Page: << < ..2122232425.. > >> Showing page 21 of 29
gsrcrxsi
Re: 3080 Ti XC3 Ultra Hydro Copper, low power consumption, hidden power cap? 2021/08/02 11:28:46 (permalink)
kongfra
gsrcrxsi
I also received the second beta BIOS. I think this one will be a winner for most people.
Long story short, I'm seeing full power limit reached (~366W), and I don't think it's a coincidence that I'm seeing up to ~75W PCIe slot power now instead of being capped at 66W. Seeing higher clock speeds and voltages than before, which again supports my comments earlier that voltage and clocks were being clamped by the artificial power limiting at the PCIe slot.
Timespy Compares:
https://www.3dmark.com/compare/spy/21819943/spy/21898806
Port Royal Compares:
https://www.3dmark.com/compare/pr/1148574/pr/1154079
GPUz logs and other stuff:
https://drive.google.com/file/d/1ATyn1SCwISDkOu6xgZCWnrGzaR9vA-CB/view?usp=sharing
That is awesome I am glad to hear!  Just curious do thermals go up more?
yes, but that's to be expected since more power is being pulled. I have a Hydrocopper card so temps went up by like 3C (47 to 50), no big deal.
Rig1: EPYC 7V12 | [4] RTX A4000
Rig2: EPYC 7B12 | [5] 3080Ti + [2] 2080Ti
Rig3: EPYC 7B12 | [6] 3070Ti + [2] 3060
Rig4: [2] EPYC 7742 | RTX A2000
Rig5: [2] EPYC 7642
Rig6: EPYC 7551 | [4] Titan V
ZheGoose
Re: 3080 Ti XC3 Ultra Hydro Copper, low power consumption, hidden power cap? 2021/08/02 11:29:02 (permalink)
That's great, I'm glad the beta bios seems like it does lift the restrictions on the HC at least. Fingers crossed they release a new bios for the XC3 air-cooled and XC3 hybrid cards with this fix.
post edited by ZheGoose - 2021/08/02 11:33:01
gsrcrxsi
Re: 3080 Ti XC3 Ultra Hydro Copper, low power consumption, hidden power cap? 2021/08/02 11:34:33 (permalink)
additionally, My main use case, which has the highest memory load (~85%), Einstein@home under Linux also shows excellent results.
previously, it was "capped" around 285W and ~1680MHz core clock (this was with 350W limit set)
now, it hits the 320W power limit that I've set, and runs ~1800MHz clock speeds
I do not have any internal monitoring methods under linux to track voltage or pcie slot draw however.
Rig5: [2] EPYC 7642
KingEngineRevUp
  • Ribbons : 9
Re: 3080 Ti XC3 Ultra Hydro Copper, low power consumption, hidden power cap? 2021/08/02 11:40:23 (permalink)
hallmark888
This is freaking awesome. Big win for Kram and you not relenting on this.
We need a FTW3 fix then, because we're not hitting a PCI-E power above 55-60 on average.
FTW3 limit is hitting 150W power cap on the 2nd 8 pin, from what I've observed from my sample. Time Spy 2 Extreme can hit 66W the 3080 Ti FTW3 I tested.
But ow do we know the PCI-E and Pin 2 don't work independently from one another? If they are independent from one another than we'd see at least a 22W increase in TDP.
  • FTW3 PCI-E average power draw in on the PCI-E slot is 50W
  • XC3 Beta Bios 2 is getting 72.5W
That would be an extra 22.5W if it is possible. PM and message EVGA_LeeM and voice your concerns. I already did, he said he'd look into it this week if he had a chance.
EVGA_Lee
Moderator
  • Ribbons : 14
Re: 3080 Ti XC3 Ultra Hydro Copper, low power consumption, hidden power cap? 2021/08/02 11:42:04 (permalink)
Just a reminder that we're talking about a beta BIOS here, and so far only one person has reported results.  I wouldn't expect everything reported by gsrcrxsi to perform the same on every card, as the card I have in my test bench has about the same overall performance as gsrcrxsi's card (with the beta BIOS), but the PCIe slot and other wattages are different.  Our team is still going to review the results from everyone who's participating.
