EVGA_Lee
Moderator
- Ribbons : 14
Adds Smart Fan control support for EVGA Z790 motherboards* *Note - EVGA Z690 motherboards must be on BIOS 2.05 or newer to support fan control function. Release Notes: - Adds Smart Fan function to X570 motherboards.
- Supports Z790/Z690/X570 Smart Fan function with profile.
As always, please leave your feedback and let us know if you run into any issues.
Shredder944
Re: Eleet X1 v1.0.16 - Adds Smart Fan control for EVGA Z690 Motherboards
2022/12/31 06:46:11
Hello, I would like to have GPU temp as a source for fan control. There are times the GPU heats up and the CPU does not, making the case fans unreliable to cool the graphics card when it warms up from gaming. Also, an ability to name the fans can be helpful to see which one you are setting.
harleyroadking
2023/01/03 05:34:49
I am getting a random error at start up its a ring0 error?
CASE: Corsair 7000DMB: EVGA Z690 CLASSIFIEDCPU: I9 12900KSRAM: 16 Gb ram GSkill Trident DDR5 6000 MhzSSD NVMe: Samsung Gen 4 NVMe 500 Gb, NVMe 2 tbGPU: EVGA RTX 3090 TIPSU: EVGA SUPERNOVA 1600W P+MOUSE: EVGA X20KEYBOARD: EVGA Z20
B0baganoosh
- Ribbons : 39
2023/01/03 07:13:00
harleyroadking I am getting a random error at start up its a ring0 error?
Try without Precision X1 running (if you have that running). I think there may have also been an issue previously where the registry for ELEET was pointing at the wrong EVGA folder, and reinstalling was supposed to fix it.
harleyroadking
2023/01/03 08:15:21
I read about that and checked to make sure that the registry was pointing to the correct folder, and it does.
EVGA_Lee
Moderator
- Ribbons : 14
2023/01/05 09:49:41
harleyroadking I read about that and checked to make sure that the registry was pointing to the correct folder, and it does.
What other EVGA software do you have installed?
harleyroadking
2023/01/07 05:57:24
I am running unleashed RGB and precision X1.
gavinheng
2023/01/11 02:37:53
After installation i get the following prompt when i try to launch "Turn off the memory integrity toggle to disable VBS on your Windows PC" It then opens up my Microsoft Security settings Window Any idea how do i fix this or what should i disable ?
> Mainboard: EVGA Z690 Dark Kingpin> CPU: Intel Core i9-12900K> Physical Memory: G.SKILL Trident Z5 32GB (2 x 16GB) DDR5 5600> PSU: Corsair AX1200i> Monitor: LG UltraGear 34GN850B> Video Card: EVGA 3080ti FTW3 > Cooling: Optimus Cooling CPU & GPU, AquaComputer D5 Next, 2x EK Quantum Surface 360
ObscureEmpyre
- Ribbons : 7
2023/01/11 20:44:57
gavinheng After installation i get the following prompt when i try to launch "Turn off the memory integrity toggle to disable VBS on your Windows PC" It then opens up my Microsoft Security settings Window Any idea how do i fix this or what should i disable ?
This is still an issue? I haven’t used Eleet X1 in months, but the last version I used presented it. Still curious what the cause is.
suzukiro
2023/01/12 02:18:40
Is it possible to add essential voltages, like Vsa/Cpu Vddq , Mem Vdd/Vddq ? I don't see the point of the ones that are curently in, there is no fine tuning and none are needed in the current software besides Cpu and Atom voltages. Finding sweetspot for imc is a pain when everytime you have to adjust from bios.
harleyroadking
2023/01/13 14:01:08
@ Evga_Lee. I am running unleashed RGB and precision X1.
post edited by harleyroadking - 2023/01/13 14:02:29
D13mas
2023/01/15 13:48:12
And we have the same issues: (can not add links here, but if try to find "EVGA ELEET X1" in search field - a few first topics) I don`t know how to fix it.
post edited by D13mas - 2023/01/15 13:50:10
13700KF(5600MHz), 32Gb DDR5(7400MHz), RTX4090FE, Z690 Classified, Corsair HX1500i, Custom water loop
B0baganoosh
- Ribbons : 39
2023/01/19 13:40:56
Pulled from the 1.0.15 thread: madman23 Having issues with newest ELEET version. When I change anything and click Apply the system freezes and requires a hard restart (holding Power button down). ELEET version v1.0.15 Z690 Classified firmware v1.02 - Bios 2.05 i9 12900K everything running stock
I experienced this issue last night. I haven't updated to 1.0.16 yet. I was wondering if this issue was addressed? There was no reply on the 1.0.15 thread. I can use the fan settings, but last night was the first time I tried to use ELEET to change the voltage and multipliers since going to 1.0.15.
