Hot!GeForce RTX 3070 Ti FTW3 Ultra Gaming Water Block
flyboy126
Saturday, January 18, 2025 0:02 PM (permalink)
I have found a good price on GeForce RTX 3070 Ti FTW3 Ultra Gaming (08g-p5-3797-bh) I am only interested if I can get a water block for it. The EKWB block is specified for (08g-p5-3797-kl). My question is there a physical difference between the 2 cards that will not allow that block to work? I know there are some performance differences but not sure about the hardware.
3 Replies Related Threads
    tattude69
    • Ribbons : 7
    Re: GeForce RTX 3070 Ti FTW3 Ultra Gaming Water Block Saturday, January 18, 2025 3:36 PM (permalink)
    you would want to get pictures' of both gpu boards and compare them for any difference. Contact Ek customer support and ask if their waterblock would work with GPU that you are purchasing. I can tell you that a 3070 waterblock  will not fit the 3070 ti card without modification. I could not find any actual info on the part number you provided most gpu's end in KL,KR, and RX. I am guessing BH is for a different country or made for a particular vendor Regardless if you go to mount a waterblock, you have to test fit and make sure the block only makes contact with thermal pads and gpu die. When the EK FTW 3070 waterblock was released it was listed to fit both the 3070 and 3070ti but after customers had problems they released a block for the 3070 ti FTW due to a change in board design. Some shops Like ModMYMods will install a waterblock for a fee As an owner of a 3070 ti i recommend a gpu with more Vram. The 3070 ti FTW was the most expensive card i ever purchased and the biggest disappointment. Good Luck
    post edited by tattude69 - Saturday, January 18, 2025 3:41 PM
    • Ribbons : 123
    Re: GeForce RTX 3070 Ti FTW3 Ultra Gaming Water Block Saturday, January 18, 2025 5:56 PM (permalink)
    Welcome to the EVGA Forum & congrats on your first thread & post
    I did a search = RTX 3070 Ti FTW3 Ultra Gaming "08g-p5-3797-bh"      ("" works better than () sometimes)
    You can email EVGA support & ask if the two GPUs are of identical construction    Support@EVGA.com
    This is the email for the Main office in North America (on the West Coast), so if you are in a different part of the world it may take more time to get a reply due to the time zone differences
    flyboy126
    Re: GeForce RTX 3070 Ti FTW3 Ultra Gaming Water Block Sunday, January 26, 2025 8:47 PM (permalink)
    Thank you guys for all the info. Quick cost benefit analysis seems like this isn't worth pursuing right now.