And I'd definitely not extrapolate any success we have with this card (which has yet to be full confirmed) to other cards, whether it's a different GPU or different PCB.  Big differences in each case.
KingEngineRevUp
  • Ribbons : 9
Re: 3080 Ti XC3 Ultra Hydro Copper, low power consumption, hidden power cap? 2021/08/02 11:52:35 (permalink)
EVGATech_LeeM
Thanks Lee. If this is successful, I hope the same can be done for the FTW3.
gsrcrxsi went from only being able to an average voltage of 0.901v to 0.939v, that puts him right with the MSI Ventus user who averaged 0.937v.
Hopefully other testers can confirm similar results, but this beta bios looks good so far.
gsrcrxsi
Re: 3080 Ti XC3 Ultra Hydro Copper, low power consumption, hidden power cap? 2021/08/02 11:57:27 (permalink)
EVGATech_LeeM
good points Lee.
people shouldn't go crazy yet. we should at least let kram submit his results and observations.
I have a feeling that cards that were already near max power draw might not see much difference. since there's less for them to catch up to. I think there might be some manufacturing/component variance that causes some cards to have a higher slot power draw than others, and when combined with the low PCIe limit, that meant some cards were getting limited at the PCIe slot, while others were not (and allowed to boost to the board limit).
I'm just glad that things seem "normal" for my card with this latest BIOS. I've said from the beginning that I don't expect 400+W on an XC3 card, I just didn't want it to feel like it was artificially limited, and now it's not, for me at least.
Rig5: [2] EPYC 7642
KingEngineRevUp
  • Ribbons : 9
Re: 3080 Ti XC3 Ultra Hydro Copper, low power consumption, hidden power cap? 2021/08/02 12:23:42 (permalink)
Sharing some interesting or not interesting data so far.
Speedy Stock Bios:
  • Board Power Draw Average: 342.73W
  • PCI-E Slot: 64.69W
  • Pin 1 Average: 137.63W
  • Pin 2 Average: 140.35
  • Average Voltage: 0.897v
grxcrxsi Beta Bios 1:
  • Board Power Draw Average: 320.6W
  • PCI-E Slot: 65.5W
  • Pin 1 Average: 129.64W
  • Pin 2 Average: 125.8W
  • Average Voltage: 0.901v
grxcrxsi Beta Bios 2:
  • Board Power Draw Average: 359.9W
  • PCI-E Slot: 72.51W
  • Pin 1 Average: 146.46W
  • Pin 2 Average: 140.95W
  • Average Voltage: 0.939v
Koopa MSI Ventus:
  • Board Power Draw Average: 346W
  • PCI-E Slot: 56.91W
  • Pin 1 Average: 149.25W
  • Pin 2 Average: 139.88W
  • Average Voltage: 0.937v
kram36
The Destroyer
  • Ribbons : 72
Re: 3080 Ti XC3 Ultra Hydro Copper, low power consumption, hidden power cap? 2021/08/02 12:53:13 (permalink)
KingEngineRevUp
gsrcrxsi
Timespy Compares:
Getting ready to apply the bios and run test. Hope it fixes my issue too, excited!
talon951
Re: 3080 Ti XC3 Ultra Hydro Copper, low power consumption, hidden power cap? 2021/08/02 13:06:48 (permalink)
They obviously increased whatever limit it was stuck on. Too bad ABE still doesn't work on 3080ti bios. We might be able to see what they changed
KingEngineRevUp
  • Ribbons : 9
Re: 3080 Ti XC3 Ultra Hydro Copper, low power consumption, hidden power cap? 2021/08/02 13:07:55 (permalink)
kram36
KingEngineRevUp
gsrcrxsi
Timespy Compares:
Got my fingers crossed for you Kram. Please send GPU-Z logs for us.