0mnious
2023/01/20 20:38:51
Thank you!
post edited by 0mnious - 2023/01/24 04:15:55
i_cruz
2023/01/31 22:17:51
D13mas And we have the same issues: (can not add links here, but if try to find "EVGA ELEET X1" in search field - a few first topics) I don`t know how to fix it.
Hi, Any word on how to get Eleet X1 working on the Z690 Classified? I have tried running it as an administrator, uninstalling it, and installing it again to no avail. Thank you!
> PSU: OCZ Fatal1ty 1000W> Mainboard: EVGA Z690 CLASSIFIED (BIOS 2.08)> AIO: EVGA CLC 280mm AIO> CPU: Intel i7-13700k 3.4GHz> Physical Memory: G.SKILL Trident Z5 64GB (4 x 16GB) DDR5 > Physical Memory Model#: F5-6400J3239G16GA2-TZ5RK> Monitor: Samsung G9> Video Card: EVGA RTX 3090 Ti FTW3[URL=https://www.evga.com/associates/default.aspx?associatecode=HV4ZYIDMNODLH84] [
Ekwb1103
2023/02/20 04:34:35
Add please dimm rgb control as a mystic light and etc also add please "turn off when monitor sleeping" function
PC - 13700KF | Z690 Classified | 32gb DDR5 | 4080 Gaming OC | Lian Li Dynamic EVO | Lian Li Galahad 360 Uni | Deepcool PQ1000M | 10 UNI FAN SLDevices - Gigabyte M27Q X | Razer Viper Ultimate | Razer Blackvidow V3 pro | Sennheiser RS175
i_cruz
2023/02/24 18:04:58
Hi All, Tried reinstalling Eleet X1 from scratch and when I tried to run the application, the same issue is still present. The Eleet X1 is just a black window and if click on it, it crashes every time. Any help is appreciated! Below is the information from Windows Event Viewer: EleetX1 1.0.16.0 Crashing Error Info from Event Viewer: Event 1026, .NET Runtime Application: ELeetX.exe Framework Version: v4.0.30319 Description: The process was terminated due to an unhandled exception. Exception Info: System.NullReferenceException at ELeetX.App.PrismApplication_DispatcherUnhandledException(System.Object, System.Windows.Threading.DispatcherUnhandledExceptionEventArgs) at System.Windows.Threading.Dispatcher.CatchException(System.Exception) at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(System.Object, System.Delegate, System.Object, Int32, System.Delegate) at System.Windows.Threading.Dispatcher.LegacyInvokeImpl(System.Windows.Threading.DispatcherPriority, System.TimeSpan, System.Delegate, System.Object, Int32) at MS.Win32.HwndSubclass.SubclassWndProc(IntPtr, Int32, IntPtr, IntPtr) at MS.Win32.UnsafeNativeMethods.DispatchMessage(System.Windows.Interop.MSG ByRef) at System.Windows.Threading.Dispatcher.PushFrameImpl(System.Windows.Threading.DispatcherFrame) at System.Windows.Application.RunDispatcher(System.Object) at System.Windows.Application.RunInternal(System.Windows.Window) at ELeetX.App.Main() Event 1000, Application Error Faulting application name: ELeetX.exe, version: 1.0.16.0, time stamp: 0xa6a74a7e Faulting module name: unknown, version: 0.0.0.0, time stamp: 0x00000000 Exception code: 0xc0000005 Fault offset: 0x00007ff885dc3ca7 Faulting process id: 0x0x73A8 Faulting application start time: 0x0x1D94897C12ABD99 Faulting application path: C:\Program Files (x86)\EVGA\ELEET_X1\ELeetX.exe Faulting module path: unknown Report Id: e59df7d8-adec-4d27-ad9f-d9852bd1b8da Faulting package full name: Faulting package-relative application ID: Information from Windows Log: Event 1001, Windows Error Reporting Fault bucket 1708944317550192537, type 5 Event Name: CLR20r3 Response: Not available Cab Id: 0 Problem signature: P1: ELeetX.exe P2: 1.0.16.0 P3: a6a74a7e P4: ELeetX P5: 1.0.16.0 P6: a6a74a7e P7: a P8: 32 P9: System.NullReferenceException P10: ~ ~ Rechecking for solution: 0 Report Id: e59df7d8-adec-4d27-ad9f-d9852bd1b8da Report Status: 268435456 Hashed bucket: 14af17e78e7b9a3de7b763cd6c806799 Cab Guid: 0
quadlatte
- Ribbons : 56
2023/03/05 14:19:44
I was getting the ring 0 error also, I removed precision since I don't have a EVGA GPU anymore and error has gone away. It's sad that EVGA has always had issues getting their software to play nice together.
