petechka
Re: Not able to update MCU for ti ftw3 to fix 3 red LED and middle fan spinning at 100%
2018/12/23 09:20:52
I used EVGA promoted X1 software latest build 3.10 two weeks ago and it ruined my first FTW3 card. Now with my 2nd FTW3 I don't know how to control it because if I run 3.10 again it may ruin my second card again. So it's not fully fixed in 3.10 and depends on something. So please Jeff what would you recommend? Take chances with X1 again? cjsquirrel Evga has revamped how the firmware writes to the card with much improved error checking since version 3.9 of PX1. They stated it should not cause the updating firmware failure anymore. I have flashed my card without issue using 3.9 and I’m now using 3.10 with no issues. I have the same card as you. I run PX1 every time I game and is stable for me. Hope this helps you.
Z390 itx / i7 8086K @ 5.1 all cores @ 25C idle/60C gaming/ 83C benching RTX 2080 Ti FTW3 @ defaults / EVGA G3 Gold 750W @ Eco On 32GB @ 3200 / single 1TB SATA 2.5 SSD Room @ 68F/20C
2018/12/23 09:59:08
petechka I used EVGA promoted X1 software latest build 3.10 two weeks ago and it ruined my first FTW3 card.
allenruan886
2018/12/26 13:09:33
Any MCU update for XC2 card? I only see the regular XC version. or is it the same?
petechka
2018/12/26 13:18:05
EVGA: Any update on PX1 software? Still can't control fans because may ruin another FTW3... Please say something..
sparetimepc
- Ribbons : 27
2018/12/27 04:44:28
There is a new px1 version 0.3.11 that was just released yesterday the 26th. Also before running the px1 software for the first time if its a new version disable any antivirus software you have installed in case there is an mcu update that may occur, and also right click and run as an administrator the first time if its a new version. Make sure your previous version of led sync and px1 are also uninstalled before the new version attemp.
post edited by dwexpress - 2018/12/27 04:49:53
twatllama
2018/12/30 18:21:02
I now have the same issue upon installing 0.3.11 version (first I have ever downloaded) and rebooting my computer. Initially software worked fine, updated MCU without issue. Then, when I rebooted, I now have fan at 100% speed and no reads or control on fans in PX1. Also, temperature readouts are for GPU1 only. Do I need an RMA because of a software install and mandatory firmware update?
ihcfr
2018/12/30 18:44:21
twatllama I now have the same issue upon installing 0.3.11 version (first I have ever downloaded) and rebooting my computer. Initially software worked fine, updated MCU without issue. Then, when I rebooted, I now have fan at 100% speed and no reads or control on fans in PX1. Also, temperature readouts are for GPU1 only. Do I need an RMA because of a software install and mandatory firmware update?
I also had this random problem. It would appear if I turn off my PC after a period of high usage and turn it on the next day. Everytime it appears I just power off and on my pc couple of times and it goes back to normal.
twatllama
2018/12/30 18:53:56
ihcfr Everytime it appears I just power off and on my pc couple of times and it goes back to normal.
This does not resolve for me. Both hard and soft resets do not change fan speed or software control (10x+ tried).
FCooley
2018/12/31 10:29:57
ihcfr
Do you happen to have your bios set to UEFI boot and PCI Express set to UEFI? My card works fine in my sons PC which is set to legacy but I get the 100% middle fan speed on my system with UEFI boot. I found that cycling normal power on a few times including sometimes holding the button off for 15 seconds can resolve the issue.
CPU: Intel i9-12900K Mainboard: EVGA Z690 Classified GPU: EVGA RTX 3090 FTW3 Ultra RAM: Corsair Vengeance DDR5 - 32GB PSU: EVGA SuperNOVA 1600 T2 OS: Windows 11
scaper28
2019/01/01 17:36:05
Sadly I have this problem too , I have only had my 2080 TI Ultra FTW3 for 3 days , I installed the 3.11 software which updated the card when I had it all went fine no crashes , the machine has been fine for two days of gaming , went to turn the pc on today and the card RGB lights were off and the power lead plugs were all lit up red and the middle fan was stuck on full , at first I thought maybe my pc didnt turn on correctly as when I turned it off and back on it worked ok, Sadly this was not the case as every time I shut the pc down and turn it back on this issue happens, the only way to get it to boot correctly is to turn the power on and off a few times. really annoying as I have only had the card a few days , I have raised a support ticket after coming across the issue on here and knowing I am not alone is good but also worrying as I wonder is there a major fault with these cards and it will just happen at random times.
