Wallzii
Re: Has anyone had problems with a RTX 3080 and it's 10GB of Vram?
2020/10/18 14:45:16
I'm also not seeing any mention of performance loss in Wolfenstein: Young Blood at maximum settings ("Mein Leben") with the RTX 3080 by any publication I've read. All are reporting huge FPS numbers compared to previous gen cards (90FPS average as a minimum without DLSS and RT enabled, much higher with DLSS on) at 4K.
Seems you're an isolated case.
EVGA RTX 3080 FTW3 Ultra | Ryzen 5 3600 | 16GB Corsair Vengeance LPX 3600MHzSabrent Rocket 1TB NVMe PCIe M.2 2280 SSD | 2x Samsung 860 EVO 1TB SATA SSDCorsair RM750x | Dark Rock Pro 4 | Meshify C
notarjy
2020/10/18 14:57:53
I have GTA V opened and with 4k max settings (no frame scaling), and in GPU-z I am not seeing it go above 7.9-8gb memory usage with everything maxed out. Drove all around the map, fps fluctuates in different areas as expected, but memory usage only goes up or down by a few 100mbs. I am not seeing any sort of build up of usage over time or major hits based on location. I will keep playing and see what happens, as I am curious.
9700k @ 5.0Ghz 1.3v AVX0 EVGA RTX 3080 FTW3 Ultra
Shikhee
2020/10/18 15:04:07
A game allocating RAM does not mean that the game is using all of said allocation.
MatthewAMEL
2020/10/18 15:07:43
Fairly easy to point out that both Nvidia and AMD’s top consumer gaming cards are coming with 10+ vram. Just to check a box?
Or because they are listening to developers who have been asking for more vram?
The 3090 has 24GB The 3080 is getting 20GB The 6900 is getting 16GB (minimum) The 3070 is getting 16GB Navi 22 is getting 12GB.
Needing 10+ GB is getting ready to be mainstream in AAA games.
lantern48
2020/10/18 15:09:29
Shikhee A game allocating RAM does not mean that the game is using all of said allocation.
Again, because this seems really difficult to grasp for some people: when I hit 9.8 GB's or over in 3 different games, there is massive FPS loss and stuttering. Keeping it under that number, everything runs fine. This is 100% reproduceable. Another person admits to starting off Grand Theft Auto V at a bit above 9 GB's at 4k max settings. Do you understand? This isn't that hard or confusing. You can test and see for yourself.
ghastlyone
2020/10/18 15:11:12
It's like clock work every new generation of GPU release. We heard the same thing with the 3gb GTX 780 vs 6gb 780. The 2gb GTX 960 vs 4gb model. The 8gb models on the 20 series. Now we're at the 30 series and being told 10gb isn't enough VRAM. You want to know a card that was truly VRAM limited? AMD's R9 Fury X. I've watched dozens of reviews of the 30 series now, and not one mentioned "catastrophic loss in performance" dude do lack of VRAM. Stop with your non sense hyperbole.
Wallzii
2020/10/18 15:12:09
lantern48
Wallzii
Uneducated opinion? Sorry, but I'm citing multiple independent 3rd-party reviews which report zero of the issues you're speaking of. Those aren't opinions, those are facts, and your inability to accept that doesn't change anything.
Looks like you need to take your own advice and do your own research.
Show me where your sources are exceeding V-RAM and not having terrible performance loss.
Go ahead. I'll wait, but I won't hold my breath for something you can't do.
None of the independent reviews are reporting any performance issues at maximum settings at 4K. Are you claiming that your machine running at the same settings and resolution somehow consumes more VRAM than these independent tests? Additionally, if your testing methodology is so definitive in determining that your performance loss is due explicitly to VRAM usage, how are you measuring your actual USAGE (not allocation)? This is a widely documented fact that allocation does not equal actual usage, and different developers use different allocation methods for their games. Do you care to elaborate further on why anyone should believe you over multiple independent sources that do not experience the same problem?
ghastlyone
2020/10/18 15:13:11
By the way, I've had Black Ops 3 "use" (allocate) all 11gb of VRAM on my 1080 Ti. I've yet to see a "catastrophic loss in performance" on that title.
lantern48
2020/10/18 15:23:51
ghastlyone By the way, I've had Black Ops 3 "use" (allocate) all 11gb of VRAM on my 1080 Ti. I've yet to see a "catastrophic loss in performance" on that title.
