- Ribbons : 282
Re: Candies for RTX 2080 Ti Kingpin
Wednesday, May 29, 2019 8:23 PM
mattaman10 Yup, that's when it brings up a list of firmware files, and the only one that worked was 3F, and .39 is no where to be found
Let me look under 16 16 E200_FA39_20190422.hex  17 E200_FA3F_20190510.hex I did just update to F3 the newest Firmware for this Card. What issues are you having? It was odd that when I install PX1 0.3.17.0 it did not prompt me to update? It did Reset my OLED. I did Power Off my Computer and turn off the Power Switch on the Power Supply. Turning back on now. This is not really an Candy issue but a PX1 Issue so our Posts might get moved or even deleted.
post edited by bcavnaugh - Wednesday, May 29, 2019 10:05 PM
mattaman10
Wednesday, May 29, 2019 8:45 PM
I'll check the file locations when I get home
mattaman10
Thursday, May 30, 2019 2:38 AM
wait so 3F is the newest! yeah im dumb to not notice dates in the files. I got the help I need so we're good. thanks!
post edited by mattaman10 - Thursday, May 30, 2019 2:41 AM
- Ribbons : 282
Thursday, May 30, 2019 3:00 AM
mattaman10 wait so 3F is the newest! yeah im dumb to not notice dates in the files. I got the help I need so we're good. thanks!
 But also FA3F (64063) is a Higher Number than FA39 (64057). Calculator Link
post edited by bcavnaugh - Thursday, May 30, 2019 3:19 AM
bp7178
Sunday, June 09, 2019 1:27 AM
I'm really liking the KPE. I managed to beat my old Superposition score and hit 10521 in Port Royal with the stock AIO cooler. My old FE card with the Micron memory would do +1000, the KPE is +1400. I had two FE cards, the other wouldn't do over +800 without artifacts. https://www.3dmark.com/pr/100779 Waiting on a water block. I got it to complete a run with a +160 offset, but temps hit 55C at the end. It only scored 10372. Which was 1.250 (1.2000 in Classified tool, +50mv via dipswitch. Got right at 600w as displayed on the OLED screen. The most amazing part is how quiet the card is. Even with the fans ramped up, it isn't that loud. With a EK block on my old FE card, it was a screamer with coil whine. KPE, not a sound. 8086k @ 5.4Ghz/4,000Mhz DDR4 16GB Asus Z390 Formula (Likely going to be a Z390 Dark soon with a 9900KS when it drops) Corsair 1600i 68F Room Temp
post edited by bp7178 - Sunday, June 09, 2019 1:39 AM
- Ribbons : 282
Sunday, June 09, 2019 1:37 AM
bp7178 I'm really liking the KPE. I managed to beat my old Superposition score and hit 10521 in Port Royal with the stock AIO cooler. My old FE card with the Micron memory would do +1000, the KPE is +1400. I had two FE cards, the other wouldn't do over +800 without artifacts. https://www.3dmark.com/pr/100779 Waiting on a water block. I got it to complete a run with a +160 offset, but temps hit 55C at the end. It only scored 10372. Which was 1.250 (1.2000 in Classified tool, +50mv via dipswitch. Got right at 600w as displayed on the OLED screen. 8086k @ 5.4Ghz/4,000Mhz DDR4 16GB Asus Z390 Formula (Likely going to be a Z390 Dark soon with a 9900KS when it drops) Corsair 1600i 68F Room Temp
 You Got The Power https://www.3dmark.com/compare/pr/100779/pr/100472https://www.3dmark.com/compare/pr/100779/pr/100472/pr/100882 Down to 10
post edited by bcavnaugh - Sunday, June 09, 2019 2:15 AM
TiN_EE
Yes, that TiN
- Ribbons : 14
Tuesday, June 11, 2019 8:31 AM
Latest firmware is FA3F (hex value). I've added it to the guide. Also magic candy got new super-secret function to improve VRM behavour for sub-zero and LN2 benchmarking.
