BennyJoy
Hi, I'm trying to start up Precision X1 and I keep getting a message saying "proceed to update led firmware, please close all 3D applications" and I don't know what to do. I have a lot of apps that's that run at start up like steel series engine, Razer Chroma, CAM, Corsair link, Express VPN, could it be those applications?
EVGA_JacobF
- Ribbons : 26
Re: EVGA Precision X1 "proceed to update led firmware, please close all 3D applications" H
2018/09/21 10:45:13
This is fixed in version 0.2.6
- Ribbons : 123
2018/09/21 11:01:41
Moving to EVGA Software section
rommelb671
2018/10/17 01:44:56
still not fixed, i have same problem.. anyone can help?
coolmistry
- Ribbons : 45
2018/10/17 02:21:42
rommelb671 still not fixed, i have same problem.. anyone can help?
Have you try latest Version > EVGA Precision X1 - 0.3.2 BETA RTX OnlyRelease: 10/12/2018 - Profile will now be highlighted when set (Use right mouse button to delete profile)
- OC Scan and Test results are saved to profiles
Windows 11 Home 64bits up to Dated i9 11900K 5,275 MHz (3,500 MHz) || EVGA Z590 FTW WIFI || 2 x Nvidia RTX 2080 Ti FE || 32Gb Dominator Platinum DDR3 3600mhz XMP OC 3800mhz || 500gb Samsung 980 Pro NVMe || 500gb Samsung 970 EVO and Sata M.2 (1 x SSD and 1xHHD) || EVGA CLCx 360 Cooler || EVGA Supernova 1300w X3 || EVGA Z10 Keyboard || EVGA TORQ X10 mouse ||EVGA DG 77 case || Acer Predator X35 35" 200Hz G-Sync || Logitech Z906 5.1 system sounds SPDIF|| Kaspersky Internet Security
rommelb671
2018/10/17 08:40:28
coolmistry
Have you try latest Version > RTX Only Release: 10/12/2018
yes i did download that, i dont have the rgb box on lower left to click and choose the colors.
rommelb671
2018/10/17 08:43:08
gave me this message after i did install the software "proceed to update led firmware, please close all 3D applications"
coolmistry
- Ribbons : 45
2018/10/17 08:48:51
rommelb671 gave me this message after i did install the software "proceed to update led firmware, please close all 3D applications"
You need to close all 3D applications that mean you have some programs are still running which PX1 cannot install to complete so you need to close 3D application before install PX1
herman285
2018/10/25 17:30:08
coolmistry
I have the same problem. I uninstall precision and led sync and reinstall precision but still have this problem. I close every application I can close, so nothing is open. Someone helpppp.
NeedForspeed73
2018/10/28 06:38:22
Same problem here and it's very annoying to have that message popping up every time I start Windows. I'm very happy of my new EVGA RTX 2080 XC but Precision X1 looks in really early beta stage. Guess I'm gonna use some other company software to control the card.
EVGA_JacobF
- Ribbons : 26
2018/10/29 12:02:56
If you are continuing to have this problem please install version 0.3.4 released today.
Xandalis
2018/10/29 13:29:40
EVGA_JacobF If you are continuing to have this problem please install version 0.3.4 released today.
Just joined the show on this... 0.3.4 isn't working as intended either. Same problems as others above.
AimAtTheHead
2018/10/29 22:19:53
Ya this still doesn't work. What application does it want me to close when I have nothing opened? And yes i've checked multiple times to make sure nothing is opened.
psynumb
2018/11/01 15:48:33
So, the first time I installed EVGA Precision X1 and tried to change LED color, I ended up with LED turned off completely ever since. I uninstalled and reinstalled it multiple time (including the latest version). It gives me the "Proceed to update the LED firmware...." message and when I click start it tells me "Firmware update failed". I have the RTX 2080 XC. Please Help!!
2018/11/01 16:39:26
psynumb So, the first time I installed EVGA Precision X1 and tried to change LED color, I ended up with LED turned off completely ever since. I uninstalled and reinstalled it multiple time (including the latest version). It gives me the "Proceed to update the LED firmware...." message and when I click start it tells me "Firmware update failed". I have the RTX 2080 XC. Please Help!!
https://forums.evga.com/FindPost/2869911
psynumb
2018/11/03 02:34:18
Thank you, it worked :)
2018/11/03 14:02:29
lifeboat
2018/11/10 10:52:20
If the LED is not saving to the card, you may need an MCU update. Please see below for the updates: Instructions = Extract and run .bat file2080 XC = 2080 XC ULTRA = 2080 FTW3 = 2080 Ti XC = 2080 Ti XC ULTRA = 2080 Ti FTW3 = I found this info elsewhere on forums.evga.com and it worked!
- Ribbons : 123
2018/11/10 12:16:42
lifeboat
Instructions = Extract and run .bat file 2080 XC = 2080 XC ULTRA = 2080 FTW3 =
The link for these updates was in post #16 above your post .... as a new member you can not post links Sajin https://forums.evga.com/FindPost/2869911
