tester300
Re:Corsair 800D Water Cooling Build Thread
2012/08/13 21:13:58
wildwill
tester300
Hey Would you recommend the Lamptron Inverterless? How bright is it from a scale of 1-10? Thanks
Build quality is nice but as far as brightness i would give it a 7 out of 10.
The cover on it is not clear so there is def more brightness 2 be had but i can't determine if it will suit my needs until i get all the tubing in.
Thanks. I might get one then.
wildwill
2012/08/16 13:55:38
Few more items arrived today so i can run all the tubing tonight and finalize my drain plug design - I switched from clear tubing to UV Green because it pops more Enzotech Drain Plug all together -
Asus Maximus Gene VI Intel 4770K Intel 520 Series 240GB SSD WD Caviar Black 2TB Asus 980 Matrix Platinum Hyper X Savage 8GB 2400MHz Silverstone Strider Gold 850 Watt Asus ROG Swift Corsair Vengeance K60 Gaming Keyboard Corsair Vengeance M60 Gaming Mouse Windows 8.1 64 Bit
wildwill
2012/08/16 21:25:59
I put in most of the tubing i am just trying to figure out the best way to get tubing from the bottom video card to the top of the pump -
malVizio
- Ribbons : 8
2012/08/16 21:52:54
nice build dude! and this case it's absolutly awesome! love it!!
Case:Silverstone FT02 M.B.:EVGA DARK X79/PSU: Corsair HX1000 GPU:EVGA GTX980Ti SC /RAM:32GB DDR3 Corsair CPU:Intel i7 3930K+Noctua NH-D14FANS:3xSilverstone SP200mm SSD/HDD:2xSamsung EVO 850 256/1xPNY 256gb/Seagate 500gb MICE:Razer DA Elite/KB:Collermaster Rapid I/HP:Shure SRH440/Logitech G633 Screen:Dell Ultrasharp 2711U
wildwill
2012/08/20 12:43:03
Started some leak testing today and so far after an hour nothing is leaking! This is not the final loop design as far as the bottom gpu to the pump but i was getting anxious to finally leak test it so excuse that. I kind of feel like there should be more pressure/flow being pushed through the loop but i am only basing this off the movement of the liquid in the res - The pump is at max speed btw http://www.flickr.com/pho...5763912/in/photostream
gamecrazeddork
2012/08/20 13:22:00
Looks good to me and I would switch rams to dominaters or g.skill blue
tester300
2012/08/20 13:30:54
wildwill Started some leak testing today and so far after an hour nothing is leaking! This is not the final loop design as far as the bottom gpu to the pump but i was getting anxious to finally leak test it so excuse that. I kind of feel like there should be more pressure/flow being pushed through the loop but i am only basing this off the movement of the liquid in the res - The pump is at max speed btw http://www.flickr.com/pho...5763912/in/photostream What UV light are you using? It's very bright. 1 or 2? Thanks
wildwill
2012/08/20 13:51:34
^ 2 Bitfenix 60CM led strips but for some reason they make the UV go crazy lol
tester300
2012/08/20 20:05:51
wildwill ^ 2 Bitfenix 60CM led strips but for some reason they make the UV go crazy lol Looks awesome though!
Afterburner
- Location: It's... Classified Yeeeeeeeeeeaaaaaaah........
- Ribbons : 110
2012/08/20 20:27:16
wildwill Started some leak testing today and so far after an hour nothing is leaking! This is not the final loop design as far as the bottom gpu to the pump but i was getting anxious to finally leak test it so excuse that. I kind of feel like there should be more pressure/flow being pushed through the loop but i am only basing this off the movement of the liquid in the res - The pump is at max speed btw http://www.flickr.com/pho...5763912/in/photostream Ok.. That is wicked looking!
