AnsweredSave LED color to card?
EVGA_Lee
Moderator
  • Ribbons : 14
Re: Save LED color to card? Friday, October 19, 2018 4:26 PM (permalink)
Thanks LeeM for fixing the picture
@ theplasticbling
1) New members have some limits on their ability to post; based on days & post count
The ultimate starter-thread for new members
Step 4If you followed these steps & it does not post picture or Links --- that is why "its not working"
In this case, I think it has more to do with the direct imgur link won't pull the image.  You can link to the image's page, but not pull it.  I had to open the image in another Window and copy that link for it to show up.
#31
EVGA_JacobF
  • Ribbons : 26
Re: Save LED color to card? Friday, October 19, 2018 4:27 PM (permalink)
theplasticbling
MCU updater does not work. Will not let me do anything. This is the screen it gives me:
I cannot open the .HEX file.
Edit: AGAIN, this forum will not let me link to/post an image. The image is at this link, just remove all the J's. hJtJtJpJsJ:J/J/JiJmJgJuJrJ.JcJoJmJ/JaJ/JQJNJmJyJ3JcJiJ
This is ABSOLUTELY ridiculous that this problem cannot be solved, and that I can't even post an image to this forum. This isn't rocket science. Just about if not every other RTX 2080 card on the market does not have this issue.
Are you running the batch (.bat) file?
#32
Frammish
Re: Save LED color to card? Friday, October 19, 2018 9:41 PM (permalink)
Hey Jacob, I tried flashing my FTW3 with the 2080Ti FTW3 E202 package using the bat file, got an error message, and now it just says this device is not supported, I have little red lights on by the power connectors, and X1 0.3.2.0 thinks it’s a 2080Ti with only two fans.
X1 now crashes if I try to go to the fan curves where before it worked fine. Something went way wrong with the flash.
Could the wrong hex file been packaged? The one I have is 140,583 bytes. Right name though.
post edited by Frammish - Friday, October 19, 2018 9:46 PM
#33
Frammish
Re: Save LED color to card? Friday, October 19, 2018 10:51 PM (permalink)
Hey Jacob - I spoke with tech support and they said you are already on this, but some extra information - my symptoms are a lot like rv112's when X1 buggered his MCU flash when it got installed (https://forums.evga.com/f...newest&m=2867464).
My LED vanity display is off and the center fan is spun up. The outer two can still be controlled by the X1 software. Not sure if that helps, but it does sound kind of similar to rv112's issue that you guys fixed with an MCU update. Which fits since trying to update the MCU is what sent my card south.
Only thing would be if you gave him the same updater that you posted here in which case I’m boned until you guys figure something out. The card still works though at least for the most part. I’m not doing any overclock scans or making any changes though.
#34
EVGA_JacobF
  • Ribbons : 26
Re: Save LED color to card? Friday, October 19, 2018 11:13 PM (permalink)
You have mail Frammish
#35
Frammish
Re: Save LED color to card? Friday, October 19, 2018 11:37 PM (permalink)
Dude! It’s back! My fan curves are back, the solid red color I had programmed is back too. Haven’t tried the temperature colors yet but you are the man! Thank the guys for me! Total respect and hats off to you guys!
#36
theplasticbling
Re: Save LED color to card? Friday, October 19, 2018 11:42 PM (permalink)
EVGA_JacobF
theplasticbling
I was just running the .exe. I tried running the batch file and received this error message:
hJtJtJpJsJ:J/J/JiJmJgJuJrJ.JcJoJmJ/J1JqJcJKJ7JzJg
Now when I run the .exe, I get this error message:
JhJtJtJpJsJ:J/J/JiJmJgJuJrJ.JcJoJmJ/JsJxJmJgJlJNJe
Again, the forum isn't letting me post pictures or link to imgur, so just remove all the J's from those links.
