boyleusa
Re: RTX 3090 K|NGP|N Power Draw Issues
2020/12/20 19:30:07
braxtonjames Doesn't seem to let me post it. h t t p s://i m g u r .co m/a/MQ3SzdX
Thanks - where was that email posted? Probably one for Jacob - I'm in the same position as you so expect a similar response to my ticket when support get around to it...
Kylearan
2020/12/20 20:01:19
johnksss Power draw test in 85F room... (Right click and open image in new tab to see full screen)
John from NBR right? (i'm falkentyne) Can you try changing your MSVDD to 1.12v and your FBVDD (MVDCC) to 1.4v and see if you still get that thick green throttle bar in Timespy Extreme? Sajin said that changing those voltages in the classified tool will help with that...
johnksss
2020/12/20 20:36:37
Kylearan
Yes Sir! Just tried it and it went from solid green to triple colors.
MSI MEG Z690 UNIFY-X | I9-12900K | 32GB G.Skill Trident Z5 6400Mhz | 1600W EVGA T2 | EVGA 3090 K|ngP|n | Custom Water Cooling Loop | Praxis Wet Bench SX Pro - Flat Edition HWBOT-PROFILE
Magrecite
2020/12/20 20:46:25
After tinkering around with Classified a bit more I may have found some ideal voltages to clear 15K in Port Royal (of which I finally did, and hit 15,042 here: https://www.3dmark.com/3dm/55237155?) NVVDD - 1.125 FBVDD - 1.400 MSVDD - 1.1375 NVVDD OCP and MSVDD OCP Disabled. Had to play around with MSVDD quite a bit more to keep stability in check and it's definitely not intended for gaming from what I can tell due to the downclocking happening right around 50C. I had to pump the Push/Pull 360mm AIO that came with the K|NGP|N to about 95% fan speed just to keep these temperatures in line. If it weren't for the obnoxious buzzing from the pump I'd probably just keep this card and not deal with an RMA, but that buzz is beyond loud. *edit* Confirmed that by reducing fan curve back to normal, not-so-jet-planey levels the max I could get up to was about 14,806 on PR with a +140/+400 offset instead of the +175/+1000 offset I had prior. The usual 37 second mark in the benchmark crashed the run as it tends to with unstable clocks. Not sure what else I can do about that but at least with these voltages I'm getting a much more consistent high 14K PR score under normalized circumstances which I'm fine with until some other fix comes about.
post edited by Magrecite - 2020/12/20 20:54:34
Kylearan
2020/12/20 22:33:43
Kylearan
Where did I say using those voltages will help pwr throttle?
You mentioned it somewhere farther up, specifically with MSVDD and FVBDD increasing allowing the full 520W of power draw. Thus possibly increasing those voltages also helping with heavy 4k loads (like Superposition 4k--Extreme shaders custom, and Timespy Extreme) :) I don't remember the post, but it was you who mentioned those voltages first.
2020/12/20 22:34:12
No perf caps baby. Gotta love that xoc vbios. :D Pci-e slot power gettin up there on superposition.
johnksss
2020/12/20 23:31:02
So your card isnt a dud as you mentioned earlier..... It's only having a PortRoyal problem.....
2020/12/20 23:35:08
I never said it was a dud. I just said it wasn't as great as others.
johnksss
2020/12/20 23:42:39
Sajin I never said it was a dud. I just said it wasn't as great as others.
Yes, I know, but that's "my" interpretation of "not as great as others".
jollib
2020/12/20 23:43:03
Kylearan
jollib So let me try to understand this. why would I need to hit 520w power limit, if I’m already getting pretty good consistent clock speeds when running PR or TSE. I didn’t break 500w to get my current score in PR. Wouldn’t power draw be a concern only if I was hitting 520 and getting low scores. Sorry for hijacking the thread btw.
