TiN_EE
Yes, that TiN
- Ribbons : 14
Wednesday, April 10, 2019 3:55 PM
fragility_V1
Re: Candies for RTX 2080 Ti Kingpin
Wednesday, April 10, 2019 3:59 PM
I love candy! Thanks TiN! (Kingpin too!)
- Ribbons : 123
Wednesday, April 10, 2019 4:02 PM
thank you for posting the Tool link I'll be looking forward to seeing your Tech Guide
- Ribbons : 282
Wednesday, April 10, 2019 4:03 PM
Waiting for the EVBOT Firmware update myself
post edited by bcavnaugh - Wednesday, April 10, 2019 4:06 PM
hotrod717
Wednesday, April 10, 2019 4:38 PM
bruno_ro
Wednesday, April 10, 2019 4:39 PM
Looking forward to tech guide!
danteafk
Wednesday, April 10, 2019 6:10 PM
the z390 dark guide is still not complete several months later after release, don't get your hopes up.
i9 9900k 5.2ghz - evga z390 dark - corsair ax1200i16GB g.skill tridentZ RGB 4600 CL18 - RTX 2080Ti 2160/8000960 -NVMe's only - LianLi O11 - ASUS ROG PG279Q Gsync @ 165hz - 2x Qnix2710 @ 120hz - klipsch promedia 2.1
viettiger
Wednesday, April 10, 2019 6:36 PM
Interesting... Thank you TiN and K|ngP|n
richiec77
Wednesday, April 10, 2019 11:49 PM
Sweet! Mine was just delivered 10 min ago.
Planning to use the 39F temps as a cheap chiller tonight. Maybe mount the ICON Pot Friday if I get some LN2.
hotrod717
Thursday, April 11, 2019 1:13 AM
Let's be thankful for the help and support we do get.
post edited by hotrod717 - Thursday, April 11, 2019 1:16 AM
Vlada011
- Ribbons : 11
Thursday, April 11, 2019 1:45 AM
What is waterblock. Someone make block for K|NGP|N? Dual radiator is more than enough for absolutely best system but I ask because people who have other watercooling parts? Bitspower maybe?
- Ribbons : 282
Thursday, April 11, 2019 2:37 AM
Not For Me!  EVGA Hydro Copper Water Blocks All The Way
post edited by bcavnaugh - Sunday, April 14, 2019 7:21 PM
scaper28
Thursday, April 11, 2019 8:44 AM
TiN_EE Grab some and enjoy the card: Classified tool. Stay tuned for tech guide for RTX 2080 Ti Kingpin Edition as well.
Hi Tin How can I get hold of one of these card in the UK , I'm desperate to get one :-(
PC SPECS Be-quiet dark pro 900 v2 Intel I9-9900k Asus XI Extreme Corsair Vengeance RGB Pro Corsair HX1000I Samsung 970 500GB EVO Samsung 960 1TB EVO KingPin RTX 2080TI Hybrid Acer Predator XB271HU EK 360 Extreme X1 EK D5 pump res combo EK-Velocity D-RGB - Nickel + Plexi Ek -Clear premix fluid
TiN_EE
Yes, that TiN
- Ribbons : 14
Thursday, April 11, 2019 9:23 AM
Sorry, I'm too far from sales team to know when cards will be available in different geo's to give you ETA dates. I think EVGA's ebay store might be an option, since it was so before.
Hopper64
Thursday, April 11, 2019 1:09 PM
I’m new to the KP. How do I use the posted tool? Thanks.
Asus Maximus Z690E i9 12900KS GSkill F5-6000U3636E16GX2-TZ5RK Samsung 980 Pro Corsair AX1600i Asus Strix 3090 OC EKWB Quantum Kinetic TBE 300 and VTX 160 Creative SB X4 Asus ROG XG349C
Hoggle
Thursday, April 11, 2019 3:23 PM
I am guessing it won't be much longer for the U.K.. to get the card. I don't know anything about the release but I would assume the sooner the better.
richiec77
Thursday, April 11, 2019 3:29 PM
Tool is working nicely! Thanks a ton TiN!
Also noticed it'll save settings when rebooting to quickly apply settings again after a restart. Super nice.
