RypeSauce
This post is in reference to the uneven power draw For the 3080 and 3090 which used the analog voltage controller UP9511,and the cards seemed to have a lot of RMA due to frequent crashes and eventual death . The new 3080ti seems to be using the OnSemi NCP8610 Voltage controller and would like your input on what your powerdraw is between the 3 power connectors and the PCIE connectors reference https://forums.evga.com/3...er-usage-m3208315.aspx
post edited by RypeSauce - 2021/06/11 01:07:06
08G-P5-3785-KL 6/15/2021 11:36:17 AM PT No08G-P5-3797-KL 6/10/2021 6:16:17 AM PT Yes12G-P5-3958-KR 6/3/2021 8:05:53 AM PT No 12G-P5-3968-KR 6/3/2021 7:48:08 AM PT No 12G-P5-3967-KR 6/3/2021 7:28:32 AM PT Yes12G-P5-3959-KR 6/15/2021 11:40:43 AM PT NoPlease use my Associate Code at your checkouts for up to 10% discounts on all your EVGA purchases: R7WBIB2D5W1AMCI
RypeSauce
Re: People that got their 3080ti,Need Data for Powerdraw Between 3 Power connectors(IMPORT
2021/06/11 02:37:56
posting on behalf of someone else for 3080ti ftw
talon951
2021/06/11 05:22:19
Same for mine. It will hit the 450w limit, but it's like 150/150/90w and 60w PCIE.
I guess that's ok unless a higher PL bios popps up.
ShoreXShot
2021/06/11 09:20:13
Waiting on the rest of my parts to come in but will post once I get it up and running.
neteng101
2021/06/11 09:46:48
PCIe slot power is no longer out of spec, but the card still draws most of its power via pin 1/2, guessing its how the power phases are wired up to the inputs. Doubtful if the card will benefit from a higher power BIOS, its pin 1/2 that will trigger the Power threshold first.
andross182
2021/06/11 10:08:48
Ill test this when I get home, any particular benchmark you wanna see or just load the card in general?
rjbarker
- Ribbons : 21
2021/06/11 10:19:30
^^^^ Great post n question..I was wondering the same as well. I this new series Cards are stil plagued with uneven power draw from the PCI-E plugs resulting in lack of reaching max power then I would look at a Stix Card.....I see in the GPU-Z image the #3 PCI-E plug is still only reaching maybe 60% of Plugs #1 and #2, but if the Card is reaching max power draw then shouldnt be an issue. The problem I have and have seen on other 3080's is the Cards only reaching 400W with a 450W BIOS....great Thread to start. For all those testing, be sure to post pics of GPU-Z indicating Max Power Draw... Thanks for this!
talon951
2021/06/11 10:52:35
neteng101 PCIe slot power is no longer out of spec, but the card still draws most of its power via pin 1/2, guessing its how the power phases are wired up to the inputs. Doubtful if the card will benefit from a higher power BIOS, its pin 1/2 that will trigger the Power threshold first.
Well it would depend how far the bios allowed the 8 pins to go above spec. For example a 390w 2x8pin bios obviously allows some since perfectly in spec is 375w.
RypeSauce
2021/06/11 14:10:27
talon951
2021/06/11 17:59:11
Hit 445w peak with Port Royal. Kombustor hit 454w. I don't have a good way to link pics right now. Kinda dumb though. 8-pin #2 hits 160w while #1 stays below 150w and #3 never makes it over 90w. What's the point of having a 3x8pin card if it's going to exceed spec anyway on one of the 8-pins?! I guess it works, but kinda dumb.
talon951
2021/06/11 20:57:53
Xatos1337
2021/06/11 21:21:41
PCI #3 is averaging 50% of whatever the other two are, regardless of the number. My card is awesome though, no problems at all.
Gigabye X570 Aorus Master AMD Ryzen 3900X Corsair 570X Case with 6x ML Pro 120's Corsair H115i Platinum 240MM AIO w ML Pro's Corsair Vengeance 16GB 3600Mhz CL16 EVGA FTW3 3080ti Ultra Gaming OC 12GB EVGA 850W Supernova Platinum Samsung 1TB m.2 NVME + 3 other drives 12G-P5-3967-KR 6/3/2021 7:25:15 AM PT Yes 08G-P5-3797-KL 6/10/2021 6:15:54 AM PT Yes
talon951
2021/06/11 21:28:33
Xatos1337 PCI #3 is averaging 50% of whatever the other two are, regardless of the number. My card is awesome though, no problems at all.