- Ribbons : 282
Tuesday, June 11, 2019 3:45 PM
TiN_EE Latest firmware is FA3F (hex value). I've added it to the guide. Also magic candy got new super-secret function to improve VRM behavour for sub-zero and LN2 benchmarking.
 The firmware is also in the Firmware Folder under PX1 Odd that I see only the KPE has an update feature in PX1, I do not see this on other Cards with PX1 0.3.17.0 Any chance in seeing a New Firmware and Bios for users who have installed the KPE Hydro Copper Water Block?  KPE  FTW3
post edited by bcavnaugh - Tuesday, June 11, 2019 8:27 PM
TiN_EE
Yes, that TiN
- Ribbons : 14
Wednesday, June 12, 2019 3:36 AM
Other cards updated automagically when PX1 detects they run older firmware, than PX has. There are no plans to make HC specific BIOS, I'm not sure what benefit that would give compared to current KPE BIOSes.
- Ribbons : 282
Wednesday, June 12, 2019 3:49 PM
TiN_EE Other cards updated automagically when PX1 detects they run older firmware, than PX has. There are no plans to make HC specific BIOS, I'm not sure what benefit that would give compared to current KPE BIOSes.
Maybe not the Bios for the GPU but a Firmware for the LED as we cannot control the White Light Fading In and Out none stop.
TiN_EE
Yes, that TiN
- Ribbons : 14
Thursday, June 13, 2019 1:51 AM
Didn't know that, will check, thanks.
- Ribbons : 282
Thursday, June 13, 2019 2:40 AM
TiN_EE Didn't know that, will check, thanks.
 Thank you.
- Ribbons : 282
Monday, June 17, 2019 7:09 PM
2080 Ti Kingpin Hydro Copper LED issue #22 TiN_EE We have a fix, will be in next PX1/FW release after QC check.
 Lets hope 0.3.2x.0 works I Dumped 0.3.17.0 and 0.3.19.0 on all three of my RTX Rigs due to Lock Ups using the Tool. Back to 0.3.16.0 but no longer a Firmware Update Feature for the KPE Card. I can make any changes in 0.3.16.0 and have No Lock Ups on any of my three RTX Rigs. Lock Ups = Having to Press the Reset Button Then it could also be caused by Driver 430.86
post edited by bcavnaugh - Monday, June 17, 2019 8:54 PM
Zeddivile
- Ribbons : 7
Saturday, June 29, 2019 5:42 PM
Perseverance is a key to success Therefor anyone know what the rear card side micro-USB located near the 8-pins of the RTX KPE is for?
"This stuff breaks my tiny often dehydrated and carb deprived hamster brain" -2019
- Ribbons : 282
Saturday, June 29, 2019 5:45 PM
Zeddivile Perseverance is a key to success Therefor anyone know what the rear card side micro-USB located near the 8-pins of the RTX KPE is for?
VirtualLink ™44 - In preparation for the emerging VirtualLink standard, Turing GPUs have implemented hardware support according to the “VirtualLink Advance Overview”. To learn more about VirtualLink, please see http://www.virtuallink.org. VirtualLink has been developed as an open standard by an industry consortium of leading silicon, software, and headset manufacturers led by NVIDIA, Oculus, Valve, Microsoft, AMD, and HTC. This open industry standard for VR connectivity advances VR interoperability and provides economic benefits to head-mounted display (HMD) makers, original equipment manufacturers (OEMs), developers, and consumers. It will accelerate the development and implementation of new VR technologies. Read the VirtualLink press release for more information. All the RTX 2070 and up have one. Also why I returned my Oculus Set. Just Kidding  , it is a Thunderbolt Display Port NOT.
post edited by bcavnaugh - Saturday, June 29, 2019 5:57 PM
Zeddivile
- Ribbons : 7
Saturday, June 29, 2019 6:03 PM
That's the front USB C. It's my understanding that the usb micro interface could not support virtual link.
