fofal
Re: Has anyone had problems with a RTX 3080 and it's 10GB of Vram?
2020/10/19 15:49:29
lantern48
Shikhee A game allocating RAM does not mean that the game is using all of said allocation.
Again, because this seems really difficult to grasp for some people: when I hit 9.8 GB's or over in 3 different games, there is massive FPS loss and stuttering. Keeping it under that number, everything runs fine. This is 100% reproduceable. Another person admits to starting off Grand Theft Auto V at a bit above 9 GB's at 4k max settings. Do you understand? This isn't that hard or confusing.
You can test and see for yourself.
post a screenshot where you are hitting so much vram in the games.
lantern48
2020/10/19 15:59:46
fofal post a screenshot where you are hitting so much vram in the games.
It's a waste of time. People here are convinced that's not the actual amount. 2 people here played Grand Theft Auto V and already said they were at 9GB's. One guy played extensively and reported around 9.3GB max. The other guy played 30-seconds and was at 9GB, but he doesn't believe that's the amount actually being used. You can read their posts. They are still there. Maybe something is wrong with my V-RAM that causes the exact same issue in 3 different games when reported use hits around 9.84GB's. FPS drops to the 20's until I lower a setting to go under 9.84Gb's. And 9.84GB's isn't actually showing 10GB or over. It's still under, so I have to take that into consideration. Or maybe it is exceeding its capacity. Doesn't matter anymore. Eventually I'll know for sure on my own.
post edited by lantern48 - 2020/10/19 16:04:19
bloodshot45
2020/10/19 16:18:18
lantern48
Because it isn't the actual amount used and you've been told this many times. If you want to see ACTUAL VRAM usage then you need to use a program like RenderDoc. Once you have RenderDoc installed, load up GTA 5 as you've been saying and show that VRAM is actually using over 10GB of VRAM. You can find the data under statistics.
post edited by bloodshot45 - 2020/10/19 16:25:17
lantern48
2020/10/19 16:25:39
bloodshot45 you need to use a program like RenderDoc. Once you have RenderDoc installed, load up GTA 5 as you've been saying and show that VRAM is actually using over 10GB of VRAM. You can find the data under statistics.
You can also use MSI Afterburner. That's what I use. https://www.resetera.com/...r-process-vram.291986/
post edited by lantern48 - 2020/10/19 16:29:15
Drwaffles
2020/10/19 16:31:46
These guys did a good comparison using Special K and FS2020 showing reported allocation is not the same as what's actually required. Most programs shows memory allocation, not usage.. https://www.resetera.com/...10gb-is-enough.280976/
post edited by Drwaffles - 2020/10/19 16:41:53
bloodshot45
2020/10/19 16:36:38
lantern48
Can you install RenderDoc and see if the numbers match up? That still looks like MSI Afterburner is just showing VRAM reserved for the game process rather than actual usage. I guess I can also test myself later and report back.
MatthewAMEL
2020/10/19 16:37:52
bloodshot45 Because it isn't the actual amount used and you've been told this many times. If you want to see ACTUAL VRAM usage then you need to use a program like RenderDoc. Once you have RenderDoc installed, load up GTA 5 as you've been saying and show that VRAM is actually using over 10GB of VRAM. You can find the data under statistics.
I am asking because I genuinely don't know...doesn't CPU-Z show actual VRAM used? I've run it on a few games during this thread to see how my 1080Ti does in 1440p. I watch it bounce between 7GB and 9GB in AC:Odyssey. 5.5GB - 7.9GB in Fallout 4 with about 200 mods.
notarjy
2020/10/19 16:44:37
MatthewAMEL
I have been using GPU-Z, which reports "memory usage", not sure what that actually represents. I got similar numbers in those same games.
9700k @ 5.0Ghz 1.3v AVX0 EVGA RTX 3080 FTW3 Ultra
lantern48
2020/10/19 17:00:15
bloodshot45 Can you install RenderDoc and see if the numbers match up?
