wolfreon
2018/10/04 11:33:06
The card is good overall with Factory Settings. But, when I crank up the voltage to 1093, it's dropping power draw thus fps drop. Restarting the machine will reset this power throttle. Do you have any suggestion for stress tool? I'm using Superposition 8k optimal.
2018/10/04 11:48:51
That's odd. Sounds like your card may have a problem. Running the 8k optimized preset in superposition is recommended.
wolfreon
2018/10/04 22:40:49
Sajin That's odd. Sounds like your card may have a problem. Running the 8k optimized preset in superposition is recommended.
Now, I'm beginning to think that this card is faulty. I tested another card from a different manufacturer and I don't encounter this power consumption drop.
09Michael
2018/10/05 13:05:42
Im having the issue that im not getting the white vertical line. The skin is the same. Afterburner 4.6.0 Beta 9 with the 416.16 driver at the EVGA 1080 TI FTW 3. Also it's not showing the voltage
post edited by 09Michael - 2018/10/05 13:09:13
2018/10/05 17:07:51
09Michael Im having the issue that im not getting the white vertical line. The skin is the same. Afterburner 4.6.0 Beta 9 with the 416.16 driver at the EVGA 1080 TI FTW 3. Also it's not showing the voltage
I tested the newest version. The white line is more faint now, but it is still there.
09Michael
2018/10/05 20:49:41
That is how it looks like...
2018/10/06 01:06:32
To make the voltage show simply go into settings and checkmark unlock voltage monitoring.
09Michael
2018/10/06 06:10:30
Fantastic now i've got the white vertical pointed line thanks
09Michael
2018/10/06 09:14:33
Well cant get it to 2,1 but i get it to a good point.  Thank you for your help Sajin
post edited by 09Michael - 2018/10/06 09:18:51
2018/10/06 14:43:09
No problem.
01tdipower
2018/10/08 07:12:18
Anyone have it where the extra voltage doesn't help in the least? I'm able to get 2063 at 1.062V. Figured I'd see 2100 by bumping it up to 1.093V, but no dice. Might as well not even throw extra voltage at it for a minimal bump in core clock. card has a hydrocopper block and temps never go above 40C. Another question I had was, does the extra voltag help the memory clock? Or completely unrelated? Edited for typos
post edited by 01tdipower - 2018/10/09 11:01:07
GGTV-Jon
- Ribbons : 19
2018/10/08 10:22:47
01tdipower Anyone have it where the extra voltage doesn't help in the least? I'm able to get 2163 at 1.062V. Figures I'd see 2100 by bumping it up to 1.093V, but no dice. Might as well not even throw extra voltage at it for a minimal bump in core clock.
Some chips like it hot, some don't. It isn't written you have to run it at max volt - you need to find the best setup for the hardware you are working with. If you cant get that OC with less voltage then
2018/10/23 14:06:08
Can confirm this guide also works with 2080 ti's.
sambryant87
2018/10/28 05:28:01
This guide has worked perfectly for me. Gone back to stock bios and finally cracked that 2075mhz mark. (2136)
Digital_Fuzion
2018/10/28 11:28:49
The greatest forum members with all the sassy tech savvy :D
2018/10/28 14:13:45
sambryant87 This guide has worked perfectly for me. Gone back to stock bios and finally cracked that 2075mhz mark. (2136)
streetglide420
2018/10/28 16:10:15
core voltage is locked on afterburner for me, is there a workaround? 2080ti ftw3
2018/10/28 16:15:45
Even after unlocking voltage control in the general menu?
streetglide420
2018/10/28 16:16:02
Sajin Even after unlocking voltage control in the general menu?
Yes sir
streetglide420
2018/10/28 16:21:38
i maxed fans with PX1, and have MSI afterburner running. Card is boosting to 2100 on its own, then throttling back with temps, 2055 @ 59c i have no OC set on either program.
2018/10/28 16:28:47
streetglide420
2018/10/28 16:29:07
EDIT. updated to newest beta and voltage is now unlocked.
2018/10/28 16:30:07
kimono
2018/11/02 03:55:03
makatech
2018/11/23 07:14:58
Great guide but when using a curve gpu clock, memory and voltage doesn't downclock in Windows when idling. :-( Idling in Windows work for me when using default clockspeed or when overclocking using the sliders only. Not sure if this may have something to do with my 1440p 165Hz Agon AG271QG monitor? Edit: Oh, opening the curve and hitting ctrl+l may help? I am not at home right now but will try this later. :-D
post edited by makatech - 2018/11/23 07:25:30
2018/11/23 11:50:36
makatech Edit: Oh, opening the curve and hitting ctrl+l may help? I am not at home right now but will try this later. :-D
Yep, hit ctrl+l inside the curve & set your desktop refresh rate to 120 hz and then you should be all good.
makatech
2018/11/24 02:32:13
Thanks, are you saying that I would have to manually deactivate my oc from Afterburner when using a curve if I want it to downclock when idling in Windows when not playing? It's no way getting this to work automatically? GPU oc using a curve really locks core, memory and voltage?
2018/11/24 11:01:56
No, hitting ctrl+l again afterwards will make the card idle on the desktop, but when you launch an application the curve should still take effect without having to use ctrl+l to lock the clocks.
makatech
2018/11/26 00:17:23
Sajin No, hitting ctrl+l again afterwards will make the card idle on the desktop, but when you launch an application the curve should still take effect without having to use ctrl+l to lock the clocks.
Thank you, I will do more testing. Actually I don't have a EVGA card (I bought a used Aorus 1080 ti) but your guide and knowledge in this area is great. :-D In Sweden EVGA have a very good reputation for good quality and support, now I understand why.
post edited by makatech - 2018/11/26 00:19:29
MuXuSS
2018/11/26 04:24:34
RIP MSi afterburner ! Precision X1 is here for your FTW3...definitively not a kid software