Frammish
Can you repost that link? It just brings me to the EVGA forum in mobile format.
post edited by theplasticbling - Friday, October 19, 2018 11:47 PM
#37
Frammish
Re: Save LED color to card? Friday, October 19, 2018 11:57 PM (permalink)
@theplasticbling - sorry about that. Just look for the thread here in the 20 Series area (same as this thread) titled "RTX2080 FTW3 fans stuck 100% after Precision X1 - FIXED!"
#38
theplasticbling
Re: Save LED color to card? Saturday, October 20, 2018 0:12 PM (permalink)
Frammish
Thanks! New update on my end: PX1 now fails to let me choose LED color at all, and LED Sync doesn't show my card:
hJtJtJpJsJ:J/J/JiJmJgJuJrJ.JcJoJmJ/JpJnJ4JRJ8JcJb
Again, you need to remove all of the J's.
Edit: Also, now I'm getting the "This device is not supported!" error message from both the .bat file and .exe.
#39
Frammish
Re: Save LED color to card? Saturday, October 20, 2018 0:34 PM (permalink)
I got the same thing until Jacob sent the link to the twin flash files. If they think your symptoms are the same, I’m sure they’ll send you the same thing. It takes a reboot toget back to normal afterwards but mine remembered my fan curves and such. Still won’t remember a LED temperature range but it does remember a solid color. Good enough for me.
Good luck!
#40
EVGA_JacobF
  • Ribbons : 26
Re: Save LED color to card? Saturday, October 20, 2018 0:44 PM (permalink)
theplasticbling
Frammish
Which card are you using?
#41
theplasticbling
Re: Save LED color to card? Saturday, October 20, 2018 4:15 AM (permalink)
EVGA_JacobF
theplasticbling
Frammish
I'm using the XC Ultra 2080.
#42
Frammish
Re: Save LED color to card? Saturday, October 20, 2018 12:07 AM (permalink)
If that is available in Ti and regular 2080, you should be more specific. It may matter.
#43
theplasticbling
Re: Save LED color to card? Sunday, October 21, 2018 4:13 AM (permalink)
EVGA_JacobF
theplasticbling
Frammish
Those files that you sent to me through email didn't work either, same device not supported error. I'm not sure what to do. I only have a few more days I can wait until I have to send my card out for RMA and I'm not going to install the new one that I get sent back if we can't get this figured out. I'm tired of this unfinished and broken software.
#44
ROB98374
Re: Save LED color to card? Monday, October 22, 2018 0:52 PM (permalink)
I have the 2080 ti Founders Edition and the 2080 ti XC Ultra.
I ran the Precision X1 program and now my lights went out on the2080 ti XC Ultra. The fans on the EVGA card are not spinning either, but I don't know if that is a new symptom or not.
I tried to run the bat file, but I get the following error....
"Hardware device 0x49 version 0x07 does not support flash update. Please contact the FW team"
I also tried running the firmware update, but I was already current at 90.02.0B.00.E4
Any suggestions on how to get the lights back on? And should the fans be spinning all the time like the Founders Edition does?
Also..
When I start the Precision X1 program, it says..
"Proceed to update LED firmware, please close all 3D applications"
I click OK, and get a "Update OK" message.
I closed everything, but I get that message each time I start the program.
post edited by ROB98374 - Monday, October 22, 2018 1:56 AM
#45
GTXJackBauer
  • Ribbons : 48
Re: Save LED color to card? Monday, October 22, 2018 4:01 AM (permalink)
ROB98374
Also..
Did you restart the PC after you updated or tried updating?
LMD3DNZM9LGK8GJ
#46
ROB98374
Re: Save LED color to card? Monday, October 22, 2018 4:37 AM (permalink) ☄ Helpfulby Cool GTX Sunday, November 18, 2018 8:38 PM
I rebooted many times.
I finally got it fixed thanks to the suggestion from another thread to remove my Founders Edition card before updating.
Here is what I had to do...
I removed the Founders Edition card, but I kept getting a "This device is not supported!" when I ran the .bat file.
The GeForce control panel wouldn't show up, so I tried re-installing the GeForce drivers, but that didn't work.