Will do. Gonna be a while until I test extensively due to an update in Wolfenstein: Youngblood locking people into the same area with an auto crash. There's supposedly a workaround to escape the load crash, but 2 areas I need to get into are auto crashes when trying to enter: https://steamcommunity.com/app/1056960/discussions/0/2968394412019261822/
post edited by lantern48 - 2020/10/19 17:02:33
bloodshot45
2020/10/19 17:03:10
MatthewAMEL
I assume you mean GPU-Z, it shows memory requested. Dug this up from an old review which actually got information from NVIDIA directly : GPU-Z claims to report how much VRAM the GPU actually uses, but there’s a significant caveat to this metric. GPU-Z doesn’t actually report how much VRAM the GPU is actually using — instead, it reports the amount of VRAM that a game has requested. We spoke to Nvidia’s Brandon Bell on this topic, who told us the following: “None of the GPU tools on the market report memory usage correctly, whether it’s GPU-Z, Afterburner, Precision, etc. They all report the amount of memory requested by the GPU, not the actual memory usage. Cards will larger memory will request more memory, but that doesn’t mean that they actually use it. They simply request it because the memory is available.” Source : https://www.extremetech.com/gaming/213069-is-4gb-of-vram-enough-amds-fury-x-faces-off-with-nvidias-gtx-980-ti-titan-x Now the review was from 2015 so clearly the tools could have easily changed since then. But as far as I know, all the known popular tools such as GPU-Z/Afterburner/Precision/etc.. still show memory requested.
post edited by bloodshot45 - 2020/10/19 17:09:22
fofal
2020/10/19 18:01:53
Some games show you how much a game will use in the settings menu. You can see what it says and compare to what afterburner is showing you. It won't be how much vram is actually used.
I sold my 1080 ti and I have an rx 550 for now lol.
I play cod warzone on lowest settings 1080 res with a res scale of 50%. In the settings it's showing me that I'm way below the required vram but the game works fine. It looks like unreal crap but it runs.
On 1440p we will never run out of vram until ps6 comes out.
ReZpawN
2020/10/19 18:09:06
lantern48
ReZpawN i love how literally everyone is like 10gb of vram is enough but you still get people that are like no its not enough, somehow i think im gonna trust nvidia and game devs more than some guy on a forum
You shouldn't trust me. Test for yourself. My goal is not be right. It was to share what I came across in testing. Instead of other people testing to see if I'm an isolated case, this turned into a thread full of Twitter level opinions. People who don't even own a 3080 making claims about what it can and can't do. People who don't play in 4k. People who don't have the games mentioned. People using a 2080 Ti as a comparison.
If it turned out what I tested was completely wrong if tested by others, then that's fine. It's not about being "right." I just never thought a forum of fellow computer geeks would think feelings and opinions matter more than data. Now I know.
i have a 3080 and play at 4k and i havent had vram issues at all, i have been able to run all the newest games at max settings at 4k
ReZpawN
2020/10/19 18:12:06
also there has been multiple devs who confirmed that there is literally no software that can show you how much vram is actually being used unless you use their in house in engine tools that they arent willing to provide to the public since they are proprietary
- Ribbons : 270
2020/10/19 20:39:06
After 4 pages, let's get back on topic. Q: Has anyone had problems with a RTX 3080 and it's 10GB of Vram? A: One person makes this claim. You decide whether than one person's claims are valid.
lantern48
2020/10/19 22:26:42
ty_ger07 After 4 pages, let's get back on topic. Q: Has anyone had problems with a RTX 3080 and it's 10GB of Vram? A: One person makes this claim. You decide whether than one person's claims are valid.
Yes and make sure to use your feelings in doing so. Feelings are the most important thing, of course. No 3080 needed. No 4k monitor/tv required. None of the games that may be exceeding are necessary. Oh, and opinions are extra valuable if you only game in 1080p and "never have V-RAM issues." And your feelings are doubly valid if you don't like the possibility that there are some games that can already exceed 10GB's. Then for sure how you feel about that should decide "your truth."
ReZpawN
2020/10/19 22:33:47
lantern48
i do have a 3080 and a 4k tv and i game in 4k, i do have most new games as well and had no issues at all at max settings
lantern48
2020/10/19 22:43:03
ReZpawN
That's such an incredibly broad statement. What does it actually mean? Don't bother answering. Or do. Whatever. This has devolved into repeating the same things over and over. Not doing it anymore.
