dc8flyer
- Ribbons : 7
2009 Alienware Aurora x58 i7 990x oc to 4.14 Three ASUS ROG PG278Q Black 27" WQHD 2560 x 1440 - 144 Hz 1ms (GTG) NVIDIA G-Sync Gaming Monitors RTX 2080ti EVGA Black XC oc 1250/160 with 456.55 CORSAIR Vengeance 24GB (6 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 memory 2TB 860evo SSD Corsair Hydro Series H80i V2 Water/Liquid CPU Cooler Two 120mm push/pull NF-F12 iPPC-3000 PWM Fan with Focused Flow Windows 10 - always the latest
boylerya
Re: Water Cooling is Dead
2019/12/20 00:06:43
If only they would finally release this product.
random_matt
2019/12/20 00:24:09
Corsair 5000D Airflow | EVGA 1000 G6 | EVGA X570 FTW | Ryzen 5800X | EVGA 360 CLC | Corsair 4000MHz 32GB| Corsair MP600 2TB | EVGA 3080 Ti FTW Hybrid | Alienware AW2721D | Windows 11
Xavier Zepherious
- Ribbons : 16
2019/12/20 00:30:50
um why??? why would i want a cooling solution that covers 1/2 the motherboard - covers up the dimms so you basically have to take the block off to do anything with the ram let alone cover up RGB DIMMS so you can't see them??? WTH look if you want standard parts like dimms then you can use standard cooling...duh! if you want better cooling a custom loop will blow that away https://www.tomshardware.com/reviews/icegiant-prototype-thermosiphon-cooler The IceGiant ProSiphon Elite prototype model we received is so large, it nearly dwarfs the rest of our AMD Threadripper hardware, while the memory DIMMs are nearly obscured beneath the cooling tech. For perspective, the image above isn't the cooler towering atop a compact motherboard. The cooler here sitting atop our 32-core 2990WX and E-ATX Gigabyte X399 Aorus XTreme motherboard. So it dominates even the largest motherboards you can buy.
post edited by Xavier Zepherious - 2019/12/20 00:35:04
random_matt
2019/12/20 02:32:38
Xavier Zepherious um why???
The finished product will be a lot thinner.
- Ribbons : 84
2019/12/20 03:34:21
I would like to see the finished product and independent reviews.
Hoggle
2019/12/20 03:44:19
I agree I would want to see the finished product. Second I heard that the final product was going to be 1/3rd the size I didn't need to see numbers from Linus since it's not a product we will be using. It's like if we saw numbers for the CLC-360 and are told it's why we should buy a CLC-120 to cool our system. It's just not the same then again the CLC-120 isn't a bad product.
GTXJackBauer
- Ribbons : 48
2019/12/20 04:11:07
Bobmitch
- Ribbons : 47
2019/12/20 04:53:04
The thing is massive! Having that hanging there doesn't give me a secure feeling...
MSI MAG X670-E Tomahawk; Ryzen 7 7800X3D; Asus TUF RTX 4070 TI OC; Seasonic Vertex GX-1000 PSU; 32 GB Corsair Vengeance DDR5-6000 CL30 RGB; Corsair iCue Link H150i LCD 360MM AIO; 2-Western Digital Black 4 TB SN850X NVMe; Creative SoundBlaster Z; Lian Li Lancool III; EVGA Z15 Keyboard; Razer Viper 8K Mouse Heatware: http://www.heatware.com/eval.php?id=72402 Affiliate code: 1L2RV0BNQ6 Associate Code: UD82LJP3Y1FIQPR
kelkel1
2019/12/20 06:07:51
If water cooling is dead, where are the head-to-head comparisons?
Brad_Hawthorne
- Ribbons : 39
2019/12/20 06:40:10
Accessibility is crap. That hanging on the mobo and putting uneven pressure on the socket and CPU is crap. I don't want to mount a brick sideways to my CPU socket.
castrator86
2019/12/20 12:10:21
Not only is the IceGiant voluminous, it also weighs in at a hefty 4.85lbs
That's a NO from me dawg. Maybe if they designed it to mount directly to the case for stability it'd have a chance. But putting all that pressure on the board/socket is not going to end well if the thing falls over or gets set down too hard.
post edited by castrator86 - 2019/12/20 12:14:18
RainStryke
The Advocate
- Ribbons : 60
2019/12/20 12:30:23
I watched that video when it first came out... Total click bait IMO. They claim the finished product will only be 30% of that size, with no loss in performance. Felt more like a pre-order sales pitch. Linus was trying his hardest to make it not sound like one.
