Fixing EVGA's 7 Figure Problem with FTW3 30 Series cards.
Page: < 12345.. > >> Showing page 3 of 6
ClowReed
Re: Fixing EVGA's 7 Figure Problem with FTW3 30 Series cards. 2021/02/12 21:00:44 (permalink)
Guys, how exactly you do this undervolt in Afterburner? Do I need to turn down every step of the curve? And, if yes, how much you lowered it in every step? Sorry... Never made vga undervolting before. :(
#61
mricypaw1
Re: Fixing EVGA's 7 Figure Problem with FTW3 30 Series cards. 2021/02/12 23:26:09 (permalink)
This might shed some further light on the issue...
post edited by mricypaw1 - 2021/02/12 23:29:30
jasonlam826
Re: Fixing EVGA's 7 Figure Problem with FTW3 30 Series cards. 2021/02/13 00:32:32 (permalink)
ClowReed
You can search for the 3080 undervolt video on Youtube made by WccftechTV.
#63
ClowReed
Re: Fixing EVGA's 7 Figure Problem with FTW3 30 Series cards. 2021/02/13 06:49:01 (permalink)
jasonlam826
ClowReed
 Thanks!! Gonna check it out!
#64
mricypaw1
Re: Fixing EVGA's 7 Figure Problem with FTW3 30 Series cards. 2021/02/13 19:53:16 (permalink)
I have a 3080 FTW3 Ultra incoming and not sure if I should just do this fix on day 1 or run it stock. Don't want to risk it until EVGA releases a bios fix.
#65
bavor
Re: Fixing EVGA's 7 Figure Problem with FTW3 30 Series cards. 2021/02/13 21:15:36 (permalink)
The main issue is that you shouldn't have to do those "fixes" to get the card to work properly in the first place.
#66
a3britton
Re: Fixing EVGA's 7 Figure Problem with FTW3 30 Series cards. 2021/02/13 23:02:51 (permalink)
Ok so a little backstory and then I'll get on with it... So...
My first 3090 FTW3 Ultra I got the red light on the 3rd PCIe plug closest to the die.
RMA'd no issues, EVGA reps and service were superb.
This card had the black screen high fan crash twice before it killed itself. 1000W gold EVGA PSU
This occurred in OCT.
Since then I have been using my current 3090 heavily with moderate issues.
In total, I have had 10+ black screen 100% fan crashes. Each time I think the card is going to kill itself. But each time I have been able to pwr off the system and recover with minimal issues.
I have replaced the 1000W PSU with a brand new 1200 watt platinum. While playing The Division 2 today I had the same crash... black screen 100% fans. So.... I will experiment with undervolting more to see if it will fix the issue.
Games that have black screened and crashed -
American Truck Sim - 1 crash (killed the first card)
Witcher 3 - 3 crashes
Division 2 - 4 crashes (1 on the new PSU)
Half Life Alyx - 1 crash
Warframe - 3 crashes
post edited by a3britton - 2021/02/17 14:29:02
#67
LocutusHUN
Re: Fixing EVGA's 7 Figure Problem with FTW3 30 Series cards. 2021/02/14 11:43:43 (permalink)
MatthewAMEL
Are we talking only 3090's? I have a 3080 FTW3. Received in November. I play a lot of older games (Fallout:NV, SupCom, Homeworld Remastered). I have put hundreds of hours in on the older games since I received my card. I've never had a crash or black screen. I do not OC my card. My most recent TS: 17205, TSE: 8890.
Good question there. I am also using my 3080 FTW3 Ultra since november, and have no such issues listed here.
I would also like to assume, that this topic is only about 3090's.
X470 Taichi Ultimate, 3700X, 32GB 3600 Ballistix, eVGA 3080 FTW3 Ultra, Seasonic Prime Titanium 850W, LG OLED55CX 4K120
#68
transdogmifier
  • Ribbons : 18
Re: Fixing EVGA's 7 Figure Problem with FTW3 30 Series cards. 2021/02/14 11:45:56 (permalink)
LocutusHUN
MatthewAMEL
And I've had my 3090 since September.
It's not always the card.
