Nazarus
- Ribbons : 6
Re: No LED after installing Hydro Copper on Hybrid edition of 2080 TI
2019/05/13 20:53:38
☄ Helpfulby Cool GTX 2019/05/17 11:30:58
Finally got it working. Busy week getting everything together for Mother's day celebration for the wife. Essentially to anyone who has this issue the sockets all face the same way on the card from the PCI-E connector. All raised edges on the connectors face towards the waterblock or hybrid water cool lines as they exit the card. Video Card all connectors should face towards this direction. This means when you plug it in the flat side will be on the other side. ^ ^ ^ ^ _______________________ | ■ | < LED Sockets | | | ________________■_■_■ | < Fan Sockets |||||||||
Associates: RQAORCJB8JNEFOB/Affiliate: YTOQRPH9OK
GTXJackBauer
- Ribbons : 48
2019/05/13 21:10:17
Glad to see it finally worked out.
AHowes
- Ribbons : 27
2019/05/14 09:20:50
Nazarus
- Ribbons : 6
2019/05/17 10:23:44
All done. I'll get some more pictures when I'm not in testing mode on the thing. It weighs like 100 lbs...
2019/05/17 10:42:21
Nice pic.
AHowes
- Ribbons : 27
2019/05/17 10:49:32
Good job! I have the same case.. bought it weeks ago and it's just all in pieces on the floor in my basement just waiting on me to figure out how I want to do it and EVGA to release the dang kingpin copper block already!
- Ribbons : 282
Nazarus
- Ribbons : 6
2019/05/17 11:19:56
I had to customize the video cards into that corner. They blocked everything. Didn't feel right having this pretty Aorus loop that was blocked by video cards. Drilled things into place quite a bit on this case. I also had to contact ThermalTake and order an additional PCI bracket so I could hold my capture card on the north side of the case. Still waiting on that to get here then it's going up on the wall like a big 1980s boombox.
- Ribbons : 282
2019/05/17 11:22:32
I removed my NU Audio Card for the same. The Hydro Copper Water Blocks are to nice looking to Cover or Block.
AHowes
- Ribbons : 27
2019/05/17 11:29:58
Nazarus
Looks very Cool
Nice to see someone else double posting every now and then hehe
- Ribbons : 123
2019/05/17 11:35:08
Very Nice Rig, glad your LEDs are working after reversing the plugs (strange that you can reverse the polarity - usually plugs only fit one way) Now you need a Mods Rigs build log - so you can share more pictures & detaild EVGA MODS RIGS
badboy64
2019/05/17 14:06:17
14th Intel® Core™ i9 13900KS CPU 3.2GHz@6.0ghz, Memory 2x24GB GSkill Trident Z Trident Z5 7200 mhz DDR5 Ram,4,000 GB MSI M480 PRO 4TB , Motherboard eVga 690 Dark , Operating System Windows 11 Pro 64-Bit, Msi Suprim X24G 4090, Monitor Acer CG437K, Logitech G910, Razer Lancehead Tournament Edition, Thermaltake View 91 RGB plus, eVga 1600w P2 PSU, Custom watercooling. Speed Way Score 11,144 points. http://www.3dmark.com/sw/1540960
Nazarus
- Ribbons : 6
2019/05/17 18:03:24
Plans are a final lift to mount it on the wall then it's up there for at least 5-10 years. Lol
Nazarus
- Ribbons : 6
2019/05/21 22:22:14
Finally working with the thing. Trying to figure out some Windows related issues but otherwise (BSOD Internal Power Error after wake from sleep) but going great.
GTXJackBauer
- Ribbons : 48
2019/05/21 23:19:22
Nazarus
That is one hell of a setup you got there Naz. Add more pics to your modsrig if possible!
