Acewonnn
Re: Save LED color to card?
Friday, October 26, 2018 4:01 AM
Friday, October 26, 2018 4:35 AM
aboillot
Tuesday, October 30, 2018 10:04 PM
I'm having issues with my card and the colors, I just installed an RTX 2080 FTW3 Ultra, I tried running the MCU update, it said it failed, something about a checksum, but before I got the error, the fans on my card spun up and the white light turned off, and I now have 3 red LEDS above where the power plugs in edit: Here's what my PX1 shows (v0.3.4.0 ) https://gyazo.com/064a9b309396867269bb45dc4e3809fc Edit 2: Fixed my issue. Checked to make sure I had an legit card w/ gpuZ, and I did, then I ran the MCU update w/ the X1 software open, it went, but the x1 software closed.. reopened it, and it applied an LED firmware update and BAM.. my LEDs working again
post edited by aboillot - Tuesday, October 30, 2018 10:22 PM
Asmodeusz
Sunday, November 18, 2018 2:12 PM
aboillot I'm having issues with my card and the colors, I just installed an RTX 2080 FTW3 Ultra, I tried running the MCU update, it said it failed, something about a checksum, but before I got the error, the fans on my card spun up and the white light turned off, and I now have 3 red LEDS above where the power plugs in edit: Here's what my PX1 shows (v0.3.4.0 ) Edit 2: Fixed my issue. Checked to make sure I had an legit card w/ gpuZ, and I did, then I ran the MCU update w/ the X1 software open, it went, but the x1 software closed.. reopened it, and it applied an LED firmware update and BAM.. my LEDs working again
aboillot can you explain more details how your run MCU update on FTW3 Ultra? X1 was open or not?:) Do you used that file - - ? Or different? Can you be so kind and show what files you have in c://ProgramFiles/EVGA/Precision X1/Firmware folder? Thank you for help.
He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you. Friedrich NietzscheCPU: i7 3930 @ 4.2GHz + LC // MOBO: Asrock Extreme 11 X79Ram: 4 x 4GB Corsair Vengeance // GPU: EVGA RTX 2080 FTW3Case: EVGA DG-87 // PSU: Antec HCG-850MSound card: Asus Xonar D2X // Monitor: Philips BDM4065UC
Snegur1
Wednesday, November 28, 2018 6:28 PM
Hello I have a similar problem with LED and fan on my rtx 2080 ftw3 ultra, and I have problems with MCU update, it says that device is not supported.
supremeMilo
Thursday, August 29, 2019 11:22 PM
I am getting the error "proceed to update led firmware, please close all 3D applications" Anyone have an idea how to fix this for a card with the XC Ultra bios on a 2080FE? I get the error from the flashtool/batfile "Hardware device 0x49 firmware version 0x07 does not support flash update." Sorry I didn't buy your card EVGA, I will next time!
post edited by supremeMilo - Thursday, August 29, 2019 11:34 PM
wolfreon
Tuesday, September 03, 2019 11:38 AM
Mine failed to update vga BIOS via precision x1 then LED stopped working. I have EVGA RTX 2080 FTW3.
Tuesday, September 03, 2019 4:20 PM
wolfreon
Tuesday, September 03, 2019 8:41 PM
wolfreon Mine failed to update vga BIOS via precision x1 then LED stopped working. I have EVGA RTX 2080 FTW3.
Sorry but I have this model. Part Number: 08G-P4-2284-KR Part Desc: EVGA GeForce RTX 2080 FTW3 ULTRA HYBRID GAMING That regular FTW3 won't launch.
nezff
Friday, October 11, 2019 2:58 PM
Use my Associates code at checkout and get up to 10% off! 95M1DJFALLX3K3L i7 11700k * Asus ROG Strix z590a WiFi * EVGA 3080 FTW3 Ultra * 32GB Corsair 3200Mhz * Samsung 970 Pro 512GB & 970 Evo Plus 1TB M.2 * Samsung 860 Evo SSD 1TB & 2TB * Lian Li Dynamic white * Corsair QL fans x9 * Corsair H150i Pro XT * Corsair Rm1000x * Samsung G7 Faker 1440p 27"
- Ribbons : 123
Friday, October 11, 2019 3:57 PM
