ipkha
- Ribbons : 6
Re: Power draw for dual 1080Ti
2017/04/08 15:48:09
Yeah, I'm probably gonna go for a 1000 Watt T2 or P2 when my April bucks get added.
howdy2u2
- Ribbons : 6
2017/04/08 17:27:59
ipkha Yeah, I'm probably gonna go for a 1000 Watt T2 or P2 when my April bucks get added.
OR you could get the 1200 and be really on the safe side and add another GPU later on............well since......you know.....you'd have plenty of power available.......
ipkha
- Ribbons : 6
2017/04/08 18:00:58
howdy2u2
Size constraints on my motherboard make tri gpus unlikely. Also, I probably can't use my 3rd pcie x16 slot at all as I am using both of my nvme slots with pcie drives. Besides the fact that the headers for power and usb block installation of 2 slot cards there. I tried it once to give more breathing space for my cards. Unless there's a pcie extender with stand so I can place it on top of psu cover.
ipkha
- Ribbons : 6
2017/04/08 18:24:06
Looks like at full load I can save $15 a year. 1000 vs 1020 watts 24/7 at 8.63 cents per. Assuming 2% Platinum vs titanium gap. Anybody wanna guess what figures we would get Diamond (gotta be something above titanium) class efficiency?
post edited by ipkha - 2017/04/08 18:25:41
Chris21010
- Ribbons : 9
2017/04/08 23:21:18
the biggest thing to note is that peak efficiency is @ 80% load. if you are only 50% load you are not at peak efficiency.
ipkha
- Ribbons : 6
2017/04/09 07:43:54
Titanium is supposed to be 2% more efficient across the board. The 10% load at 90% efficient is the main draw for me. The more expensive your power, the sooner you break even. It's a shame it cost so much to run a 240V line.
toddryoungblood
2017/04/11 09:30:14
My 3 1080 Ti at full Folding@Home load w/ 85% fan speed runs 800W.
- Ribbons : 282
2017/04/11 21:14:24
Remove the UPS and re-test.
redleader00
- Ribbons : 7
2017/04/12 05:26:03
A friendly reminder for everyone. If online calculators say you need, for example, 649W power supply, dont go and buy a 650W power supply and think everything will be fine. Always stay safe a buy a bit more. Trust me, it will make your life much easier on the long run.
toddryoungblood
2017/04/12 06:22:20
bcavnaugh Remove the UPS and re-test.
I don't have a UPS?
Chris21010
- Ribbons : 9
2017/04/12 06:39:37
i guess he sees that your 90 degree plug that does not come with that power supply and assumed one is there? but ~810W on air seems fine to me. 90% tpd for the 1080ti is 225W. times three cards is 675W. plus the rest of the parts at 145W is 810W total.
post edited by Chris21010 - 2017/04/12 06:40:52
- Ribbons : 282
2017/04/12 14:52:16
redleader00 A friendly reminder for everyone. If online calculators say you need, for example, 649W power supply, dont go and buy a 650W power supply and think everything will be fine. Always stay safe a buy a bit more. Trust me, it will make your life much easier on the long run.
Yes, thank you for your Post. I think only Chris21010 goes by them He still wants us to use an 850 PSU
post edited by bcavnaugh - 2017/04/12 14:54:19
Chris21010
- Ribbons : 9
2017/04/12 15:20:44
no, i do not need calculators when i can do the math myself. and 850W for two 1080ti's is plenty. spending more money on something you'll never use/need is just wasteful.
Opolis
- Ribbons : 7
2017/04/12 15:39:02
This^^^^ Fun fact, I ran through the EVGA Wattage tool and it recommended 850W for 2 x 1080ti with a Z170/i7 6700k and one hard mechanical drive.
toddryoungblood
2017/04/13 05:55:28
nathan_P
2017/04/13 07:23:23
My 1080 and one 1070 are currently pulling 400w from the wall on a AX860i, granted I only have a 25w cpu idling away and 1 HDD but I would not be worried about a pair of 1080Ti's and a 1070 onto this PSU.