AMD Ryzen 7900x3d
Deepcool LT720
Gigabyte Aorus Elite AX X670 (Might change..don't like this board)
eVGA GeForce RTX 3090 FTW3 Ultra Gaming (Hybrid kit on it)
Asus ROG Swift PG43UQ 4k Monitor
eVGA 1600W Supernova T2 PSU
32GB Kingston 6000 DDR5 (2x16GB) Fury
Corsair MP600 Pro 2TB (Boot)
Corsair MP600 2TB (Games/Data)
Phanteks P500A Case
#69
donnie123
Re: Fixing EVGA's 7 Figure Problem with FTW3 30 Series cards. 2021/02/15 03:49:03 (permalink)
Ok so I have my 3080 FTW3 Ultra since around 2 months now, its a 2014 black lips, it has an uneven power draw, and the 3rd plug on stock is reaching max 91w. Although the card is hitting 400w normally, and is spiking to 419w sometimes with 105% power setting in precision x1.
The clocks are boosting up to 2100 on stock bios with +105 on core, but during gaming in cyberpunk 2077 or warzone the clocks are sustained at around 2070 mhz. This is with zero voltage added.
I've had so far zero crashes, backscreens or whatsoever problems, I been playing long hours of League of Legends, CBP2077 and Warzone. I've checked and seen voltage spike like somebody mentioned..
Should I consider myself lucky so far? Well knocking on something wooden rn.
#70
Rewire92
Re: Fixing EVGA's 7 Figure Problem with FTW3 30 Series cards. 2021/02/15 12:45:49 (permalink)
donnie123
The problem is not at high power, it's at low power states.  If you've been able to play League without crashing, you do not have the issue.
post edited by Rewire92 - 2021/02/15 12:48:39
#71
a3britton
Re: Fixing EVGA's 7 Figure Problem with FTW3 30 Series cards. 2021/02/17 13:07:57 (permalink)
After playing around with undervolting I have some more input on my experience.
I have played around 10 hours with my current undervolt. BL3 and Division 2 mostly. I have had ZERO hard crashes. 1 crash to desktop for each game. (attributed to my undervolt I suspect. Tuned slightly after each crash)
Today while playing Division 2 I had another hard crash black screen 100% fan. This happened after I removed my undervolt. I set MSI to 107% pwr and added a +75Mhz OC to core and +250Mhz to mem.
I proceeded to reapply my undervolt and for another 3 hours or so and no crashes whatsoever.
IMPORTANT NOTES:
My card is a FTW3 Ultra 3090
I have a brand new 1200w PSU Platinum rated from Thermaltake
I have replaced the cooling solution with EVGA's own Hybrid kit
I have installed the official Stock EVGA Hybrid FTW3 Ultra BIOS.
My fans for the radiator currently run of my Motherboard. I have found this to be a more stable option.
 Currently set my card at 1.000v 1935Mhz and it really seems to be solid. This profile sort of mimics the core clock performance of stock settings for my card. While using about 40 less watts and 5-6c cooler.
I will continue to keep testing and playing around with this and report back. Maybe a week or two of testing and I will have a better idea of how this profile performs while tweaking as needed.
Using HWiNFO64 I can see my voltage maintain and stick to 1.000v. The total PWR draw seems to top out at 390-405w.
Linked is a 10 minute snapshot of me playing Division 2.
You can see the Core clock peaked at 1950 - but I maintain 1935Mhz pretty solid. dipping here and there and raising here and there.
This behaves just like stock essentially. Anyway - I hope this helps anyone else experiencing issues. I'm not sure this is even viable tho. Most users will not put in the time or have the necessary knowledge to do this. I would prefer a new card that does not behave this way.
Day 1 Update - bumped voltage up to 1.012v due to 3 soft crashes while playing today. Another 3 stable hours afterwards.
post edited by a3britton - 2021/02/17 22:48:27
nosde
Re: Fixing EVGA's 7 Figure Problem with FTW3 30 Series cards. 2021/02/17 14:03:53 (permalink)
a3britton
IMPORTANT NOTES:
Good information. But to be honest, it makes no sens to buy a $2000 card and you can't use it to its full potencial.
I'm doing a little overclock on mine and i'm going to continue. If fail, i will do RMA.
