TiN_EE
Yes, that TiN
- Ribbons : 14
Re: Candies for RTX 2080 Ti Kingpin
2019/05/05 22:07:19
- Ribbons : 282
2019/05/05 22:18:05
TiN_EE Try this rar one?
It worked, thank you. If I zip it up it is a larger file than the zip file you have posted.
post edited by bcavnaugh - 2019/05/05 22:21:49
TiN_EE
Yes, that TiN
- Ribbons : 14
2019/05/05 22:28:48
ZIP shenanigans, my apologies. Can you try ZIP file again, I've repacked it with winrar. WinRAR is my go to archiver, it gives good recovery and packs better :)
- Ribbons : 282
2019/05/05 22:30:36
☄ Helpfulby TiN_EE 2019/05/05 22:33:30
TiN_EE ZIP shenanigans, my apologies. Can you try ZIP file again, I've repacked it with winrar. WinRAR is my go to archiver, it gives good recovery and packs better :)
The Zip File is Good to Go Now.
post edited by bcavnaugh - 2019/05/05 22:37:02
Q56_Monster
- Ribbons : 5
2019/05/06 07:31:38
Thanks for the goodies Question: one of my KP cards is crashing windows on start up (about 75% of the time). I can get in sometimes, and have run a successful 3dmark once or twice. If I do get in to windows it freezes up when I start google chrome. Do I need to go through RMA headache or is there something else simple that will make it stable? My other KP card works fine and both my 1080ti's work fine. Any advice is appreciated!
Mobo: Asus Rampage VI Extreme CPU: i9-7980XE GPU: RTX 3090 KPE HD: Samsung 1TB 970 Pro NVMe M.2 PSU: EVGA Supernova 1600 T2 OS: All of them Monitor: 48" LG CX OLED Other Cooling Fun: F1 Gemini/Tek-9 Fat LN2 | 12k BTU A/C to Chiller Conversion
- Ribbons : 282
2019/05/06 07:44:20
Q56_Monster Thanks for the goodies Question: one of my KP cards is crashing windows on start up (about 75% of the time). I can get in sometimes, and have run a successful 3dmark once or twice. If I do get in to windows it freezes up when I start google chrome. Do I need to go through RMA headache or is there something else simple that will make it stable? My other KP card works fine and both my 1080ti's work fine. Any advice is appreciated!
Have you tested each card alone in your computer? If so are you seeing the Same Issue? Have you Tested with and without the NVLink Bridge Installed or with a Different Bridge? Have you reversed the card location on your motherboard? What NVIDIA Driver Version are you running and have tested with? You might want to create your own Thread under EVGA GeForce 20/16 Series to allow others to help out.
post edited by bcavnaugh - 2019/05/06 08:42:28
TiN_EE
Yes, that TiN
- Ribbons : 14
2019/05/06 08:30:06
Do I need to go through RMA headache Sounds like that's the right road, sorry. Card should start and always work, as expected.
Q56_Monster
- Ribbons : 5
2019/05/06 10:17:30
Have you tested each card alone in your computer? Yes, only single config If so are you seeing the Same Issue? No, 1 KP 2080 and 2 1080ti's working fine in single card Have you Tested with and without the NVLink Bridge Installed or with a Different Bridge? I don't have NVlink yet, so only testing single cards Have you reversed the card location on your motherboard? I'll try that What NVIDIA Driver Version are you running and have tested with?The latest with the .53 hotfix You might want to create your own Thread under EVGA GeForce 20/16 Series to allow others to help out. Will do if I don't RMA
Thanks bc. I responded above. I think TiN might be right though
- Ribbons : 282
2019/05/06 11:25:58
Q56_Monster, Bummer if you have to RMA your New Card. 425.31 seems to be the last best driver at least in my testing.
Q56_Monster
- Ribbons : 5
2019/05/06 17:01:43
OK, so I got this card working pretty good now. Thanks bc, I re-seated the card and all is well now. No more crashes. http://www.3dmark.com/pr/89009 Now to SLI tomorrow. I got to say these KP cards are nice and quiet and run supper cool. Perfect for gaming.
post edited by Q56_Monster - 2019/05/06 17:08:24
- Ribbons : 282
2019/05/06 17:06:50
TiN_EE
Yes, that TiN
- Ribbons : 14
2019/05/06 18:57:52
Great, Happy to be wrong in this case :)
k|ngp|n
- Ribbons : 5
2019/05/07 05:50:56
Q56_Monster
- Ribbons : 5
2019/05/07 20:32:55
Hey Vince! :) I missed the postman today :(....new gpu brackets from your store.
Q56_Monster
- Ribbons : 5
2019/05/09 17:14:08
Got brackets Vince ;), Thanks man
mattaman10
2019/05/20 14:55:32
What is everyone getting not using the classified tool and just using precision x1?
I cant seem to get this card stable past 2130-2145mhz? I've even bought a new power supply as Evga tech support suggested. Power limit is maxed out, I tried every voltage setting in X1, and I am even using the Ln2 bios (flashed to the OC bios position). Temps are 40C at full load on GPU and 46 degrees on memory during stress tests. Please help as I'm really not impressed by the results I am getting.
- Ribbons : 282
2019/05/20 14:59:40
AHowes
- Ribbons : 27
2019/05/20 18:05:44
mattaman10 What is everyone getting not using the classified tool and just using precision x1?
