20219348762341
I'm about to change motherboards and since I'm at it I will take apart my 3 year old Titan Blacks and replace VRM and mosfet thermal pads. I have Heatkiller Blocks so the pads are what came with it, so now once I reinstall them they will stay in my system for next few years again, unless I'm force to take it apart before that. Mosfets take 1mm pads and VRMs 0.5mm, I'm trying to get Fujipoly Ultra or premium, but performancepcs is out of stock and might not have it for a while. Any suggestions on next best thermal pads that will last long and perform well. Also, how long on average thermal pads last before they start losing their thermal conductivity Thanks
- Ribbons : 282
Re: Need help choosing thermal pads
Tuesday, May 16, 2017 4:19 PM
20219348762341
Tuesday, May 16, 2017 4:28 PM
Thanks a lot. I don't know why I struggle with picking thermal pads  , sometimes a little push helps I appreciate that. How long thermal pads can last before they became less conductive, do they even need to be replaced. What i do is check temps with laser gun on VRMs and Mosfets every 6-12 months and if temps are the same I assume they are OK. I have so many systems, some of them I just don't have time to even do regular updates
- Ribbons : 282
Tuesday, May 16, 2017 4:52 PM
I like this of them; The Thermal Conductivity amounts to 6.0 W/mK. Not sure how long, you may need to ask them that question or it may be posted on their site. Arctic
post edited by bcavnaugh - Tuesday, May 16, 2017 4:56 PM
Vlada011
- Ribbons : 11
Tuesday, May 16, 2017 5:29 PM
Give us pictures... We want to see Huge ASUS X99 WS and i7-6950X...
20219348762341
Tuesday, May 16, 2017 6:22 PM
Just ordered my thermal pads, thanks bcavnaugh.Give us pictures... We want to see Huge ASUS X99 WS and i7-6950X... Sorry Vlada, no pictures yet, at least with the board in system  . The original M/B had to be send back for replacement I bricked after updating BIOS so for now i went back to my Rampage 4 black but within 2 weeks I will put it back together, its already here but just don't have time until then  Once I get things in order i will post some nice photos
post edited by AWK16 - Tuesday, May 16, 2017 6:34 PM
Tuesday, May 16, 2017 7:07 PM
I'd go with some thermal grizzly pads.
20219348762341
Tuesday, May 16, 2017 7:14 PM
I'd go with some thermal grizzly pads. I have consider them, but when bcavnaugh posted ARCTIC pads I didn't even know they made pads and I use MX-4 for years and I like it, so this was it for me, already ordered them before I changed my mind again.
- Ribbons : 282
Tuesday, May 16, 2017 7:54 PM
Sajin I'd go with some thermal grizzly pads.
Double the Cost for only 2 more W/mK for the Grizzly 8.0 W/mK Thermal Pads.
Tuesday, May 16, 2017 8:27 PM
Still a low cost imo.
20219348762341
Tuesday, May 16, 2017 8:55 PM
Thermal grizzly....is that a new brand, haven't hears much about is until recent. I might get some for my other systems and compare if there is any difference at all. At this point I care more about longevity, so I don't have to replace them too often, temps.. I think they all might be in close rage, just like with thermal compound. I can't find anywhere on how long they could last thou
Tuesday, May 16, 2017 9:29 PM
AWK16 Thermal grizzly....is that a new brand, haven't hears much about is until recent. I might get some for my other systems and compare if there is any difference at all. At this point I care more about longevity, so I don't have to replace them too often, temps.. I think they all might be in close rage, just like with thermal compound. I can't find anywhere on how long they could last thou
Yes, thermal grizzly is new brand. I also can't find how long thermal pads are suppose to last.
- Ribbons : 282
Tuesday, May 16, 2017 9:32 PM
Thermal Grizzly A New company in Germany. Kryonaut Paste some say better than any other in the World. Minus Pad 8
post edited by bcavnaugh - Tuesday, May 16, 2017 9:39 PM
Yes, thermal grizzly is new brand. I also can't find how long thermal pads are suppose to last. I remember when I was getting my Heatkiller blocks and some extra pads in case I would mess up some during install I asked how long untouched pad (in plastic bag) would last I got an answer from manufacturer ( generic pads) nothing fancy, the once that comes with blocks would last up to 1.5 years, that is shelf life so I would presume good quality thermal pad that is installed and used would lasts few years, maybe life of GPU (3-6 years) or longer  If any of you came across on that, please share here Thermal Grizzly A New company in Germany Usually Germans produce quality stuff. Thank you guys for your input I appreciate that
post edited by AWK16 - Tuesday, May 16, 2017 9:47 PM
Vlada011
- Ribbons : 11
Wednesday, May 17, 2017 6:43 AM
I hear a lot positive comments about Thermal Grizlly pads and thermal paste. We talk about few dollars and no point saving on such things.