*sigh* So you're stating that when you ACTUALLY exceed V-RAM usage, there is no performance loss? That everything is fine? Do you have a 3080 to test any of the 3 games I'm stating exceed V-RAM and can 100% reproduce? That's rhetorical. No, you don't. Just more opinions instead of actually testing. I think I can have 200 FPS in Control at 4k, but I don't have the game and can't test. <---------- Amazing opinion. You should believe it without question.
post edited by lantern48 - 2020/10/18 15:32:10
bloodshot45
2020/10/18 15:26:35
Exactly and no game developer is stupid enough to cause "catastrophic loss in performance" on purpose for users that have 10GB of VRAM or less. Game companies are smart enough to know the main target audience will be those that have less VRAM NOT more. I've yet to run into 1 steam game where my 3080 FTW3 Ultra has major performance issues due to having only 10GB of VRAM. There is also a reason 3080's are being distributed far more than 3090's and that is price so clearly the best business decision is to target a 3080 NOT a 3090. But yes, stop feeding the "troll". The "troll" is clearly having buyers remorse and is now trying to make himself feel better for spending 2x the price for a few extra FPS in gaming.
z1nonly
2020/10/18 15:27:18
MatthewAMEL Fairly easy to point out that both Nvidia and AMD’s top consumer gaming cards are coming with 10+ vram. Just to check a box?
My 1080Ti has never needed even 8gb of vram. The "box was checked" but the vram was never used. The games I want to play are crushing my old 1080Ti, but the vram buffer? -Nope.
Wallzii
2020/10/18 15:33:51
lantern48, that isn't how any of this works. You're going against independently published results that don't acknowledged any of the issues you're claiming are a problem. The burden of proof doesn't lay on me, that's on you. Nice try, though. If you've got definitive testing results that are contrary to what has been observed in other independent testing, then by all means, publish it; otherwise, stop telling people they need to verify results that are already widely available (no issues at the settings you describe), when that burden of proof lies on you to claim otherwise.
If all you've got is "I saw my allocated VRAM go down when I adjusted X setting," then you clearly have no clue what you're testing and are in no position to cite anything as fact. You've so far managed to dodge every question I've posted to you, and I expect that to continue. VRAM allocation and usage are NOT the same thing.
ghastlyone
2020/10/18 15:34:21
bloodshot45
All anyone has to do is a take a glance at the Steam hardware stats. 8gb of VRAM is currently the most popular amount of memory used for GPUs, followed by 6gb cards and then 4gb after that. People using 11gb cards (2080ti and 1080ti users) make up only 4% of the gaming population. Seriously, game developers know how to develop their games based on the hardware being used in the population.
notarjy
2020/10/18 15:35:30
lantern48 Yes you did. And I only used the number you said. Go back in GTA V and play until it shows close to 10 GB's. Watch what happens. Even if you will lie about it, you will know the truth for yourself. I am attempting this now. I see that over time I am now at around 8.3gb used, so it has gone up. Can you suggest specific areas to go where I can push this further? I have also noticed that entering missions or switching between characters causes the total to go down, so now I am avoiding that specifically.
notarjy
2020/10/18 15:45:30
Can someone clarify to me that what GPU-Z reports as "memory usage" is actually memory allocated?
lantern48
2020/10/18 15:46:43
ghastlyone All anyone has to do is a take a glance at the Steam hardware stats. 8gb of VRAM is currently the most popular amount of memory used for GPUs, followed by 6gb cards and then 4gb after that. So that means you can't exceed V-RAM usage in games because of the popularity of cards? What?? Where did you come up with such an awful take? How about you push a 3080 to exceed V-RAM and see what happens. I already listed 3 games. I can give you exact settings to test. Bet you won't. Yours might be the most awful opinion yet. And that's saying something. ghastlyonePeople using 11gb cards (2080ti and 1080ti users) make up only 4% of the gaming population. Again, so this means V-RAM can't be exceeded? ghastlyoneSeriously, game developers know how to develop their games based on the hardware being used in the population. Again, so this means V-RAM can't be exceeded?
lantern48
2020/10/18 15:54:26
notarjy I am attempting this now. Great. notarjyI see that over time I am now at around 8.3gb used, so it has gone up. Thanks for verifying it functions as I claimed. notarjyCan you suggest specific areas to go where I can push this further? I do think it's a bit odd that you're saying you have everything maxed at 4k and are only showing usage in the 8GB range. But yeah, as said earlier pick a fast car and drive full speed going up a road on a very grassy hill. That will jump up your V-RAM usage. It is 100% reproduceable. I'm interested to see what your results are.
post edited by lantern48 - 2020/10/18 15:56:40
Jacob.jenson6
- Location: utah... where all hardware must be ordered online.