wildwill
2012/08/20 21:40:11
After final loop design thoughts and pondering i placed another order tonight and this should be the last for a while - Enzotech 90 Degree Rotary Compression Fitting ID1/2 - OD3/4 - Matte Black X2 EK-BAY SPIN Reservoir - Plexi - The XSPC 1 i have now is nice but just has a boring feel to it so i wanted something that will add more flare. Enzotech Stop Plug - Matte Black X3 MaxFinder Triple Braided 3-Pin Fan Extension Cable - 60cm Black - 3 Pack X2 4-Pin Molex Powe Adapter Cable w/ Remote On/Off Toggle Switch - 36" Sleeved Sunbeamtech Rheosmart 6 Fan Controller - This have been out of stock every where for a while and i figure for the money they have great reviews so it should suit me well. Akasa PWM Fan Splitter Cable - 15cm X3 - So i can run 2 fans on each channel
wildwill
2012/08/20 21:44:54
Afterburner Ok.. That is wicked looking! I appreciate that sir and its better in person i just need a real camera instead of an iphone to capture these pics. tester300 Looks awesome though!
I am def impressed with the brightness on them at this rate i don't even need a UV tube.
wildwill
2012/08/21 19:00:18
I updated the first post with a updated hardware list and total cost so far for this custom water cooling loop upgrade.
SlashPT
2012/08/22 10:50:45
Wow that's looking so awesome men, I might change my case. xD
wildwill
2012/08/22 20:39:50
I have been thinking about adding a 140mm rad and fan to the middle partition fan location. I am curious if this will be overkill and impede flow or is it worth it to some degree and how would i incorporate it in to the loop ?
Dejahboi
2012/08/23 01:29:05
Do it lol, I've been following your build over at OCN ;P. Jealous how you got your 800D up and going while I still have the basic loop :(
Case: Corsair 800D Mobo: Asrock P67 Extreme 4 Gen 3 CPU: I5-3750K GPU: EVGA GTX 680 PSU: XFX Platinum PRO 1000W OS: Windows 8 Pro 64-bit
wildwill
2012/08/23 13:55:05
A few more items arrived today - This is a V2 BTW which was not stated on the website so it has the slits on the sides which prevents me from needing to bend my 5.25'' tabs out the way.
wildwill
2012/08/24 12:37:04
wildwill
2012/08/24 23:33:03
Ordered a few small items tonight to touch up the build a little bit - Apevia 140mm UV Green LED Case Fan - This will go to the middle partition fan location to add more pop. 1,200rpm,20.6dba,59.6cfm Bitspower Dual LED - Pre-wired with 4-Pin Connector - 5mm Green - For the EK Spin Res MaxFinder Triple Braided 3-Pin Fan Extension Cable - 60cm Black 3 Pack - I need 3 more to make the run to the fan controller cleaner Molex Extension Cable 36" Black Sleeved - Cheap and i can def use em.
wildwill
2012/08/27 20:20:40
Ordered a few more things tonight - XSPC 5.25" Drive Bay Temperature Sensor Display Frame - XSPC LCD Display Temperature Sensor - Green X2 - Going to use to monitor the interior temps. I wanted something to monitor the coolant temp but the only thing they offer is a stop plug which would have to be soldered on to this unit. Molex Extension Cable 36" Black Sleeved X2 Phobya Noise Destructor V.1 for Pump Decoupling - I am using this to hold my loop coming from the bottom video card to the top of the pump. It sags down so i need something to support it. FilterRight 120mm Aluminum Fan Filter UV Green - For the rear intake 120mm fan
post edited by wildwill - 2012/08/27 20:23:24
wildwill
2012/09/04 14:09:14
Decided too hold off on the Caselabs build until next year some time since it seems crazy to switch cases so fast after all this work. I will improve on this 800D build in the mean time with the following - Swiftech Maelstrom Dual Bay Basic Standalone Reservoir - It should be an improvement over the EK spin res in some way shape or form. Bitspower Galaxy Freezer DIMM4 RAM Liquid Cooling Block - Clear - Its useless i know but i want to add more pop to other wise boring looking ram. Bitspower Universal RAM Cover X4 I am also changing my drain plug set up to something more simple in design - I wont have a feed coming off the bottom of my video card and back to the pump anymore so i can just run a tube to the bottom of the case with this drain plug attached. Bitspower D5 Mod Pump Top V2 (Acrylic Version) - To add more pop visually and also add more performance in the process.
eternitykh
2012/09/06 14:37:07
hm.. hey wildwill, are you still using aurora liquid? cuz im looking at the maelstrom res, that "anti-vortex" sponge doesn't look too healthy for aurora's pearl particles...
