Helpful ReplyTechnical Guide and candies for RTX 2080 Ti Kingpin
Page: < 12345.. > >> Showing page 3 of 7
tresnugget
Re: Candies for RTX 2080 Ti Kingpin 2019/04/22 07:56:57 (permalink)
OLED/x1
#61
tresnugget
Re: Candies for RTX 2080 Ti Kingpin 2019/04/22 08:43:32 (permalink)
polishsweed
tresnugget
polishsweed
Question for everyone. What's your power draw at your highest stable overclocks? I'm drawing over 300w on my best runs which can spike as high as 340w. That's right at the limit for max TDP on the stock BIOS.
Regular gaming overclocking I never see past like 310. Serious benchmark overclocking  I'm thinking I'm around 340 but I can't say I've seen it higher although I've been paying more attention to the clocks. I assume these cards can push 520w out the box when set to 144% as 360*1.44=518.4
Was that measured from a Multimeter or the OLED?
The crazy thing is how little power is required compared to other cards. My FTW3 is a pretty good overclocker, (capable of hitting 2130 but can only sustain about 2050) and its hitting 320 to 360w while at the same clocks my Kingpin is like 100+w less.
post edited by tresnugget - 2019/04/22 09:08:18
#62
kingx11
Re: Candies for RTX 2080 Ti Kingpin 2019/04/22 11:20:37 (permalink)
how about the waterblock ? any news ?!
#63
TiN_EE
Yes, that TiN
  • Ribbons : 14
Re: Candies for RTX 2080 Ti Kingpin 2019/04/22 17:19:26 (permalink)
I'm still waiting for mine to test :)
#64
tresnugget
Re: Candies for RTX 2080 Ti Kingpin 2019/04/22 17:55:12 (permalink)
I see a lot of people talking about restarting after applying the voltages. I haven't been restarting and it's still taking effect. When the driver crashes after failed clocks I have to close the tool and reopen to get it to take further changes sometimes. Is there any advantage to restarting after applying voltages?
#65
  • Ribbons : 282
Re: Candies for RTX 2080 Ti Kingpin 2019/04/22 18:05:05 (permalink)
I do if for the Memory.
#66
GregorysBrain
Re: Candies for RTX 2080 Ti Kingpin 2019/04/22 18:18:58 (permalink)
TiN_EE
Haha...I've seen your latest addition to the OC Guide. 500w+ spikes on stock BIOS is what I was expecting. I've noticed the boost throttle on several runs despite being at 29Β°c on the die temp at 2230MHz. Patiently waiting for the XOC BIOS with no PL.
Gregory "Grzesiu" Oleksy
YouTube - Gregorysbrain
Twitch - Computer_Enthusiasts
Current Setup
Lian Li Bench (black brushed aluminum)
EVGA Z690 Dark K|NGP|N
I9 13900K 7GHz/5.8GHz/58cache LN2
32GB G.Skill Trident Z5s 7600CL36 (8000 32-39-39-28 2T)
2x EVGA GTX1080Ti Kingpins, EVGA RTX 2080Ti Kingpins, and EVGA RTX3090 Kingpin
3x EVGA 1600P2s
Kingpin Cooling T-Rex Rev.4
Kingpin Cooling Tek-9 Fats
Kingpin Cooling ICON 3.0
Kingpin Cooling Inferno
Kingpin Cooling KPx
Kingpin Cooling Hellfire (Coming Soon)
#67
GregorysBrain
Re: Candies for RTX 2080 Ti Kingpin 2019/04/22 18:20:17 (permalink)
tresnugget
You should do a soft reset after setting FBVDD to allow the memory to train. NVVDD can be adjusted on the fly.
Current Setup
3x EVGA 1600P2s
Kingpin Cooling KPx
#68
tresnugget
Re: Candies for RTX 2080 Ti Kingpin 2019/04/22 18:34:25 (permalink)
polishsweed
tresnugget
Oh, okay. That makes sense. Question regarding power limit, are you actually seeing precision saying that you're hitting the power limit in hwm? Like the power limit going from 0 to 1? These binned gpus seem to just be way more efficient than most. Like I said my ftw3 hybrid reports 330 to 360w just to hit 2050 whereas the kingpin is almost 100 watts less at the same clocks. I just assumed you'd have to be doing some serious xoc to hit 500.
#69
TiN_EE
Yes, that TiN
  • Ribbons : 14
Re: Candies for RTX 2080 Ti Kingpin 2019/04/22 18:55:13 (permalink)
Driver/card will still limit power even if power peak is really short.
PX1 reported power limit (0/1 value) need to reach some duration threshold before it flips.
#70
AHowes
  • Ribbons : 27
Re: Candies for RTX 2080 Ti Kingpin 2019/04/22 19:00:26 (permalink)
tresnugget
polishsweed
tresnugget
I see a lot of people talking about restarting after applying the voltages. I haven't been restarting and it's still taking effect. When the driver crashes after failed clocks I have to close the tool and reopen to get it to take further changes sometimes. Is there any advantage to restarting after applying voltages?Β
Prob all about temps with the bigger rad. Card is clocking higher cause of temps.
Asus Z390 ROG Extreme XI MB
#71
tresnugget
Re: Candies for RTX 2080 Ti Kingpin 2019/04/22 19:06:05 (permalink)
AHowes
tresnugget
polishsweed
tresnugget
Yeah, of course. not to mention the difference in silicon quality. I wasn't referring to the clocks. I'm referring to the 100 watts less the kpe is using at the same clocks as the ftw3.