And to be more honest. If i had a card with Blackscreen problems like your, i would have already opened the RMA Ticket.
post edited by nosde - 2021/02/17 14:06:04
#73
B1gbeard
Re: Fixing EVGA's 7 Figure Problem with FTW3 30 Series cards. 2021/02/21 02:08:52 (permalink)
Rewire92
Hey all,
I have had the unfortunate displeasure of dealing with 2 broken 3090 FTW3 Ultras, and upon the issue happening yet again with my 3rd card, I decided to do some deep trouble shooting.  Let me lay out the experience for you.
I enjoy playing older titles, as well as the newer AAA titles from time to time as well.  My first 3090 did great in demanding games, but was netting me a subpar overclock (+75 Core/+500 Mem), I played 100+ hours in Cyberpunk 2077 and I really had a great time.  However, I was getting black screen high fan spinning usage when playing less demanding titles such as League or Halo MCC.  I had to hard reset my computer to get the card to turn back on, and I did so over the next few weeks whenever I played those games, until one day, it wouldn't turn back on at all.  I had no lights on the card, and a red light over one of the PCIE power pin slots.
I RMAed.  The new 3090 came, and I was happy.  50 more hours of Cyberpunk, and no issues.  But in League....more crashing.   6 more black screens later, the 2nd card was dead.  Red light over a PCIE pin power slot, but the card still lit up.  Not sure why about that.
My 3rd card came yesterday.  And I knew right where to look.  The reason that doctors press until it hurts is to find out where the problem is, because patients sometimes lie.
I launched League and without 3 minutes going by in game, black screen, high fans, no output, and the card was running at stock speeds.   I called up EVGA, and I had a nice long chat with a rep while I tried to reproduce the issue.  They told me the symptoms I was experiencing were "Over-Current Protections" kicking in, and also that my first RMA card had failed because of a power related issue.  They suggested I switch out my power supply (an EVGA 1200W P2) with the gold power supply I had before (EVGA 1300W G2).  I played a full 16 minutes of league while on the phone with them, and experienced no crashing, but a minute after we hung up, it black screened, and crashed again.
Now, I dabble in overclocking quite a bit.  I'm aware of how voltages can cause instability in cards, and how too much current breaks transistors and traces inside CPUs.  I'd never had this issue with GPUs before, because I would always just do mild overclocks.
So I started using GPU-Z to watch my voltages while gaming on League.  What did I see while playing League?  Well, the card would *usually* be at 1800 Mhz, using 0.8680 V while I was in game, but occasionally, the voltage would spike along with the clock speed, all the way up to 2025Mhz and 1.0810 V.  Now, I like I said, I don't do much "hardcore" overclocking for my GPUs, but I have used MSI Afterburner for literally 10 years.  I've never seen a video card go over 1.050 Vs.  I looked up the max safe voltage for the 3090, and wasn't able to find it using google, but I had another solution that I knew would work.
So, I booted up Cyberpunk, since I knew I could game on that for hours on end without crashing.  Max Voltage I saw in that game?  1.050V.  Played fine for an hour.  Then I thought to myself, let's try overclocking?  So I set my power limit to 107%, with a mild OC of +75 Core and +750 Mem.   1.075 V when the game started, and 1.068 V while in game.  Ok....Let's crank the overclock.  +150 Core and +1500 Mem.  Played fine for another hour, still max voltage in game?  1.068 V.
I then had a thought.  What if the voltage curve in lower power states is messed up somehow?  I set MSI Afterburner to "Force Constant Voltage" and booted up a League custom game.   I was able to play the game for 35 minutes before the game crashed, so I knew I was on the right track.  There were less voltage spikes, and less core Mhz spikes as well.  But it still crashed?  Why?  Well, when it finally did crash, it had gone up to 1.081 V again.
The fix?  Voltage curves.
As you can see here, the normal voltage curve stops ramping only when the card gets up to a whopping 1.118 V on the core.  Well, I'm crashing at well below that at using only 150 watts and the core at 1.081V, and I know the card is stable using 450 Watts at 1.068V so what can I do to fix this?
I set the core Mhz to plummet after 1.068 V, and since I'm not getting anywhere near those higher voltage numbers without a higher power limit BIOS, I don't need to worry about them.
