jollib
Re: RTX 3090 K|NGP|N Power Draw Issues
2020/12/20 14:04:03
I’m going to go through the. Rma hopefully they send a new one. Then I can compare to see if a have a really good binned card.
LVNeptune
2020/12/20 14:05:17
jollib I’m going to go through the. Rma hopefully they send a new one. Then I can compare to see if a have a really good binned card.
I as well as others aren't remotely hitting what you have. You are giving up a good card if you send that off.
jollib
2020/12/20 14:06:12
If they don’t benchmark the same. I’m going to wait to see if they can fix it. Crossing figures it’s my current setup...
LVNeptune
2020/12/20 14:09:34
jollib If they don’t benchmark the same. I’m going to wait to see if they can fix it. Crossing figures it’s my current setup...
https://www.3dmark.com/3dm/55224728? this is after 6 hours of tweaking today.
jollib
2020/12/20 14:11:51
Ok maybe I’ll wait to see if there is a firmware fix. Now I’m really scared to get an underperforming card and a replacement.
jollib
2020/12/20 14:24:14
I still think temps has something to do with it. I was at 46 degrees compared to Your 52. Don’t temps determine how high the clocks go?
2020/12/20 14:26:08
jollib I still think temps has something to do with it. I was at 46 degrees compared to Your 52. Don’t temps determine how high the clocks go?
Doesn't look like it... https://www.3dmark.com/pr/653720
hallowen
- Ribbons : 14
2020/12/20 14:27:56
Now that's got to be a good bin.
ASUS: Rampage VI Extreme | i9-7940X | 2X RTX 2080 Ti Kingpin SLI | 32GB DDR4 3200MHz Memory - SAGER: NP9870-G | i7-6700K | GTX 980M 8GB | 64GB DDR4 | 950 PRO M.2 512GB | 17.3 QHD 120Hz Matte G-Sync | Prema bios - EVOC Premamod: P870TM1 | i9-9900K-LM | RTX 2080N 8GB | Modded Vapor Chamber | 32GB 3000MHz Ripjaws | 960 EVO M.2 1TB | 17.3 3K QHD 120Hz Matte G-Sync | Intel 8265 -
LVNeptune
2020/12/20 14:29:05
Supposedly temps over 50c drop 15 mhz for every 1c over that. The score that Sajin just posted blows that out of the water though.
jollib
2020/12/20 14:31:44
But there might be other factors put into that one. I didn’t toucch voltages. So maybe if you increase those. The boost bin if I’m understanding correctly is higher then in stock voltages.
2020/12/20 14:35:15
hallowen
I know right. heh. I wish I had a chip like that.
johnksss
2020/12/20 14:39:00
Power draw test in 85F room... (Right click and open image in new tab to see full screen)
MSI MEG Z690 UNIFY-X | I9-12900K | 32GB G.Skill Trident Z5 6400Mhz | 1600W EVGA T2 | EVGA 3090 K|ngP|n | Custom Water Cooling Loop | Praxis Wet Bench SX Pro - Flat Edition HWBOT-PROFILE
hallowen
- Ribbons : 14
2020/12/20 14:39:14
hallowen
All the 3090 KP's should come high binned like that.
2020/12/20 14:42:10
hallowen
hallowen
I agree.
jollib
2020/12/20 14:44:28
Damn I don’t know what’s up with my card you are hitting power limit at lower clocks. Let me try slowing the fans down to see if I can recreate an apples to apples scenario.
markuaw1
2020/12/20 14:52:27
I have my 3090 strix on a EK block with a alphacool X -flow 360rad 60 mm running the Kingpin bios that's it nothing more done to it +170 clock +1250 mem gets me 15 322 @ 34c
johnksss
2020/12/20 15:14:56
jollib
2020/12/20 16:20:38
Is that just water cooled?
Nealx01
2020/12/20 17:17:30
zak00
2020/12/20 17:26:43
Having the same power draw issues on LN2 bios. Card never draws over 450w fully loaded on any benchmark I run. Never gotten above 47c. Submitted a support request today.
boyleusa
2020/12/20 17:31:23
LVNeptune
I can only scrape similar scores to you. hallowen All the 3090 KP's should come high binned like that.
Agreed. I was hoping a KP would be a better experience than my FTW3 but it isn't looking that way.
johnksss
2020/12/20 17:37:42
You only need to run test 2 of TPE and you really need the classy tool to set the voltage to 1.1V and that's it. This just makes your life easier. And drop the high memory overclocks till you figure out what your core overclock is first. That is only advice....
braxtonjames
2020/12/20 18:50:45
They (EVGA) told me “anything over 350W is not guaranteed by EVGA and is not a valid reason for RMA” when I opened a ticket.
F.
LVNeptune
2020/12/20 18:54:16
braxtonjames They (EVGA) told me “anything over 350W is not guaranteed by EVGA and is not a valid reason for RMA” when I opened a ticket.
F.
For a $2100, yes it damn well is. Also, 350W is 3080, 3090 is 400W, minimum.
EVGA1225
2020/12/20 18:55:45
F.
That applies for Kingpins too??? ****
braxtonjames
2020/12/20 18:56:03
LVNeptune
F.
Here's a copy/paste from the response on the ticket for my K|NGPIN: "Thank you for reaching out to us regarding your graphics card. Please note that the RTX 3090 has a rated power wattage of 350 watts. Wattage and power demands for the graphics card beyond that are not guaranteed and EVGA does not guarantee overclocking results beyond the factory overclocks automatically applied to your card out of the box."
LVNeptune
2020/12/20 19:04:11
braxtonjames
LVNeptune
F.
Vince said in an email these are binned GPUs though. If people are scoring significantly higher, that should be covered.
braxtonjames
2020/12/20 19:08:48
LVNeptune
braxtonjames
LVNeptune
F.
Yeah, not really sure what to do. If I return it, I won't be able to get another one for quite some time. :(
boyleusa
2020/12/20 19:14:35
LVNeptune Vince said in an email these are binned GPUs though. If people are scoring significantly higher, that should be covered.
Do you have a copy of that email or a link anywhere? Thanks...
braxtonjames
2020/12/20 19:18:53
boyleusa
Doesn't seem to let me post it. h t t p s://i m g u r .co m/a/MQ3SzdX