Core i7-3770k De-Lidded @ 4.8ghz // Asus Sabertooth z77 // Corsair Vengeance Black 1866mhz 9-10-9-27 4x4GB DDR3 2x EVGA GTX 670 FTW+ 4GB SLI // 3x Asus VH238H Monitor in Surround // Asus Xonar DX7.1 Sound Card Corsair Obsidian 700D Chassis // Corsair AX850 PSU // Corsair Neutron 240 SSD Corsair Individually sleeved Modular Cables // Custom Black Rigid 2-way SLI bridge XSPC RASA Black CPU Water Block // XSPC RS360 Radiator // XSPC X2O 750 Dual 5.25” Bay Reservoir Pump 2x Watercool Heatkiller GPU-X³ Hole Edition Waterblock Nickel/Black // 2x Watercool Heatkiller GPU-X³ Polished Backplate Corsair Vengeance K70 Keyboard // Corsair Vengeance M95 Mouse // Corsair Vengeance 1500 HeadsetCorsair Vengeance MM400 Compact Mouse Pad // Corsair Link Commander // Corsair Link Cooling and Lighting node
wildwill
2012/09/07 13:04:34
I was convinced not to you use it for 24/7 use since my computer is consistently on for that period of timer or longer. I am currently using Mayhems UV Green/Distilled Water. I should have the Maelstorm up and running soon so i report back if i have any issues with the coolant i am currently using.
eternitykh
2012/09/07 16:54:01
aah ok, yeah i've been told by many as well as read up on it, that the aurora is a nice showcase liquid but not a good daily, as the in-system life is relatively low because of the particles, especially in complex systems and block/pump compatibility. and you know... i just realized how close our system specs are, lol
wildwill
2012/09/08 00:40:18
LOL i was looking at that before as well. I noticed you had the 4GB version of the 670 FTW's and i was like dammit mine are only 2 GB each lol. I don't plan on running a multi monitor set up so you def need them more then i do.
wildwill
2012/09/08 21:22:11
I have been thinking of some where else to mount my D5 pump since i have it sitting right above the middle partition 140mm fan location. I am mounting a Corsair AF140mm fan there and i want to put out as much air flow as i can with no restriction. The only idea i can come up with because i will not be mounting the pump in the PSU heat chamber is this - There is a sliding cover that slides over the HD hot swap sata board right above the said 140mm fan location. I can most likely drill 2 holes through it and mount 1 of these brackets to it and adjust the pump as i wish for the best tubing run. Any 1 else have a better idea ? If any 1 is not familiar with these water cooling based brackets - http://www.undesignsbrackets.com/products/
post edited by wildwill - 2012/09/10 13:03:09
wildwill
2012/09/10 13:02:41
I received my Bitspower ram block today and realized the base is made up of a high durability nickel finished in shining black.
I originally thought it was made of solid copper based of this product description but it is not -
Block Base Made Of Hi-Quality Copper. Block Base High Durability Nickel Finished In Shining Black.
Will this impact anything along my loop since everything else is pure copper ?
wildwill
2012/09/10 13:33:32
Few more items arrived today - Swifttech Maelstrom dual bay res - I have not seen many reviews or anything 1 with this res on OCN so i look forward to integrating it to my build and sharing my thoughts. Bitspower Ram Water Block - I am doing this for looks only and at this point in my build i might as well go all out.
eternitykh
2012/09/12 10:51:50
nah wont hurt anything with the nickel. copper and nickel mix fine in a loop.
wildwill
2012/09/14 11:17:19
Few more items arrived today to put the finishing touches on this build -
