gsrcrxsi
- Ribbons : 5
Tuesday, August 10, 2021 6:08 PM
kongfra
Tuesday, August 10, 2021 6:22 PM
EVGATech_LeeM Here's the new version of PX1: https://www.evga.com/precisionx1/ After installing, go to the ReBAR icon at the top, and click the update button. This will update your card to the latest BIOS for what your card currently shows in PX1. If you installed a hybrid kit on your card, I recommend using the force flash on the BIOS page here first: https://forums.evga.com/EVGA-GeForce-30-Series-HYBRIDXOCDefault-BIOS-Thread-m3407542.aspx, and then updating the card through PX1. Obviously, no need to do this if you purchased the XC3 HYBRID card.
Thanks for the hard work. One question, should I uninstall old version of PX1, then install new, or can install over it? Will it save my curve fan profile? or I would need to recreate? Thanks!
3080 TI XC3, i9-10850K, Noctua NH-D15S, Gigabyte Z590 Aorus Elite, Crucial Ballistix 32 GB Ram DDR4-3200 CL16 , EVGA Supernova G6 1000W 80+ Gold, Windows 10 Pro, LG 27GP83B-B with Dual Dell S2716DG Monitor, 2 TB Crucial MX500 SSD, Phanteks Enthoo Pro Case
Sir_Sizzle77
Tuesday, August 10, 2021 6:45 PM
Thank you. Look forward to seeing everyone's before and after results.
For referral at product registration: For discount at checkout: My Rewards Program Code: IR2IS16H62 Associate Code: MS709K401ICWSI5  Remember to upload an invoice after product registration.
EVGA_Lee
Moderator
- Ribbons : 14
Tuesday, August 10, 2021 6:46 PM
kongfra One question, should I uninstall old version of PX1, then install new, or can install over it? Will it save my curve fan profile? or I would need to recreate? Thanks!
I would just install PX1 over the old version. That would probably be the best way to keep your settings intact.
speedysloth
Tuesday, August 10, 2021 7:35 PM
Just to confirm, before the update, we should make sure that we have CSM and Fast Boot disabled in the motherboard's BIOS?
kram36
The Destroyer
- Ribbons : 72
Tuesday, August 10, 2021 7:42 PM
speedysloth
Yes.
Aruzedragon
Tuesday, August 10, 2021 7:47 PM
Flashed the new Bios to my card and WOW, getting close to 19000 on stock settings and the core voltage is a lot higher at ranging from .93 to .95 in timespy. This is a lot better than the past stock settings giving me low 18000s scores and my core voltage being limited to .8 ~.812ish
gtx690evga
Tuesday, August 10, 2021 7:50 PM
EVGATech_LeeM Here's the new version of PX1: After installing, go to the ReBAR icon at the top, and click the update button. This will update your card to the latest BIOS for what your card currently shows in PX1. If you installed a hybrid kit on your card, I recommend using the force flash on the BIOS page here first: , and then updating the card through PX1. Obviously, no need to do this if you purchased the XC3 HYBRID card.
Yes!!! I just tested it out. I'm averaging over 360w now and my max board draw was 376.3 386.2! Much improved, much appreciated!
post edited by gtx690evga - Tuesday, August 10, 2021 10:55 PM
pasaquina23
Tuesday, August 10, 2021 8:21 PM
I'm getting the 3080 ti xc3 gaming tomorrow. And, I've never flashed a bios on any of my previous gpus. Are there any precautions or steps to follow prior to updating the bios? Thank you.
EVGA_Lee
Moderator
- Ribbons : 14
Tuesday, August 10, 2021 8:37 PM
pasaquina23 I'm getting the 3080 ti xc3 gaming tomorrow. And, I've never flashed a bios on any of my previous gpus. Are there any precautions or steps to follow prior to updating the bios? Thank you.
See kram's answer to speedysloth's question a few posts above. That's really all you need to do.
icehotshot
Tuesday, August 10, 2021 8:39 PM
So I updated to the new PX1 and I'm not getting any bios update for my card? Anything else I need to do?