if you're getting a nice fat thick green throttle bar in GPU-Z, then your performance is definitely being held back. I'm not talking about a green throttle bar in 30 FPS benches like Superposition 4k Custom-->Extreme textures or Timespy Extreme (these seem to throw up a power limit even on 600W bioses/mods--Sajin said that these can be removed by increasing MSVDD and MVDCC, which makes a lot of sense since it seems to be the memory / soc's getting hammered here). I'm talking about in regular Timespy (NOT the two small green throttle bars at the beginning--those seem intentionally driver related), and Port Royal. With +200 to core and +1000 to RAM, I can see Port Royal doing "some" throttling at 600W and a bit more at 550W, but with +0 core and +0 memory on the 520W LN2 vbios, PR should not throttle at all. Unless the default clocks are something like 2050 mhz (boost at 50C) and 10000 mhz memory (equal to +250 mhz memory on FE cards). If you don't mind doing a little work, please do the following: 1) Open GPU-Z, click the mouse on the wattage fields until it says "max" in green for each one. 2) Open HWinfo64 (sensors only), mouse down to the GPU field, and have the TDP% and TDP Normalized % (GPU-Z does NOT show Normalized! Only hwinfo does!) showing. Bonus points if you can have the voltage rails showing also. 3) Run Timespy and take a screenshot with the GPU-Z and HWinfo64 windows open right after the bench ends, with your score visible. 4) Run Port Royal and do the same thing (remember to press "RESET" on GPU-Z and hwinfo BEFORE running the second bench run). 5) upload a screenshot on imgur.com and post the direct link to it (from the album).
Running these tests now. I was actually hitting powerlimit. When you select max value for perfcap it always says idle. Since I was away from it long enough the green bar was away from the screen.... gonna upload my tests soon as per request
2020/12/20 23:43:42
I interpret dud as defective.
johnksss
2020/12/20 23:52:59
Sajin I interpret dud as defective.
Fair enough.
jollib
2020/12/20 23:57:38
jollib
2020/12/21 00:08:39
808sting
- Ribbons : 6
2020/12/21 00:45:11
My advice is not to get hung up on power limits and don't overdo voltage tweaks. https://www.3dmark.com/3dm/55242288 I think I have a decent chip compared to others at similar temps. Using PX1 and LN2 bios with 190-GPU/1000-MEM. Ave 2235 with peaks of 2250 with starting temp at 18c idle with VRM and MEM in the low/mid 20s. Ave board power usage is 470w. I wouldn't recommend brute forcing voltage at office level ambient air(25c) with OCP disabled to get around power limits. By right, the card's warranty is void due to Classified tool usage if something dies. The intent to disable OCP is for LN2. Keeping temps low is key if you don't have a golden silicon lottery chip. It's deminishing returns unless you go chill water or LN2 since daily gaming at this extremes are not practical. P Performance cap is vREL and vOP. Not ready to use Classy or request XOC. I want to make sure the card is solid since it's 2 days old. So far, gaming at 25c room ambient and 150-GPU/800-MEM is stable. This yielded PR 15004. Doom Ancient Gods GPU hovers around 2175-2190, Ultra everything, except motion blue with HDR on. Haven't tried Cyberpunk, yet. Once you've establish your GPU baseline, you'll know how much you can push it.
post edited by 808sting - 2020/12/21 01:43:11
MonnieRock
2020/12/21 06:17:00
If I am understanding some of the comments correctly, the following actions would void warranty? 1) Applying for the XOC BIOS from Vince? 2) Using the Classified Tool Software? 3) Altering the DIP Switches on the back of the card from default positions? If I remember correctly, when the 3090 K|ngp|n card was announced, EVGA/Jacob said the XOC BIOS would be released to the public? Thanks, Monnie
http://www.heatware.com/u/105144 Rack Rig: Rosewill RSV-L4000 | Koolance ERM-3K3UC | Xeon E5-1680v2 @ 4.9ghz | Asus Rampage IV Black Edition | 64GB 2133mhz | EVGA TitanX Hydrocopper SLI | 970 Evo Plus nvme | Seasonic 1000w PSU | Win10 Pro 2004 | TM Warthog HOTAS | MFG Crosswind Rudders | Obutto R3volution | HP Reverb
arestavo
- Ribbons : 76
2020/12/21 06:50:24
Anyone with a power limited, way below what it should be that is, kingpin try the XC3 VBIOS yet?