The result?  I just streamed and watched a movie on my 5 monitors while playing a 2 hour custom game of League by myself.  I'm going to need more testing, but I believe I've fixed the problem.
EVGA needs to adjust their voltage curves for the standard BIOS, because I believe it's breaking Voltage limits in lower power states while still attempting to go to higher core clocks. Also, while my experience here is only anecdotal, it *has* fixed my League crashing problem, so I can only assume that the voltage curve *is* the issue.  The card attempts to go up to a voltage it shouldn't be at when the temperature is not low enough on the card to do so, breaking copper traces in the card with too much voltage at too high of a temperature.
While my experience here is a solitary thing, I would like to have some other people experiencing this issue chime in, and let me know if this fixes the issue.  Maybe I've fixed EVGA's RMA problem with these cards, an experience that I can only assume has reached a large dollar cost figure, with how many people I've seen having the same issues.
Good luck!
EDIT: While I fix my images.
EDIT 2: For those that don't feel like reading through the entire thread, the problem was fixed by limiting my voltage for OC to 1.062V and below, and having the card run at stock speeds at any voltage above 1.062 V.  Comfortably running at +120/+1250 for about 5 days with no crashes.  While you obviously shouldn't have to do this sort of workaround to prevent your card from dying, I can say with confidence this solves whatever issue is causing game crashes and constant RMAs.  Happy Gaming!
Can I ask what your voltage curve looks like after you apply the changes? I can recreate something similar to what you have but when I apply it it moves the curve back where it was.
#74
Rewire92
Re: Fixing EVGA's 7 Figure Problem with FTW3 30 Series cards. 2021/02/21 02:56:39 (permalink)
An update....
After a 4 hour gaming session of League today, I hard crashed at 1.062 V....after the card was fine for about 2 weeks.
Guess I'm lowering the voltage limit further.....
I sense an RMA in my future unfortunately....
#75
yaggaz
Re: Fixing EVGA's 7 Figure Problem with FTW3 30 Series cards. 2021/02/21 03:00:54 (permalink)
Feklar
It better not be considered a solution if it limits the cards perfomance. This is not why we buy FTW3 cards at a higher cost. I wouldn't accept that.
||  CPU: Intel 10700k   ||  GPU:  evga 3080 XC3 Ultra Hybrid ||  MB: Gigabyte z490 UD AC  || RAM: 2 x 16GB 3000mhz DDR4 SDRAM  || Samsung EVO 970 Plus 2TB   ||    Dell S2417DG Monitor    ||  Soundblaster AE-7  ||  Phanteks p400a Case  ||   be Quiet! Dark Rock Slim CPU Cooler  ||  Corsair AX1600i PSU  ||  9 Fans total in system ||
#76
Pwnstix
Re: Fixing EVGA's 7 Figure Problem with FTW3 30 Series cards. 2021/02/21 17:03:37 (permalink)
I've got a RTX 3080 FTW3 Ultra, and I've been experiencing reboots at high loads. At first I thought it was just Cyberpunk 2077, so I'd tried the usual: DDU, reinstall driver/install older driver, but that didn't help. So, I thought maybe it was just that one game, as I'd been playing several other games before it released, including the Resident Evil 2 and 3 remakes, RE7, Red Dead Redemption 2, and Wolfenstein Youngblood. No issues with those. And I didn't have any problems with my previous RTX 2080, which I had sold about a month and a half after I'd got my 3080. My temperatures are at max load: ~60C on the CPU and GPU. I have pretty good airflow in this case, with plenty of fans, and I keep it cleaned regularly.
I have also disabled Windows' Startup and Recovery/System Failure/Automatic Restart, to see if I could see any BSODs. When my PC reboots like this, however, I don't receive any BSODs--just a reboot, like the reset button had been pressed. In the Windows Event Viewer, it only displays an Event ID 41 Kernel-Power, with no timestamps or bugcheck codes.