5800x, 32gb b-die @ 3800 cl15, Gigabyte Aorus Pro Wifi, EVGA 1000 G3, RTX 3080 ti ftw3 ultra, RTX 3080 ti ftw3 ultra hybrid, RTX 3080 ti XC3, custom loop
EVGA_JacobF
- Ribbons : 26
Tuesday, August 10, 2021 8:44 PM
What is the part number on your card?
icehotshot
Tuesday, August 10, 2021 8:46 PM
EVGA_JacobF What is the part number on your card?
Part Number: 12G-P5-3953-KR Part Desc: EVGA GeForce RTX 3080 Ti XC3 GAMING, 12G-P5-3953-K
pasaquina23
Tuesday, August 10, 2021 8:50 PM
EVGA_Lee
Moderator
- Ribbons : 14
Tuesday, August 10, 2021 8:52 PM
icehotshot So I updated to the new PX1 and I'm not getting any bios update for my card? Anything else I need to do?
This is the latest BIOS for your card, so it's up-to-date.
icehotshot
Tuesday, August 10, 2021 8:55 PM
EVGATech_LeeM
Interesting.....odd I didn't need to update to 1.2.4 to have the latest bios......guess I'll continue to be capped at 289w...oh well. Appreciate the effort with other people's cards though.
speedysloth
Tuesday, August 10, 2021 9:22 PM
icehotshot
EVGATech_LeeM
Have you updated your BIOS recently? Leem's comment does say that there is a BIOS update for 3953 and if your's the latest then you must have the power fix bios.
kongfra
Tuesday, August 10, 2021 9:25 PM
I just updated my 3080 TI XC3 - 3953 and has bios now: 94.02.71.80.BF here are my time spy results, looks better, not huge difference getting about 380 more points then before, I was getting 19005 before, but looks like my Clock is better. I should add I was not having major issue so no complaints, but I don't mind more performance , and this is at stock https://www.3dmark.com/3dm/64726626? Here was my previous results before I upgraded BIOS just to compare https://www.3dmark.com/spy/21887954 Also tested a quick game and ran benchmark of Red Dead Red Demption 2, getting constant 345 - 347 Watt, where as before I was getting 330, so definitely an improvement and saw 1950 mhz on average as clock speeds
post edited by kongfra - Tuesday, August 10, 2021 9:41 PM
DonaldTheGiver
Tuesday, August 10, 2021 9:33 PM
Is 12G-P5-3959-KR current bios version 94.02.71.80.C0? Only asking because I have been on this version for a bit and just installed 1.2.4 and also have no bios update available.
EVGA_Lee
Moderator
- Ribbons : 14
Tuesday, August 10, 2021 9:49 PM
DonaldTheGiver Is 12G-P5-3959-KR current bios version 94.02.71.80.C0? Only asking because I have been on this version for a bit and just installed 1.2.4 and also have no bios update available.
That's the latest. Just so you guys know, these BIOS versions have been "live" for a little over a day, so even if you were on an older version of PX1, it might have offered you this BIOS to download before PX1 v1.2.4 was available. These new versions are also different than the beta versions that I provided to members.
DonaldTheGiver
Tuesday, August 10, 2021 9:57 PM
EVGATech_LeeM
Awesome, thank you and the team for the update!
KingEngineRevUp
- Ribbons : 9
Tuesday, August 10, 2021 10:21 PM
kongfra I just updated my 3080 TI XC3 - 3953 and has bios now: 94.02.71.80.BF here are my time spy results, looks better, not huge difference getting about 380 more points then before, I was getting 19005 before, but looks like my Clock is better. I should add I was not having major issue so no complaints, but I don't mind more performance , and this is at stock https://www.3dmark.com/3dm/64726626? Here was my previous results before I upgraded BIOS just to compare https://www.3dmark.com/spy/21887954 Also tested a quick game and ran benchmark of Red Dead Red Demption 2, getting constant 345 - 347 Watt, where as before I was getting 330, so definitely an improvement and saw 1950 mhz on average as clock speeds
I think it's going to affect everyone differently. Some people were stuck at 280-300W, imagine the clock bins when them accessing 350-366W of power now. But if some of you were already pushing 320-330W, then an extra 15-30W will probably get you a bin (15 Mhz) or two (30 Mhz).