I finally ended up putting the EVGA card in the first slot, and then I was able to see the GeForce control panel and run the .bat file.
Now I need to shut down and move the EVGA card back to slot 2 and put the FE card back in.
More work than it should have been, hopefully I don't have to do this for every update.
#47
GTXJackBauer
  • Ribbons : 48
Re: Save LED color to card? Monday, October 22, 2018 6:59 AM (permalink)
ROB98374
Glad to hear it all worked out.
LMD3DNZM9LGK8GJ
#48
theplasticbling
Re: Save LED color to card? Monday, October 22, 2018 1:07 PM (permalink)
GTXJackBauer
ROB98374
You'd be sad to hear that nothing has worked out for me! I can't even update my card
On another note, can somebody tell me if the LED color can be saved to the cards BIOS now? Is the breathing setting actually a breathing setting or a fade-in fade-out setting?
#49
Freegris
Re: Save LED color to card? Tuesday, October 23, 2018 11:49 AM (permalink)
MCU updater doesn't work. I didn't understand, is an hardware or software problem? evga support send me the same link to update mcu but nothing change at start! always this (removed) blue led!
edit TOS language removed by Cool GTX
post edited by Cool GTX - Tuesday, October 23, 2018 4:03 PM
#50
  • Ribbons : 282
Re: Save LED color to card? Tuesday, October 23, 2018 3:58 PM (permalink)
Freegris
MCU updater doesn't work. I didn't understand, is an hardware or software problem? evga support send me the same link to update mcu but nothing change at start! always this REMOVED blue led!
Are you Running Version 0.3.3 BETA Release: 10/19/2018?
https://www.evga.com/precisionx1/
#51
Freegris
Re: Save LED color to card? Tuesday, October 23, 2018 6:29 PM (permalink)
All problem about LED color (blue color at start) is fixed with precision x1 3.3! Finally my 2080ti starts with my custom color! Thank you EVGA! I love you.
#52
mrl00001100
Re: Save LED color to card? Thursday, October 25, 2018 10:44 AM (permalink)
EVGA,
I extracted the folder ran the .bat file. I then rebooted the machine. The LED came back on (solid blue) but there is no longer any option to change the color. Also, other functionality within the LED UI is not working properly, or at least it doesn't seem to be working. I included a screenshot. LED breathing only produces blue, then green, then blue; doesn't look like 'breathing'.
Please help, this is kind of annoying.
- Matt
Edit: This is for the EVGA RTX 2080 XC...
post edited by mrl00001100 - Thursday, October 25, 2018 10:46 AM
EVGA_JacobF
  • Ribbons : 26
Re: Save LED color to card? Thursday, October 25, 2018 3:25 PM (permalink)
#54
mrl00001100
Re: Save LED color to card? Thursday, October 25, 2018 7:12 PM (permalink)
@EVGA_JacobF
This worked, thank you. End-user experience salvaged. Build stable with no other issues with my other EVGA products.
- Matt
post edited by mrl00001100 - Thursday, October 25, 2018 7:16 PM
#55
Acewonnn
Re: Save LED color to card? Thursday, October 25, 2018 10:45 PM (permalink)
imgur.com/a/Ki75pkB
I get this when trying to open the MCU updater.
#56
Re: Save LED color to card? Thursday, October 25, 2018 11:14 PM (permalink)
Acewonnn
imgur.com/a/Ki75pkB
Run the .bat file instead of the .exe.
#57
Acewonnn
Re: Save LED color to card? Thursday, October 25, 2018 11:18 PM (permalink)
Ok. I just get a quick cmd prompt and then it disappears. No text on the prompt or anything.
#58
Re: Save LED color to card? Thursday, October 25, 2018 11:21 PM (permalink)
Acewonnn
Extract all three files to a folder then run the .bat file as admin.
#59
magnusfl
Re: Save LED color to card? Thursday, October 25, 2018 11:45 PM (permalink)
What with the FTW3 cards? simple very unavailable at this time but not as totally unavailable as there hybrid 2080ti
#60