2020/10/18 15:55:50
There have been situations where 10 gig wouldn't be quite enough. If I ran Doom Eternal on my 5120x1440 on the same settings as I do my 3090, it would exceed the 10 gig.
https://www.modsrigs.com/detail.aspx?BuildID=42222
MatthewAMEL
2020/10/18 15:59:34
z1nonly
I think it's more important to note they are future-proofing an aspect of the card that will soon be necessary. It may be due to GPU requirements or forthcoming features like RTX-IO (DirectStorage). They are telling you 10GB is about to be behind the curve.
notarjy
2020/10/18 16:01:22
alright, now we are getting somewhere. I got forced into a mission and during it ramped all the way up to 9.7gb! i thought here we go let's break this game, but then it went all the way back down to 7.8gb, and now back around 8.3gb. I will go drive around the hills. I am using max everything with 8x msaa, however in this mode txaa is disabled, it is only available in 4x msaa mode, I wonder if that would have more impact.
notarjy
2020/10/18 16:19:00
driving around grassy hills definitely tanks the fps. the vram usage is the highest Ive seen in free roam but still only at max around 9gb, and falling back down to 8.8gb regularly.
lantern48
2020/10/18 16:27:37
notarjy driving around grassy hills definitely tanks the fps. the vram usage is the highest Ive seen in free roam but still only at max around 9gb, and falling back down to 8.8gb regularly.
notarjy alright, now we are getting somewhere. I got forced into a mission and during it ramped all the way up to 9.7gb! i thought here we go let's break this game, but then it went all the way back down to 7.8gb, and now back around 8.3gb. I will go drive around the hills. I am using max everything with 8x msaa, however in this mode txaa is disabled, it is only available in 4x msaa mode, I wonder if that would have more impact.
So I went in game to test at max settings everything 4k, since I was not at max, but mostly there. What I noticed is that I actually started off like you at 8GB's. I'm bringing this up because I don't care about being right, I'm trying to get to the facts here. At my previous settings, lower than max, I was ramping up to 9 GB's pretty quickly, which is odd that lower settings were getting to higher V-RAM usage faster. The big change is starting at all max already has FPS dropping to the 40's. Whereas the previous settings kept me at/above 60 FPS until I'd hit 9.84 GB's of V-RAM used. That's when FPS would drop to less than 30 in the 20's and stay there until I would lower a setting a notch. Usually lighting or shadows. Same on Wolfenstein: Youngblood and Far Cry 3.
post edited by lantern48 - 2020/10/18 16:35:27
LinS123
2020/10/18 17:10:11
Don't you get it guys? Developers will definitely blow past 10GB VRAM. They won't bother optimizing cause they'll use what's there. Never mind the fact less than 5% of PC playerbase probably have 10GB or more of VRAM. PANIC NOW SO WE DON'T HAVE TO PANIC LATER. Sources: Trust me, I said so. In three examples. Go test it yourself, I know you have all the time in the world to do so. See I'm right. I'm smarter than all the independent 3rd party reviewers. They're stupid and I am right. VRAM allocation? Pshh, you don't know what you're talking about. Almost everyone in this thread is wrong and I am right. You are all just wrong wrong wrong. If I keep pointing back to my three games and how I had this problem, I am right. Despite statements from others in the thread and the one gentlemen who has been trying the GTA V example this whole time and has NOT experience a catastrophic failure. /s On a more serious note. I thought we got past this 10GB being not enough around launch. Around the time the 20GB rumors started coming out. I thought the consensus was we'll run out of GPU horsepower before we actually start running out of VRAM. Horribly optimized games not withstanding. EDIT: Also I bought a 3090 FTW3 cause I have a spending problem. So yeah. Bad life decisions.
post edited by LinS123 - 2020/10/18 17:43:24
5950X / 32GB 3600CL16 / 3090 Kingpin / Corsair AX1600i
Jacob.jenson6
2020/10/18 17:13:49
Agreed. I enjoy not having to worry about it. At all. 24 gig? Awesome. I won't have to fine tune for Vram usage after I'm done fine tuning HDR and RT settings, using a hex editor to change config files to support my resolution in the first place, playing with Gsync settings to see whether or not it's worth even using in whatever title I'm setting up...
There's already plenty for me to do. Why would I want to watch vram usage?
Yes, to me 10 gig wouldn't be enough in some cases. I expect there to be even more cases in the future. Especially when we start loading directly to vram from our pcie gen 4 ssd. 😁 Now I won't have to wonder whether or not I have enough.
Sad side note though... My 3090 FTW3 gaming is being RMA'd. It died Friday. My old 2080 is being used by a friend in SLI with his card until he can get ahold of his own 3090, so I'm stuck using an old MSI gtx 970 afterburner out of my wife's retired machine. Most games won't even load in 5120x1440. Biggest problem is not enough vram available.
Delirious
- Ribbons : 61
2020/10/18 17:21:42
lets start over. Posts removed for language, trolling and personal attacks.
"Be quick to listen, slow to speak and slow to anger" Affiliate Code XZUMV9TJW5 Associate Code: 7PM43CU71IB2IAP education may be expensive but wait until you get the bill for ignorance A wise man once said that we can't make anyone feel or do anything. We can throw things into the wind, but it's up to each person to decide how they want to react, where they want to stand when things fall.
