Helpful ReplyHot!EVGA SC17 Spares i.e. Power Supply, Battery, Fans, etc. Availability and Where to buy them
Epsilon748
Re: EVGA SC17 Spares i.e. Power Supply, Battery, Fans, etc. Availability and Where to buy 2018/05/22 15:31:21 (permalink)
Is there anywhere I can get a 300w power supply for the SC17 1080? The 240 is going to be underpowered but it's the only one in the store right now. I sent a message to CS asking for one.
#31
xvga1
Re: EVGA SC17 Spares i.e. Power Supply, Battery, Fans, etc. Availability and Where to buy 2018/05/23 06:19:58 (permalink)
Epsilon748
From what i have read, your laptop charger has 19.5V DC output. You are lucky, as many laptops use that. You should get a Dell 330W Delta Power Adapter. Check ebay as OEM 330W Dell chargers are selling for 50$. Search for 'OEM Y90RR' without quotes on ebay.
post edited by xvga1 - 2018/05/23 06:22:20
#32
saccaed
Re: EVGA SC17 Spares i.e. Power Supply, Battery, Fans, etc. Availability and Where to buy 2018/05/25 12:16:57 (permalink)
Don't like the title of the thread, but have liked all the links. Have a second psu on order now after the store got more in stock.
#33
codyst
Re: EVGA SC17 Spares i.e. Power Supply, Battery, Fans, etc. Availability and Where to buy 2018/05/25 18:31:22 (permalink)
I like that I can buy a backup PSU if needed but having a second battery to carry around with you is a bit absurd for the SC15. After having taken it apart to swap out the HDD with an SSD, you're not going to break down the laptop out in the field.
#34
vistarshook
Re: EVGA SC17 Spares i.e. Power Supply, Battery, Fans, etc. Availability and Where to buy 2018/05/25 19:59:21 (permalink)
deleted...typed from my phone full of grammar/spelling errors. Sorry.
post edited by vistarshook - 2018/07/23 12:24:26
EVGA SC17 4K G-SYNC | i7-7820HK | GTX 1080 | 32GB DDR4 3200MHz | Samsung 960 Pro 2TB + 2TB Micron 1100| Firestrike | CB15@4.9GHz
Razer Blade 14 FHD | i7-6700HQ | GTX 1060 | 16GB DDR4 2400MHz | Samsung SM961 1TB | Firestrike
#35
xvga1
Re: EVGA SC17 Spares i.e. Power Supply, Battery, Fans, etc. Availability and Where to buy 2018/06/30 05:46:17 (permalink)
Still no word from EVGA about selling spare batteries.
#36
Epsilon748
Re: EVGA SC17 Spares i.e. Power Supply, Battery, Fans, etc. Availability and Where to buy 2018/07/19 20:55:01 (permalink)
xvga1
Epsilon748
 Ha, I should have checked back here sooner - I'm pretty sure you're correct. I've got the Dell 330w LA330PM160 laying around for a small form factor PC build and whaddya know, it's the same plug and voltage. 19.5v and same DC barrel jack. It's even 16.9A versus 15.4A since it's 30W extra power. This might even give me some overclocking room.
#37
vistarshook
Re: EVGA SC17 Spares i.e. Power Supply, Battery, Fans, etc. Availability and Where to buy 2018/07/23 12:21:46 (permalink)
Besides battery replacement, I am also concerned for fan replacement in the future, which is a part that sometimes needs replacement after a few years.
#38
ajiyengar
Re: EVGA SC17 Spares i.e. Power Supply, Battery, Fans, etc. Availability and Where to buy 2018/08/01 22:41:02 (permalink)
FWIW, for a small volume company, I have been very happy with EVGA support - particularly pushing out BIOS updates for Spectre, Display glitch, etc. and actively listening to customer feedback for selling the PSU accessory.
#39
  • Ribbons : 123
Re: EVGA SC17 Spares i.e. Power Supply, Battery, Fans, etc. Availability and Where to buy 2018/08/02 09:21:42 (permalink)
OP has edited the title,
temp lock while I update the thread
Title of all posts have been updated to reflect the Op's new title
Unlocking
post edited by Cool GTX - 2018/08/02 09:38:26
#40
xvga1
Re: EVGA SC17 Spares i.e. Power Supply, Battery, Fans, etc. Availability and Where to buy 2018/08/24 05:52:41 (permalink)
Still no word on batteries from EVGA. To make things worse, Laptop Battery continues to discharge despite shutdown properly, and EVGA has failed to resolve it. This has been replicated by several users in the concerned thread. Heading towards a disgusting Experience!
#41
Mayora13
Re: EVGA SC17 Spares i.e. Power Supply, Battery, Fans, etc. Availability and Where to buy 2018/08/30 23:25:51 (permalink)
So how can someone in Asia buy the battery? All the way from US?
That would be pretty expensive and takes a long time..
#42
Bonecrusher52
Re: EVGA SC17 Spares i.e. Power Supply, Battery, Fans, etc. Availability and Where to buy 2018/09/26 06:19:25 (permalink)
xvga1
Please find a solution, tech support. I find it extremely disconcerting to discover a three-year-old issue (continuous battery discharge during shutdown) haven't been fixed by now.
