blue for over 3 years now and the Only Stain I have is on my Carpet.
Must have a good stain.
2017/03/28 14:18:05
Oxyclean distilled water and primochill liquid utopia - protectant (biocide & corrosion)
GTXMan
2017/03/28 14:22:02
Thanks for the responses. Looks like I'm gonna go with distilled water + and Liquid Utopia.
GTXJackBauer
- Ribbons : 48
2017/03/28 15:25:40
GTXMan Thanks for the responses. Looks like I'm gonna go with distilled water + and Liquid Utopia.
I almost forgot. If you're on soft tubing, make sure you're running some PrimoChill Advanced LRT. Best tubing out there for a number of years now.
GTXMan
2017/03/28 19:07:37
GTXJackBauer
Went with PETG.
joder
2017/03/29 01:05:00
Still slightly gun shy to pull the trigger on another copper EK block. I would love the nickel, however, the way they handled their nickel flaking issues...
trawetSluaP
2017/03/29 04:29:41
I vcaved. Have an Ek block/backplate being delivered today!
Case: Phanteks Enthoo Elite CPU: i9-7900X Motherboard: Rampage VI Extreme RAM: Corsair Dominator Platinum 32GB 3200 MHz GPU: RTX 2080 FE Storage: 960 Pro 512GB, 2 x 840 Evo 250GB PSU: EVGA SuperNOVA 1200 P2 Monitor: HP Omen 27i, MX27AW Custom Watercooling LoopAquaero 6 XT
the_Scarlet_one
- Ribbons : 79
2017/03/29 04:42:39
joder Still slightly gun shy to pull the trigger on another copper EK block. I would love the nickel, however, the way they handled their nickel flaking issues...
That was YEARS ago. Just dont use the biocide that they say not to use.
Afterburner
- Location: It's... Classified Yeeeeeeeeeeaaaaaaah........
- Ribbons : 110
2017/03/29 05:04:10
I have decided to wait for EVGA's Hydro Copper.
damstr
2017/03/29 06:33:35
gravedigger78
2017/03/29 11:31:02
I will be patient. Heck if it is another 3-4 months I might have the money to get a new MOBO and CPU. I don't like my 3770K anymore.
the1320god68
2017/03/29 14:10:27
I'm using this. no complaints at all! http://www.performance-pcs.com/mayhems-pastel-coolant-1-liter-ice-white.html
warrior10
2017/03/29 14:34:17
Scarlet-Tech
I am very worried about how we tell some people how easy it is to do these Hyro, Hybrid and Water-cooling kits when it fact if your a beginner, you stand a good chance of ruining the Gpu and then have to RMA them, etc. I myself have never ever built a Water cooling device pre-fabricated or otherwise, and that is because I have been told for over 20 year i don't have the best Dexterity, which i don't unfortunately even though most Computer stuff i can still build on my own. Fact is that I think the more Tech-inclined people should be "more inclined to tell people to get Help" with their Hybrid Water and/ or Air-cooled unless they without a doubt can do it themselves. That's just what i tell people. Always better to be safe a learn first before charging in heheh.
My new https://www.gigabyte.com/...70-Gaming-K7-rev-10#kfHAF-X Coolermaster: 4 Fans New Rig:Ryzen 1700 CPU-H100i Liquid arctic Cooled. 16gigs Corsair Vengeance DDR4-2400 180Ti Hybrid Blu-ray drive SCSI CDRW-RW drive SCSI Black WD Black caviar 2-1TB's and 1 500gig WD Blue 1 TB 1 Sand disk SSD 240 for OS Corsair PSU 1020 SWTOR Mouse and Headset Razer CHROMA Keyboard Dell 1444p G-Sync Monitor @144htz to 160htz
warrior10
2017/03/29 14:38:47
Afterburner I have decided to wait for EVGA's Hydro Copper.