ReZpawN
2020/10/19 22:49:52
lantern48
ReZpawN
its means that 3080 has no issues playing newest games at 4k at max settings
lantern48
2020/10/19 22:55:46
jamexr
2020/10/20 03:52:03
Remember most monitoring tools are telling you ALLOCATED vram by the application, not what’s really used. The only one that shows real vram usage is the latest afterburner, but you must do this: Install MSI Afterburner 4.6.3 Beta 2 Build 15840 from https://www.guru3d.com/fi...ner-beta-download.htmlEnter the MSI Afterburner settings/properties menu Click the monitoring tab (should be 3rd from the left) Near the top and next to "Active Hardware Monitoring Graphs" click the "..." Click the Checkmark next to "GPU.dll", and hit OK Scroll down the list until you see "GPU Dedicated Memory Usage", "GPU Shared Memory Usage", "GPU Dedicated Memory Usage \ Process", "GPU Shared Memory Usage \ Process" Pick and choose what you want to be tracked using the checkmarks next to them. "GPU Dedicated Memory Usage \ Process" is the # that most closely reflects the # we find in FS2020 Developer Overlay and Special K (DXGI_Budget, except Unwinder uses D3DKMT api) Click show in On-Screen Display, and customize as desired. ??? Profit Important Note: “GPU dedicated memory \ process” and “GPU shared memory \ process” are currently not supported for EAC/BattleEye protected games (as they require opening game process from external application, such request won't work for EAC/BE protected games). -Unwinder I have tried most intensive games at 4K maxed out and most if them don’t pass 6GB of ram, 7ish at the most.
post edited by jamexr - 2020/10/20 03:56:48
jamexr
2020/10/20 03:53:20
ReZpawN also there has been multiple devs who confirmed that there is literally no software that can show you how much vram is actually being used unless you use their in house in engine tools that they arent willing to provide to the public since they are proprietary
Wrong, see my post. Afterburner beta does now.
LinS123
2020/10/20 06:18:18
the_Scarlet_one z999,
I really think a better question would be, “if anyone has a 3090, is it actively using over 10gb of VRAM.”
A lot of what people are saying here is speculation, and others are talking about very specific games. I think if you look at cards that have the ability to use over 10gb, without it being a limit, you could see what games even have the ability to exceed the 10gb mark.
I remember when 4K started becoming a mainstream goal back in 2014, most people said the whole point of 4K was so you don’t need things like AA, and other features, since the resolution was so high and monitors so small, that it literally wouldn’t make a difference. Now folks are using massive TV’s for gaming as well, so AA and those other features are becoming important. I feel that the games that are actually exceeding the limit could also use a little optimization to make use of the faster memory as well.
If a game from 2015 is exceeding the limit at 4K, that is probably a game engine issue or some sort of mods, since the game didn’t even have the option to use that much VRAM in 2015.
So I'm one of the lucky (unlucky for the wallet) few that managed to get a 3090 FTW3 on launch. I also picked up a 4K 144Hz monitor (LG 27GN950 , I double tapped my wallet RIP) to game on. While I don't play the three specific games someone has stated to have VRAM limitations, my VRAM allocation has never really gone past 7-8GB. I'll download the new Afterburner beta and check actual usage. Games I've played so far in 4K max settings: Monster Hunter World Iceborne, Total War War Hammer 2, Vermintide 2, Division 2, Horizon Zero Dawn. As it stands to the OPs original question. No, there are no issues with 10GB of VRAM, I know I have 24GB but allocation doesn't seem to go past 7-8GB at max settings in what I play and I haven't even gone through most of my other games yet. I am not saying there might not be, but it sounds like those are fringe cases that most people will not run into. 10GB is fine and if anyone wants peace of mind, just wait and pay the slight premium for the 20GB model when that comes out.
5950X / 32GB 3600CL16 / 3090 Kingpin / Corsair AX1600i
lantern48
2020/10/20 07:11:57
jamexr
Yeah, I actually linked to an article explaining that it works and how to use it. You must have not clicked. But anyway, it was immediately shot down. I didn't even want to make this post to be honest because this whole thing has become silly and unproductive. I'm going to force myself to avoid this thread.