#43
  • Ribbons : 271
Re: EVGA SC17 Spares i.e. Power Supply, Battery, Fans, etc. Availability and Where to buy 2018/09/26 07:23:02 (permalink)
Bonecrusher52
I don't think it can be fixed. I don't think it will ever be fixed. It is a hardware design issue which cannot be revised. There are voltage regulators which never turn off, which slowly drain the battery.
You should install one of those racing-style battery shutoff switches onto the bottom of your laptop. Lol.
post edited by ty_ger07 - 2018/09/26 07:25:05
#44
Bonecrusher52
Re: EVGA SC17 Spares i.e. Power Supply, Battery, Fans, etc. Availability and Where to buy 2018/09/26 07:39:00 (permalink)
Bonecrusher52
I hope not...  Does anybody know if EVGA laptop (SC15) can be powered on only by AC adapter, without battery?
#45
  • Ribbons : 271
Re: EVGA SC17 Spares i.e. Power Supply, Battery, Fans, etc. Availability and Where to buy 2018/09/26 08:55:16 (permalink)
Bonecrusher52
Bonecrusher52
You hope not? Sorry, but it is true.
Regarding your question, unplug the battery connector and find out. It should.
#46
Spirery1070
Re: EVGA SC17 Spares i.e. Power Supply, Battery, Fans, etc. Availability and Where to buy 2018/09/26 13:35:34 (permalink)
Power Adapter is not listed on the eu site are they going to be also?
post edited by Spirery1070 - 2018/09/26 13:38:27
EVGA SC17 4K i7 GTX 1070 GSYNC
#47
Spirery1070
Re: EVGA SC17 Spares i.e. Power Supply, Battery, Fans, etc. Availability and Where to buy 2018/09/29 00:56:20 (permalink)
I got mail back from EVGA they are not going to be available in the uk but if they break they will be replaced just wanted a spare power adapter and battery.
PS i did try and order the power adapter but EVGA wont ship it to the uk cant understand why its not in the EU store or ship to the uk i dont mind paying shipping.
post edited by Spirery1070 - 2018/10/01 02:37:05
#48
Mayora13
Re: EVGA SC17 Spares i.e. Power Supply, Battery, Fans, etc. Availability and Where to buy 2018/10/07 19:57:43 (permalink)
Sooo.. Why do you all expect the adapter to die anytime after the 2 years?
My Old Toshiba Qosmio (2011) adapter still works fine until this day (only changed the battery once in all these years).
Is EVGA's adapter quality bad?
Won't we be able to buy them once the warranty is over?
#49
  • Ribbons : 271
Re: EVGA SC17 Spares i.e. Power Supply, Battery, Fans, etc. Availability and Where to buy 2018/10/08 16:23:18 (permalink)
Mayora13
There was a high fail rate of SC17 power supplies at one period of time. Some people had 2 or 3 fail in a row within 6 months. I think EVGA got the problem taken care of and they are reliable now.
Another concern is the batteries since the SC15 and SC17 drains the batteries within a week while the laptop is unplugged and turned off. Lithium ion batteries are chemically less stable when fully charged or fully drained. Since the laptop drains the batteries within a week, storing it for extended periods of time in that state is likely to decrease the battery's life.
post edited by ty_ger07 - 2018/10/08 19:22:00
#50
Mayora13
Re: EVGA SC17 Spares i.e. Power Supply, Battery, Fans, etc. Availability and Where to buy 2018/10/08 23:42:18 (permalink)
Thanks, good to know that its solved (hopefully).
Now just the battery problem, because it will eventually die.
#51
xvga1
Re: EVGA SC17 Spares i.e. Power Supply, Battery, Fans, etc. Availability and Where to buy 2018/11/15 05:42:59 (permalink)
Looks like motherboard is available as spare, from aliexpress:
https://www.aliexpress.co...-N17E/32842574301.html
#52
xvga1
Re: EVGA SC17 Spares i.e. Power Supply, Battery, Fans, etc. Availability and Where to buy 2019/01/08 09:26:03 (permalink)
Still no word on batteries.
#53
vistarshook
Re: EVGA SC17 Spares i.e. Power Supply, Battery, Fans, etc. Availability and Where to buy 2019/01/08 11:18:56 (permalink)
It is clear now that EVGA opted to leave the notebook segment, so consider the SC17 and SC15 as an experiment.  They already said that they will support the laptop for the warranty period and then after that good luck.
#54
Spirery1070
Re: EVGA SC17 Spares i.e. Power Supply, Battery, Fans, etc. Availability and Where to buy 2019/01/08 22:41:11 (permalink)
Can’t get any in the uk store only in the us
#55
xvga1
Re: EVGA SC17 Spares i.e. Power Supply, Battery, Fans, etc. Availability and Where to buy 2019/02/09 09:26:39 (permalink)
Spirery1070
Try freight forwarding, or get dell power supply
#56
ruslanguns
Re: EVGA SC17 Spares i.e. Power Supply, Battery, Fans, etc. Availability and Where to buy 2024/04/27 10:27:12 (permalink)
i know it's been a while since I bought this laptop but I wish I can fix some spare pieces... so does any one knows about any place to buy spare pieces in 2024? I only need the speakers and a good batery (or instead a compatible solution, since the original it's really bad)? Just want to continue using it but without it, is just a big paper holder.
#57
