Helpful Reply2080ti FTW3 Fan + 3 Red LED ISSUE on Start up
Page: < 12345 > Showing page 4 of 5
Lord Odin
Re: 2080ti FTW3 Fan + 3 Red LED ISSUE on Start up 2018/11/24 19:43:30 (permalink)
kyleqianlima
Lord Odin
Looks like I'm in the same boat as you guys.  This is stupid if cards have to be RMA'd just for a simple update.
Also what does it say when you try to flash the MCU according to the faq post? Device not supported?
First time, it flashed just fine.  Anytime after that, "Device not supported".  Which is weird because X1 still recognizes it as a Ti FTW3.
Evolv X | i9-9900k | Asus Maximus XI HeroEVGA 1000 T2 | 32gb DDR4-3600 | 512 GB Samsung 970 Pro M.2 | 1 TB Samsung 970 Pro M.2 2TB Samsun 860 Evo |Custom Water Cooling | 2080 Ti FTW3 Ultra | Hydrocopper SoundBlaster Zx
#91
kyleqianlima
Re: 2080ti FTW3 Fan + 3 Red LED ISSUE on Start up 2018/11/24 20:44:28 (permalink)
Lord Odin
kyleqianlima
Lord Odin
So even after you flashed it first time the red led are all still on?
#92
Lord Odin
Re: 2080ti FTW3 Fan + 3 Red LED ISSUE on Start up 2018/11/24 20:56:58 (permalink)
kyleqianlima
Yup.  Even tried turning the system off, unplugging the PSU, held power button for 30 secs, and even removed card from the rig.  Still there.  Thinking of disconnecting the middle fan header until I can figure this out for my sanity.
#93
kyleqianlima
Re: 2080ti FTW3 Fan + 3 Red LED ISSUE on Start up 2018/11/24 21:01:19 (permalink)
Lord Odin
kyleqianlima
Was the fault first came on due to PX1 tried to flash the firmware but somehow failed?
#94
Lord Odin
Re: 2080ti FTW3 Fan + 3 Red LED ISSUE on Start up 2018/11/24 21:07:38 (permalink)
kyleqianlima
That's the weird part.  It didn't fault on the first time.  I didn't notice the red lights until after the issues were already present.  The GPU is mounted vertically and the lights were hidden behind the cables.
#95
_JeffP
Re: 2080ti FTW3 Fan + 3 Red LED ISSUE on Start up 2018/11/26 21:25:51 (permalink)
If anyone is still having this issue and I do not reach out to you today please open a support ticket so that we can work to get this solved.
Everything is security.
#96
stx34
Re: 2080ti FTW3 Fan + 3 Red LED ISSUE on Start up 2019/02/21 12:18:35 (permalink)
Good evening,
I just bought a RTX 2080 FTW 3 and by installing the latest version of Precision X1 my card is illuminated by 3 red LEDS and the middle fan that turns very loud. I tried to patch the MCU, without success.
Help me please.
#97
Asmodeusz
Re: 2080ti FTW3 Fan + 3 Red LED ISSUE on Start up 2019/02/21 13:36:42 (permalink)
stx34
Good evening,
Help me please.
Hi stx34
There is just one simple solution for that - RMA to support and warranty. You can try fix it by manually "kick in" firmware... but in 98% its to late when you have 3red light and fan 100%.
Good luck
He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you.
             Friedrich Nietzsche
CPU: i7 3930 @ 4.2GHz + LC // MOBO: Asrock Extreme 11 X79
Ram: 4 x 4GB Corsair Vengeance // GPU: EVGA RTX 2080 FTW3
Case: EVGA DG-87 // PSU: Antec HCG-850M
Sound card: Asus Xonar D2X // Monitor: Philips BDM4065UC
#98
tjohnston3
Re: 2080ti FTW3 Fan + 3 Red LED ISSUE on Start up 2019/02/21 14:38:14 (permalink)
I also get the 3 red lights but only after i have had my pc unplugged, shutting it down and then restarting it turns them off.
