kram36
The Destroyer
- Ribbons : 72
Re: People that got their 3080ti,Need Data for Powerdraw Between 3 Power connectors(IMPORT
2021/06/14 11:53:04
FunktasticLucky
FunktasticLucky Bud did you not read the whole thread? I set the record with a FTW3 Hybrid with no mods or flashes bios. It's a none issue. People are basing this assumption off a 3rd pin power draw but they are forgetting that the card doesn't receive all it's power from the 8 pin connectors. It can receive up to 75W from the pcie slot. 150-75 is you guessed it... 75W. So 150(8 pin)+150(8 pin)+75(PCIe Slot)=375W. Leaving another 75W for the 3rd 8pin. The 3rd pin is being supplemented by the slot which usually hovers around 50-60W.
1) This isn't about you. 2) Not all cards have this problem. Same story for the previous 8 months.
3) The PCI-E slot doesn't provide 75 watts of 12 volt power. 4) Your math only works if the card power balances properly. If your card is one of the cards which doesn't power balance properly, you get the result above.
Is 5% or 10% performance impact substantial in your opinion? It can't be defined. It depends on each person. If I paid $1400 for a video card, I wouldn't be able to accept it. It's especially embarrassing that EVGA didn't fix this same problem when it released this new product line.
Let's see core clocks, and voltages from these settings? What are your afterburner/precision settings? If you're slamming all sliders to the right you're doing it WAY wrong.
He doesn't have a 30 series card.
kevinc313
- Ribbons : 22
2021/06/14 12:16:08
talon951 I'll try it tonight when I get home. My peak won't be that high but I'm pretty sure the average is 440w or a little more.
FWIW, I do agree the average matters, much more than the peak IMO, if that's what you're getting at.
Hey thanks I appreciate it. Needs to be a full constant load like Furmark to keep the card on the power limit. Start test, reset HWiNFO (clock button) then run for a few minutes.
- Ribbons : 270
2021/06/14 12:49:36
kram36
FunktasticLucky
Sure don't. You wonder why.... lol That is not my screenshot. That screenshot is of a 3080 Ti FTW3, posted in this thread, and is relevant to the content which we have been discussing. You are aware of the content we are discussing, yes? Regardless of whether or not that user is doing it "way wrong", don't you think that the relevant thing is that the card isn't power balancing properly? Is it not clear that it is not balanced? Do you believe that it is acceptable for the card to be designed in a way that it is able to work improperly?
post edited by ty_ger07 - 2021/06/14 13:02:20
kram36
The Destroyer
- Ribbons : 72
2021/06/14 12:54:21
kram36
FunktasticLucky
Because you can't get one or at least not at scalper pricing? Other then that, no reason except you just don't need one. It surely can't be because of performance of these cards.
- Ribbons : 270
2021/06/14 12:56:38
kram36 Because you can't get one or at least not at scalper pricing? Other then that, no reason except you just don't need one. It surely can't be because of performance of these cards.
I don't want one. I don't need one. And if I buy one some day, it will not be a 30xx EVGA FTW3, that's for sure. I have said this numerous times. The power balance issue. The lack of proper engineering. The fuses burning out. The gimmicky features and associated buggy software. And worse of all, the price premium for something which is marginally interesting, which is designed for the most basic enthusiast. I would be WAY more interested in buying and modifying a founders edition or vanilla reference version.
post edited by ty_ger07 - 2021/06/14 13:00:59
kevinc313
- Ribbons : 22
2021/06/14 13:13:09
Well, I'm pretty happy with my 3080 ($750!) but am super disappointed in the 3080 Ti. Bleh. Wanted a 500w XOC bios, SLI and Hybrid for about $1200 or so. Let alone the hash rate limiter. Had I have known the 3080 Ti was going to be such a ripoff, I would have just gotten a Kingpin. I've got a late April notify in, so maybe I can buy one in 2026.
post edited by kevinc313 - 2021/06/14 13:16:06
talon951
2021/06/14 14:21:40
kevinc313 Thanks man, looking for the HWiNFO average reading. From what I've seen so far these cards pull 40-50w less than my 3080. Prove me wrong.
