theplasticbling
Is it possible to save the LED color that I have set in LED sync to the card? Every time I start my PC the LED is blue and waits until the PC boots aand LED Sync starts to apply my settings. Can I have the card save my configuration for when the PC is booting? I have the RTX 2080 XC Ultra.
rv112
Re: Save LED color to card?
2018/10/15 21:25:03
☄ Helpfulby theplasticbling 2018/10/15 22:31:30
theplasticbling
2018/10/16 12:59:12
That's extremely unfortunate. You would think a card of this price would be more capable. Edit: I called EVGA to confirm. Can the developers add the option to flash the LED settings to the GPU bios?
post edited by Hoggle - 2018/10/16 22:52:29
Freegris
2018/10/16 15:02:31
me too, my 2080ti starts every time with blue led! please fix this...
TheParagonHero
2018/10/16 15:07:00
It's funny how two seconds of blue can give people the blues.
ASUS ROG Maximus VII HERO - Intel Core i7 4790k /w Corsair Hydro H10516GB Corsair Vengeance Pro DDR3 2133MHz - EVGA GeForce RTX 2080 Ti XC Black Edition
Acewonnn
2018/10/16 15:13:36
My 2080 XC defaults to green LED every time I restart. I'm running on the latest version of X1. Profiles won't save or load either.
EVGA_JacobF
- Ribbons : 26
2018/10/16 15:15:34
This is not correct, the latest version of PX1 will save the LED to firmware. Can you confirm what version of PX1 you are using? Also please attach a screenshot of Precision if possible.
Freegris
2018/10/16 15:23:02
V0.3.2.0 still starts with blue led.
Acewonnn
2018/10/16 15:23:42
Here is mine...
EVGA_JacobF
- Ribbons : 26
2018/10/16 15:23:57
Which color are you setting it to?
Freegris
2018/10/16 15:25:08
Acewonnn
2018/10/16 15:25:47
I'm setting mine to breathe with red and blue. imgur.com/a/qS74vYr
post edited by Acewonnn - 2018/10/16 15:27:54
theplasticbling
2018/10/16 15:38:43
Can confirm with the users above that no matter what, the card starts in blue RGB mode. I'm also curious as to if the LED Sync settings can be saved into PX1? I'm surprised it's not natively built in. The LED Sync program and LED tab in PX1 are completely different and I'm wondering why EVGA decided to go this route. LED Sync is far superior to the LED tab in PX1 and I can't imagine why Sync doesn't replace the tab and get built into PX1 instead of being sideloaded. Seems inefficient. Edit: I've tried to attach screenshots, but the forum won't let me.
post edited by theplasticbling - 2018/10/16 15:42:12
EVGA_JacobF
- Ribbons : 26
2018/10/16 16:01:53
☄ Helpfulby Cool GTX 2018/10/19 08:20:47
Don't use LED sync for a single graphics card, use the LED control at the top nav.
theplasticbling
2018/10/16 16:23:05
EVGA_JacobF Don't use LED sync for a single graphics card, use the LED control at the top nav.
Even doing this doesn't fix anything. The card still boots with the RGB set to blue, no settings saved. Nothing changes until I open PX1. Also, LED Sync overwrites these settings at boot and displays a prompt for me to allow my computer to run it (it also overwrites PX1 settings every time I open LED Sync). Also, the settings in the LED tab in PX1 are inferior to the settings in LED Sync. I'm very confused as to why EVGA has built the software this way. The "Breathing" setting in the LED tab in PX1 isn't even breathing, it's just fade in and out. It's missing many features that LED Sync provides such as "Rainbow" and "Pulse" to name a few. The settings from either program are not saved to the card itself, either, causing the RGB to display blue when booting.
Frammish
2018/10/16 19:31:00
Jacob, mine is a 2080Ti FTW3 Ultra and I am running X1 0.3.2 beta, and can confirm that at least the temperature-based colors do not get saved. Every time the system boots, the card defaults to steady green.
rommelb671
2018/10/16 22:19:35
same problem, i have single card, doesnt change my rgb, now my led is off i cant turn on the led or change it. what happen???
rv112
2018/10/16 22:52:37
Also the static colors didn't save to BIOS with PX1.
rommelb671
2018/10/17 01:24:42
i just got my gpu and i didnt even know if it is broken... lols. any help???
rommelb671
2018/10/17 01:28:06
im here at led control, and i dont see the little box from lower left. ive seen some videos that they able to change by clicking it. but i dont have that option. just plain and empty
theplasticbling
2018/10/17 22:38:16
Is this going to be fixed and is the breathing mode going to be changed to an actual breathing mode? I'm sending my card out for RMA due to coil whine and want to know whether to sell it or not when I receive my new card.
rommelb671
2018/10/18 01:46:09
@EVGA_JacobF Finally! thanks for help! the link that you send me it works!
rv112
2018/10/18 02:41:03
What with the FTW3 cards?
theplasticbling
2018/10/18 03:06:08
rommelb671 @EVGA_JacobF Finally! thanks for help! the link that you send me it works!
What link? Is there a fix to this?
EVGA_JacobF
- Ribbons : 26
2018/10/18 09:36:12
☼ Best Answerby Sajin 2018/10/19 19:19:51
theplasticbling
2018/10/18 19:21:40
MCU updater does not work. Will not let me do anything. This is the screen it gives me: I cannot open the .HEX file. Edit: AGAIN, this forum will not let me link to/post an image. The image is at this link, just remove all the J's. hJtJtJpJsJ:J/J/JiJmJgJuJrJ.JcJoJmJ/JaJ/JQJNJmJyJ3JcJiJ This is ABSOLUTELY ridiculous that this problem cannot be solved, and that I can't even post an image to this forum. This isn't rocket science. Just about if not every other RTX 2080 card on the market does not have this issue.
post edited by theplasticbling - 2018/10/18 19:26:09
Freegris
2018/10/18 20:09:57
theplasticbling
2018/10/19 01:32:53
Update: PX1 is now crashing on me. When I try to go past Temp Tuner or VF Curve Tuner with the arrows on the bottom, the program hangs and crashes.
EVGA_Lee
Moderator
- Ribbons : 14
2018/10/19 06:15:30
☄ Helpfulby theplasticbling 2018/10/19 16:39:08
theplasticbling MCU updater does not work. Will not let me do anything. This is the screen it gives me:
Linking the pic for you:
2018/10/19 08:05:41
☄ Helpfulby theplasticbling 2018/10/19 16:39:12
Thanks LeeM for fixing the picture @ theplasticbling 1) New members have some limits on their ability to post; based on days & post count The ultimate starter-thread for new membersStep 4 If you followed these steps & it does not post picture or Links --- that is why "its not working"