PC SPECS Be-quiet dark pro 900 v2 Intel I9-9900k Asus XI Extreme Corsair Vengeance RGB Pro Corsair HX1000I Samsung 970 500GB EVO Samsung 960 1TB EVO KingPin RTX 2080TI Hybrid Acer Predator XB271HU EK 360 Extreme X1 EK D5 pump res combo EK-Velocity D-RGB - Nickel + Plexi Ek -Clear premix fluid
zombiesfeelpain
2019/01/02 11:03:31
Same issue here, turning my PC on after inactivity causes it to go into flash mode, a shut down then powering on my PC again the card works flawlessly, has happend on my first FTW3 2080Ti which had major coil whine at idle and now my second FTW3 2080Ti but luckily this one is perfect, just this issue though, curious but what specs do you guys have?
post edited by zombiesfeelpain - 2019/01/02 11:06:54
scaper28
2019/01/02 11:09:33
zombiesfeelpain Same issue here, turning my PC on after inactivity causes it to go into flash mode, a shut down then powering on my PC again the card works flawlessly, has happend on my first FTW3 2080Ti which had major coil whine at idle and now my second FTW3 2080Ti but luckily this one is perfect, just this issue though, curious but what specs do you guys have?
My card is only 3 days old :-( my specs Asus Maximus Hero X non Wi-Fi latest Bios 1801 I7 8700k Corsair HX750I PSU 16 GB Corsair Vengeance RGB 2993 mem 2 x 4GB Samsung 970 Evo 500gb Boot Samsung 960 Evo 1Tb Games WD Sata Drive 1TB Data windows 10 pro 1809 all updates installed. software running Bitdefender antivirus corsair Icue Asus AI Suite 3 Steam Discord Nvidia Experience
post edited by scaper28 - 2019/01/02 12:02:04
zombiesfeelpain
2019/01/02 11:17:27
scaper28
My card is only 3 days old :-( my specs Asus Maximus Hero X latest Bios 1801 I78700k Corsair HX750I PSU 16 GB Corsair Vengeance RGB 2993 mem
Well the only similar thing is we have Asus boards, there is another guy with the exact same issue, he also has a Asus Crosshair VII Hero non WIFI model though. Ryzen 2700x Asus Crosshair VII Hero Wifi Newest Bios 1103 2x8GB Corsair RGB Vengeance Pro 3600 Samsung 960 Pro 512GB Samsung 860 Evo 500GB Crucial MX100 256GB Seagate Firecuda 2TB EVGA 850W P2 Windows 10
scaper28
2019/01/02 11:23:55
zombiesfeelpain
scaper28
I have tried playing with bios settings but nothing helped and odd why only happened after 2 days , my board is the non wifi I forgot the HDD Samsung 970 evo 500gb Boot Samsung 960 Evo 1Tb Data windows 10 pro 1809 all updates installed. bitdefender anti virus
ihcfr
2019/01/02 12:04:34
zombiesfeelpain
scaper28
Woah we might be onto something here. I also have 2700X and Asus CH7 board. So it might be related to compatibility with asus mobos.
post edited by ihcfr - 2019/01/02 12:07:44
scaper28
2019/01/02 12:06:05
ihcfr
zombiesfeelpain
scaper28
Woah we might be onto something here. I also have 2700X and Asus C7H board. So it might be related to compatibility with asus mobos.
Yes I am wondering the same , I would like to know if someone with the new Asus Z390 chipset motherboards still have the same issue .
post edited by scaper28 - 2019/01/02 12:28:11
zombiesfeelpain
2019/01/02 12:37:31
I'm gonna try my brothers MSI B350 Tomahawk Arctic board later, he uses a R5 1600 a different PSU, but I can't imagine the PSU being the issue since it does his system fine and did my previous 1080Ti fine too.
scaper28
2019/01/02 12:39:40
zombiesfeelpain I'm gonna try my brothers MSI B350 Tomahawk Arctic board later, he uses a R5 1600 a different PSU, but I can't imagine the PSU being the issue since it does his system fine and did my previous 1080Ti fine too.
I would be interested to know how you get on with the MSI MB , I don't think its a PSU issue . my 1080TI ASus strix oc was fine never had an issue .
scaper28
2019/01/03 10:31:17
UPDATE . I have just tried my video card in my sons I7700 pc he has a msi gaming mother board , I couldn't get my card to fail once , I must of turned the pc on and off 30 times and tried all sorts, put the video card back in my machine , boot up then shut down and turn on and bang instantly failed. I am now 99% sure the card is fine and its an issue with Asus motherboards. If anyone else can try similar please report back. Thanks everyone :-)
cgarcia0458
2019/01/03 12:47:31
Just chiming in here. I am on my second card and am still having issues. I also have an Asus motherboard. Maximus X Apex Z370. This is a major issue.
scaper28
2019/01/03 12:50:23
cgarcia0458 Just chiming in here. I am on my second card and am still having issues. I also have an Asus motherboard. Maximus X Apex Z370. This is a major issue.
