https://www.techpowerup.com/310522/montech-launches-the-air-903-max-and-air-903-base-cases MONTECH, an innovative PC components and peripherals brand, announces the launch of its newest addition to the AIR PC Case series - AIR 903. Manufactured with premium grade materials and innovative design; the AIR 903 offers users a wide range of build options along with enhanced cooling performance. The AIR 903 is available in AIR 903 MAX and AIR 903 BASE, available in both black and white. In order to provide users with maximum airflow for high-performance use, the AIR 903 series features an ultra-cooling front panel offering 51% porosity ventilation rate. Dust filters are also equipped at the top and bottom of the case for all-around dust protection.
AIR 903 BASE is equipped with 3 pre-installed HP140 high-performance cooling fans with PWM functions. On the other hand, AIR 903 MAX, is equipped with 4 pre-installed HP140, 3 of which are mounted at the front and features ARGB, and a single HP140 PWM at the rear. The pre-installed fans are connected to MONTECH's LED/PWM controller - allowing users to easily switch between 21 RGB modes with the LED button. (Please note: controller only available for AIR 903 MAX)
Both cases can support up to a total of up to 9 x 120 mm fans, or 6 x 140 mm and 2 x 120 mm cooling fans offering users the ultimate cooling experience. The fan RPM for both cases can be manually adjusted through BIOS.
Hardware Compatibility
AIR 903 is designed and engineered for maximum capacity, compatible for both air cooling and water cooling support. Able to support 360 mm AIO coolers at the front and top, or a maximum height of 180 mm for CPU tower coolers. Furthermore, supporting graphic cards of up to 400 mm length and 190 mm width, with a 240 mm clearance for PSU. It is also compatible with any flagship 4090 GPUs.
In addition, the AIR 903 not only supports True E-ATX form factors, but also SSI-EEB motherboards. Featuring 5 SSD and 2 HDD drive bays, as well as an USB TYPE-C port and USB 3.0 ports.
Easy Cable Management
In order to provide users with a user-friendly cable management system and easy access, the AIR 903 series features a spacious 27 mm cable route with rubber grommets and Velcro straps.
Vertical GPU Mounting
MONTECH AIR 903 features a GPU clearance of 400 mm in length and 190 mm in width for maximum capacity. All PCIe slot covers can be removed to install MONTECH's vertical GPU mounting kit sold separately.
MSRP:
- AIR 903 BASE: Black $65, White $69
- AIR 903 MAX: Black $75, White $79
I can't really say anything bad about a PC case that costs as low as 69 dollars.