So I downloaded OCCT to stress test my components. The CPU, Linpack, RAM, VRAM, and PSU tests all passed, but as soon as I ran the 3D (GPU) test, my PC would reboot. Other benchmarks and stress tests wouldn't cause a reboot, such as the ones included with 3DMark. I also used memtest86 to check my RAM, and it also passed the full length test. And of course I also set my CPU and RAM overclock to all stock/default/auto settings in my motherboard BIOS. This also didn't help.
Also ran sfc /scannow and DISM.exe /Online /Cleanup-image /Restorehealth and found no system file integrity errors.
I tried using lower power settings, but that didn't help, either. I tried reseating my GPU, plugging and replugging the power connectors. No luck. So then I wondered it my PSU was faulty, even though I'd installed it at the same time as my RTX 3080. I'd bought this Seasonic Prime TX-1000 specifically for this RTX 3080, in case my previous Seasonic Prime Titanium 750W PSU was underpowered. But I went ahead and swapped the older PSU back into my PC, along with all the power cables. Oh and I'm using separate cables for each of the video card's power connectors---in fact, both of these PSUs only use single cables; no daisy chained cables here. Well, that didn't work, either. I'd still get PC reboots with OCCT 3D stress test.
Then, I put my 1000W PSU back in, and decided to bypass my uninterruptible power supply (UPS) and just plug my PC directly into the wall. That seemed to fix the problem, as I was able to pass the OCCT 3D stress test then. I'd also bought that UPS, a Cyberpower 1500VA/1000W UPS, just recently. I had been using a 600W Cyberpower UPS before that. But I had the idea to use both of my UPS's, and plug everything but my PC into the smaller one, and just my PC into the larger one. That also seemed to work, as I was able to pass the stress test and play Cyberpunk 2077 without issue for at least a week. But then I got another reboot while playing Cyberpunk, along with reboots while running the OCCT 3D stress test, so I unplugged my PC from the UPS and went with plugging directly into the wall again.
That also seemed to work, for a while...until I eventually started to get reboots in both Cyberpunk and OCCT's 3D stress test once again. So...I don't think it's any of my PSUs or UPSs.
I came across this thread, and tried lowering my power limit even further than I had, down to 65% as someone else had tried. I got more reboots while trying OCCT's 3D test again. I also tried an undervolting method mentioned in this thread, and it didn't work, either. Actually, before I ran the stress test, I tried the Unigen Heaven benchmark, which hadn't crashed before, while all this has been happening...but my PC rebooted while running it. So it doesn't look like undervolting has helped me, either. So I reset the GPU back to stock settings again.
Strangely, I've been able to play Battlefront II without any issue, and played a round of StarCraft II earlier today without any problems. And while I had been able to play Heroes of the Storm without crashing or rebooting, as it's a fairly lightweight game, I did get a reboot while trying to load a map today. So, it seems like the problem is getting worse. But, I'm not getting any red lights on the video card.
I've already started the RMA process for the RTX 3080 and I'm just waiting for approval. Hopefully this fixes the issue. But I wonder if it could be my motherboard, or my motherboard's PCIe slot. I haven't tried the 3080 in the lower slot, yet. But I figured that if the PCIe slot is faulty, I'd have other issues, such as artifacting, or black screening, losing connection to the monitor, etc. I'm not getting any of those problems. I also haven't tried replacing my CMOS battery. But in the case of the battery, I think I'd be experiencing other issues (such as losing time and date, BIOS settings, etc.). I've experienced faulty motherboards in general, and I know the usual symptoms of that: reboots at idle, freezing, no signal to monitor, corrupt Windows file integrity, etc.--I'm not getting any of that here.
I'm really at my wits' end here. I hope the replacement GPU solves these issues, but if not, then I'll know it's my motherboard (or something else, I guess..). I'm just really not looking forward to replacing it, since the stock on any that would fit my CPU is very low, and prices are higher than they would normally be. And this isn't the best time to build a new PC (the core components anyway, the CPU and motherboard and maybe also RAM), since there's new stuff coming out and scalping is still rampant. I was hoping to keep my core setup for at least another few years.