Rbk_3
2020/10/28 11:19:05
Yes, in Warzone. There is some sort of issue with the Vram, as I have to keep it below a certain level in the in game menu or I get micro stutter due to high fluctuation in frame times. Lowering the texture resolution to low fixes the problem. The same settings on my 2070S are fine so it has to be a driver or game issue. Regular multiplayer is fine. Even when I lock my FPS to something low I get huge fluctuations in Frametime from 5ms to up to 12ms.
post edited by Rbk_3 - 2020/10/28 11:35:48
MatthewAMEL
2020/11/03 19:08:03
- Ribbons : 270
2020/11/03 19:28:31
Interesting... an AMD partner game needs more GPU memory than NVIDIA's most popular current gen video cards? Who would have guessed!?!? I definitely wouldn't use that as a canary in the coalmine.
mobhill
2020/11/03 22:29:48
So is it true or not that when you hit actual VRAM limitation your game will slow and become unpleasant to play until you back off on the settings? I mean, if it's only allocated use, you wouldn't expect a dip at all, right? So if you are going along in your game and it hits 9.84 GB or whatever and your performance tanks, would that not indicate a real VRAM limitation, rather than just the "allocated" figure? I don't have a 3080, but I do have a 4k OLED that I game on, so if I get a 3080 I will be interested to test this out in the games mentioned. I would rather see for myself if 10GB is enough, rather than taking anything as gospel from people who haven't tested specifically to see if there are VRAM limitations at the highest settings possible. My bet is that there are indeed VRAM limitations, because that's just common sense. At some point 10,000GBs would run into a limitation, if you pushed it far enough. It's also pretty fair to claim that even if there are VRAM limitations, it won't be a big deal for 99% (or more) of games and gamers out there for the next few years.
CraptacularOne
- Ribbons : 222
2020/11/03 22:58:39
mobhill So is it true or not that when you hit actual VRAM limitation your game will slow and become unpleasant to play until you back off on the settings? I mean, if it's only allocated use, you wouldn't expect a dip at all, right? So if you are going along in your game and it hits 9.84 GB or whatever and your performance tanks, would that not indicate a real VRAM limitation, rather than just the "allocated" figure? I don't have a 3080, but I do have a 4k OLED that I game on, so if I get a 3080 I will be interested to test this out in the games mentioned. I would rather see for myself if 10GB is enough, rather than taking anything as gospel from people who haven't tested specifically to see if there are VRAM limitations at the highest settings possible. My bet is that there are indeed VRAM limitations, because that's just common sense. At some point 10,000GBs would run into a limitation, if you pushed it far enough. It's also pretty fair to claim that even if there are VRAM limitations, it won't be a big deal for 99% (or more) of games and gamers out there for the next few years.
That is exactly what happens. When your card ACTUALLY runs out of VRAM the game will turn into a virtual slideshow as assets are being swapped from the page file in windows. It won’t be just a little hitch or micro stutter, it will be a large hang or stall and the game will start to chop and run in the single digits FPS until the GPU is able to fetch whatever data it was looking for. Most people here (hell I’d venture say virtually all by reading their replies) have never actually seen what happens when you are truly VRAM limited.
paulmcpazzi
2020/11/04 01:36:02
Godfall System Requirements List 12 GB VRAM for 4K and Ultra HD Textures: techpowerup.com/274218/godfall-system-requirements-list-12-gb-vram-for-4k-and-ultra-hd-textures
- Ribbons : 270
2020/11/04 04:57:05
paulmcpazzi Godfall System Requirements List 12 GB VRAM for 4K and Ultra HD Textures: techpowerup.com/274218/godfall-system-requirements-list-12-gb-vram-for-4k-and-ultra-hd-textures
Already posted above. Post #115. As I said above, it's an AMD partner game and it is interesting that they specifically say that a RTX 3080 may not be enough compared to the RX 6800 XT. In other words, there's a lot of marketing at stake, and I wouldn't use it as my benchmark of the norm.
