davidvm97
I just boght a new 3090 FTW3 ULTRA and in EVGA's product page and everywhere else it says that the TDP is 350W () But when I use it and benchmark it, at a 100% its pulling around 420W.
post edited by davidvm97 - 2022/01/15 11:05:37
nomoss
- Ribbons : 7
Re: Why is my 3090 FTW3 ULTRA pulling more power than the advertised TDP?
2022/01/15 11:05:16
Do you have the switch set on OC?
davidvm97
2022/01/15 11:08:35
nomoss
- Ribbons : 7
2022/01/15 11:18:44
☼ Best Answerby davidvm97 2022/01/15 11:26:25
Well it's the FTW3 so it might just be the factory boost needs that power. All the cards say 350w TDP on spec, even the Kingpin! If you need to limit the power draw, you can downclock it in PX1 or Afterburner.
davidvm97
2022/01/15 11:20:18
Ok thanks, and what does that OC switch do? I normally overclock on Afterburner.
nomoss
- Ribbons : 7
2022/01/15 11:24:55
☄ Helpfulby davidvm97 2022/01/15 11:26:02
bavor
- Ribbons : 6
2022/01/15 11:40:44
davidvm97 I just boght a new 3090 FTW3 ULTRA and in EVGA's product page and everywhere else it says that the TDP is 350W () But when I use it and benchmark it, at a 100% its pulling around 420W.
350 watts is the default TDP of RTX 3090 cards according to Nvidia. However, the 3090 FTW3 can pull 450 watts witht he standard OC BIOS and 500 watts with the XOC BIOS. Its deigned to do this to give you better performance than the founder's edition/reference design cards.
god503
2022/01/18 06:08:19
Mine pulls 650 watts on the 1k bios so don't worry. The card can more than handle it
nomoss
- Ribbons : 7
2022/01/18 06:54:25
god503 Mine pulls 650 watts on the 1k bios so don't worry. The card can more than handle it
Custom loop?
god503
2022/01/18 06:58:17
Yes. With the optimus cooler
- Ribbons : 270
2022/01/18 07:49:48
RIP The VRM are not long for this world.
god503
2022/01/18 08:03:28
Over year and still going..... the optimus block is a beast
2022/01/18 09:40:34
Ftw3 pulling 650 watts? You hard modding along with the vbios flash?
god503
2022/01/18 10:01:06
No. Just the vbios. The card won't use more than 650 with out modding the voltage past 1.1.
The only time it ever hits that high is on time spy extreme. I haven't had a game hit that max yet.
2022/01/18 10:22:31
That is interesting because I had to use above 1.1mv to pull 600+ watts on my 3090 kingpin in tse.
god503
2022/01/18 10:49:03
I only see it when I over clock. +160 and +1000. That's stable for me. I can do port royal with +200 but every else crashes. Also I got my card in October 2020 red lips
god503
2022/01/18 10:51:28
Funny part is rebar did nothing for me when I run with these settings. And I did confirm with gpuz that it was enabled
god503
2022/01/18 10:57:05
I have said this before on the forums when these cards first came out and everyone was crying about power balance on plugs and the power draw on the slot.... THE AIR COOLER ON THEM CANT CANDLE THESE CARDS. Once I put on the optimus cooler it became a different card. The trick in my opinion is that the optimus has a FULL fuji thermal pad across the WHOLE back plate. Sucks the heat out of the card and mem chips. My temps are in the upper 40s for the gpu and 60s for memory.
god503
2022/01/18 10:59:22
When I first got the card I notice that the gpu was throttling in the 60s on air. And I have a big case. The Thermaltake coffin.
kevinc313
- Ribbons : 22
2022/01/18 18:00:24
How can there be 19 posts but no direct answer to this question? Both the normal and OC bios on the 3090 FTW3 Ultra have a 420W 100% power limit, right out of the box. 350W is the nominal 3090 TDP and is used on the FE and Reference design cards as the 100% power limit. The custom AIB cards typically have a higher 100% power limit. Easiest way to confirm this is by checking the bios limits in GPU-Z, under the advanced tab pulldown.
post edited by kevinc313 - 2022/01/18 18:16:57