- Ribbons : 282
2017/04/13 08:30:41
Killed it
post edited by bcavnaugh - 2017/04/14 14:48:15
Chris21010
- Ribbons : 9
2017/04/13 08:38:02
he did say he will be adding two more 1080's to that rig on another thread.
- Ribbons : 282
2017/04/13 08:44:11
Chris21010
Not sure what the point is anymore in this thread seems you all want to say 850 is all you need fine so be it get your 850 and be done with it. It was a simple Question "Power draw for dual 1080Ti" I posted mine. Done
post edited by bcavnaugh - 2017/04/13 09:07:10
Chris21010
- Ribbons : 9
2017/04/13 08:47:13
the point is as the title suggests. we are discussing the power draw of two 1080ti's and to my knowledge it seems the consensus is 850W is plenty for two 1080ti's.
- Ribbons : 282
2017/04/13 08:54:30
Wow! I really messed up this post.
post edited by bcavnaugh - 2017/04/14 14:43:38
- Ribbons : 282
2017/04/13 09:15:21
toddryoungblood
- Ribbons : 282
2017/04/14 14:41:45
toddryoungblood
toddryoungblood I have 3 1080 Ti and a (AIO) water cooled CPU on a 1300W PSU and it's only pulling 808W, so...
And, then with them slow cards all you need is an 850 Watt PSU overhead I would still say a 1000 Watt PSU. So pull out your 1300 Watt PSU and put in an 850 and be done with it.
Is wanting enough power to cover my ass a bad thing? I just added my 4th card, so now the 1300W serves me well.
I was Joking based on what Chris21010 said all you need is a 850W for two GTX 1080 Ti Graphics Cards. But now I know you are adding a 3rd card from another Thread from Chris21010 . (Now you are posting a 4th card) Coin On You should see my big rig it has a 1300 G2 AND a 1600 G2 One for the MB/CPU/Pumps and one for the GPUs I am all for Overkill, but some are not. Also you do not use UPSs and I use them heavily.
post edited by bcavnaugh - 2017/04/14 14:46:32
chap34
2017/04/16 19:32:29
Folding with a i7 7700, SSD, two 1080ti, Set to 120% TDP. Thermaltake DPS G 1050w. Never breaks 700W per the PSU
ipkha
- Ribbons : 6
2017/05/06 08:20:50
Got in on the Hybrid Kit when it came back in stock. So I am now expecting it and a 1000W P2 power supply Wednesday the 10th. Now I have to do the step up from the 1080FTW2 within 20 days or so. I'm still hoping for another step up option but I'm setup either way. The FTW3 elite in blue is due to ship at the end of the month. Can't wait to kick my ppd into high gear.
- Ribbons : 282
2017/05/06 08:43:32
ipkha Got in on the Hybrid Kit when it came back in stock. So I am now expecting it and a 1000W P2 power supply Wednesday the 10th. Now I have to do the step up from the 1080FTW2 within 20 days or so. I'm still hoping for another step up option but I'm setup either way. The FTW3 elite in blue is due to ship at the end of the month. Can't wait to kick my ppd into high gear.
Both of Mine or Overclocked @ +230 running @2138MHz and on my New Horizons a single card Overclocked @ +190 @ 2100MHz. All three are on Water Blocks and Temps never go over 41C.
ipkha
- Ribbons : 6
2017/05/07 13:17:06
That sounds great. I don't get near your ppd so my processor might be underpowered. My 1080 only gets 750k on a good day, most of the time it's down in the high 600s.
ipkha
- Ribbons : 6
2017/05/12 17:06:02
Got my new PSU hooked up and waiting for my FTW3 and just requested SC Black step up. Now I've got a hybrid kit to see about offloading.
Chris21010
- Ribbons : 9
2017/05/12 17:11:51
that hybrid kit would work great on a 1080 ti founders. that is what i did on my founders card as you can keep the fan, front/back plate, and most of the housing. you basically just remove the clear cover over the heatsink and plop that bad boy right on there.