Just to round this off, here are my full specs:
CPU: Intel i7 8700K @4.7 GHz
Motherboard: Asus ROG Maximus X Hero (Wi-Fi AC) - Z370 chipset
RAM: 32GB (4 x 8 GB) Corsair Vengeance LPX DDR4-3200 CL16
GPU: EVGA GeForce RTX 3080 10 GB FTW3 ULTRA GAMING
Storage: Samsung 850 Pro Series 1 TB 2.5" Solid State Drive
Storage: Western Digital Caviar Black 4 TB 3.5" 7200RPM Internal Hard Drive
Storage: Samsung 970 Evo 1 TB M.2-2280 NVME Solid State Drive
PSU: SeaSonic PRIME TX 1000 W 80+ Titanium Certified Fully Modular ATX
Case: Corsair Air 740 ATX Full Tower Case
UPS: CyberPower CP1500PFCLCD
***just a quick edit to add some info on the Cyberpunk 2077 reboots: So when this first started happening, it wasn't happening all the time. In fact, at first I thought it was just a fluke. Anyway, it was only happening in Cyberpunk 2077 when I hit the Esc key to pause the game. It wouldn't happen in normal gameplay. It normally runs very smoothly with mostly high settings and the top level ray tracing settings, with DLSS on Balanced. It would just reboot whenever I hit pause, but not all the time. Sometimes I could be playing for a few hours and it would happen, sometimes when I first loaded into the game, and sometimes not at all. It wasn't happening on any other screens that would effectively pause the game, such as the inventory, character, or map screens (I had heard some people were getting this same issue in those other screens). But at one point it did crash/reboot when I had used a fast travel station, which is basically the map screen. More recently, I got a reboot before I got into the main menu; I hadn't even loaded a save. But it still wasn't happening in any other game or benchmark, until just recently, when I had a crash/reboot while running Unigen Heaven, and today when it rebooted while loading into a Heroes of the Storm game. But that is why I was interested in this thread, because with Cyberpunk, which is very graphics-intensive, I can see the wattage (using HWInfo and RTSS) drop from ~380W to ~140W, and the talk about low power states made me think of this. I'm not sure if that's in the same vein of the discussion or not, though.
***edit 2: I know I could still try a few more things to rule out my motherboard (and I can always do that later, I guess), but the posts below mine make me feel better about starting the RMA process for this 3080 now.
***waiting for my replacement 3080 to get here. Thought I'd try to play Europa Universalis IV (EU4) before I take my current 3080 out to ship back on Monday, since it wouldn't go anywhere right now on the weekend. EU4 is an very lightweight game, essentially just a map. My PC rebooted right as the main menu was about to load. So yeah, whatever the problem is, it's definitely worse than it was.
***Update, 3/3/2021: I got my replacement in today. Black accents (not the red lips this time), serial number first 4 digits 2114, packaged in USA. Just for reference, my previous card was: serial number 2014, made in Taiwan. Everything seems to be okay; no reboots yet with OCCT 3D stress test--tested on shader complexity levels 3, 5, and then 8. I'll be fairly satisfied that the rebooting issue is fixed if I continue to pass gaming/benchmarks/stress tests over the next week or so.
Initially, I had a loud clicking noise coming from one of the fans, but I updated the firmware to the latest and it went away, although the standard fans ramping to 100% during the firmware update scared me...the clicking was very, very loud. But then I rebooted my PC myself, and the fans always spin up during reboots, just as they do during power on, and they didn't make any noises then. I ran the stress test and a few benchmarks and sometimes I'll hear a faint clicking/rattling when the fans ramp up, but it stops. I've checked that I don't have anything up in the fan shroud/heatsink, but I could check again I suppose. I've checked to make sure all fans are running at roughly the same RPM, and they are, so I don't think any of them were damaged.
post edited by Pwnstix - 2021/03/03 18:16:06
CPU: AMD Ryzen 7 5800X
Motherboard: Asus ROG X570 Crosshair VIII Dark Hero
RAM: 32GB (2 x 16GB) G.Skill Trident Z Neo DDR4-3600 CL16 F4-3600C16D-32GTZN
Storage 1: Samsung 850 Pro 1 TB 2.5" SSD
Storage 2: Samsung 870 Evo 4 TB 2.5" SSD
Storage 3: Samsung 970 Evo 1 TB M.2 NVME SSD
PSU: EVGA SuperNOVA P2 850W
#77
Rewire92
Re: Fixing EVGA's 7 Figure Problem with FTW3 30 Series cards. 2021/02/21 18:35:44 (permalink)
Another update.