Aruzedragon
Re: 3080 Ti XC3 Ultra Hydro Copper, low power consumption, hidden power cap? 2021/08/02 13:25:28 (permalink)
😀 the new numbers from gsrcrxsi is giving me a lot of hope. Can't wait till I either get the beta bios or this fix goes into "production" cards 😁
talon951
Re: 3080 Ti XC3 Ultra Hydro Copper, low power consumption, hidden power cap? 2021/08/02 13:45:46 (permalink)
KingEngineRevUp
They do not work independently.  As I've been saying all along, the XC3/FTW3 hit a limit other than total board power which is why you see a total power reported below the limit (366w or 450w).  You can see that in the numbers.  All 3 sources (2 8pins and slot) increase with that new beta bios.  The power balance is determined at a lower level or hardware level (not sure exactly how it works), not by the bios.  The bios/drivers simply move up and down the voltage/freq curve based on the limits set.  They could increase whatever limit we are hitting with the FTW3 to get it to sit at the 450w total power more consistently, same as the XC3 though.  We know the 8pin limit on the FTW3 is higher than 150w since you can get to a total power of 450w with Kombustor with the 2nd 8-pin reading 155-160w.  So the limit is not 150w.
kram36
The Destroyer
  • Ribbons : 72
Re: 3080 Ti XC3 Ultra Hydro Copper, low power consumption, hidden power cap? 2021/08/02 13:52:13 (permalink)
KingEngineRevUp
kram36
KingEngineRevUp
gsrcrxsi
Timespy Compares:
It helped on my Hydro Copper card!
Still need to check the new bios on my air cooled card. I have logs files on all runs, also did the 2nd graphics test only on Time Spy you requested. Not sure how I share the logs?
Time Spy Stock vs OC +150 GPU +1000 Memory vs gsrcrxsi OC.
https://www.3dmark.com/compare/spy/21900754/spy/21900959/spy/21898806
Port Royal Stock vs OC +150 GPU +1000 Memory vs gsrcrxsi OC.
https://www.3dmark.com/compare/pr/1154288/pr/1154302/pr/1154079
EVGA_Lee
Moderator
  • Ribbons : 14
Re: 3080 Ti XC3 Ultra Hydro Copper, low power consumption, hidden power cap? 2021/08/02 13:55:54 (permalink)
You should be able to add a text file either as an attachment or add it to something like a google drive, dropbox, One Drive, etc.
If you wouldn't mind, capture the logs for both graphics runs, since our team didn't specify which they wanted.
kram36
The Destroyer
  • Ribbons : 72
Re: 3080 Ti XC3 Ultra Hydro Copper, low power consumption, hidden power cap? 2021/08/02 13:57:24 (permalink)
EVGATech_LeeM
I can attach them to a pm to you, would that be okay for you? I know the rest want to see it too.
EVGA_Lee
Moderator
  • Ribbons : 14
Re: 3080 Ti XC3 Ultra Hydro Copper, low power consumption, hidden power cap? 2021/08/02 13:57:55 (permalink)
kram36
EVGATech_LeeM
Sure, that will work.
gsrcrxsi
Re: 3080 Ti XC3 Ultra Hydro Copper, low power consumption, hidden power cap? 2021/08/02 13:58:16 (permalink)
kram can you run a standard time spy run instead of a custom one? So the run parameters are a little more comparable.
Rig5: [2] EPYC 7642
jboud47
Re: 3080 Ti XC3 Ultra Hydro Copper, low power consumption, hidden power cap? 2021/08/02 14:03:03 (permalink)
Thanks gsrcrxsi, kram, & Lee for the input on this thread. It at least gives me hope - I again plan on grabbing the 3953 once my queue number comes up. Better than not having anything at the moment and the progress today has me hopeful. Especially interested in Kram's air cooled run.
"It was I who helped the Prime Evils mastermind their own exile to your world. The plan we set in motion so long ago cannot be stopped by any mortal agency. Hell, itself, is poised to spill forth into your world like a tidal wave of blood and nightmares. You and all your kind... are doomed."
MartinUK
Re: 3080 Ti XC3 Ultra Hydro Copper, low power consumption, hidden power cap? 2021/08/02 14:04:52 (permalink)
Interesting progress. Nice to see an EVGA employee active in this manner on the forum.
Would be nice, when you are done here, if the fixes also made it to the non-Ti 3080 FTW3's with the Onsemi controller, that are stuck with the ~50w PCI-E slot, ~80w 8pin #3, and ~400w total, despite having a 450w BIOS power limit.