Cpt.Derrek
2023/03/07 11:15:07
Hi All, I had similar situations with Eleet X1 not loading and would load a black screen the crash. In Bios for cpu configuration I enabled undervolt protection and presto! Eleet X1 working again! I noticed when opening Intel XTU one of the requirements was that and it fixed my Eleet Issue, hopefully this helps others.
13900k Unleashed and undervolted EVGA Z690 Classified 64Gb G.Skill 6400Mhz CL32 EVGA RTX 3080ti Hydrocopper @2Ghz
suzukiro
2023/03/22 02:26:59
"Is it possible to add essential voltages, like Vsa/Cpu Vddq , Mem Vdd/Vddq ? I don't see the point of the ones that are curently in, there is no fine tuning and none are needed in the current software besides Cpu and Atom voltages."
Is it a dead topic :D ?
i_cruz
2023/03/30 21:44:38
Cpt.Derrek Hi All, I had similar situations with Eleet X1 not loading and would load a black screen the crash. In Bios for cpu configuration I enabled undervolt protection and presto! Eleet X1 working again! I noticed when opening Intel XTU one of the requirements was that and it fixed my Eleet Issue, hopefully this helps others.
I tried this ^^^ and finally, Eleet X1 started working. Thank you!
Volumetrik
2023/05/05 07:47:26
Is this possible to add on Z590 motherboards ?
i7-920 D0 | 4-Way Classy| 12GB ST 2000 | GTX 580 3GB | 60GB Mushkin SSD | HAF X | HX850
shephp01
2023/05/17 18:29:08
shephp01
2023/05/17 18:35:24
I'm running the latest firmware for Z690 - v2.13. However Eleet starts with this: Your Z690 firmware needs to be updated. Click Start to start the process. *DO NOT TURN OFF WHILE UPDATE IS IN PROGRESS* I am worried that it will downgrade the bios and remove support for Intel 13th gen. Any suggestions to get past this screen? edit: text only post; I guess the EVGA forum does not like to show images?
sneefy
2023/05/19 09:19:26
shephp01 I'm running the latest firmware for Z690 - v2.13. However Eleet starts with this: Your Z690 firmware needs to be updated. Click Start to start the process. *DO NOT TURN OFF WHILE UPDATE IS IN PROGRESS* I am worried that it will downgrade the bios and remove support for Intel 13th gen. Any suggestions to get past this screen? edit: text only post; I guess the EVGA forum does not like to show images?
Same. Assuming maybe need to wait for the newer version of the program? Back to going to the bios and setting my fans to max while I try to tame the 400 watt i9
post edited by sneefy - 2023/05/19 09:22:37
shephp01
2023/05/19 09:56:31
sneefy
I went ahead and "updated" with the same firmware. It seemed to have worked, and it was worth it to get ELEET working; happy to get to tune the fan profiles.
Black_Hawx1
2023/08/12 13:38:45
The memory tweaking part is only for K processors? been trying to activate the MEMORY tab without any successful results Im using the 2.12 BIOS version in my Z690 classified. The fan controller is working properly
MONITOR: MSI 27" IPS MAG274R2 G-Sync 165Hz 1080PCASE: EVGA DG 77 BLACK -MODDEDMB: EVGA Z690 CLASSIFIED (BIOS 2.12)CPU: i5 12400 5.3 GHZ overclocked via BCLKAIO: Asus ROG Ryuo 120 -MODDEDRAM: 32 Gb ram Corsair DOMINATOR DDR5 5200 MhzSSD NVMe: WD SN850 NVMe 500 Gb 7000 mb/s (+500 x2 SATA3 SSD)GPU: EVGA RTX 3060 12 Gbs XCPSU: EVGA P6 SUPERNOVA 1000W PLATINUM MOUSE: G Pro X SuperlightKEYBOARD: G915
build: https://i.imgur.com/s56ZcCq.jpeg
Black_Hawx1
2023/10/12 08:12:38
When I activate Hyper-V or Windows Sandbox (win 11) Eleet x1 stops working, evga precision x1 and DG tuner keeps working fine, but Eleet just crashes. is there any way to fix this?
jason9755
2023/10/12 09:24:38
Turn off Core Isolation memory integrity and always run Eleet x1 as admin.
PSU: EVGA SuperNOVA 1000 G6MB: EVGA Z690 CLASSIFIED (bios v. 2.12)CPU: Intel Core i9-12900KCPU Cooler: EVGA CLC 360mmMemory: Corsair 32 GB (2 x 16GB) DDR5 6000mhzMonitor: Alienware AW2521H GPU: EVGA 3080 Ti FTW3 ULTRA Case: Corsair 5000D Airflow OS: Windows 11 ProKeyboard: EVGA Z20Mouse: Finalmouse Starlight Poseidon