Had a crash at 1.056 V....less than 24 hours after my first crash.  Just playing League again.
Limiting to 1.05 V.....
This may not work as a long term solution.
post edited by Rewire92 - 2021/02/21 18:59:01
#78
freestylingford
Re: Fixing EVGA's 7 Figure Problem with FTW3 30 Series cards. 2021/02/21 18:41:29 (permalink)
 I thought I had my issue figured out too. I went from a x99 classified system with evga p21000 power supply and a 3090rtx ftw3 ultra. System did the black screen wide open fans in low usage game several times.  I decided to build a 10900k system asus strix e gaming z490 maxtytan 1050w PSU  same gpu obviously...... I went no issues for about 2 weeks and then bam just did it last night low usage games guess I will RMA the card this time.
10900k Asus Z490E
32GB GSkill 4100mhz
3090ftw ultra
Enermax Maxtytan 1050w Platinum
#79
Kylearan
Re: Fixing EVGA's 7 Figure Problem with FTW3 30 Series cards. 2021/02/21 19:54:36 (permalink)
Rewire92
Another update.
This is bad news.
Looks like the card is dying, and limiting the voltage simply prolonged the death from happening :(
#80
KickAssCop
Re: Fixing EVGA's 7 Figure Problem with FTW3 30 Series cards. 2021/02/21 21:44:40 (permalink)
Rewire92
Another update.
Damn, I was really hoping your solution would work long term.
PC: Ryzen 5900X | X570 Tomahawk | 3090 FTW3 Ultra | CX 55, G7 32 | 660P 1 TB, P1 1 TB, EVO 850 1 TB, EVO 840 500 GB, 830 256 GB, MX500 1 TB | TridentZ NEO RGB 32 GB 3733 C16 | Supernova 1300W G2 | P500A | H150i PRO | K70 | G502Consoles: PS5, XSX, PS4, Switch X 2
#81
jackal24
Re: Fixing EVGA's 7 Figure Problem with FTW3 30 Series cards. 2021/02/21 23:28:40 (permalink)
Well, reading these forum posts have been a bit of a nail biter for the past two months. I have a 3080 FTW Ultra I was fortunate enough to snag during a drop at Micro Center in November and it's been problem free...so far. For the first two months of use, I was never really concerned because I was completely oblivious to the issues ya'll have been having: never bothered overclocking it (PX1 was pretty much only ever used to play around with the RGB lighting) and I've never experienced any crashes in the games I'd ordinarily play on it (Cyberpunk 2077, Fallout 4 with an ENB that made the 2080 Ti cry at 1440p, Gears 5, Doom Eternal, and so on). About a month ago I decided to give GTA IV a spin because...why not, it runs terribly on everything and seeing performance akin to my C2D E8400 + HD 4870 combo back in the day was nostalgic. No crashes or black screens with a whopping 6% GPU utilization and less on the CPU (undervolted 5900x). Played around in GTA V for about an hour or so just to compare the two and, like wise, no crashes or instability.
The micro-second I stumbled across this thread, I locked the voltage and set the curve to tap out at .875v and 1800 MHz and I've yet to play the GTA games again. Fired up the MCC just to see what the voltage was (constant .875v) and to see what the max draw was across the PCIe slot and the three individual 8pin cables (came out to be less than 250w across all 'em, PCIe peaked at 50) but exited after about 20 minutes because that gnawing feeling was clawing at the back of my mind. I've got a reasonably new 850 G3 PSU (about two years, spent most of its time on reddit or youtube) behind it all.
I've yet to have any problems but am I being overly paranoid in thinking that this card might be a ticking time bomb?
#82
KickAssCop
Re: Fixing EVGA's 7 Figure Problem with FTW3 30 Series cards. 2021/02/22 00:40:38 (permalink)
What’s the power draw on the PCIe slot. If it is under 80 using various workloads then you should be good.
#83
Rewire92
Re: Fixing EVGA's 7 Figure Problem with FTW3 30 Series cards. 2021/02/22 02:32:00 (permalink)
Wish EVGA would tell us what's going on.
