schoolofmonkey
Re: Help, Riser compatible with evga RTX 3090 FTW3 ULTRA HYBRID GAMING and Sfx power suppl
2021/02/17 13:22:35
EthanBurke No, I think I will get a Lian Li PC-O11 Dynamic. But I have a question, in the mini model, did you put the 3090 hybrid vertically? I have ordered the Lian Li PC-O11 Dynamic model, unfortunately there is no stock at the moment.
I mounted both ways in the mini, both cooked the card. But what mech9t5 said, the tubes touch the glass, so vertical is the best way to go, though in the mini you have to cut the horizontal PCI cover holders (little structural supports running across the pci slots) unlike the standard Dynamic that already is clear. I have a mini I can't even sell cause I cut the supports.
EthanBurke
2021/02/17 14:45:50
mech9t5
EthanBurke
schoolofmonkey DON'T GET THE O-11 MINI!! Tried that myself, you can get a Silverstone 1000w Platinum SFX-L power supply, it runs my 3090 XC3/5900x system fine, but the mini is a oven unless you run your case fans at 100% or a fully water cooling. https://www.silverstonetek.com/product.php?pid=965&area=en
I now have everything in a standard O-11 Dynamic, way better, I reused the 1000w SFX-L PSU using a ATX bracket, this has been running a Inn30 RTX 3090, now the 3090 XC3 Hybrid for a little over 2 weeks with no issues. Power draw barely hits 750w from the wall, the Silverstone is a little loud as it doesn't have zero fan, so it will be replaced at some point closer to winter, the AC drowns out the noise currently...
You will need to install the hybrid vertically. If you install card horizontally, the tubes will be touching the side glass. Take a look at the picture below. The case is the Lian Li O11D Air, but it has the same dimensions.
I have looked at two other pc cases: -A micro atx: -Un micro atx: https://es.thermaltake.com/level-20-vt.html Another user has mounted it there, it has fit everything incredibly Y: And Atx Case: https://es.thermaltake.com/level-20-xt.html What do you think?
mech9t5
2021/02/17 15:21:05
Both might work for the 3090 hydrid for tube clearances. It looks The 20-XT would have more space to accommodate the hybrid tubes as compared to the 20-VT because in the 20–XT, you can put a 140 fan or radiator at the rear. You can only put a 120 fan or radiator at rear in the 20-VT.
Associate Code: P7JUX093GU7RID0
EthanBurke
2021/02/17 15:43:19
mech9t5 Both might work for the 3090 hydrid for tube clearances. It looks The 20-XT would have more space to accommodate the hybrid tubes as compared to the 20-VT because in the 20–XT, you can put a 140 fan or radiator at the rear. You can only put a 120 fan or radiator at rear in the 20-VT.
But in the Vt you can put two 240 tradiators on top. The graph can be placed vertically or horizontally?
mech9t5
2021/02/17 16:12:44
Quite honestly, if I had the choice, I would go for the 20-XT. More space to work with. But I don’t want to tell you what to buy. Based on the website, It seems that the video card can be installed as shown in the ThermalTake website. Just make sure the radiator fans for the video card is blowing out from the case.
post edited by mech9t5 - 2021/02/17 16:17:07
Ajax0z
2021/02/18 02:30:03
Hiya, My LianLi O11 Dynamic with the new EK riser holding the 3090. It uses screws and spacers on the mobo for the bracket to avoid any sag, works astonishingly well. Those Noctuas I have in there blow past front and back of the GPU so all is kept cooler. :)
post edited by Ajax0z - 2021/02/18 02:42:07
EthanBurke
2021/02/18 08:38:06
