Help, Riser compatible with evga RTX 3090 FTW3 ULTRA HYBRID GAMING and Sfx power supply
EthanBurke
2021/02/16 12:31:32 (permalink)
Hello, I want to put the graph vertically. I have looked at various risers but I have read that some could give compatibility problems.
I have looked at the model of cosair:
https://www.corsair.com/es/es/Categor%C3%ADas/Products/Accesorios-%7C-Piezas/Componentes-para-PC/Fuentes-de-alimentaci%C3%B3n/Cable-de-extensi % C3% B3n-PCIe-3-0-x16-Premium-300% C2% A0mm / p / CC-8900243
I've also looked at sfx power supplies: https://www.silverstonetek.com/product.php?pid=670&area=es How about that model?
36 Replies Related Threads
    Dabadger84
    • Ribbons : 10
    Re: Help, Riser compatible with evga RTX 3090 FTW3 ULTRA HYBRID GAMING and Sfx power suppl 2021/02/16 12:44:23 (permalink)
    That PSU with a 3090 is asking for trouble.  Just putting that out there.
    Unless you're running it with a very lower power draw CPU (which would make zero sense because a 3090 needs all the CPU you can give it, see Hardware Unboxed's video on CPU scaling with Ryzen 5s on the 3090 they put out recently) - I would not risk that.
    I don't think there's an SFX power supply that is actually completely "safe" for the 3090.  That Silverstone is decent, but I wouldn't do it personally.
    ModRigs: https://www.modsrigs.com/detail.aspx?BuildID=42891
    Specs:
    5950x @ 4.7GHz 1.3V - Asus Crosshair VIII Hero - eVGA 1200W P2 - 4x8GB G.Skill Trident Z Royal Silver @ 3800 CL14
    Gigabyte RTX 4090 Gaming OC w/ Core: 2850MHz @ 1000mV, Mem: +1500MHz - Samsung Odyssey G9 49" Super-Ultrawide 240Hz Monitor
    EthanBurke
    Re: Help, Riser compatible with evga RTX 3090 FTW3 ULTRA HYBRID GAMING and Sfx power suppl 2021/02/16 13:14:42 (permalink)
    kevinc313
    • Ribbons : 22
    Flagged as Spam (4)
    Re: Help, Riser compatible with evga RTX 3090 FTW3 ULTRA HYBRID GAMING and Sfx power suppl 2021/02/16 13:23:29 (permalink)
    wHy ArE aLl ThE 3o9oS fAiLiNg.....?
    • Ribbons : 135
    Flagged as Spam (1)
    Re: Help, Riser compatible with evga RTX 3090 FTW3 ULTRA HYBRID GAMING and Sfx power suppl 2021/02/16 13:25:32 (permalink)
    EthanBurke
    and this??
    https://www.corsair.com/e...Series/p/CP-9020186-EU
    I'd be concerned that you're apparently considering building a SFF system, with a 3090 stuffed in it?
    You might get some better replies if you gave us more information on what you're trying to accomplish.
    • Ribbons : 135
    Flagged as Spam (3)
    Re: Help, Riser compatible with evga RTX 3090 FTW3 ULTRA HYBRID GAMING and Sfx power suppl 2021/02/16 13:26:03 (permalink)
    kevinc313
    Go away troll, reported.
    kevinc313
    • Ribbons : 22
    Re: Help, Riser compatible with evga RTX 3090 FTW3 ULTRA HYBRID GAMING and Sfx power suppl 2021/02/16 13:31:04 (permalink)
    kevinc313
    You're the troll here, reported.
    https://knowyourmeme.com/memes/lurk-moar
    • Ribbons : 86
    Re: Help, Riser compatible with evga RTX 3090 FTW3 ULTRA HYBRID GAMING and Sfx power suppl 2021/02/16 13:31:22 (permalink)
    Yes, please keep this thread on target of the OP.
    EthanBurke
    Re: Help, Riser compatible with evga RTX 3090 FTW3 ULTRA HYBRID GAMING and Sfx power suppl 2021/02/16 13:32:29 (permalink)
    [quote = HeavyHemi]
    [cita = EthanBurke]
    ¿¿y esto??
    [/cita]
    Me preocuparía que aparentemente estés considerando construir.
    Ese es mi gabinete. Puede encajar un 3090 perfectamente, es Atx pero la fuente es el sistema sfx.ga SFF, ¿con un 3090 relleno?
    Es posible que obtenga mejores respuestas si nos brinda más información sobre lo que está tratando de lograr.
    [/cita]
    That is my cabinet. You can fit a 3090 perfectly, it is Atx but the source is sfx.
    https://lian-li.com/product/o11-dynamic-mini/
    kevinc313
    • Ribbons : 22
    Flagged as Spam (2)
    Re: Help, Riser compatible with evga RTX 3090 FTW3 ULTRA HYBRID GAMING and Sfx power suppl 2021/02/16 13:33:25 (permalink)
    EthanBurke
    and this??
