TiN_EE
Yes, that TiN
- Ribbons : 14
Re: Candies for RTX 2080 Ti Kingpin
2019/07/20 22:47:05
It is not available, sorry. There is no benefit to benchmarking anyway, just for showcase as clocks don't go to low p-state when idle in desktop.
Zeddivile
- Ribbons : 7
2019/07/21 12:13:47
I thought I read that the next version of PX1 will have a force clock function? would this be like old XOC Kboost? And wouldn't it provide the functionality of "p0 force tool?" in a sense anyway?
"This stuff breaks my tiny often dehydrated and carb deprived hamster brain" -2019
2019/07/21 13:02:19
If anyone needs to force p0 state you can simply use msi afterburner to do so.
- Ribbons : 282
2019/07/21 13:06:10
Zeddivile I thought I read that the next version of PX1 will have a force clock function? would this be like old XOC Kboost?
It is coming soon, I watched the live broadcast with Jacob showing it off.
post edited by bcavnaugh - 2019/07/21 13:08:32
DubEuro
2019/07/22 23:31:56
How do you adjust pump speed in PX1. Is it one of the fan speeds? And if so whick fan speeds setting is it?
DubEuro
2019/07/22 23:33:10
- Ribbons : 282
2019/07/23 07:34:19
DubEuro How do you adjust pump speed in PX1. Is it one of the fan speeds? And if so whick fan speeds setting is it?
What Version of PX1 are you running? I know that you cannot control the Hybrid Pump even with PX1 so not sure what you are seeing that would show or allow you to. If you see Pump on the OLED then you need to update the Firmware and it will rename it to Rad.
post edited by bcavnaugh - 2019/07/23 07:38:42
HawkOculus
2019/07/23 07:36:34
Anyone know any specifics about the improved support for KPE in the new version of PX1? What about the new KPE firmware?
- Ribbons : 282
2019/07/23 07:39:54
HawkOculus Anyone know any specifics about the improved support for KPE in the new version of PX1? What about the new KPE firmware?
I would assume that someone has but has not posted yet, you could be the first.
Myersjames93
2019/07/24 15:01:17
Kingpin requires 3 8 pins can I use 3 different graphics card cords from my power supply to power it? I don’t have a power supply that has an actual 3 8 pin connector my power supply is the 650 super nova gold from evga
- Ribbons : 282
2019/07/24 16:29:44
Myersjames93 Kingpin requires 3 8 pins can I use 3 different graphics card cords from my power supply to power it? I don’t have a power supply that has an actual 3 8 pin connector my power supply is the 650 super nova gold from evga
"3 different graphics card cords" is a Must on this Graphics Card. But a 650 Watt Power Supply is NOT going to work. You will be lucky that a 750 Watt Power Supply will even work but if you never overclock the KPE then a 750 would work.
post edited by bcavnaugh - 2019/07/24 16:35:30
Myersjames93
2019/07/24 17:38:48
How much power does your kingpin consume overclocked?
- Ribbons : 282
2019/07/24 17:57:37
Myersjames93 How much power does your kingpin consume overclocked?
Peek in Time Spy 680 Watts. But this is the for the Complete Computer.
ironbrillopad
2019/07/24 20:08:51
Yes, 3 separate cables is actually ideal but you're cutting it close on OC headroom with a 650 watt power supply
Myersjames93
2019/07/24 20:34:44
What cpu do U have? Trying my absolute best to keep my power supply, I have an 7820x
Myersjames93
2019/07/24 20:43:18
Yeah I’m going have try look into getting 750 to 850 watt supply soon,
TwoEvilOne
- Location: NW Ohio. EVGA Associate Code: 2QME1VF65K9ZY8B
2019/07/24 21:04:05
850 watt PSU was not large enough for my system during overclocking. i9-9900k, KPE, and a few SSDS and AIO's My 1300 Watt PSU is more than adequate.