wmmills
- Ribbons : 40
Wednesday, May 17, 2017 7:34 AM
MOBO: EVGA x299 Dark, CPU: I9 10900X, RAM: Patriot Viper RGB 3600 32gb, SSD: Samsung 860 EVO 1TB, M2: Samsung 970 EVO+ 1TB, PSU: CoolerMaster M2 1500, CPU HSF: EVGA 240 CLC HSF~ P/P EK Furious Vardar, G-CARD:EVGA RTX3090 FTW3 Ultra Gaming w/Hybrid kit and Noctua IPPC 3000 P/P, CASE: LIAN-LI PC-V2010B w/ Window mod, OS: Windows 10 Pro 64bit, MON: Alienware AW3821DW  New EVGA product? Register it NOW with this link: http://www.evga.com/register/default.asp?affiliatecode=4QFQRAMOII Help Our Vets From K-2! [link=https://strongholdfreedom
20219348762341
Wednesday, May 17, 2017 1:51 PM
Alpfhacool seem close in specs to Fujipoly. I have few systems that I need to do some maintenance over this summer so never to much of thermal pads. I wouldn't mind getting some of the Alphacool Ice Thermal Pad - 11W/mK few sheets of it but the shipping is crazy expensive. The only way I would get this if the shipping was more reasonable and there is 1 but I'm not sure if I can use it its United State postal Service First-Clas Package International Service $10.50. I always use FedEx or UPS and I'm not familiar with this 1. I live in Canada, do you guys know if I could use that service? I know long time ago and that was 3-4 years ago when I was getting my first Caselabs case I used that service, at the time they had that and because I was in Europe on vacation I didn't care about the time, but it took I think 8 weeks, but now I'm not sure about this service if I can still use it?  Didn't see that they don't have any 0.5mm that changes things I wouldn't pay for shipping just to get part of what I need Oooo!! Almost forgot I was asking in my very first post how long thermal pads last or if you ever need to change them..I got an answer from ARCTIC. If you use in normal condition, average ambient temps (21-25C) and card its not OC, you never have to change it, it will last for a long time 6-8 years and upwards. If you live in very hot place (India, Australia, Ethiopia ext.) and you OC your card(s) it will still last long time before you might need to change it (5-7 years) maybe even longer. Personally I think ARCTIC might be the best choice at least for me and I am not a cheap guy, but considering the price and the temps difference between those and the most expensive thermal pads, there is latterly small margin of the difference 1-3 C at best. But what made me lean towards ARCTIC is the amount of reviews that are very positive, very few cons. I already ordered Thermal Grizzly 8 as well so once installed I will have better view on the difference between them. Thank you guys for your help.
post edited by AWK16 - Wednesday, May 17, 2017 3:41 PM
- Ribbons : 282
Wednesday, May 17, 2017 3:45 PM
20219348762341
Wednesday, May 17, 2017 4:00 PM
No they are not cheap  If there was substantial difference between the less expensive and this Aquacool pads than that might be worth it, but there isn't much improvement from what I have seen in some of the reviews on the net. A lot of its marketing hype and brand names, if I got any of it and would see no difference and I'm sure I wouldn't, it would bug me. For a long time (years) I have been using Gelid Extreme compound for my CPUs and GPUs with good results, at least for a while, but after few months I know this my temps would creep out, so when I took one of my systems apart the compound was bone dry and that was not a fluke I took all my systems CPUs apart and they all had the same thing. Emailed Gelid several times, send pictures, never got response and all new tubes I got (10-15) of compound were nothing but oil on top and bone dry powder on the bottom, they all were stored in cool dark place. Ever since then I got MX-4 and I love it. My decision on ARCTIC pads now is based on many positive feedback from all over the place, but if you didn't post them here I wouldn't even know they are in existence , so thank again, it was good help
post edited by AWK16 - Wednesday, May 17, 2017 4:14 PM
Hoggle
Wednesday, May 17, 2017 8:06 PM
The best way to know when to replace the pad would be to monitor the temperature. Make a document and save the temperature and make note of how hot the room is as well. The more you update this the easier it will be to track when the thermal pad starts to lose it's ability to conduct heat as the temperature will start to rise. Also by knowing the temperature and checking it like monthly you can see how often you might need to clean the computer as temperatures will start to rise.
20219348762341
Wednesday, May 17, 2017 9:48 PM
Yes, that is exactly what I do I have temps monitored and stored to compare months later
20219348762341
Friday, May 26, 2017 0:26 PM
Took a week but got them, They feel really nice to the touch. Tomorrow is day of switching back to x99
20219348762341
Wednesday, May 31, 2017 5:23 PM
Its taking longer switching back to x99 than I thought but it's coming along OK I will post the whole thing once is done....soon enough  I got the ARCTIC thermal pads last week, nice texture to them, they feel high quality.
post edited by AWK16 - Wednesday, May 31, 2017 5:29 PM