DonaldTheGiver
Tuesday, August 10, 2021 10:29 PM
So any chance were going to get an increased target power for at least the HC models? At stock clocks I hit power limit all the time with temps in the 40's
KingEngineRevUp
- Ribbons : 9
Tuesday, August 10, 2021 10:47 PM
DonaldTheGiver So any chance were going to get an increased target power for at least the HC models? At stock clocks I hit power limit all the time with temps in the 40's
You can hope but I doubt it. A XOC hasn't been released for the 3080 and 3090 XC3s, I don't see one coming out for the 3080 Ti. But never say never I guess.
hinanin
Tuesday, August 10, 2021 11:13 PM
With the bios update out do you guys recommend this card now or should I hold my breath for the FTW?
I9 10900k @ 5.1 / 32 GB DDR4 4133 16-16-16-36 / EVGA 3080 Ti XC3 w/Hybrid Kit I7 6700K / 32 GB DDR4 / EVGA 1080 w/Hybrid Kit I7 3930K @ 4.3 / DDR3 32 GB ram / EVGA GTX 780 x 2 I7 960 24GB GB Ram / GTX 570 / EVGA X58 SLI3 Q6700@3.0 8GB of Ram / EVGA 780i
Aruzedragon
Tuesday, August 10, 2021 11:15 PM
hinanin With the bios update out do you guys recommend this card now or should I hold my breath for the FTW?
I would recommend the card now, it can match a FE but it has way better cooling for Vram and EVGA support.
bcat24
Tuesday, August 10, 2021 11:19 PM
Just to provide another datapoint, I updated my XC3 Gaming (3953) and my graphics score went from 18540 to 19039. This seems comparable to the FE and about in line with what I'd expect from a base model card. Comparison: compare/spy/21687946/spy/22070332 (I can't post the full link, sorry; add 3dmark DOT com at the start) At least in Time Spy, it looks like average temp went up 3c, with peak temp maybe 1c higher. I could probably squeeze more performance out of the card with a more aggressive fan curve or a hybrid kit. I'll look at power draw, temp, and fan RPM in gaming later on.
post edited by bcat24 - Tuesday, August 10, 2021 11:20 PM
DonaldTheGiver
Wednesday, August 11, 2021 0:26 PM
XC3 HC - I'm running on some older hardware yet so not bothering with time spy scores at the moment, playing around with overclocks though. GPU-Z is showing a power spike up to 425.9 at one point, going to run some more tests and see if it's something I can reproduce but I have a stable overclock right now of +500 on memory and +135 on core with no extra voltage, going to see how much further I can push it.
2070 GPU clock 48.7C Max Temp Average Max Board Power Draw 374.1 W
Seeing power limit spikes to 107-110
glenn37216
- Ribbons : 9
Wednesday, August 11, 2021 1:00 AM
Still tweaking O.C's but first run is already my best Timespy score. w00t ! 3080 ti XC3 Gaming @ 1455/1220 (+260/90) TIMESPY - Graphics Score 19979 https://www.3dmark.com/spy/22072517Max Boost clocks - 2040 Board Power Draw - 374.5 Pin 1 Power - 153.6 Pin 2 Power - 154.1 Max Temp 69.8 Max FanSpeeds - 100% 107 % TDP GPU VOLTAGE 1.0680 - Max ReBar - off Bios : 94.02.71.80.BF
post edited by glenn37216 - Wednesday, August 11, 2021 1:05 AM
9800x3DGIGABYTE X870 AORUS ELITEG.SKILL Flare X5 Series AMD EXPO 64GB 60004TB - SAMSUNG 990 EVO SSD2X - Crucial MX500 4TB 3D NAND SATA 2.5 Inch Internal SSDMontech King 95 Pro Dual Chamber ATX CaseCooler Master MasterLiquid 360L EVGA - 1300 G2 PSURTX 5080 - COMING SOONCULTS3D PRINTABLES
kongfra
Wednesday, August 11, 2021 2:03 AM
KingEngineRevUp
oh yeah I am not complaning, in fact very happy for the extra performance whatever it is, maybe I will try to overclock now just to see if I can get more out of it but for games I think I am great right now!