LinS123
2020/10/18 17:36:31
richardwu190
2020/10/18 17:37:39
might as well buy a 3080 10 GB now, flip it on eBay for a scalper price, and put that toward the 20 GB version when it comes out. Then you can come back to tell us about the performance of the 20 GB version.
notarjy
2020/10/18 17:43:44
lantern48
Interesting to hear your results. The FPS for me was very location dependent, with full max I can get 60-75 in the city but up in the grassy hills it drops down to around 30. Never was able to get much higher than 9gb usage again but I can see how this could turn into a problem in some scenarios, there are a lot of ways the game can be played. Turning msaa down from 8x to 2x improved the performance a lot, up to around 60fps in these same grassy hills and even higher in less intensive areas. I find that in 4k 2x msaa is enough to get rid of all the jaggies, but at that point its up to personal preference, as I enjoy the higher refresh rates.
lantern48
2020/10/18 18:32:47
LinS123 Well since we're starting over. Let's start with some 3rd party numbers. Overclockersclub 3080FE: https://www.overclockersclub.com/reviews/nvidia_geforce_rtx3080_founders_edition/7.htm GTA V - Max settings, FXAA, MSAA x2 4K average - 78.81fps (Intel system) 76.82(AMD system) There are areas in the game where you can spike V-RAM usage and get it to exceed a 3080's capacity. Notarjy didn't quite get there, but he got close. For me it was 9.84 GB's. Just because this reviewer didn't go in those areas to exceed V-RAM doesn't mean it can't happen. Again, Notarjy and the Crap One guy both got into the 9GB range. Really close to exceeding. LinS123 Anandtech 2080Ti (It's got an extra GB of VRAM but the GPU is obviously less powerful): https://www.anandtech.com/show/13346/the-nvidia-geforce-rtx-2080-ti-and-2080-founders-edition-review/11 GTA V - "Very High" quality is used, where all primary graphics settings turned up to their highest setting, except grass, which is at its own very high setting. Meanwhile 4x MSAA is enabled for direct views and reflections. This setting also involves turning on some of the advanced rendering features - the game's long shadows, high resolution shadows, and high definition flight streaming - but not increasing the view distance any further." 4K average - 64.9fps (intel system) This is a 2080 Ti. Not a 3080. Completely irrelevant when I'm stating 9.84 GB's is when the massive FPS loss starts and stays in the 20's until a setting is lowered on a 3080. LinS123 Gamersnexus 3080FE: https://www.gamersnexus.net/hwreviews/3618-nvidia-rtx-3080-founders-edition-review-benchmarks GTA V - 4K "custom settings" 4K average - 95.5fps (stock) 99.5fps (OC) Techpowerup Wolfenstein Youngblood Performance Review: https://www.techpowerup.com/review/wolfenstein-youngblood-benchmark-test-performance/4.html 4K (3840x2160) Mein Leben settings 4K average - 118.9fps (2080Ti) 6294MB VRAM usage None of the 3 games I'm citing were even tested here. Why did you even post this? LinS123 Thefpsreview 3080FE review: https://www.thefpsreview.com/2020/09/16/nvidia-geforce-rtx-3080-founders-edition-review/6/ Wolfenstein Youngblood 4K (3840x2160) Mein Leben settings + Ray Tracing 4K average - 155fps (no RT) 91fps (RT On) 134fps (RT On + DLSS) There's no showing V-RAM usage at all. There are also areas in this game where you spike V-RAM usage and exceed the 3080 capacity. I'm not even on max settings and once I hit 9.84 GB usage, the same thing that happens in Far Cry 3 and Grand Theft Auto V happens here: Drop to less than 30FPS and stays there until a setting lowers V-RAM usage lower than 9.84 GB's. The reviewer/tester may not have reached an area in the game or played long enough to cause this. They also may have and not mentioned exceeding the 10GB. There's no graph or data about V-RAM usage at all. LinS123So just a few examples essentially debunking this 10GB is not enough panic. Will it be enough down the road? Who knows, I can't tell the future. But my opinion which is based off of actual research and not anecdotal stories, it's a non issue. You haven't debunked anything by showing data from a 2080 Ti and no data at all showing V-RAM usage on the 3080. I can give my exact settings for Far Cry 3 or Wolfenstein: Youngblood. And anyone can test for themselves to see V-RAM usage. But if it makes you feel more safe and secure to pretend these games can't exceed V-RAM on a 3080, then ok. If that's what you're already predetermined to believe no matter what, so be it.
post edited by lantern48 - 2020/10/18 18:41:22
Jacob.jenson6
2020/10/18 18:38:00
It's all about use case. If you don't need more than 10 gig of vram, good on you! You get to save some cash. A small subset of people do, or will, want more than that.