    Thank you captain obvious for blessing us with your infinite wisdom.  We are truly grateful that you participate in this thread.
    BLESSED
    phroze
    Re: Help, Riser compatible with evga RTX 3090 FTW3 ULTRA HYBRID GAMING and Sfx power suppl 2021/02/16 13:52:15 (permalink)
    EthanBurke
    and this??
    Not enough. Even 850 is pushing it. I was hitting overcurrent protection with an 850. 1000+ is recommended. With an overclock and especially if you are running an intel CPU 1200+
    Case: Lian Li O11 Dynamic XL
    Mobo: Asrock X570 Taichi
    CPU: Ryzen 5900x
    GPU: EVGA RTX 3090 FTW3 Ultra
    RAM: Crucial Ballistix OC to 3800 16 18 18 1:1
    PSU: EVGA SuperNova G2 1600w
    Cooling: Custom hardline loop: optimus blocks, primochill stuff, lian li stuff, HW Labs 60mm radiators, custom stuff
    EthanBurke
    Re: Help, Riser compatible with evga RTX 3090 FTW3 ULTRA HYBRID GAMING and Sfx power suppl 2021/02/16 13:55:24 (permalink)
    phroze
    EthanBurke
    and this??
    I have not overlocked. The processor is a ryzen. There are users moving it with a 650w power supply
    phroze
    Re: Help, Riser compatible with evga RTX 3090 FTW3 ULTRA HYBRID GAMING and Sfx power suppl 2021/02/16 13:56:45 (permalink)
    EthanBurke
    phroze
    EthanBurke
    and this??
    Not with an FTW3 Ultra
    CPU: Ryzen 5900x
    kevinc313
    • Ribbons : 22
    Flagged as Spam (2)
    Re: Help, Riser compatible with evga RTX 3090 FTW3 ULTRA HYBRID GAMING and Sfx power suppl 2021/02/16 13:57:14 (permalink)
    phroze
    EthanBurke
    and this??
    Dead GPU in how many days?
    phroze
    Flagged as Spam (2)
    Re: Help, Riser compatible with evga RTX 3090 FTW3 ULTRA HYBRID GAMING and Sfx power suppl 2021/02/16 13:58:48 (permalink)
    kevinc313
    phroze
    EthanBurke
    and this??
    Your dad is going to get mad when he finds out you are using his account here on the forum. Get lost.
    CPU: Ryzen 5900x
    kevinc313
    • Ribbons : 22
    Flagged as Spam (1)
    Re: Help, Riser compatible with evga RTX 3090 FTW3 ULTRA HYBRID GAMING and Sfx power suppl 2021/02/16 14:02:41 (permalink)
    phroze
    kevinc313
    phroze
    EthanBurke
    and this??
    What are you and HeavySemi the fun police?  You should be roomates at the old folks home.
    I'm pretty sure the 3090 FTW3 Hybrid runs at like 400W out of the box. My 3080 FTW Hybrid is like 380W and I use a 1300w PSU.
    phroze
    Re: Help, Riser compatible with evga RTX 3090 FTW3 ULTRA HYBRID GAMING and Sfx power suppl 2021/02/16 14:08:41 (permalink)
    kevinc313
    phroze
    kevinc313
    phroze
    EthanBurke
    and this??
    The transient spikes are well over 500 watts. Happens in heavily ray traced games. With my 850 it would hit OCP within 1 minute of playing ray traced minecraft. In WOW sometimes it would last an hour before hitting OCP.
    CPU: Ryzen 5900x
    • Ribbons : 271
    Re: Help, Riser compatible with evga RTX 3090 FTW3 ULTRA HYBRID GAMING and Sfx power suppl 2021/02/16 14:16:01 (permalink)
    phroze
    kevinc313
    phroze
    kevinc313
    phroze
    EthanBurke
    and this??
    You guys all agree with eachother.  Why are your arguing?
    Lord Winchester
    Re: Help, Riser compatible with evga RTX 3090 FTW3 ULTRA HYBRID GAMING and Sfx power suppl 2021/02/16 14:23:11 (permalink)
    kevinc313
    phroze
    kevinc313
    phroze
    EthanBurke
    and this??
    My 3090 with stock bios spikes 460 watt.
    With the XOC BIOS I have logged a handful of 520w Spikes (with an average of 470w) You really don't want to cheap out on PSU
    Dabadger84
    • Ribbons : 10
    Re: Help, Riser compatible with evga RTX 3090 FTW3 ULTRA HYBRID GAMING and Sfx power suppl 2021/02/16 15:44:19 (permalink)
    kevinc313
    phroze
    EthanBurke
    and this??
    I give it 2 weeks max.
    Y'all be gettin' all kindsa bent when he's joking around.  Learn from other's mistakes, have some gigs & move on.
    I would not do an SFX build with a 3090, that's personal preference, there aren't any PSUs in that form factor that are FOR SURE going to be able to handle the 3090's spikes I don't think.  Good luck to the OP if he chooses to proceed anyway, RIP 3090 we hardly knew ye.