Myersjames93
2019/07/24 23:03:53
Will 1000 power supply be enough for overclocked King, overclocked 7820x 4.8ghz 1 ssd, 1 hdd and a couple case fans and a custom loop Ek pump, my board is an x299 dark
- Ribbons : 282
2019/07/25 07:52:10
Myersjames93 What cpu do U have? Trying my absolute best to keep my power supply, I have an 7820x
At least a 1000 Watt Power Supply. I have the Core i9-7920X ATM on the X299 Dark but will be moving over to the Intel® Core™ i9-9900KF Processor on the Z390 Dark.
TwoEvilOne
2019/09/06 19:36:25
1000 watts is not enough for Hall of Fame top 50 standings. You have this card for a reason, push it. The K|NGP|N 2080 Ti Hybrid can draw close to 700W When overclocked to extremes for benchmarking with the XOC bios, found here ==> https://xdevs.com/guide/2080ti_kpe/ and the Classified voltage tool at Tins web site But yes a 1000 watts will work fine for temps between 20-60c, if thats your benchmark target, with it drawing around 520W approximate, its self. The left over wattage should be plenty for your CPU over clock, memory, ssd, fans/pumps etc. wattage. But really! If you bought this card its not for the 1000 watt power supply enthusiast. 1200 - 1600 watts is what your system should be using if you have a K|NGP|N card. You bought the best of the best for a reason! Use the power given to you! Set world records! Keep her cool and feed her with voltage. The KPE will love you for it, and make you smile. Port Royal 10856 score with my KPE with stock cooler http://www.3dmark.com/pr/121051 currently #32 on the HOF 1 GPU rankings. Enjoy your binned GPU's they are awsome! Get your own K|NGP|N 2080 ti HYBRID with my associates code applied at check out at evga's web site, for a $95.00 savings, associatecode is 2QME1VF65K9ZY8B
post edited by TiN_EE - 2019/09/10 20:44:29
View to question
2019/11/16 07:29:42
Why don't you spend £1900 on a 2080ti kingpin and LN2 overclock? If you're so sure everyone that owns one isn't using it right if they don't break a world record. I believe he was asking a question about a psu.
djtetsui
2019/11/20 01:38:59
This is going to sound like a dumb question, but I'm having problems with my second display not displaying any readouts. Is this just me being dumb or am I missing something here lol?
- Ribbons : 123
2019/11/20 06:13:22
djtetsui This is going to sound like a dumb question, but I'm having problems with my second display not displaying any readouts. Is this just me being dumb or am I missing something here lol?
To configure OLED mode EVGA Precision X1 software is required Did you See this ? Integrated OLED functionality
djtetsui
2019/11/28 00:21:26
Turned out to be a bent pin in the OLED. Glad I saw it but I'm a little upset it came like that.
Vlada011
- Ribbons : 11
2019/11/28 02:34:41
I couldn't know EVGA RTX2080Ti K|NGP|N will be so good and EVGA X299 Dark. I would miss X99 and wait X299 Dark, install i7-7800X and now upgrade to 10920X. But again RTX2080Ti KP is too expensive and out of my budget. Because X299 Dark and K|NGP|N are really top combination for guys not plan to upgrade so often, exactly as I imagine high end PC. No matter on performance and TRX40 AMD combinations not attract me so much.
post edited by Vlada011 - 2019/11/28 02:36:58
SalvatoreMundi
2019/12/07 10:52:25
Hi, is FBVDD 1.53V high for my (KP) VRAM on a 8500MHz clock with a mem temp of 55c ?
2019/12/07 16:19:53
Yes. 1.50 is max recommeded for the stock cooler.
mattaman10
2020/01/03 23:17:45
Havent posted in a couple months, but just thought I would say if anyone is having trouble getting high overclocks just adjust the vf curve tuner manually so that 1093mv is at your desired overclock and make sure you create a decent curve up to it. I was getting 2115mhz max with voltage, power, etc all maxed out, now I'm getting stable 2200 mhz on stress testing at 45C! Might I add I'm on stock cooler!
post edited by mattaman10 - 2020/01/03 23:21:18