Liar, i bet you probably have all of your Hardware including even your HDD in an over-soaked fish tank lol. J/k Good luck waiting, because i can't, i've had some bad Gpu's years ago from the reference editions, and i don't OC. :/
post edited by warrior10 - 2017/03/29 14:42:00
GTXJackBauer
- Ribbons : 48
2017/03/29 14:46:13
There is no RMA if you spill on your stuff unless the product is faulty and leaked. Than you'd have to deal with said company from that faulty product. They investigate as they don't just give you free replacements based on some wording. Another confusion is that there are sealed AIOs and custom water cooling pre-kits being confused with the other. More attention and research needs to be done on those kits.
post edited by GTXJackBauer - 2017/03/29 14:51:34
TheWizardMan
2017/03/29 15:02:36
warrior10 I am very worried about how we tell some people how easy it is to do these Hyro, Hybrid and Water-cooling kits when it fact if your a beginner, you stand a good chance of ruining the Gpu and then have to RMA them, etc. I myself have never ever built a Water cooling device pre-fabricated or otherwise, and that is because I have been told for over 20 year i don't have the best Dexterity, which i don't unfortunately even though most Computer stuff i can still build on my own. Fact is that I think the more Tech-inclined people should be "more inclined to tell people to get Help" with their Hybrid Water and/ or Air-cooled unless they without a doubt can do it themselves. That's just what i tell people. Always better to be safe a learn first before charging in heheh.
I actually think it's pretty straight forward and the actual risk to your components if you aren't plugged in is negligible. Obviously there's a baseline of intelligence and craftsmanship required, but the baseline on both is pretty low. I will say that you should do a lot of research on watercooling if you are doing a custom loop, because there are way too many hangups. But overall, the process is simple in comparison to a lot of other things I've done.
| Asus Maximus IX Formula | Intel 6700K @ 4.8GHz | EVGA 1080 Ti w/ EKWB WBs (x2) | Phanteks Luxe TG | Custom Loop | | 32GB G.Skill Trident Z 3733 MHz | Samsung 960 EVO 500 GB M.2 Drive | Samsung 850 EVO 1 TB SSD | Cablemods Sleeved Cable Kit |
the_Scarlet_one
- Ribbons : 79
2017/03/29 16:05:59
Raise your hand is you remember all the 980ti Hydrocopper owners that never had an idea that the hydrocopper required watercooling... *raises both hands*... You can tell people to get help, but when the refuse to read even the most basic instructions or understand what they read, you will never be able to truly help them.
post edited by Scarlet-Tech - 2017/03/29 16:11:56
GTXJackBauer
- Ribbons : 48
2017/03/29 16:20:48
Scarlet-Tech Raise your hand is you remember all the 980ti Hydrocopper owners that never had an idea that the hydrocopper required watercooling... *raises both hands*...
I'll never forget that Newegg review I read once on a HC a few years back that left a 1 egg review because they were upset at the fact that they weren't told they needed a water cooling system. That's like buying a CPU and being upset you were never told you'd need a MB for it. You just can't make this stuff up folks.
post edited by GTXJackBauer - 2017/03/29 16:23:18
warrior10
2017/03/29 16:36:16
GTXJackBauer
Yeah, if some people won't even try to help themselves then you just can't help them. For me i'll have a licensed friend do it as i have never done water-cooling and just have never had time to get proffecient with the stuff, though i would love to learn when i have a chance and get it right.
TheWizardMan
2017/03/29 16:42:03
warrior10 Yeah, if some people won't even try to help themselves then you just can't help them. For me i'll have a licensed friend do it as i have never done water-cooling and just have never had time to get proffecient with the stuff, though i would love to learn when i have a chance and get it right.
You also won't learn until you take the chance and do it. It's all about priorities. I personally chose to do my first build because I wanted to learn how it all worked and become proficient in the lingo. Would have never learned if I didn't just go for it. If you're looking for a computer that runs, buy it from someone else and turn it on. If you're looking to learn a bit and take pride in things you create, then take a little time to learn and build your own. It's all about what you're after.