Pretty close. Lower peak, but same average. https://i.imgur.com/ksUfwzp.jpg
post edited by talon951 - 2021/06/14 14:22:48
kevinc313
- Ribbons : 22
2021/06/14 14:48:34
talon951
Wow really great work, much appreciated. Seems to be running just dandy, regardless of the power balancing being a bit strange and the warm temps. Thanks!!! One thing that's kinda sus is the ICX temp readouts and the mem junction temps. Your ICX temps are within about 10C-25C of mine and the mem junction temps are identical at 84C. But a 30C core delta. Yeah my hybrid fan setup is very effective, but that is strange. GPU core power ~250w if I'm reading it right. I'll bet when someone pulls one of these apart they find inadequate pressure on the die and thick layer of thermal paste. Just a guess.
post edited by kevinc313 - 2021/06/14 15:03:10
talon951
2021/06/14 15:07:56
kevinc313
talon951
Yea it runs stupid hot. Note though my ambient temp was 25-26C during that run. IMO that's the real disappointment though. I'm either going to build another loop for this machine or at least buy the hybrid kit. Also though, the hybrid doesn't pass water over the mem directly, so it won't be as effective at cooling the mem as it is the core.
post edited by talon951 - 2021/06/14 15:10:17
rjbarker
- Ribbons : 21
2021/06/14 17:00:16
kevinc313
rjbarker
kevinc313
talon951
kevinc313 So nobody wants to Furmark one of these cards and check average power? Proving they can use 450w?
I ran Kombustor and posted that back before all the bickering started.
kevin...what does your Card draw total ? I'm assuming close to 450W with 450W XOC Bios ?
445W AVERAGE, 485W GPU-Z MAX. With externally powered fans. If you are seeing a 435W GPU-Z MAX READING, your card has a 400W power limit. Prove me wrong.
Thanks kevin.....no my Card 3080FTW3 Ultra will only hit 405W Max....with XOC 450W Bios and under water...running numerous power intense tests...max GPU Temps I see is 43c....
2021/06/14 17:02:36
Please watch the personal attacks/language everyone. Thank you.
If more personal attacks/foul language is used then warnings/bans will be issued.
kram36
The Destroyer
- Ribbons : 72
2021/06/14 17:03:26
talon951 Yea it runs stupid hot. Note though my ambient temp was 25-26C during that run. IMO that's the real disappointment though. I'm either going to build another loop for this machine or at least buy the hybrid kit.
The memory is cooled by the Hybrid cooler and it works pretty good. I have one on a GTX 1080 Ti card and was very surprised at how well it does.
kevinc313
- Ribbons : 22
2021/06/14 18:10:38
kram36
He is correct that the memory is cooled through a secondary plate conducting heat to the AIO. On these GDDR6X cards it can be better or worse than an air cooler depending on the implementation, but I'd say the Hybrid is better in most cases out of the box. It's very strange to see a stock air cooled card, or any card, with mem junction only a few degrees above core, since they are right next to each other, on the same chonk of metal.
post edited by kevinc313 - 2021/06/14 18:25:32
talon951
2021/06/14 19:10:28
kevinc313
kram36
Do these cards all have thermal puddy rather than pads now (EVGA) ? If it has pads then EVGA could have chosen some are to thick or too stiff as they will change your core pressure. At least they do in water blocks. Seems like I've seen EVGA using puddy though.
kevinc313
- Ribbons : 22
2021/06/14 20:26:59
talon951 Do these cards all have thermal puddy rather than pads now (EVGA) ?
No idea on the pads vs. putty, but it seems like something that could go out of spec in manufacturing or procurement and not get caught in QC, due to the temps not being a huge difference and hard to measure pressure once mounted. I usually like to blame people's poor case airflow, but we're seeing excessive reports with poor temps with the 3080 Ti FTW3 Ultra and they should have the same temps as the 3080 and 3090.
post edited by kevinc313 - 2021/06/14 20:40:27
madonionring
2021/06/14 20:31:51
Here is mine while playing Cyberpunk. Assuming that it shows PerCap reason as power limited due to the imbalance between the rails? Or is that a reference to ~400w being pulled in total?
post edited by madonionring - 2021/06/14 20:36:37
rjbarker
- Ribbons : 21
2021/06/14 20:49:06
madonionring Here is mine while playing Cyberpunk. Assuming that it shows PerCap reason as power limited due to the imbalance between the rails? Or is that a reference to ~400w being pulled in total?