Try your card in a non asus board , like msi and I bet your card will be fine :-)
cgarcia0458
2019/01/03 13:07:31
Unfortunately, I don't have another motherboard
scaper28
2019/01/03 13:17:16
cgarcia0458 Unfortunately, I don't have another motherboard
Well guys I think I have fixed the issue with Asus boards, I have flashed back 3 revisions of firmware , the last one before updated to support the new I9 cpus and I haven't been able to make my card fail :-) I have only spent like 24 hours solid trying multiple things lol
post edited by scaper28 - 2019/01/03 15:22:52
zombiesfeelpain
2019/01/03 15:25:48
So I tried it on my brothers MSI B350 Tomahawk Arctic board and it was perfect, couldn't get it to go into flash mode at boot, even after leaving my system off for 9 hours which would have booted it into flash mode on my Asus board 100% and how did you flash back your firmware Scaper28?
scaper28
2019/01/03 15:32:00
zombiesfeelpain So I tried it on my brothers MSI B350 Tomahawk Arctic board and it was perfect, couldn't get it to go into flash mode at boot, even after leaving my system off for 9 hours which would have booted it into flash mode on my Asus board 100% and how did you flash back your firmware Scaper28?
Brilliant and thank you for letting me know :-) this bug has been driving me crazy and I didn't want to have to send my card off as its days old . its 100% an asus bios issue , I have turned on and off 30 plus times to be sure before posting and I cant get it to fail. before it would do it instantly after shutting down then turning the pc back on . I went to asus download centre and tried each one until I found this one that worked , I think its 3 revisions backwards, for me it was the one that doesn't support 9th gen , id love to know what is causing it but hopefully asus will fix it and produce a new bios for this . download the bios from there website for your model board then rename the file ,each mb different name my was M10H.CAP , format a usb stick to fat32 then copy the file onto it , put in the bios usb port on the back of pc and then press and hold the bios flashback button until it flashes , then wait for it to upload once the blue light stops flashing turn your pc back on and setup bios to your personal settings , ie overclock etc. then hopefully like me job done :-) ofcourse I am going by my maximus hero x , I have no idea on the other model asus boards I can help you look into it if you would like to try now ? UPDATE spoke to soon , after gaming for an hour I thought I would do one more power off and try again and now its doing it again non stop , I'm still sure its a bios issue but will keep testing and report back ,
post edited by scaper28 - 2019/01/03 17:25:08
cgarcia0458
2019/01/04 07:20:13
Would it theoretically be possible to disconnect the middle fan and run the card as is? My card is showing up and although i cant control the middle fan, I can control the other 2 just fine. Im managing to get 9172 on Firestrike Ultra and 12991 on Superposition with +115 on the clock and +950 on the memory. Any input on these results?
FCooley
2019/01/04 12:10:15
I tried to do this and those connectors are on really tight. I was afraid I was going to break the wires so I stopped.
scaper28
2019/01/04 12:12:18
cgarcia0458 Would it theoretically be possible to disconnect the middle fan and run the card as is? My card is showing up and although i cant control the middle fan, I can control the other 2 just fine. Im managing to get 9172 on Firestrike Ultra and 12991 on Superposition with +115 on the clock and +950 on the memory. Any input on these results?
what motherboards are you using ? maybe we should get a list of all the motherboards with this issue , to prove if bios or the evga card bios
FCooley
2019/01/04 12:12:26
I have the same issue but can sometimes get it to go away with the power off/power on technique. I did put my FTW3 in my son's PC and it works fine. I have my bios set to UEFI and he is legacy. His mainboard is an EVGA X79 dark and mine is an X99FTW K. I did replace my power supply which did not help at all.
scaper28
2019/01/04 12:13:37
FCooley I have the same issue but can sometimes get it to go away with the power off/power on technique. I did put my FTW3 in my son's PC and it works fine. I have my bios set to UEFI and he is legacy. His mainboard is an EVGA X79 dark and mine is an X99FTW K. I did replace my power supply which did not help at all.
I have found it was fine in a msi board, going to try a gigabyte one tomorrow and report back