Main PC | Secondary PC Intel i9 10900K | Intel i7 9700KMSI MEG Z490 ACE | Gigabyte Aorus Z390 MasterASUS TUF RTX 3090 | NVIDIA RTX 2070 Super32GB G.Skill Trident Z Royal 4000MHz CL18 | 32GB G.Skill Trident Z RGB 4266MHz CL17SuperFlower Platinum SE 1200w | Seasonic X-1250Samsung EVO 970 1TB and Crucial P5 1TB | Intel 760p 1TB and Crucial MX100 512GBCougar Vortex CF-V12HPB x9 | Cougar Vortex CF-V12SPB-RGB x5 3DMark Results:Time Spy|Port Royal
- Ribbons : 270
2019/12/20 12:53:40
2019/12/20 12:55:42
and its not even 01 April good luck getting the side cover on your case
CraptacularOne
- Ribbons : 222
2019/12/20 14:29:25
The tech does have solid theory and principle behind it, however it won't compete with high end custom loops in performance. It will be a suitable substitute for an AIO if they can get the size down to their claimed dimensions when it's ready. However as pointed out above it will inherently have accessibility issues because of it's size even when scaled back.
flyinion
- Ribbons : 8
2019/12/20 14:45:36
castrator86
Same, I finally went to watercooling on my recent build after using a D14 since 2010. I wanted to get away from needing big bulky coolers hanging off my motherboard and causing clearance issues whenever I wanted to run better than basic RAM (i.e. something with decent heatspreaders etc.). I guess it could be worse. I remember "back in the day" when copper and copper/aluminum hybrid heatsinks first started coming out. They still attached directly to the socket itself instead of going through the motherboard or or being clipped onto brackets mounted through the board (like AM4). You'd see reports of them literally ripping the CPU socket off the board due to the weight!
AMD Ryzen 5950X | Asus Crosshair VIII Hero | Gigabyte Gaming OC 4090 w/EK Vector2 | GSkill Trident Z Neo 2x16GB DDR4-3600 | WD SN850 2TB | Samsung 970 EVO Plus 500GB & 860 Evo 2TB | Phanteks Enthoo 719 | Seasonic Prime Ultra Gold 1000W | Steelseries M750 TKL | SteelSeries Prime Wireless | SteelSeries Arctis Pro + GameDAC | Kanto YU2 + Yamaha sub | Schiit Magni 2 Uber & Modi 2 Uber | LG 34GN850 | Asus PG279Q | Win 11 Pro | Custom water loop
2019/12/20 21:42:57
notfordman
- Ribbons : 28
2019/12/20 22:42:04
Maybe why he didn't run the test with side on. I was wondering about that. CraptacularOne The tech does have solid theory and principle behind it, however it won't compete with high end custom loops in performance. It will be a suitable substitute for an AIO if they can get the size down to their claimed dimensions when it's ready. However as pointed out above it will inherently have accessibility issues because of it's size even when scaled back.