Case: Cooler Master HAF 700 Berserker
Motherboard: EVGA Z690 Classified
CPU: Intel Core i9 12900K 5.2 (all cores)
Cooler: EK-Quantum Velocity2
Dac/Amp: Fosi Audio K5 Pro
RAM: G.SKILL Trident Z5 2x16 DDR5 6000
GPU: MSI 4090 SuprimX
PSU: EVGA 1000W G3
Storage: Samsung  890 Pro 512 NVMe Gen4 (os)
Storage2: WD Black SN770 NVMe 1TB
Storage3: WD Black SN770 NVMe 2TB
OS: Win10 64bit
#99
albone
Re: 2080ti FTW3 Fan + 3 Red LED ISSUE on Start up 2019/02/21 20:03:01 (permalink)
tjohnston3
This scenario also occurs with my 2080 FTW3 Hybrid.
post edited by albone - 2019/02/21 20:05:11
EVGA Z390 Dark | Intel i9900k | EVGA CLC 280 Liquid / Water CPU Cooler | EVGA GeForce RTX 2080 FTW3 Ultra Hybrid | Corsair-Vengeance LPX 32GB DDR4-3200 | Samsung 970 Pro 512 M.2 Nvme | EVGA SuperNova 1000w P2 80+ Platinum | DG-86 Case
stx34
Re: 2080ti FTW3 Fan + 3 Red LED ISSUE on Start up 2019/02/22 00:10:42 (permalink)
Strangely today when I turn on my PC I don’t have the three leds on. Will they still go to the RMA if I send them?
Asmodeusz
Re: 2080ti FTW3 Fan + 3 Red LED ISSUE on Start up 2019/02/22 01:26:28 (permalink)
stx34
If problem is not there why you want to create RMA?:D
             Friedrich Nietzsche
Asmodeusz
Re: 2080ti FTW3 Fan + 3 Red LED ISSUE on Start up 2019/02/22 01:30:00 (permalink)
Also its some time from release of 2080ti/2080 FTW . I hope that EVGA just find solution to fix that issue in "normal" way by software at user PC :) not by RMA and sending card to manufacturer. Its worth to ask customer service for solution. In my case they respond quick and with solid information :)
             Friedrich Nietzsche
stx34
Re: 2080ti FTW3 Fan + 3 Red LED ISSUE on Start up 2019/02/22 01:47:35 (permalink)
what I don’t understand is that it doesn’t do it all the time. I feel like it’s the lottery.
That’s why I wonder if sending the card and he doesn’t see it by testing it I’d be a little stupid...
Asmodeusz
Re: 2080ti FTW3 Fan + 3 Red LED ISSUE on Start up 2019/02/22 02:11:00 (permalink)
stx34
So 3red lights its random? Can you check pc with different PSU? and PSU you have anyway :)
             Friedrich Nietzsche
stx34
Re: 2080ti FTW3 Fan + 3 Red LED ISSUE on Start up 2019/02/22 05:59:17 (permalink)
Today by turning on PC everything works perfectly. But last night when turning it on, the acronym "RTX 2080 was not lit, the middle fan was turning strong and the 3 red leds lights on.
I’ll see if it remakes it. Otherwise I’d have to do an RMA
Asmodeusz
Re: 2080ti FTW3 Fan + 3 Red LED ISSUE on Start up 2019/02/22 06:11:59 (permalink)
stx34
Maybe start with mail to customer service with description of issue. And check PSU. If I good remember faulty PSU or to weak also can make this issue (ofc if I good remember:P)
             Friedrich Nietzsche
ihcfr
Re: 2080ti FTW3 Fan + 3 Red LED ISSUE on Start up 2019/02/22 06:15:00 (permalink)
Many of us who had the same problem in another thread are Asus mobo owners. Do you also happen to use Asus motherboard?
stx34
Re: 2080ti FTW3 Fan + 3 Red LED ISSUE on Start up 2019/02/22 12:07:51 (permalink)
Asmodeusz
Ok thanks. So 750W it's to short for use a 2080 FTW ?
Graphite8five
Re: 2080ti FTW3 Fan + 3 Red LED ISSUE on Start up 2019/02/22 17:31:54 (permalink)
What are those 3 led's on the card anyway?
stx34
Re: 2080ti FTW3 Fan + 3 Red LED ISSUE on Start up 2019/02/22 23:21:13 (permalink)
Graphite8five
Check 1st page
Graphite8five
Re: 2080ti FTW3 Fan + 3 Red LED ISSUE on Start up 2019/02/22 23:34:47 (permalink)
stx34
Graphite8five
Check 1st page
I couldn't actually find anything that described what they're purpose is, mind pointing me to it?
