SadCapriSonne
Hey guys, last year i had an evga hybrid kit on my 1080 Ti and was i highly disappointed with the pump noise/ buzz. I am using Silents Wings 3 and the hybrid kit pump was the loudest part of my pc. I RMAed the kit and sold the new replacement. That was the first and last time i dealt with evga's hybrid kits. Now i am thinking about a hybrid kit for my 2080 Ti FTW3 Ultra. Is the buzzing noise from the pump still the same? Will evga some day acknowledge the issue and fix it or for the love of god switch to a pwm controllable pump/ newer pump generation? I read on reddit about fixing a small magnet to the pump unit to reduce the buzzing noise, did anyone tried this? If yes, did it work? I also thought about getting a Pwm to female mini gpu cable to control the pump with my mainboard. I actually really dislike the looks of the cable and i want my gpu to look as clean as possible. Should i get the hybrid kit or should i save up some more money and go custom loop? Thanks for your answers.
i9-9900K @5.0GHz 1.315vAsus Z390 Hero XI WifiCorsair 32GB DDR4 3200MHz RGB Pro WhiteEVGA GTX 1080 ClassifiedBe Quiet! Dark Power Pro 11 850WCustom Loop: EKWB Velocity, Kinetic D5, Alphacool 420 UT60Be Quiet! Dark Base Pro 900 WhiteSamsung 970 Pro 1TB
Re: EVGA 2080 Ti FTW3 Ultra + Hybrid Kit - Owners - buzzing/ pump noise fix
2019/07/30 10:26:28
I've heard the magnet trick works.
SadCapriSonne
2019/07/30 12:43:38
@Sajin have you tried it yourself?
2019/07/30 12:44:17
No, but I've seen others say they tried it, and it did work for them.
SadCapriSonne
2019/07/30 12:51:03
@Sajin Ok, thank you for the information
2019/07/30 12:51:36
advise429
2019/07/30 13:17:48
SadCapriSonne @Sajin Ok, thank you for the information
IMO the buzzing is worse on the 2080 hybrids than the 1080 hated my 2080ti ftw3 hybrid in terms of noise bought a hydo copper block and couldnt be happier
SadCapriSonne
2019/07/30 14:09:10
@advise429 have you tried the magnet trick?
ikeike
2019/07/31 00:59:06
SadCapriSonne
2019/07/31 05:02:10
dtgill
2019/07/31 18:52:05
The hybrid kit at least for me and others sucked! The pump sounds like an old MOFO Annoying to a fault! I sent my original Hybrid back to EVGA for rma, I never reinstalled the replacement I got the NZXT g12 and a Kraken X42, no pump noise, I changed the fans out for some Noctua's Very Very quiet, not that the other fans were loud I just wanted to have all of my fans Noctua's
SadCapriSonne
2019/08/01 07:05:01
@dtgill Thanks. I dont like the design of the G12. Nevertheless, thanks for the tip. I might just go custom loop at that point, considering all the negativ comments on the hybrid kits.
ksgnow2010
2019/08/01 07:11:17
Are you guys (with the pump noise) mounting the radiator proper according to EVGA suggestions? If you have an air bubble trapped in the pump, is will make noise due to cavitation...just like any water cooled system.
SadCapriSonne
2019/08/01 07:15:42
@ksgnow2010 yes, the pump just sounds like a (language removed) beer fridge. EVGA must improve their pumps, change to a newer generation of asetek pumps or just use a pwm controllable unit. edit by Cool GTX removed masked language - for clarity see: EVGA Forums Terms of Use
post edited by Cool GTX - 2019/08/01 08:05:45
ksgnow2010
2019/08/01 07:39:09
SadCapriSonne @ksgnow2010 yes, the pump just sounds like a f*cking beer fridge. EVGA must improve their pumps, change to a newer generation of asetek pumps or just use a pwm controllable unit.
I currently own 2 2080 Ti FTW3 hybrid, and have owned 3 other EVGA hybrids before that. Never had an issue with pump noise. Sorry to hear that you are.
SadCapriSonne
2019/08/01 07:48:51
ksgnow2010 I currently own 2 2080 Ti FTW3 hybrid, and have owned 3 other EVGA hybrids before that. Never had an issue with pump noise. Sorry to hear that you are.
No offence, but can it be that your case fans drown out the noise of the hybrid kit or that your pc is under your desk?
- Ribbons : 123
2019/08/01 09:10:45
Custom Loop has the potential for best cooling & quietest operation I've bought scraps of self-sticking sound absorbing "rubber" mat from my local custom audio installer - when this case side had a resonance issue
ksgnow2010
2019/08/01 09:11:42
Nope - I have two PCs that sit on my desk...one is 2.5 feet from me, and the other is 4 feet from me. It took me a long time to find fans that didn't annoy the crap out of me. (I don't use the radiator fans that come with the hybrid).
SadCapriSonne
2019/08/01 14:11:11
Cool GTX I've bought scraps of self-sticking sound absorbing "rubber" mat from my local custom audio installer - when this case side had a resonance issue
Looks good. Nice trick. My Be Quiet! Dark Base 900 White is insulated and absorb a lot of noise already. ksgnow2010 Nope - I have two PCs that sit on my desk...one is 2.5 feet from me, and the other is 4 feet from me. It took me a long time to find fans that didn't annoy the crap out of me. (I don't use the radiator fans that come with the hybrid).
My Pc is like 30cm (~1 feet) away from my face. I use "Be Quiet Silent Wings 3 140mm PWM Highspeed" on 900 rpm, which are pretty silent and a "Be Quiet Dark Power Pro 11 850W" PSU which also runs a silent wings 3. I might be a little sensitive to noise, but for example the Corsair H110i is use for almost 5 years now is still near silent. The hybrid kit pump on my 1080 Ti was the loudest part in my entire pc and filled the whole room with its buzzing. I could hear the hybrid kit pump from 7m (~23 feet) on my bed.