Very astute post, Mr. CrapT. :)
Nereus
Captain Goodvibes
- Ribbons : 58
2019/12/20 22:57:28
Xavier Zepherious
- Ribbons : 16
2019/12/20 23:51:38
https://www.icegiantcooling.com/reviews The review compares the ProSiphon Elite Prototype with the top heat pipe cooling options for AMD's 32-core Threadripper 2990wx CPU, i.e., the Noctua NH-U14S TR4-SP3 and the Arctic Freezer 50TR, on overclocked settings.At maximum fan speeds for each cooler, the ProSiphon Elite Prototype beat out the Noctua and the Arctic coolers by 4.2 C and 8.2 C, respectively. not even compared to Watercooling ...yeah like duh any watercooling..ie thermisiphon should beat out a metal block Linus should be shamed for this one furthermore the thermisiphon is like 3-4x the size of those blocks.... like duh! unfair advantage -of course it should do better just imagine bigger blocks might do better - its the airflow you need real world testing??? where linus.... where? was it open case where it could get fresh air or closed? did you have the case vertical or horizontal? ...what is the stress on the cpu socket? - im considering shear force weight here as well - vs impact of full weight on cpu socket - long term we have no real 1/3 size version to test - so it could be bull K'rap to get investors and may never pan out - they have no final product to live up to their promise yet - just a ugly awful prototype and the proposed 1/3 size is longer and taller and sits closer to board - and offset - which may have shear force implications - i understand the offset - its for gravity to force liquid(not water) to cpu where its evaporated - so it has to be offset for vertical case what gets me is you are putting a cheap solution on a very expensive threadripper and motherboard - and probably has a hefty stack of ram spend $4-5k on cpu,ram and MB and put a $100 solution on it - rather than properly cool it?????? if you can afford the highest offering from AMD or INTEL you can afford proper cooling - by gods you'd rather put your faith on a cheap cooling system - i can't fathom it
post edited by Xavier Zepherious - 2019/12/21 01:40:04
kougar
- Ribbons : 22
2019/12/21 03:45:10
All the Thermalsiphon review units shipped with max-speed fans, which are not what will be shipping in production units. Most of the reviews aren't even substituting normal fans, which will have trouble moving air through the thing at lower speeds. The 4.85lbs may as well round to 5lbs after you include the fans. Even for the massive sTRX4 socket I would be worried about moving the system case around, and board damage from gradual flex over time. If anyone remembers the Thermalright TRUE Copper, even at 4.18lbs with a backplate it caused flex and even broke some motherboards.
Have water, will cool.
seth89
- Ribbons : 14
2019/12/21 18:25:45
Delirious
- Ribbons : 61
2019/12/21 19:57:57
"Be quick to listen, slow to speak and slow to anger" Affiliate Code XZUMV9TJW5 Associate Code: 7PM43CU71IB2IAP education may be expensive but wait until you get the bill for ignorance A wise man once said that we can't make anyone feel or do anything. We can throw things into the wind, but it's up to each person to decide how they want to react, where they want to stand when things fall.
knightsilver
- Ribbons : 14
2019/12/21 21:55:39
Didn't realize it was Linus, i lasted 10secs into the video, blow hard much dude......
GTXJackBauer
- Ribbons : 48
2019/12/21 22:01:47
lehpron
Regular Guy
- Ribbons : 191
2019/12/21 22:48:21
What's with the 'one and therefore all' assumptions?
Just because this bulky bs is how the technology is being implemented first time doesn't mean all variations will look just like it from here onwards.
Meaning, every argument from weight and accessibility will be moot once (and provided) competition sets in.
Think back (or just Google) the first water cooling systems more than a decade ago, they weren't anything like what we have today, and it wasn't until the AIO type that put regular air cooling to rest.
Xavier Zepherious
- Ribbons : 16
2019/12/22 08:02:05
no use testing unless you have the actual product ....not some bogus prototype that doesn't meet the specs and design for the final product they are no where near each other in size secondly this cooler blows some of the heat back into the case(because it is mounted on CPU rather than the case side and CPU) where a AIO would blow all of it out the case this is basically a AIO cooler - just no moving parts -they wanted to simplify things(no moving parts to fail) a water cooler has more ability to a absorb and get rid of more heat than a phase cooler thats because a gas can't hold much more heat and diaelectric fluids do not have as high of thermal thermal transfer rate https://koolance.com/cooling101-heat-transfer water is your best coolant https://www.lytron.com/product-support/resource.cfm?aid=1242 so basically to match a AIO cooler they have to offer more surface area to compete and more airflow my suggestion - just build a better AIO with better pumps and maybe 2x140(which they have)or 3x140's and maybe thicker with more surface area its how fast you can move fluid -(volume) and surface area of Rads and the airflow over them that make the difference
GTXJackBauer
- Ribbons : 48
2019/12/22 08:09:46
Too bulky and heavy. It won't work and looks hideous. This will also block ambient lighting in most systems. Maybe this would have been fine back in the 2000s when AIO weren't around much and everyone had motorcycle parts for custom loops but almost 15-20 years later, things have changed. This hideous looking block came way too late. lol I'm sure a hand full of people will buy this but majority won't. To each their own at the end of the day.
mudge991
2019/12/22 08:50:13
You may want to research that a little more- there are a number of things you got wrong about it. Or you can check out Jays2cents on youtube- did a review on the pre production model, Which is what the pic showed.