#72
tresnugget
Re: Candies for RTX 2080 Ti Kingpin 2019/04/23 04:52:54 (permalink)
polishsweed
TiN_EE
So, I just got done doing some Port Royal runs as I was trying to get a 2200 Mhz score. (https://www.3dmark.com/3dm/35599986? wish it was higher. temps made it clock down.) Ended up needing about 1.25v to get that stable enough to get through. In running at such high voltage I finally saw the power up in the 450s via the oled. So it looks like they will push some serious power but you just have to be pushing some serious voltage.
#73
GregorysBrain
Re: Candies for RTX 2080 Ti Kingpin 2019/04/23 05:06:36 (permalink)
tresnugget
polishsweed
TiN_EE
Yeah, it'll really start drawing power at 1.2v+, but that voltage is way to high for the stock cooler. How does your core vDroop look? I'd imagine you had a pretty high LLC level for that run? I managed this with auto voltage and +25mv on the manual dip switch with quite a bit of LLC at 3 so minimal droop. Still showed a power draw over 400w in GT2 through most of the run.
https://www.3dmark.com/pr/81003
Current Setup
3x EVGA 1600P2s
Kingpin Cooling KPx
#74
tresnugget
Re: Candies for RTX 2080 Ti Kingpin 2019/04/23 05:25:44 (permalink)
Yeah, I just don't think my card is as good as yours. I tried your settings and instant crash as soon as it hit anything at or above 2175. I left llc at 10 but it was really set at 1.29 to get it to 1.25. Temps were my downfall but I don't think it ever saw 50c so I don't think it would be considered dangerous, do you?. I started my runs once it got down to 30c or below and let her rip. It's probably about 65f in here.
#75
tresnugget
Re: Candies for RTX 2080 Ti Kingpin 2019/04/23 05:38:44 (permalink)
Also, I'm doing runs with my ftw3 hybrid still in the second slot. Do you think I'd get any extra stability by taking it out? I figure I might get an extra 1% or less in score just from being at 16x but I'm curious about just raw stability. Maybe the extra draw on the pcie might be causing some instability at such high clocks?
#76
kingx11
Re: Candies for RTX 2080 Ti Kingpin 2019/04/23 10:35:56 (permalink)
TiN_EE
could someone at EVGA Check if the block can fit inside Lian-li O11 Dynamic ? it happened once when i had to keep the case open because of the terminal sticking out and i don't wanna be in that position again
#77
HawkOculus
Re: Candies for RTX 2080 Ti Kingpin 2019/04/24 03:02:29 (permalink)
kingx11
TiN_EE
Why wouldn’t it? That case is huge.
#78
GregorysBrain
Re: Candies for RTX 2080 Ti Kingpin 2019/04/24 05:00:47 (permalink)
Hahaha...the password for the XOC BIOS is amazing!
Current Setup
3x EVGA 1600P2s
Kingpin Cooling KPx
#79
kingx11
Re: Candies for RTX 2080 Ti Kingpin 2019/04/24 09:20:56 (permalink)
HawkOculus
kingx11
TiN_EE
it's not that simple , this happened when i had a WB on Lightning Z
#80
AHowes
  • Ribbons : 27
Re: Candies for RTX 2080 Ti Kingpin 2019/04/24 12:40:24 (permalink)
The hydro block has ports on every side. Top,bottom and side. But in your case.. you need a new case.
#81
  • Ribbons : 282
Re: Candies for RTX 2080 Ti Kingpin 2019/04/24 12:58:48 (permalink)
Not going to help here
Another Thread being taken off topic  OP Should Create their own Thread about this Case.
#82
tresnugget
Re: Candies for RTX 2080 Ti Kingpin 2019/04/24 18:15:18 (permalink)
Anyone tried the new bios yet?
#83
AHowes
  • Ribbons : 27
Re: Candies for RTX 2080 Ti Kingpin 2019/04/25 07:50:30 (permalink)
If I owned one it would be done!
#84
  • Ribbons : 282
Re: Candies for RTX 2080 Ti Kingpin 2019/04/25 09:02:20 (permalink)
AHowes
I think it is time to rename the K|NGP|N to AHowes Wanna Be
EVGA GeForce RTX 2080 Ti AHowes Wanna Be GAMING, 11G-P4-2589-KR, 11GB GDDR6, iCX2 & OLED
post edited by bcavnaugh - 2019/04/25 09:04:30
#85
AHowes
  • Ribbons : 27
Re: Candies for RTX 2080 Ti Kingpin 2019/04/25 10:37:46 (permalink)
AHowes
I think it is time to rename the K|NGP|N to AHowes will take any K|NGP|N but bcavnaugh's
EVGA GeForce RTX 2080 Ti AHowes will take any K|NGP|N but bcavnaugh's GAMING, 11G-P4-2589-KR, 11GB GDDR6, iCX2 & OLED
There fixed that for ya! Lol
#86
  • Ribbons : 282
Re: Candies for RTX 2080 Ti Kingpin 2019/04/25 10:40:17 (permalink)
AHowes
AHowes
I Guess.
#87
kingx11
Re: Candies for RTX 2080 Ti Kingpin 2019/04/25 12:37:22 (permalink)
tresnugget
i'm using it now , i think the older Bios was better for OC , i'll keep trying though maybe i got it wrong but so far getting to 2190 is kinda hard
#88
  • Ribbons : 282
Re: Candies for RTX 2080 Ti Kingpin 2019/04/25 13:17:29 (permalink)
kingx11
tresnugget
Are you also using the Classified Tool?
#89
kingx11
Re: Candies for RTX 2080 Ti Kingpin 2019/04/25 13:38:15 (permalink)
ok
FSU , 9666
https://www.3dmark.com/3dm/35655835?
how good is that ?!
#90