Asmodeusz
Re: 2080ti FTW3 Fan + 3 Red LED ISSUE on Start up 2019/02/23 03:38:15 (permalink)
stx34
Graphite8five
3 red lights are information to user that card is ready to update firmware. When Evga software is installing, firmware is updated but warning about that is (for me) not enough visible. So lots of ppl just click next next next ok... and if any other program is running in background (program what using graphics) card can just stuck in firmware update state.
post edited by Asmodeusz - 2019/02/24 00:59:42
             Friedrich Nietzsche
stx34
Re: 2080ti FTW3 Fan + 3 Red LED ISSUE on Start up 2019/02/23 11:32:40 (permalink)
It's bull !! You buy a card that costs 900€ and because of a bad software that at the present time is still not updated to avoid this problem becomes a GTX 560. WTH EVGA ??
I had a 970 then a 1060 at EVGA but now, finished!  the last will be a 2080
post edited by Sajin - 2019/02/23 12:46:38
Asmodeusz
Re: 2080ti FTW3 Fan + 3 Red LED ISSUE on Start up 2019/02/24 01:14:30 (permalink)
stx34
It's not a bull :) Software itself its fine. User dont need to install EVGA Precision X1 :) and if they do, they need to read what is on screen :) I installed X1 for it information section (temps, fan speeds etc) My fault was ( as 99.99% users ;) ) next,next, next... ok. And I don't read what software will do, exactly that will update firmware on my GPU. To be sure, I just check EVGA website with X1, still no information that X1 Precision its changing firmware :)
Great card - yes. Great 3 fan cooling system - yes. Bad marketing of software from EVGA - definitely yes.
All luck EVGA customer service accept RMA for 3 red lights without problems :)
And stx34 - card working with this same power as normal card, no matter red light or not :) Just sound of starting jet from pc case is problematic :)
             Friedrich Nietzsche
Kevincease
Re: 2080ti FTW3 Fan + 3 Red LED ISSUE on Start up 2019/02/24 13:59:32 (permalink)
Hi I bought two of these 2080ti FTW3's and only one of them works. The other has this led issue. When using just the one with the issue, I cannot get past the "press del to enter bios screen" because my keyboard stops working and the screen doesnt go away. When I use the one that works, everything is fine. When I insert the one with the issues in the second slot and run them together, same issue.
I've been in email contact with customer support but not getting anywhere right now. They seem to not be able to understand that I am having issues with only one. I need to get them on the phone i guess.
AMD 2950
g.skill 64gb
Asus x399-e rog strix
EVGA 850w GQ
AMD 2950x
Asus X399-e Rog Strix
2 x G.SKILL Ripjaws 4 series 32GB (4 x 8GB) 288-Pin DDR4 SDRAM 3000 (PC4-24000) Model F4-3000C15Q-32GRK
2 x EVGA 2080ti FTW3
EVGA 1200 P2
Asmodeusz
Re: 2080ti FTW3 Fan + 3 Red LED ISSUE on Start up 2019/02/24 23:04:02 (permalink)
Kevincease
AMD 2950
g.skill 64gb
EVGA 850w GQ
I know its loooong shot buy try this:
Ask you friends who have ps2 keyboard/mouse connector on motherboard. Power PC with connected PS2 keyboard and check do GPU have still this same issue.
Also - what happen when you use "faulty" GPU in second slot and good one in first?
And for customer service - just "remove" working card from description of issue :D - you have ONE card with red light issue, when you insert ONE card to PC he is going to "press del to enter bios screen", etc :) To many variables in case make solution hard to find. So remove working parts, and focus of faulty. :)
             Friedrich Nietzsche
BigART71
Re: 2080ti FTW3 Fan + 3 Red LED ISSUE on Start up 2019/03/30 12:40:16 (permalink)
I'm having this issue.  I just received my card yesterday.  If I turn the psu off in the back for 10 seconds and power back on it's fine.  If I do a normal shutdown than turn it back on it's got the 3 red led's and middle fan is at 100%.  Is there a fix out of for this yet?
Fullautonewfie
Re: 2080ti FTW3 Fan + 3 Red LED ISSUE on Start up 2019/07/10 18:21:13 (permalink)
Same issue. Turn pc on and randomly get fans on 2080 ti ftw3 spinning at max speed. Card is 3 days old!!!
BigART71
Re: 2080ti FTW3 Fan + 3 Red LED ISSUE on Start up 2019/07/10 18:24:50 (permalink)
They replaced mine. No issues since other than one fans rpm is different than the other two at the same percentage. Other than that it’s been good to go.
