ObscureEmpyre
- Ribbons : 7
2021/08/17 09:34:17
EVGATech_LeeM Clearly, I need to start using sarcasm tags....
Ordinarily, I’m Mr. Sarcastc and catch onto such things, but I was seriously trying to help and this went completely over my head. lol
Xal3R
2021/08/18 14:20:42
For statistics (I can't post links  ), Time Spy: Before: http s://ww w.3dmark.com/spy/21818718 - 18435 After: http s://ww w.3dmark.com/spy/22250421 - 18915 Have HWinfo stats logged http s://drive.google.com/file/d/1RzS_XqgATXVFHy5g555TvK78V2PBxlUj/view?usp=sharing, not 100% if during this run. Time Spy Extreme: Before: http s://ww w.3dmark.com/spy/21818896 After: http s://ww w.3dmark.com/spy/22249286 Don't have before for any other test really. But most important... "Ladies and gentlemen... We got him!!!"  Silly, I know.  I wasn't getting enough GPU score to beat him before... Sadly, no way to get Top 1 in Port Royal, but oh well, it is still good!
post edited by Xal3R - 2021/08/18 14:29:28
Smithship
2021/08/21 12:42:28
kram36
Gato84 I received my 3080 TI XC3 Gaming, and I have some questions. 1) What tests should I run to see if my card actually come with the power cap? 2) What temps do you consider are normal/fine for this card (air cooling one)? Do you recommend me to change thermal pads or something to improve cooling? (not WC) 3) Do you guys purchased 3Dmark from Steam (29.99) to run the Time Spy benchmark? Is it worth it? Is it not free anymore? Thanks.
Go into your motherboard bios, turn off Fast Boot and CSM. Download and install the latest Precision X1, run it so it will update your card on the first use of PX1. If you don't get an update then go to the Re-Bar section and check to see what bios is on the card. If you have the 12G-P5-3953-KR card the bios number should look like this.
 EDIT: Time Spy is free to run, you just can't turn off the demo. Download 3DMark from here, you will need an account to download it. https://www.3dmark.com/settings/download/3dmark.zip/
dang. these are great instructions. i noticed my 3080ti xc3 is much slower than other brands with same model. so, i have not researched yet, what benefits does this update give us - in your experience?
ObscureEmpyre
- Ribbons : 7
2021/08/21 12:54:40
Smithship
kram36
Have you overclocked your card any, or at least shifted the power slider far to the right? Cooling solution is also a factor. The cooler you can keep your card, the better it will perform. Also, it can depend on your CPU. If you’re using a 6-year old chip, for example, you overall score will be lower. Doesn’t mean you can’t game with a 6-year old CPU, as I myself had done for a few weeks using a 3080 Ti. It’ll just be more evident in benchmarks.
post edited by ObscureEmpyre - 2021/08/21 12:57:09
xReason
2021/09/01 19:14:42
Can't believe I'm 4 weeks late to this new bios. I definitely see a nice improvement with my power draw. Thanks goes out to everyone who got on EVGA about this problem.
homestyle
2021/09/09 14:03:38
I couldn't read the whole thread. But has the problem been resolved for newer cards?
KingEngineRevUp
- Ribbons : 9
2021/09/09 15:07:51
homestyle I couldn't read the whole thread. But has the problem been resolved for newer cards?
Then read the last 2 pages at least?
Priggy
2021/09/15 09:11:45
It's not a function of the age of the card, but the BIOS version. Use X1 and update your BIOS and any problems should be resolved. I received a new card a week ago and it didn't have the updated BIOS, so it's likely that "new cards" will still need the update, at least for a while.
ericc191
- Ribbons : 6
2021/10/21 20:33:49
May I ask the max wattage I can pull from a 3080 Ti XC3 Hybrid? Is there a bios that will allow me to pull even more?
HeatwareOS: W10 64 CPU: Intel Core i9-9900K @5GHz 1.28v Cooling: Corsair H100i RGB Mobo: Asus Z390i Gaming RAM: G.Skill TridentZ Royal 16GB 3200MHz SSD: Intel 660P 1TB | Samsung 850 EVO 1TB M.2 GPU: EVGA GTX 2080 Ti (Custom Hybrid) 2150MHz PSU: Corsair HX1000i Case: White Caselabs(RIP) Mercury S3 Display: Alienware AW3418DW 21:9 120Hz GSync Mouse: Logitech G403 Wireless Keyboard: Max Keyboard Blackbird Audio: Infinity IL10 paired to SA-50 amp
kram36
The Destroyer
- Ribbons : 72
2021/10/22 02:42:31
ericc191 May I ask the max wattage I can pull from a 3080 Ti XC3 Hybrid? Is there a bios that will allow me to pull even more?
350W and No.
matmat
2021/11/17 07:37:27
Found the updated Bios (94027180BF) for the 12G-P5-3953-KR card on tech power up and wondering if I can just flash it to my GPU via HiveOS?
post edited by matmat - 2021/11/17 07:40:30
gsrcrxsi
- Ribbons : 5
2021/11/17 09:03:31
kram36
350W and No.
366W*
Rig1: EPYC 7V12 | [4] RTX A4000Rig2: EPYC 7B12 | [5] 3080Ti + [2] 2080TiRig3: EPYC 7B12 | [6] 3070Ti + [2] 3060 Rig4: [2] EPYC 7742 | RTX A2000 Rig5: [2] EPYC 7642 Rig6: EPYC 7551 | [4] Titan V
sledzik1
2021/12/16 02:57:03
hymm my bios is 94.02.71.80.C0 and X1 does not propose any update to it... Does this mean my bios already have this fix? Or I still need to downgrade to the other one? If so how?
EVGA_Lee
- Ribbons : 14
2021/12/16 10:00:32
sledzik1 hymm my bios is 94.02.71.80.C0 and X1 does not propose any update to it... Does this mean my bios already have this fix? Or I still need to downgrade to the other one? If so how?
If this is for the 3080 Ti XC3 ULTRA HC, then yes, this is the latest BIOS for your card and it contains the improved power profile.
diasflacog
2022/04/23 04:03:54
Hello. Does this bios already come pre-applied onto new 3080ti XC3 Ultra's? I ask because I like the way this card looks and i'm planning on buying it. Thank you in advance :)
kram36
The Destroyer
- Ribbons : 72
2022/04/23 07:33:09
diasflacog Hello. Does this bios already come pre-applied onto new 3080ti XC3 Ultra's? I ask because I like the way this card looks and i'm planning on buying it. Thank you in advance :)
Buying directly from EVGA it should, if not Precision X1 will install the bios for you.