Granted, you won't be able to use the classified tool, but it'll confirm if it's EVGA's component/design choice this go around.
I'm partial to the explanation that the XC3 gets around the FTW3 power problems by changing things up enough that the PCIE slot power draw is lower (60s instead of 80+), and likely the VRAM and that other reading that can cause a power limit flag at 390W on a 500+ watt VBIOS.
pat182
2020/12/21 09:19:09
LVNeptune
jollib If they don’t benchmark the same. I’m going to wait to see if they can fix it. Crossing figures it’s my current setup...
https://www.3dmark.com/3dm/55224728? this is after 6 hours of tweaking today.
rip
johnksss
2020/12/21 11:37:23
Interesting, the card is able to hit 650W to 700W(Another teammate was able to get) using the 520W bios using the PX1 Scanner.
TheHyperMatrix
2020/12/21 11:50:41
I gotta pitch in here because there's a lot of complaints about something people don't understand. This is NOT an issue like the FTW3 hitting a power limit at 420-440W. The card is NOT hitting power limit but it CAN depending on a few things: 1) Your GPU Bin 2) Your voltage 3) Type of load Run your highest overclock with superposition custom with shaders set to extreme and you should max out your power limit. I've had 2 KingPin cards in my hand. One didn't go above 460W with the highest clock it was capable of. That chip could only do 2130-2145 max. But if I used the classified tool to up the voltages, it would go up past 500W. So there is nothing limiting you from hitting 520W other than your chip not being to clock high enough and the workload in question not being particularly power hungry. I've had a total of 6 RTX 3090s in my possession for testing. Asus Strix, FE, 2x FTW3 Hybrid, 2x KingPin Hybrid. One of the FTW3s I had was a very good overclocker. I could do 2130MHz at 0.975v. But even on that, using the XC3 bios, trying to push a run through PR at 2130-2145MHz, I'd be getting a ton of green power limit perfcap in GPU-Z. On the KingPin I'd do the run locked at 2190MHz and only have a few slim power limited bars. So I'm going to repeat: - There is no issue with the KingPin cards not being able to hit 500W+ unless there is a different issue your specific card has. In general, the KingPin Hybrid cards are using less power than other card variants that I've tested. - You can't RMA your card for a bad bin. These cards are only binned for 2100MHz. If they were binned for guaranteed 2200MHz+ they'd be charging more than just $200 over the bargain bin quality FTW3 board (no offense...but it's true). Is it disappointing to get a card that only clocks to 2130-2145 like my first KingPin? Yes. But there is no guarantee above 2100MHz. - You can't RMA your card for "not pulling enough power." Because it can pull more power. Your chip just isn't clocked high enough to need to pull it. Again...unless there's something specific to your card that is different from the vast majority of claims being made in this thread. No green power perfcap limit in GPU-Z? You're NOT being artificially limited by the card. Just so you don't think I'm defending the KingPin and EVGA for no reason....let me share some concerns I do have with the card: - The fans that come with the FTW3 Hybrid are 7-8W fans. The fans on the KingPin card are 2.4w fans. This is beyond garbage. After a few minutes of basic overclocking on it, my temps were up to like 56C and climbing with fans at 100%. Under those settings with my own fans connected to my own fan controller, temps were 42-44c pretty much stable. - There seems to be a big problem with overclocking this card where it desyncs. So you *think* you're getting a certain clock/voltage, because that's what it's reporting, but internally it's downclocked heavily. I did a lot of testing on static scenes and monitoring of power consumption to get it working properly. But with my card, but buddy was doing "above 2200MHz" runs while scoring 13200 in PR. It's a very weird behavior that I noticed when OC'ing both his KingPin and my own. Very frustrating until you figure out how to control it. Overall...the KingPin is actually a well designed card. It has an amazing AIO cooler with a substantially better radiator/pump than on the FTW3 Hybrid. But you do have to replace the fans. And there's no guarantee of getting above 2100MHz. Because while my original KingPin did 2100MHz at 0.975v which is decent, I definitely couldn't get anything above 2130-2145 stable. So understand what you're buying. And set your expectations. And don't rage out about something that is little more than a misunderstanding. Right now people seem to have trouble deciding if they want to be mad that a card IS hitting a power limit and they want a higher limit bios released, or complaining that they're NOT hitting a power limit, but wish they were for some reason.
