Helpful ReplyTechnical Guide and candies for RTX 2080 Ti Kingpin
Page: < 12345.. > >> Showing page 4 of 7
kingx11
Re: Candies for RTX 2080 Ti Kingpin Thursday, April 25, 2019 8:46 PM (permalink)
kingx11
tresnugget
Anyone tried the new bios yet?
i'm using it now , i think the older Bios was better for OC , i'll keep trying though maybe i got it wrong but so far getting to 2190 is kinda hard
Are you also using the Classified Tool?
yes
1.2v on the core , 1.6v on the memory
#91
  • Ribbons : 282
Re: Candies for RTX 2080 Ti Kingpin Thursday, April 25, 2019 9:18 PM (permalink)
kingx11
kingx11
tresnugget
yes
Are you going to Start to Post your Scores from 3DMarks?
It would be great to be able to compare them.
#92
kingx11
Re: Candies for RTX 2080 Ti Kingpin Thursday, April 25, 2019 9:25 PM (permalink)
kingx11
kingx11
tresnugget
yes
i did post FSU in the last page
#93
  • Ribbons : 282
Re: Candies for RTX 2080 Ti Kingpin Thursday, April 25, 2019 9:29 PM (permalink)
Spoiler
kingx11
kingx11
kingx11
tresnugget
yes
close
Thanks I Missed it https://www.3dmark.com/compare/fs/19157501/fs/19051091
You may want to use the Standalone Version over the Steam 2.8.6546 s64 Version to remove Steams Overhead.
Alternatively, you can download the complete installer here.
Remember to write all your Keys down before you change over to the Standalone Version, they are the same.
You can find them under Options in the 3DMark Application.
post edited by bcavnaugh - Thursday, April 25, 2019 9:53 PM
#94
AHowes
  • Ribbons : 27
Re: Candies for RTX 2080 Ti Kingpin Friday, April 26, 2019 2:21 AM (permalink)
What's the temps at 1.2v and 1.6v on the mem?
Prob going backwards cause of too much heat.
Asus Z390 ROG Extreme XI MB
#95
richiec77
Re: Candies for RTX 2080 Ti Kingpin Friday, April 26, 2019 8:56 AM (permalink)
I agree. Could be seeing negative scaling. Also 1.6v mem is pretty high for ambient OC'ing.
When I pushed up to 1.156v Core, I had negative scaling if using LLC 0-3. Using 5 drops temps a bit to stabilize my runs. And for memory, going well over 1.5v just added heat and scaled worse.
EDIT: meant 1.156v NVVDD not 1.56.
post edited by richiec77 - Friday, April 26, 2019 7:09 PM
#96
HawkOculus
Re: Candies for RTX 2080 Ti Kingpin Friday, April 26, 2019 10:14 AM (permalink)
richiec77
When I pushed up to 1.56v Core, I had negative scaling if using LLC 0-3. Using 5 drops temps a bit to stabilize my runs. And for memory, going well over 1.5v just added heat and scaled worse.
Not surprising. TiN has stated that beyond 1.5v on memory on ambient isn’t really safe and may negatively impact performance.
#97
tresnugget
Re: Candies for RTX 2080 Ti Kingpin Friday, April 26, 2019 1:05 PM (permalink)
I see a lot of people using llc of 3 when the default is 10. Can someone explain why you'd wanna go down. I haven't been experimenting with llc yet but I'm just curious. Even at 10 I'm getting vdroop when pushing higher voltages. Is it that the lower llc, the less vdroop with GPUs vs Mobo/CPU? I'm pretty new at this level of gpu overclocking (as if it wasn't apparent)
#98
kingx11
Re: Candies for RTX 2080 Ti Kingpin Friday, April 26, 2019 4:27 PM (permalink)
yeah i was using way too much voltage
turns out i can game with default settings using a lovely curve with MSI AB
#99
  • Ribbons : 282
Re: Candies for RTX 2080 Ti Kingpin Friday, April 26, 2019 4:46 PM (permalink)
kingx11
ok
FSU , 9666
https://www.3dmark.com/3dm/35655835?
how good is that ?!
Still Seems Low 9887
https://www.3dmark.com/compare/fs/19157501/fs/19051706/fs/19051091
Run the Plain Fire Strike and Time Spy and post.