post edited by Zeddivile - Monday, August 05, 2019 8:54 PM
- Ribbons : 282
Saturday, June 29, 2019 6:05 PM
Zeddivile That's the front USB C. It's my understanding that the usb micro interface could not support virtual link. I have a room dedicated to HTC Vive btw. Not to VR flex but ya VR FLEX
Maybe why they are calling it " Future Proof" No but you are correct. Also "you can also use VirtualPort as standard USB Type-C host port." "Rear card side with micro-USB" (Maybe This or the same as the Old "User upgradeable ECU with firmware flexibility for future upgradability.") Link1 × VirtualLink USB Type-C port with USB 3.1 Gen2 host functionality. Maybe I have the Old Style USB Header on my GTX 1080 Ti Cards and I did have to use it once, I think I update something. Let me go back in time and look it up. I know I connect it to my Motherboard Header at one time. ECU Interface port (GTX)Card also have additional interface 9-pin port, compatible with standard USB 2.0 ATX motherboard header. Located right under lower 8-pin, it is currently used for EC firmware update function and diagnostics. There will be upcoming feature to use this port for additional real-time card health monitoring or XOC use. More details to be revealed in this guide soon. It Never Happened as far as I Know Link
post edited by bcavnaugh - Saturday, June 29, 2019 6:24 PM
Zeddivile
- Ribbons : 7
Saturday, June 29, 2019 6:46 PM
Yes. I have read through the 980ti kpe and 1080ti kpe xdevs. Johnksss and I were thinking this was the case but then TiN chimmed in and said something like NO SERIAL this gen. He also said he would cook a RPI app and maybe meant to be interfaced with the micro USB we are talking about. I am just trying to gain as much info as I can about it before digging into it myself. Having to much fun with the Icon pot and ugh maybe I just need to buy a 2nd KPE while they are in stock to play with...
post edited by Zeddivile - Monday, August 05, 2019 8:55 PM
- Ribbons : 282
Saturday, June 29, 2019 6:47 PM
Zeddivile Yes. I have read through the 980ti kpe and 1080ti kpe xdevs. Johnksss and I were thinking this was the case but then TiN chimmed in and said something like NO SERIAL this gen. He also said he would cook a RPI app and maybe meant to be interfaced with the micro USB we are talking about. I am just trying to gain as much info as I can about it before digging into it myself. Having to much fun with the Icon pot and ugh maybe I just need to buy a 2nd KPE while they are in stock to play with...
No Serial or No USB 2.0 ATX Motherboard Header or is this the Same Thing?
post edited by bcavnaugh - Saturday, June 29, 2019 6:52 PM
Zeddivile
- Ribbons : 7
Saturday, June 29, 2019 6:55 PM
So serial.
- Ribbons : 282
Saturday, June 29, 2019 7:15 PM
Got it, I still do use a Serial Port (RS232) for my Weather Station  Old School. Oh and Back in the Day of Modems.
Zeddivile
- Ribbons : 7
Sunday, June 30, 2019 6:07 PM
im on zee new new fw/bios.  bout to open her up!
vladdimplr
Tuesday, July 09, 2019 8:12 PM
Any reason why the classified tool wouldnt work with the xoc bios?
TiN_EE
Yes, that TiN
- Ribbons : 14
Thursday, July 11, 2019 1:38 AM
You didn't update to latest version from guide?
vladdimplr
Thursday, July 11, 2019 1:48 AM
TiN_EE You didn't update to latest version from guide?
Good Call, Ty Sir!
splave
Wednesday, July 17, 2019 2:09 PM
Hi I was directed here by Gregory Olesky to ask for the p0 force tool used in the jayz vs gamers Nexus video! Thank you look forward to it.
- Ribbons : 282
Wednesday, July 17, 2019 3:05 PM
splave Hi I was directed here by Gregory Olesky to ask for the p0 force tool used in the jayz vs gamers Nexus video! Thank you look forward to it.
Not listed here? https://xdevs.com/guide/2080ti_kpe/
splave
Wednesday, July 17, 2019 3:14 PM
ironbrillopad
Sunday, July 21, 2019 0:08 PM
I am also very interested in the p0 force tool
- Ribbons : 282
Sunday, July 21, 2019 0:16 PM
ironbrillopad I am also very interested in the p0 force tool
Have any link to this Tool? Leave off http:// or https://