post edited by TheHyperMatrix - 2020/12/21 11:55:25
Need to spamtribute 100 posts for Elite status to be able to get a KingPin because Jacob. My apologies in advance.
2020/12/21 11:52:00
GruntLife
2020/12/21 11:54:16
Hey there. I’m getting ready to buy the EVGA GeForce RTX 3090 K|NGP|N HYBRID. So you are saying this is worth the buy?
johnksss
2020/12/21 11:55:31
Sajin Lol. 650w for 2055 MHz?
Exactly! I have stated this before a few times.... More watts does not always mean better. In this case all I see are a bunch of wasted watts with no gain. Now, this will in fact tell you if your card is gimped, that's for sure.
2020/12/21 12:14:36
MonnieRock If I am understanding some of the comments correctly, the following actions would void warranty? 1) Applying for the XOC BIOS from Vince? 2) Using the Classified Tool Software? 3) Altering the DIP Switches on the back of the card from default positions? If I remember correctly, when the 3090 K|ngp|n card was announced, EVGA/Jacob said the XOC BIOS would be released to the public? Thanks, Monnie
1. Yes. 2. Hard to prove if you never state you used it. 3. Probably hard to prove as well.
808sting
- Ribbons : 6
2020/12/21 12:46:52
808sting
- Ribbons : 6
2020/12/21 12:54:59
Clovis559
2020/12/21 14:00:12
The max power draw I've seen on my card is 580w according to GPU-Z. The higher watt didn't provide more performance, and I found the sweet spot around 540w. I just do that for benchmarks though, and game at stock as I'm pretty pooped from tinkering to find a sweet spot for gaming... Are you guys using the classified.exe also? I don't believe I got the higher power draw without it
post edited by Clovis559 - 2020/12/21 14:03:53
maxsul
2020/12/21 14:16:00
808sting My advice is not to get hung up on power limits and don't overdo voltage tweaks. https://www.3dmark.com/3dm/55242288 I think I have a decent chip compared to others at similar temps. Using PX1 and LN2 bios with 190-GPU/1000-MEM. Ave 2235 with peaks of 2250 with starting temp at 18c idle with VRM and MEM in the low/mid 20s. Ave board power usage is 470w. I wouldn't recommend brute forcing voltage at office level ambient air(25c) with OCP disabled to get around power limits. By right, the card's warranty is void due to Classified tool usage if something dies. The intent to disable OCP is for LN2. Keeping temps low is key if you don't have a golden silicon lottery chip. It's deminishing returns unless you go chill water or LN2 since daily gaming at this extremes are not practical. P Performance cap is vREL and vOP. Not ready to use Classy or request XOC. I want to make sure the card is solid since it's 2 days old. So far, gaming at 25c room ambient and 150-GPU/800-MEM is stable. This yielded PR 15004. Doom Ancient Gods GPU hovers around 2175-2190, Ultra everything, except motion blue with HDR on. Haven't tried Cyberpunk, yet. Once you've establish your GPU baseline, you'll know how much you can push it.
Proceeds to post a ridiculous score from a lottery chip.
CPU: i9-10850k 5GHZ@1.35vcore MOBO: ASUS Prime z490-a VIDEO CARD: EVGA 3090 K|NGP|N CASE: Phanteks Enthoo 719 Cooler: Deepcool Castle 360EX RAM: Corsair Vengeance 64GB 3200 PSU: EVGA Super Nova G5 1000W SSD: Samsung 970 EVO Plus 500GB M.2 NVMe
