ipkha
- Ribbons : 6
Can someone already running dual 1080Ti for folding give me some power usage numbers. I'm getting odd results from various power config websites and could use some real world results.
toddryoungblood
Re: Power draw for dual 1080Ti
2017/04/06 10:02:02
How specific are you looking to get? I have two 1080 Ti and a 1070 but I don't think I have a way to measure power. If you look at benchmark tests, under load, a single 1080 Ti is around ~280W. I went for a 1000W PSU and I'm doing fine with 2 1080 Ti and a 1070.
NxtGenCowboy
2017/04/06 10:02:37
Wait so no-one waited for the Titan Xp? (Didn't mean to hijack post, thought I was on a different post) my bad!
post edited by NxtGenCowboy - 2017/04/06 10:10:57
toddryoungblood
2017/04/06 10:09:25
I don't think anyone knew about it until now. I would grab one but the price isn't worth the ~10-20% increase over the 1080 Ti.
Chris21010
- Ribbons : 9
2017/04/06 11:31:00
well... i hate to say this but i just couldn't hold onto $1500 without spending it >. < so i'll have two 1080ti's that i can put on my kill a watt power meter and give you exact power draw friday. BUT, i will say that if you are using founders cards they will most definitely be throttling down due to their hard thermal limit of 84C. so unless you are putting them under water you will most likely never see more than ~200W max out of each card.
- Ribbons : 282
2017/04/06 11:43:33
Posted in another Thread as well. I am Pushing 850 Watts Folding on my 2 Cards, SLI is Disabled. Max or Peek Wattage while Folding and or Crunching was 910 Watts. Click on Image Twice for a Larger View.
post edited by bcavnaugh - 2017/04/06 11:49:11
2017/04/06 11:49:15
900 watts with Nibbler - 3GPU - no CPU folding CPU will push it to 1100 watts total system including monitor
ipkha
- Ribbons : 6
2017/04/06 11:50:46
I'm looking towards a 1080Ti FTW3 and whatever AIB style card I can stepup my 1080 FTW2 to. Pretty sure my 660W power supply ain't gonna cut it, but I've seen one SLI review put combined draw at 654 Watts at the wall. I've seen between 1000 and 1350 watts depending on the power supply calculator.
- Ribbons : 282
2017/04/06 11:55:00
ipkha I'm looking towards a 1080Ti FTW3 and whatever AIB style card I can stepup my 1080 FTW2 to. Pretty sure my 660W power supply ain't gonna cut it, but I've seen one SLI review put combined draw at 654 Watts at the wall. I've seen between 1000 and 1350 watts depending on the power supply calculator.
I do not think a single Game out their can push a Graphics Card as hard as Folding and some BOINC GPU Tasks can.
ipkha
- Ribbons : 6
2017/04/06 12:30:23
I can at least go by your numbers. I'm strictly on air cooling here and 2062Mhz is as far as I've gotten so far as stable overclocks. My gaming needs aren't SLI friendly anyway. I only run a 4 core processor so I'm hoping 1000 Watts will be enough. Them 1200 Watt units are expensive. If I'm gonna buy one I'm gonna go titanium.
- Ribbons : 282
2017/04/06 13:05:29
I would say anyone going SLI or Two GTX 1080Ti Graphics Cards should get no less than a 1000 Watt Power Supply.
Chris21010
- Ribbons : 9
2017/04/06 13:37:31
The cards are rated @250W TDP each and 130W for cpu and another 50-100W for everything else is only 750W. Getting 850W will work as long as you do not OC.
ipkha
- Ribbons : 6
2017/04/06 13:42:39
I don't go to extreme with the overclocking. My CPU isn't overclock able but I do oc my folding cards if possible.
Chris21010
- Ribbons : 9
2017/04/06 13:48:11
well each card can do 120% tdp, so max of 300W per card is only another 100W across the two. even so when was the last time you saw F@H run at 120% tdp?
bill1024
- Ribbons : 65
2017/04/06 17:27:54
I am running two GTX980Ti and an E5-1550 on an EVGA 850G and it seems to be running fine. Just make sure your using the heaver duty cord that comes with the 850W and not a light weight one from a 650W PSU. I learned the hard way!!
ipkha
- Ribbons : 6
2017/04/06 19:42:30
I have a server grade power cable from a blade rack. It's a pretty thick cable. I think I'm gonna get a 1200P2 unit for some spare capacity.
- Ribbons : 282
2017/04/06 19:52:51
ipkha I have a server grade power cable from a blade rack. It's a pretty thick cable. I think I'm gonna get a 1200P2 unit for some spare capacity.
The Cable that comes with 1200 P2 is the same size as my Dell Server Cables just not a long.
post edited by bcavnaugh - 2017/04/13 08:48:31
AzN-SoLjA
- Ribbons : 14
2017/04/06 22:30:24
Anyone think I'm pushing it if I run 1080Ti FTW3 and 780Ti SC together on AX850? 1070FTW & 780Ti ran fine though while I had it. edited**
post edited by AzN-SoLjA - 2017/04/06 22:43:41
| EVGA Z68 FTW | EVGA GTX 780 Ti SC 3GB | EVGA GTX 1080 Ti FTW3 | Custom EK Water Loop | Red Harbinger Cross Desk | i7 2600K @ 4.5GHz @ 1.24v | Corsair 16GB Vengeance | Corsair Neutron 256GB SSD | Corsair AX850 | Lamptron FC5V3 | ASUS VE278 27" | | Creative Inspire T6160 5.1 & X-Fi Fatal1ty 7.1 Champ | Razer Marauder & Spectre & Tiamat 7.1 | Affiliate Code: 3MHCIBME48 | Associate Code: 08HWLPJXE0O5MPM
- Ribbons : 282
2017/04/06 22:38:01
AzN-SoLjA Anyone think I'm pushing it if I run 1080Ti and 780Ti together on AX850? 1070FTW & 780Ti ran fine though while I had it.