GuessWhoItIs
Thursday, April 11, 2019 4:39 PM
Also new to this, not sure how to get the sweet candy to work/run.
richiec77
Thursday, April 11, 2019 4:47 PM
GuessWhoItIs Also new to this, not sure how to get the sweet candy to work/run.
Disable Auto to get the NVVDD control to work. Then adjust voltages and Apply. Worked with the OC and LN2 BIOS. Didn't test with normal.
GuessWhoItIs
Thursday, April 11, 2019 5:00 PM
richiec77
Great, thanks for that! I believe I'm working off of the normal BIOS, is there a place to get the OC and LN2 BIOS? Maybe thats why I'm hitting limits. Can you explain the major differences between these BIOS settups, or have a link? Thanks!
richiec77
Thursday, April 11, 2019 5:21 PM
GuessWhoItIs
richiec77
The KP has the bios already loaded. Use the switch to change between versions. Far right is normal. Middle is OC and left position is LN2. You’ll need to power down, move the position and restart. As to what’s different between versions I do not know 100%. LN2 more would most likely disable temp controls and safety limits for XOC use. Try using the OC 1st. Then adjust the NVVDD and Mem voltages just a tad. Like 1.10v and 1.43v core and mem. You don’t want to push the voltages much with ambient temps. Vince said the core and Mem respond to a touch more voltage. That’s what you would apply for benches. If this is for gaming...not worth really. Might negatively scale if it pushes temp points a touch too far.
GuessWhoItIs
Thursday, April 11, 2019 5:25 PM
richiec77
GuessWhoItIs
richiec77
Thanks for the breakdown. I'll play with the settings and see what I can bench, curious as to what the limits are without overdoing it. Very informative.
TwoEvilOne
- Location: NW Ohio. EVGA Associate Code: 2QME1VF65K9ZY8B
Thursday, April 11, 2019 11:16 PM
richiec77
GuessWhoItIs
richiec77
Thanks for the info. very informative.
degenerate
Friday, April 12, 2019 0:10 PM
Big thanks for the updated Classified Tool, k|ngp|n & TiN. Can't wait to play with it a little later!
|5900x|MSI B550 Unify-X|2x16GB G.Skill 3800 C14 @ 1900 FCLK|2TB WD SN850 M.2|EVGA 3090 KPE|EVGA 1600T2|Alienware '25' & LG 48" CX OLED|
TiN_EE
Yes, that TiN
- Ribbons : 14
Friday, April 12, 2019 10:01 AM
jab383
Friday, April 12, 2019 5:51 PM
Great guide as always. Thanks K|ngp|n and TiN. The technical detail is exactly what I've come to expect in those guides. Note to all: There links to more candy in the guide.
richiec77
Friday, April 12, 2019 10:50 PM
Interesting. No Memory Heater on Board. I'm guessing the Sammy GDDR6 can go cold without issue if applying 1.45-1.50-1.55v depending on temps?
post edited by richiec77 - Friday, April 12, 2019 10:59 PM
Vlada011
- Ribbons : 11
Saturday, April 13, 2019 11:13 AM
Before one year I lived in dream if I add 100-150 euro on 750 I had maybe I will have enough for 2080Ti K|NGP|N or some model with waterblock.  Reality was different... When I saw 1300$ price of RTX2080Ti. I hope EVGA will continue tradition with AIO Cooler for K|NGP|N... Air cooling was real suffering for such graphic card. Gaming without side panel on 80C and 80% fan speed.
Hopper64
Sunday, April 14, 2019 3:26 AM
TiN_EE EVGA RTX 1080 Ti Kingpin Edition card Technical Guide Grab some tools and enjoy the card. Classified tool.
So from the tech guide it sounds like you can simply use the tool to apply voltage tweaks to the card. You can then rescan for a better OC. It says to uncheck “auto”, but is that with the tool or in MSI AB or PX1? I can’t get to my machine currently. Thanks.
richiec77
Sunday, April 14, 2019 4:02 AM
Yup! Un-check Auto. Apply your settings and restart. Soft reboots hold the values. This's in reference to the Classified Tool which isn't a part of AB or PX1 This is for the voltage control. Not sure how it works with any of the auto scanning stuff. Never use it.
post edited by richiec77 - Sunday, April 14, 2019 5:14 AM