Yea it's a solid card. I've been comparing it to my water cooled 3090 and it's really close due to losing the silicon lottery on vram with my 3090 (Zotac). Kinda a toss up whether I swap them or not in my main gaming machine. Really like this card. At least I don't have to push 400w+ through 2x8pin with it. Lol
Hotwario
2021/06/11 21:31:44
i have no idea what any of this mean time to go to youtube
- Ribbons : 270
2021/06/11 21:46:23
EVGA, why again? Why can't they power balance?
kram36
The Destroyer
- Ribbons : 72
2021/06/11 21:48:07
Ever thought the 3rd PCIe plug has a different function and the power isn't needed there? The XC3 doesn't even has 3 power plugs.
- Ribbons : 270
2021/06/11 21:50:53
kram36
1) Irrelevant. It should be able to power balance properly regardless of whether or not it has a positive or negative impact. It is simply sloppy if it can't power balance. 2) The screenshot posted is of a 450 watt BIOS power limiting at 405 watts due to power imbalance. The same old song and dance. Negative impact confirmed in that instance. 3) This isn't a XC3, so what's your point? EVGA can't properly engineer separate products? Is that somehow an argument in favor of EVGA?
post edited by ty_ger07 - 2021/06/11 21:52:00
RypeSauce
2021/06/11 21:55:14
kram36
what could the possible causes be for improper power distribution between the pins , and also any idea on the new voltage controller they used this time and how it's better compared to the previous one
andy11466
2021/06/11 21:59:19
3090 FTW3 Ultra here. Rev 1.0 PCI / 2114 Serial. Using a GEN4 PCI Vertical Mount (max 60W PCI Slot) PSU is HX1200 #1/2 can get up to 130-140 during stress testing #3 will get around 70-90 Definitely getting uneven power draw. Doesn't seem to affect stability or overclock atm. Could be different with someone else using higher power usage requiring over 150W per cable.
CPU: AMD 5950XCooler: EK-AIO 360 D-RGBMother Board: Asus X570 Crosshair Dark HeroGPU: EVGA RTX 3090 FTW3 UltraRAM: 4X8GB(32GB) G.Skill TridentZ | 3800Mz - CL14SSDs(NVME): Sabrent 2TB Rocket M.2Case: Lian Li PC-O11 DynamicPSU: Corsair HX1200 PlatinumMonitor: Alienware 27" 1440P 240HZ G-Sync (AW2721D)
kram36
The Destroyer
- Ribbons : 72
2021/06/11 22:01:12
kram36
1) How do you know it's not power balanced properly? Did you design the card? Do you know what the 3rd power plug is providing power to? 2) There is a screen shot provided by talon951 with his card getting well over 405W. 3) XC3 proves that a 3rd power connector is not necessary for the card to operate properly. So the 3rd power plug on the FTW3 is probably giving power to an area of the card that doesn't need that much power. Why is this so hard to comprehend?
ipaine
2021/06/11 22:21:59
Well I was just testing my 3080 FTW3 Ultra and mine came out fairly even. Don't have the screenshot anymore (yes I forgot to save the snip) but the max draw over the course of a few runs of port royal and time spy was: PCI-E slot: 52W 8 Pin #1: 110W 8 Pin #2: 126W 8 Pin #3: 115W Now that is just me trying to remember so they are not exact but the power draw was fairly even across all 3 power connectors. Oh and that is on the normal bios. Just a thought, but could the reason for some of the unevenness we are seeing be the psu?
- Ribbons : 270
2021/06/11 22:52:30
kram36
kram36
1) Because the numbers show that they aren't balanced. Therefore, not balanced. Power balancing is supposed to balance power. It isn't balanced. Not sure what else I can say. The way power balancing is supposed to work is not in relation to "what it is providing power to". It is supposed to be able to balance power properly wherever power is needed. It should not be limited by any one thing. They are all 12 volt inputs and they should all have full ability to balance power properly to whatever 'needs power provided to' at any instant. 2) This card's max power limit is supposed to be 450 watts. In the screenshot, it is being power limited at 405 watts due to PCI-E #2's power limit. Is 405 watts 450 watts? No. If PCI-E #3 wasn't so low (if it balanced properly), PCI-E #2 wouldn't be reaching power limit. Therefore, the card's total performance is being negatively impacted by the inability to balance all of the inputs. 3) The XC3 is not the FTW3. This is the FTW3 which is supposed to be limited to 450 watts. This is a 450 watt card being power limited to 405 watts. How can you justify that by any amount of reasoning? Your only defense would be 'well, maybe this card didn't NEED all of the 450 watts and was limited by something other than power'; but that is not defensible by the fact that it is reporting that the current limit is power. Let me point something out for you. "Power Balance". PCI-E Slot: 47 out of 68 watts PCI-E #1: 135 out of 150 watts PCI-E #2: 154 out of 150 watts PCI-E #3: 67 out of 150 watts Now, use those critical thinking skills to determine whether those numbers are balanced. It's a card with connectors capable of 518 watts, which is limited by EVGA to 450 watts, which is limiting itself to 405 watts by power balancing issues. Same old song and dance. How has EVGA not fixed this?