Is the 3080Ti 400W or 450W ? If its 400W you simply hit the 400W Power Limit....
kevinc313
- Ribbons : 22
2021/06/14 20:55:07
madonionring Here is mine while playing Cyberpunk. Assuming that it shows PerCap reason as power limited due to the imbalance between the rails? Or is that a reference to ~400w being pulled in total? Looks totally normal for a card set to 100% power. It usually triggers for overall card total power vs. bios limit. For example on a hybrid card, if you power the pump and fans externally via MB header, the card will still try to hit the same power limit and usually succeed, even though you've made more power available for the electronics to use. From comments I've read on overclock.net of people trying 2x8-pin bios on the FTW3 in an attempt to get more power, they are being thwarted by the 3rd connector and slot power balance staying the same, meaning full card power on the alt bios because of the 1+2 connectors pulling full power. I have a feeling this is an intentional design feature, not a bug.
- Ribbons : 270
2021/06/14 21:27:36
rjbarker Is the 3080Ti 400W or 450W ? If its 400W you simply hit the 400W Power Limit....
450 watt is the max limit of the default BIOS if you slide the power limit to the max.
Slade__
Flagged as Spam (1)
2021/06/14 21:33:04
mnelson260z
2021/06/14 23:43:12
On the 400w bios with the slider maxed to the right I am seeing 147.9/158/81 with a slot max of 52.1. And fwiw, temp max is 81.6 gpu, 87.1 hot spot, and 90.0 memory.
Endworld
2021/06/15 01:10:20
So...you just hang out here like a weirdo and talk smack about the products? lol You need a hobby.
talon951
2021/06/15 02:32:51
kevinc313
Yea I was wondering that too. I have a feeling it's just a side effect from other design decisions though. Oddly, most of the 3x8pin bios from other cards don't work correctly either. Seems like EVGA must have deviated from the design other manufacturers are using too.
- Ribbons : 270
2021/06/15 04:30:42
mnelson260z On the 400w bios with the slider maxed to the right I am seeing 147.9/158/81 with a slot max of 52.1. And fwiw, temp max is 81.6 gpu, 87.1 hot spot, and 90.0 memory.
Just to clarify, the "400 watt BIOS with the slider maxed to the right" is 450 watts. Why call it a "400 watt BIOS"? Maybe "default BIOS" or "normal BIOS" would be less confusing.
kevinc313
- Ribbons : 22
2021/06/15 05:33:09
The colloquial way of discussing these bios on forums has been to refer to the max nominal power limit. For example 373w 2080 Ti FTW3 bios or 380w Galax.
KingEngineRevUp
- Ribbons : 9
2021/06/15 12:29:44
Question. Some people reported that the Strix bios from 3080 to their 3080 allowed them to hit higher power. Can it be possible the same can be done?
KingEngineRevUp
- Ribbons : 9
2021/06/15 13:50:33
I got my hands on an EVGA FTW3 3080 Ti and I'm here to report that the power slider doesn't work for ****. Even though I slide it to 100%, it doesn't go past that. The max TDP I saw was 105%. When I have the slider at 100%, I notice the power draw will float around 380-390W. Can this be a BIOs issue? So now what, I'm stuck with a gimped card that won't really go over 400W and touches 420W for just a second?
post edited by KingEngineRevUp - 2021/06/15 13:54:15
unicosm
2021/06/15 14:20:32
Does it matter the order of cables from the PSU?
kram36
The Destroyer
- Ribbons : 72
2021/06/15 14:23:45
unicosm Does it matter the order of cables from the PSU?
Depends on if you have a single or multi rail PSU.
unicosm
2021/06/15 14:25:56
kram36
Thanks for reply. I will do my research.