Install Afterburner..Set up the OSD. Close it. Then open PX1 and set the fans/power/voltage to max hit apply and close it. Then open afterburner.. check that the voltage and power limit are maxed. Then open the curve. Think its press Control+ F? Select the dot for 1.093v and raise it to what you want to try for.. say 2160 or 2190 or 2205mhz and before you hit apply press control+p which will being up a ventricle yellow line. Then hit apply to lock it in. Kinda like locking in the voltage. Test it out. Px1 dont seem to use the max voltage.. for me it's like locked at 1.050v. You can also use the classified tool and the top voltage is for GPU. You can lock the voltage at 1.093v and change the Loadline voltage to say 0 or 1.. hit apply. Low numbers keep the voltage droop to a minimum. I still like to use AB with the classified tool and lock the voltage in with the classified tool. Setting the overclock curve with AB, it will report only the voltage you set for in AB.. so it can say 1.093v I On the on screen display but it's not the real voltage which will be what you selected in the classified tool.. should hook up a dmm to the card to read the actual voltages during idle and load.
vladdimplr
2019/05/20 22:51:06
- Ribbons : 282
2019/05/20 22:58:46
vladdimplr The AB trick may push it further, but this is without the classified tool being used, mem +1300, gpu +105 https://www.3dmark.com/3dm/36254668
https://www.3dmark.com/compare/pr/94402/pr/94317Move over the PR to see if I can match yours. https://www.3dmark.com/compare/spy/7238047/spy/7237906/spy/7237877 I have no apps running in the background not even PX1. Maximum turbo core clock 5,103 MHz gives you the edge. My PX1 Setting M=1350 G=145 >>> I run the same settings 3 times on the same Benchmark, got this tip from Zeddivile <<< Here you go https://www.3dmark.com/compare/pr/94403/pr/94404 Sorry Got you by 5 https://www.3dmark.com/compare/pr/94403/pr/94404/pr/94406 Hit 9921 Crashed on the 3rd run My PX1 Setting M=1350 G=150 (Under Description I put my settings used) https://www.3dmark.com/compare/pr/94402/pr/94404/pr/94406/pr/94410 9953 2,220 MHz 1 run crashed running 3rd run now, Crashed Going with M=1400 G=145 https://www.3dmark.com/pr/94414 9969 G:2,190 MHz M:2,100 MHz Next Going with M=1450 G=149 Going to see if I can hit 10,000 on PR tonight. I do not want take away from this Thread to much "Candies for RTX 2080 Ti Kingpin" So I will add more to this Post. PS All without using the Classified Tool. For Gaming I only run my CPU @ 4600MHz and GPU @ 2145-2160MHz But summer is coming even though it is Snowing ATM, we have about 2 inches now. On the Crash Crash I ran the CPU 1 Test from 3DMark Vantage Performance (Only the CPU) upped my vCore until I could pass it and that is where I am at now. I won't say it is at 1.365. But ATM not seeing temps above 60°C and it is now 5.7°C in the room Intel Core i9-7920X Processor 3DMark rank 5 Nice CPU Info on the Links The Intel Core i9-9900K Processor 3DMark rank 6 is doing very well and most users are killing me. But is doing a Killer compared to the Intel Core i7-8700K Processor and this I have in a Z370. Maybe time to update to your CPU if my MB supports it.
post edited by bcavnaugh - 2019/05/21 00:23:36
vladdimplr
2019/05/20 23:00:41
https://www.3dmark.com/3dm/36254863closed apps down in background 7920x at 5.0 is bad ass! I can't get stable at 2175 unless its just a pass through 3d mark, gaming it crashes almost instant :( hoping hydro copper block cools it enough to game around 2200 (optimistic) https://www.3dmark.com/3dm/36255027 @2175 What voltage settings are you using in classified? I want to try it out see if I can pass 2200 Without classified? oooooooooh, I'm going to try as well, no go at +135, crash crash crash, voltage in classified to 1.15 LL10 crash LL5 crash, I keep mine at 5.1 all around, beefy cooling but it has 4 less cores than you!
post edited by vladdimplr - 2019/05/20 23:21:40
mattaman10
2019/05/29 12:29:50
Does anyone have the latest firmware for this card? Not BIOS but firmware
- Ribbons : 282
2019/05/29 12:41:45
mattaman10 Does anyone have the latest firmware for this card? Not BIOS but firmware
It comes with PX1 0.3.17.0 and is the current version You will find the file under \Program Files\EVGA\Precision X1\Firmware You can update inside of PX1 as well.
post edited by bcavnaugh - 2019/05/29 12:46:49
mattaman10
2019/05/29 12:48:50
Yeah I had 2B.FA.39, but now I have 2B.FA.3F as I manually updated it which was a mistake lol
- Ribbons : 282
2019/05/29 12:55:49
mattaman10 Yeah I had 2B.FA.39, but now I have 2B.FA.3F as I manually updated it which was a mistake lol
The Update is not working from within PX1?
mattaman10
2019/05/29 13:06:38
Oddly no, it's just asking for me to pick a firmware file from a list, and that's how I ended up in this mess lol
mattaman10
2019/05/29 13:07:57
It's not prompting me to update when opening Precision X1 either
mattaman10
2019/05/29 13:15:35
I should clarify that the .39 firmware is not in the file of firmware. 3F was the only one it was able to update to.
- Ribbons : 282
2019/05/29 13:17:51
mattaman10 It's not prompting me to update when opening Precision X1 either
Click Update, I see we need to know the File Name......
post edited by bcavnaugh - 2019/05/29 13:20:41
mattaman10
2019/05/29 13:20:26
Yup, that's when it brings up a list of firmware files, and the only one that worked was 3F, and .39 is no where to be found