post edited by ty_ger07 - 2021/06/12 07:04:54
RypeSauce
2021/06/12 07:42:29
is theree anyway we can get someone in here with Ample knowledge on GPU circuitry in this forum help us figure out whats going on ?, like buildzoid ?
TheGuz4L
2021/06/12 07:55:05
So when my Ti goes above 400W in a game or benchmark, the core drops like 50-75Mhz from normal games. Is this normal behavior? Example port royal or heaven. I get 1920-1980 a etc age but in normal games like War Zone and cyberpunk I average 1995/2010mhz and it uses around 390W in those games.
Just want to make sure I’m not missing something
talon951
2021/06/12 08:01:07
TheGuz4L So when my Ti goes above 400W in a game or benchmark, the core drops like 50-75Mhz from normal games. Is this normal behavior? Example port royal or heaven. I get 1920-1980 a etc age but in normal games like War Zone and cyberpunk I average 1995/2010mhz and it uses around 390W in those games.
Seeing different clocks at the same power level is normal. Some games/benchmarks put more load on the GPU than others. Also depends on the resolution you run.
kram36
The Destroyer
- Ribbons : 72
2021/06/12 08:09:55
kram36
kram36
They may not be balanced according to your preferences, but EVGA may have designed the card this way. Like I said, that 3rd power plug isn't needed for a RTX 3080 Ti to run properly, proof is the RTX 3080 Ti XC3 card. One member said the Kingpin RTX 3090 does not do this, but the Kingpin RTX 3090 is a completely different animal.
post edited by kram36 - 2021/06/12 08:11:03
TheGuz4L
2021/06/12 08:16:06
talon951
Port Royal seems to put a big load and knocks down clocks like 75Mhz from normal games. I guess that’s normal?
- Ribbons : 270
2021/06/12 08:29:23
kram36
kram36
kram36
It IS REQUIRED for THIS card to operate at 450 watts. The FTW3 is a 450 watt card which is not balancing properly and therefore this card was only operating at 405 watts. You think it is EVGA's preference for the card to misbehave and power limit early, way below the expected power limit? That is an odd "feature" Quit talking about the XC3 card. The XC3 card isn't a 450 watt card and therefore doesn't need this extra plug. This card does need this third PCI-E power plug. It is messed up man! Just admit it! It's messed up just like the other FTW3 cards of this generation were messed up! EVGA even released a new revision of the 3090 FTW3 to fix this problem! Admit it! But then these cards came out and still have the same old problem!? It's crazy.
post edited by ty_ger07 - 2021/06/12 08:34:45
looniam
2021/06/12 08:47:10
ty_ger07 It IS REQUIRED for THIS card to operate at 450 watts. The FTW3 is a 450 watt card which is not balancing properly and therefore this card was only operating at 405 watts. You think it is EVGA's preference for the card to misbehave and power limit early, way below the expected power limit? That is an odd "feature"
no, it is not required that the card will use that much power. it's still dependent on the quality of silicon. the only thing messed up is the rampant imaginative speculation thats going on. first thing is stop using software readings as gospel and break out a multi meter. second thing is not all chips equal . . nice chat.
i7-3770K/Z77-V Pro/980TI SC+/16Gb @1866/EVGA supernova 750 G2/custom loop
rjbarker
- Ribbons : 21
2021/06/12 08:55:02
kram36
kram36
kram36
Yep here we go again....my non Ti 3080 has had this power balancing since I got it. Although not a huge deal that it cannot achieve 450W with XOC BIOS....still kind of a drag that Im power limited to 400W (yes #3 PCI-E plug same thing, only drawing 1/2 the power of the othe other 2 plugs). My rig is a fairly large Custom Water Loop (3 radiators w 2 Liters of liquid), but I hit an OC wall on my FTW3 Ultra at +165/+930 Boost to 2115 due to "Power Limit" reached (Max temp of GPU is 42c)...kind of a drag when going for those higher Bench runs.. This is a common problem with the 3080 FTW3 Ultras (not all, just some....which is strange). The problem was also identified on the 3090 Cards.