Power Load Balance 3080 FTW3 - EVGA Forums
kram36
The Destroyer
  • Ribbons : 72
Re: 3080 Ti XC3 Ultra Hydro Copper, low power consumption, hidden power cap? 2021/08/02 14:06:04 (permalink)
EVGATech_LeeM
kram36
EVGATech_LeeM
Got this message when sending you the logs.
"EVGATech_LeeM : Inbox is full. Private Message will be delivered automatically once the recipient cleans up his inbox."
KingEngineRevUp
  • Ribbons : 9
Re: 3080 Ti XC3 Ultra Hydro Copper, low power consumption, hidden power cap? 2021/08/02 14:06:59 (permalink)
talon951
KingEngineRevUp
Okay that makes sense. At least I have logs from a Strix and the average voltages are very similar to the FTW3 so not feeling like we're missing out on too much.
kram36
KingEngineRevUp
kram36
KingEngineRevUp
gsrcrxsi
Timespy Compares:
They're text files right? You can upload them anywhere on a file hosting service and post the links here.
kram36
The Destroyer
  • Ribbons : 72
Re: 3080 Ti XC3 Ultra Hydro Copper, low power consumption, hidden power cap? 2021/08/02 14:08:23 (permalink)
gsrcrxsi
My Hydro Copper is in a system with a i5-9500T CPU, full test that includes CPU score not really needed.
EVGA_Lee
Moderator
  • Ribbons : 14
Re: 3080 Ti XC3 Ultra Hydro Copper, low power consumption, hidden power cap? 2021/08/02 14:12:12 (permalink)
kram36
Yeah, I'm a popular guy today, lol.
gsrcrxsi
Re: 3080 Ti XC3 Ultra Hydro Copper, low power consumption, hidden power cap? 2021/08/02 14:14:20 (permalink)
kram36
gsrcrxsi
It just makes it easier to do a direct comparison on the compare links. Since the full test has several graphics tests.
Rig5: [2] EPYC 7642
kram36
The Destroyer
  • Ribbons : 72
Re: 3080 Ti XC3 Ultra Hydro Copper, low power consumption, hidden power cap? 2021/08/02 14:24:52 (permalink)
Not sure if this link works, but here should be a zip file link with my logs, including the Time Spy Graphics Test 2 only log.
https://www.dropbox.com/s/rihmy6xh77alc9r/logs2.zip?dl=0
ObscureEmpyre
  • Ribbons : 7
Re: 3080 Ti XC3 Ultra Hydro Copper, low power consumption, hidden power cap? 2021/08/02 14:33:04 (permalink)
gsrcrxsi
And with the same CPU?
kram36
The Destroyer
  • Ribbons : 72
Re: 3080 Ti XC3 Ultra Hydro Copper, low power consumption, hidden power cap? 2021/08/02 14:33:55 (permalink)
gsrcrxsi
kram36
gsrcrxsi
Time Spy full test has two GPU test and one CPU test. I just skipped the CPU test only.
gsrcrxsi
Re: 3080 Ti XC3 Ultra Hydro Copper, low power consumption, hidden power cap? 2021/08/02 14:36:29 (permalink)
And the demo at the beginning.
Rig5: [2] EPYC 7642
KingEngineRevUp
  • Ribbons : 9
Re: 3080 Ti XC3 Ultra Hydro Copper, low power consumption, hidden power cap? 2021/08/02 14:40:20 (permalink)
Timespy 2 runs
Speedy Stock Bios:
  • PCI-E Slot: 65.5W
Kram beta Bios 2 stock: <--- Newest test added
  • Board Power Draw Average: 350.16W
  • PCI-E Slot: 73.98W
  • Pin 1 Average: 135.92W
  • Pin 2 Average: 140.25W
  • Average Voltage: ??? (GPU-Z log doesn't have voltage readings, maybe using older GPU-Z)
  • Kram's average clocks are at 1810 Mhz at least so that's a good sign
Koopa MSI Ventus:
post edited by KingEngineRevUp - 2021/08/02 14:41:44