If you have 3DMark 11 run the Performance Benchmark and also post back.
post edited by bcavnaugh - Friday, April 26, 2019 4:52 PM
AHowes
  • Ribbons : 27
Re: Candies for RTX 2080 Ti Kingpin Friday, April 26, 2019 6:22 PM (permalink)
kingx11
Awesome!
Now to find that perfect medium of temp and voltage to go higher if possible.
Leave mem clock at default first to take that out of the equation.. then add mem after you find the sweet spot.
richiec77
Re: Candies for RTX 2080 Ti Kingpin Friday, April 26, 2019 7:37 PM (permalink)
tresnuggetI see a lot of people using llc of 3 when the default is 10. Can someone explain why you'd wanna go down. I haven't been experimenting with llc yet but I'm just curious. Even at 10 I'm getting vdroop when pushing higher voltages. Is it that the lower llc, the less vdroop with GPUs vs Mobo/CPU? I'm pretty new at this level of gpu overclocking (as if it wasn't apparent)
The lower the number, the less VDroop or LLC you have. Basically inverse Asus LLC.
With around Level 0-2 there is much less Droop compared to Level 10. BUT there is more heat and more Power Target used. There is also typically more Ringing in the Voltage line that can be overshoots and transient instability. Basically you'd need an O-Scope with a fast triggering speed to capture the resulting fluctuations. Most DMM (Digital MultiMeter) will not capture the fast transients.
If setting say 1.150v NVVDD: you'd idle roughly the same. But under load, you would maybe catch a spike up to 1.18v-1.20v before it settles to say 1.085-1.105v under load. Once the load completes, the voltage line will rebound. The excess current needs to go to ground. You could see a rebound spike on the Voltage line.
So it's not best practice to just max out LLC and hope it works well. Better practice is to go in steps with NVVDD locked in place and experiment with the LLC levels to see how it effects your OC.
Even with a VRM this well made: there's still the laws of physics to contend with.
tresnugget
Re: Candies for RTX 2080 Ti Kingpin Saturday, April 27, 2019 1:26 AM (permalink)
richiec77
Gotcha! I appreciate that as it would've taken me forever to figure that out. My first overclocking motherboard was an evga x58 and it had vdroop control but I don't think they used the term llc. Everything else has been Asus ROG. This card has definitely been a learning experience but man is it fun.
tresnugget
Re: Candies for RTX 2080 Ti Kingpin Saturday, April 27, 2019 3:27 AM (permalink)
richiec77
I also really appreciate the instructions as I'd never had tried that. I would've gone the longer way around and started with llc then jumped around on voltage. Your way makes a lot more sense, though.
TriOx
Re: Candies for RTX 2080 Ti Kingpin Tuesday, April 30, 2019 8:27 PM (permalink)
Spoiler
kingx11
kingx11
kingx11
tresnugget
yes
close
Hey bcavnaugh, looks like you got me off the line with the extra cores but I almost caught up on the top end.
https://www.3dmark.com/compare/fs/19051091/fs/19198368
EVGA Z390 Dark #15
EVGA 2080Ti K|INP|N Edition #23
Intel i9 9900K 5.3/5.1AVX/4.8Ring
G.Skill TZ Royal F4-4400C18D-16GTRS (A2 Layout)
EVGA CLC-280 Cooler with Corsair ML-140 fans.
  • Ribbons : 282
Re: Candies for RTX 2080 Ti Kingpin Tuesday, April 30, 2019 8:48 PM (permalink)
TriOx
Spoiler
kingx11
kingx11
kingx11
tresnugget
yes
close
Nice, I will be running more latter today. It seems I am stuck at 5000MHz on my CPU.
Looks like this is my max for 3DMarks 11 https://www.3dmark.com/3dm11/13284536 HOF#40
A hard Benchmark to get the right settings.
post edited by bcavnaugh - Tuesday, April 30, 2019 8:52 PM
TriOx
Re: Candies for RTX 2080 Ti Kingpin Tuesday, April 30, 2019 8:59 PM (permalink)
To your point, I lost a day to 3dmark11 tuning haha.  I'll probably try it again tonight but doubt I can get much more.
https://www.3dmark.com/compare/3dm11/13284536/3dm11/13281246
EVGA Z390 Dark #15
  • Ribbons : 282
Re: Candies for RTX 2080 Ti Kingpin Tuesday, April 30, 2019 9:02 PM (permalink)
TriOx
It took me the last two days to get P38110.