    Specs:
    EthanBurke
    Re: Help, Riser compatible with evga RTX 3090 FTW3 ULTRA HYBRID GAMING and Sfx power suppl 2021/02/16 15:47:10 (permalink)
    Dabadger84
    kevinc313
    phroze
    EthanBurke
    and this??
    So if I buy a 750 watt sfx thing, my rtx 3090 will end up breaking down ???
    kevinc313
    • Ribbons : 22
    Re: Help, Riser compatible with evga RTX 3090 FTW3 ULTRA HYBRID GAMING and Sfx power suppl 2021/02/16 16:11:26 (permalink)
    phroze
    kevinc313
    phroze
    kevinc313
    phroze
    EthanBurke
    and this??
    Cuz Internetz.
    This guy is going to be way undergunned with the SFF psu.  That Lian Li case is not intended for a 500W gpu.  I've had my 3080 spike to 485w and average 445w.
    post edited by kevinc313 - 2021/02/16 16:13:29
    kevinc313
    • Ribbons : 22
    Re: Help, Riser compatible with evga RTX 3090 FTW3 ULTRA HYBRID GAMING and Sfx power suppl 2021/02/16 16:16:18 (permalink)
    EthanBurke
    Yes.  We all recommend a very high quality and well reviewed 1000w Gold PSU or better to run the 3090 FTW3 Ultra, air cooler or hybrid.
    Just get a standard O11 case, skip the mini version.  You can even run bottom intake and dual exhausting radiators, which will please Debadger.
    #23
    EthanBurke
    Re: Help, Riser compatible with evga RTX 3090 FTW3 ULTRA HYBRID GAMING and Sfx power suppl 2021/02/16 16:18:07 (permalink)
    kevinc313
    EthanBurke
    Thanks
    #24
    kevinc313
    • Ribbons : 22
    Re: Help, Riser compatible with evga RTX 3090 FTW3 ULTRA HYBRID GAMING and Sfx power suppl 2021/02/16 16:20:13 (permalink)
    EthanBurke
    kevinc313
    EthanBurke
    Thanks
    #25
    EthanBurke
    Re: Help, Riser compatible with evga RTX 3090 FTW3 ULTRA HYBRID GAMING and Sfx power suppl 2021/02/16 16:24:32 (permalink)
    Yo haré eso. Muchas gracias a todos por vuestra ayuda. Eres maravilloso.
    The only doubt I have now is the type of laugh that I will have to use to place the graphics card vertically
    #26
    phroze
    Re: Help, Riser compatible with evga RTX 3090 FTW3 ULTRA HYBRID GAMING and Sfx power suppl 2021/02/16 18:54:57 (permalink)
    Dabadger84
    kevinc313
    phroze
    EthanBurke
    and this??
    It just the dead horse being beaten to death over and over again. Gets to you. I want to pretend my card will never die lol.
    CPU: Ryzen 5900x
    #27
    schoolofmonkey
    Re: Help, Riser compatible with evga RTX 3090 FTW3 ULTRA HYBRID GAMING and Sfx power suppl 2021/02/16 19:33:29 (permalink)
    DON'T GET THE O-11 MINI!!
    Tried that myself, you can get a Silverstone 1000w Platinum SFX-L power supply, it runs my 3090 XC3/5900x system fine, but the mini is a oven unless you run your case fans at 100% or a fully water cooling.
    https://www.silverstonetek.com/product.php?pid=965&area=en
    I now have everything in a standard O-11 Dynamic, way better, I reused the 1000w SFX-L PSU using a ATX bracket, this has been running a Inn30 RTX 3090, now the 3090 XC3 Hybrid for a little over 2 weeks with no issues.
    Power draw barely hits 750w from the wall, the Silverstone is a little loud as it doesn't have zero fan, so it will be replaced at some point closer to winter, the AC drowns out the noise currently...
    #28
    EthanBurke
    Re: Help, Riser compatible with evga RTX 3090 FTW3 ULTRA HYBRID GAMING and Sfx power suppl 2021/02/17 11:23:10 (permalink)
    schoolofmonkey
    No, I think I will get a Lian Li PC-O11 Dynamic. But I have a question, in the mini model, did you put the 3090 hybrid vertically? I have ordered the Lian Li PC-O11 Dynamic model, unfortunately there is no stock at the moment.
    #29
    mech9t5
    Re: Help, Riser compatible with evga RTX 3090 FTW3 ULTRA HYBRID GAMING and Sfx power suppl 2021/02/17 11:58:34 (permalink)
    EthanBurke
    schoolofmonkey
    You will need to install the hybrid vertically. If you install card horizontally, the tubes will be touching the side glass. Take a look at the picture below. The case is the Lian Li O11D Air, but it has the same dimensions.
    post edited by mech9t5 - 2021/02/17 12:03:21
    Associate Code: P7JUX093GU7RID0
    #30