With No GPU Overclocking I would say yes and with GPU Overclocking I would say Maybe you will be OK. 780 Ti Graphics Card Power (W) 600 WMinimum System Power Requirement (W) One 8-pin and one 6-pin 1080 Ti 250 WGraphics Card Power (W) 600 WRecommended System Power (W)4 One 6-pin, One 8-pin 1070 FTW - Minimum of a 500 Watt power supply.
- Two available 8-pin or 6+2pin PCI-E power dongles
- Total Power Draw : 215 Watts
1 - Windows 10 requires November 2015 update or newer. 2 - 7680x4320 at 60 Hz RGB 8-bit with dual DisplayPort connectors or 7680x4320 at 60 Hz YUV420 8-bit with one DisplayPort 1.3 connector. 3 - DisplayPort 1.2 Certified, DisplayPort 1.3/1.4 Ready. 4 - Recommendation is made based on PC configured with an Intel Core i7 3.2 GHz processor. Pre-built system may require less power depending on system configuration.
post edited by bcavnaugh - 2017/04/06 22:42:18
AzN-SoLjA
- Ribbons : 14
2017/04/06 22:45:54
updated my post xP I left submodel info out on accident. I sold my 1080Ti step up to preorder FTW3 Thanks for that quick response :)
ipkha
- Ribbons : 6
2017/04/07 12:21:14
bcavnaugh Posted in another Thread as well. I am Pushing 850 Watts Folding on my 2 Cards, SLI is Disabled. Max or Peek Wattage while Folding and or Crunching was 910 Watts. Click on Image Twice for a Larger View.
What cpu are you using?
- Ribbons : 282
2017/04/07 18:42:44
ipkha
bcavnaugh Posted in another Thread as well. I am Pushing 850 Watts Folding on my 2 Cards, SLI is Disabled. Max or Peek Wattage while Folding and or Crunching was 910 Watts. Image Removed to Save Space
An Old MODS RIGS EVGA X79 Classified MB with the Intel Core i7-3930K Hexa-Core Processor 3.2 Ghz 12 MB Cache Been Running Einstein@Home @2138 MHz for over 24 Hours Now. Computer Tasks Less than 7 Minutes to complete a task.
post edited by bcavnaugh - 2017/04/07 18:46:15
Chris21010
- Ribbons : 9
2017/04/07 22:01:15
OK! two 1080ti's on a 650W PSU will work until the ambient room temps start to cool down and the cards are no longer throttling themselves down to 1700MHz. as for what i read from my kill a watt meter i saw 550W avg while it was running and not rebooting itself due to power spikes. 750W should be fine on air, no OC, but 850W is what i would consider safe for two 1080ti's.
- Ribbons : 282
2017/04/08 12:22:40
Chris21010
post edited by bcavnaugh - 2017/04/13 09:09:27
Chris21010
- Ribbons : 9
2017/04/08 12:38:51
the user doesnt set the Mhz the thermal limit does and i did say founders and on air.
ipkha
- Ribbons : 6
2017/04/08 12:59:24
Well, this certainly puts things in perspective. I definitely need a new PSU. But that price jump from 850 to 1000 to 1200 is just frightening. I guess I'll finally cash in my evga bucks. Of course I'm only considering Platinum and above, I wish I could afford titanium but that's a stretch.
- Ribbons : 282
2017/04/08 13:31:15
EVGA SuperNOVA 850 G2, 80+ GOLD 850W, Fully Modular, EVGA ECO Mode, 10 Year Warranty, Includes FREE Power On Self Tester Power Supply 220-G2-0850-XR$120 EVGA SuperNOVA 750 G2, 80+ GOLD 750W, Fully Modular, EVGA ECO Mode, 10 Year Warranty, Includes FREE Power On Self Tester Power Supply 220-G2-0750-XR$100 (1) EVGA SuperNOVA 1300 G2, 80+ GOLD 1300W, Fully Modular, 10 Year Warranty, Power Supply 120-G2-1300-XR $190. I love This PSU (2) EVGA SuperNOVA 1200 P2, 80+ PLATINUM 1200W, Fully Modular, EVGA ECO Mode, 10 Year Warranty, Includes FREE Power On Self Tester, Power Supply 220-P2-1200-X1 $230 Amazon (3) EVGA SuperNOVA 1000 G2, 80+ GOLD 1000W, Fully Modular, 10 Year Warranty, Includes FREE Power On Self Tester Power Supply 120-G2-1000-XR $140
post edited by bcavnaugh - 2017/04/08 13:35:14
howdy2u2
- Ribbons : 6
2017/04/08 13:43:55
1000 platinum is on sale in the EVGA store- 189.99 + shipping
ipkha
- Ribbons : 6
2017/04/08 15:24:38
howdy2u2 1000 platinum is on sale in the EVGA store- 189.99 + shipping
I'm torn right now between that one and the 1200P2. I really need that platinum efficiency. At these wattage, even titanium could save some long term money.
- Ribbons : 282
2017/04/08 15:38:21
Well all 3 do have a 10 Year Warranty.