TriOx
Re: Candies for RTX 2080 Ti Kingpin Tuesday, April 30, 2019 9:13 PM (permalink)
The 9900K/Z390 is way easier. Actually now that you mention it, I'm two days also.  The first was on my i7-9800X/X299 Dark but I've blocked that experience out haha.  I was comparing my X299 scores to yours, last week, and realized I must have a cpu cooling problem so I switched the TIM out and re-seated the water block and managed to get the i7-9800X solid at 5.1Ghz with HT on.  Even after that I was still in the dust.
https://www.3dmark.com/compare/3dm11/13284536/3dm11/13266953
EVGA Z390 Dark #15
  • Ribbons : 282
Re: Candies for RTX 2080 Ti Kingpin Tuesday, April 30, 2019 9:27 PM (permalink)
TriOx
1.0.132.0 s is the Steam Version. You might want to change over to the Standalone version to remove Steams Overhead.
TriOx
Re: Candies for RTX 2080 Ti Kingpin Tuesday, April 30, 2019 9:55 PM (permalink)
Oh I see the little 's' there.  Awesome, thanks for pointing it out! Hopefully it will give me 152 more points in Firestrike Ultra. 10k or bust.
EVGA Z390 Dark #15
AHowes
  • Ribbons : 27
Re: Candies for RTX 2080 Ti Kingpin Wednesday, May 01, 2019 7:03 PM (permalink)
Stupid question time..
When its said to restart to enable the changes.. does that mean to restart the pc or the classified program?
Also the Loadline setting.. I dont have the proper hardware to test.. higher number more droop, lower equals less?
post edited by AHowes - Wednesday, May 01, 2019 7:06 PM
AHowes
  • Ribbons : 27
Re: Candies for RTX 2080 Ti Kingpin Wednesday, May 01, 2019 7:11 PM (permalink)
Also its twice now that when I tried to set the NVVDD to 1.093 or 1.1000v the screen would go instant black. Hit the reset button on the system and the system would beep with an error and then I'd have to power off and power back on to recover.
Only settings changed was loadline at level 10 and FBVDD at 1.4v.
  • Ribbons : 282
Re: Candies for RTX 2080 Ti Kingpin Wednesday, May 01, 2019 7:12 PM (permalink)
AHowes
The Computer.
Using Loadline of 10 See https://xdevs.com/guide/2080ti_kpe Loadline was added mid way down.
post edited by bcavnaugh - Wednesday, May 01, 2019 7:19 PM
  • Ribbons : 282
Re: Candies for RTX 2080 Ti Kingpin Wednesday, May 01, 2019 7:13 PM (permalink)
AHowes
See https://forums.evga.com/FindPost/2949934 it may help.
You need to work your way up not start at the very top.
After a Crash using the Classified Tool you need Power Off Your Computer.
A restart still has the last Settings you applied, FBVDD needs the Power Down.
post edited by bcavnaugh - Thursday, May 02, 2019 0:04 PM
AHowes
  • Ribbons : 27
Re: Candies for RTX 2080 Ti Kingpin Wednesday, May 01, 2019 7:37 PM (permalink)
Thanks!
One last one for now.. if one is using ab and classified tools and sets over 1.093v like 1.1+ and it still only shows 1.093v on the osd, is it using 1.093v or really 1.1v and it just cant display the correct voltage.
Edit:
Ab only shows what voltage you set in there software. I believe px1 shows the actual voltage used.
post edited by AHowes - Sunday, May 05, 2019 9:48 PM
TiN_EE
Yes, that TiN
  • Ribbons : 14
Re: Candies for RTX 2080 Ti Kingpin Monday, May 06, 2019 4:16 AM (permalink)
For everyone who not seeing correct voltage on OLED = You need to select GPU NVVDD sensor to get real reading.
  • Ribbons : 282
Re: Candies for RTX 2080 Ti Kingpin Monday, May 06, 2019 4:30 AM (permalink)
Seeing this error on the new Classified Tool.
TiN_EE
Yes, that TiN
  • Ribbons : 14
Re: Candies for RTX 2080 Ti Kingpin Monday, May 06, 2019 4:38 AM (permalink)
Try again? Maybe download failed? :)
  • Ribbons : 282
Re: Candies for RTX 2080 Ti Kingpin Monday, May 06, 2019 4:43 AM (permalink)
TiN_EE
I did 8 times now from 2 different computer but will give it another go.
Still error as above under Windows 7 and Windows 10.
post edited by bcavnaugh - Monday, May 06, 2019 4:48 AM
