[Guide] How to force max voltage & curve overclock with msi afterburner
Page: << < ..11 Showing page 11 of 11
Drudicta
Re: [Guide] How to force max voltage & curve overclock with msi afterburner 2021/07/21 23:54:39 (permalink)
Is the shortcut still ctrl+F? Because with MSI afterburner open, that does nothing at all for me. ctrl+L works and locks and unlocks like it's supposed to. I've got version 4.6.2 and it says there are no updates for MSI Afterburner.
Re: [Guide] How to force max voltage & curve overclock with msi afterburner 2021/07/22 00:00:57 (permalink)
Yep, I have 4.6.3 beta 2.
tyung87
Re: [Guide] How to force max voltage & curve overclock with msi afterburner 2021/09/05 19:01:12 (permalink)
Great guide
Kagashini
Re: [Guide] How to force max voltage & curve overclock with msi afterburner 2021/09/27 22:21:03 (permalink)
Thanks for guide.
emanuel1996
Re: [Guide] How to force max voltage & curve overclock with msi afterburner 2021/09/29 02:32:50 (permalink)
do u know max voltage to 1050 ti lp 4gb?
stebru94
Flagged as Spam (1)
Re: [Guide] How to force max voltage & curve overclock with msi afterburner 2021/09/29 15:54:54 (permalink)
this is final guide that I had searched. Thank you.
stebru94
Flagged as Spam (1)
Re: [Guide] How to force max voltage & curve overclock with msi afterburner 2021/09/30 08:25:25 (permalink)
I want to test it. NOW!
jaredcrobinson
Re: [Guide] How to force max voltage & curve overclock with msi afterburner 2021/12/25 17:40:06 (permalink)
I'm hoping someone will still comment.  Is it okay to leave the voltage locked?  I'm achieving my best clocks with my MSI Seahawk EK GTX 1080 with an ASUS Rog Strix 1080 bios.  I have it to 1200mv and I'm stable at 2200mhz w/ memory at 5500mhz. The voltage is pegged at 1200mv all the time - is this bad? Should I unlock and allow the curve to downclock when max performance isn't needed?
Re: [Guide] How to force max voltage & curve overclock with msi afterburner 2021/12/25 23:38:10 (permalink)
jaredcrobinson
I would. Should make the card last longer, and you’ll use less power by doing so.