This does not make me confident on the card's longevity.
#84
nosde
Re: Fixing EVGA's 7 Figure Problem with FTW3 30 Series cards. 2021/02/22 06:36:24 (permalink)
Rewire92
This is very true, i have a card (FTW3 3090) that has a great performance and i think i got lucky on the silicon
But just out of concern I ended up buying a 3090 strix that is on the way. If I don't get an EVGA return in the next few weeks, I will end up selling my card.
#85
flg2010
Re: Fixing EVGA's 7 Figure Problem with FTW3 30 Series cards. 2021/02/22 06:45:15 (permalink)
And yet another post makes me happy I decided to buy that extended warranty.  Adding 2 years is piece of mind.  I am sure I will find a place for this card even when I upgrade in a few years.
I might be due for a failure.. been using this card since November.. 2090 ftw3 ultra...
2012  red lipped version...
---Main Rig Build ---
CPU: AMD Ryzen 9 5950X, CPU Cooler: NZXT X73 360, GPU: EVGA 3090 FTW3 Ultra, MB: ASUS CH VIII Formula, RAM: 64GB G.Skill Trident RGB 3600, Storage:  2TB Adata M.2, 2TB WD SSD, 500GB WD SSD, Case:  Thermaltake ARGB View51
#86
Rewire92
Re: Fixing EVGA's 7 Figure Problem with FTW3 30 Series cards. 2021/02/22 08:41:28 (permalink)
....another crash, only at 1.05V, less than 10 hours after restricting it to that.
Guess my card is going to die soon.
What a joke.  Two Thousand Dollars.
post edited by the_Scarlet_one - 2021/02/23 03:49:06
#87
icylogik
Re: Fixing EVGA's 7 Figure Problem with FTW3 30 Series cards. 2021/02/22 09:00:34 (permalink)
My card has been running great since I set clock to -200 and voltage limit of 900mv. In fact games run MUCH better than factory settings (Gears 5, CoD bops cold war). I used to get low FPS and janky performance and it was demoralizing after I paid what I did for my card. I have begun to tell people not to buy EVGA due my own issues and the many other complaints going around.
EVGA needs to make a statement on this and work on a vbios update. And nvidia needs to improve their drivers instead of wasting silicon on freaking mining cards.
#88
jackal24
Re: Fixing EVGA's 7 Figure Problem with FTW3 30 Series cards. 2021/02/22 12:00:44 (permalink)
Gears 5 w/o the voltage curve:
Boost clock: 1905 Mhz
Max PCIe slot power: 47.9 watts
Max 8 pin #1: 108.7 watts
Max 8 Pin #2: 117.3 watts
Max 8 Pin #3: 110.3 watts
Peak GPU voltage: 1.081v
Avg framerate: 85.7
1440p, Ultra + Insane settings, SVOGI with 32 rays, VRS disabled
Gears w/ voltage curve:
Boost clock: 1900 Mhz
Max PCIe slot power: 35.6 watts
Max 8 pin #1: 86.3 watts
Max 8 Pin #2: 98.4 watts
Max 8 Pin #3: 71.6 watts
Peak GPU voltage: .875v
Avg framerate: 84.6
Without and with the voltage curve, I usually see a max of 12-13w getting pulled from the PCIe slot at idle or putzing around Reddit with Youtube in the background. In games, the most I've ever seen was around 65w getting pulled from the PCIe slot and that was without the curve. Now, it tops around 49w. The GPU voltage was all over the place without the VC: it'd peak at 1.081v, but would pingpong from .950 to 1.062 depending on the scene and would occasionally spike in just desktop usage if going from Reddit to a streaming service for a blip before settling back down. I dunno if the pre-VC numbers are good or not for what amounts to stock settings, though the uneven power draw across the 8 pins is a bit more evident with the VC in place.
Temps w/o the VC didn't exceed 70C under load but were around 40C at idle (set to maximum performance in the control panel, Windows has been set to the high power plan) and with the VC it never goes over 60c. Not a stellar result, but not horrific when one considers the 5900x has a NH-15s on it and my power-to-DB skews to quiet more than anything else (Cooler Master Cosmos II as a case, Noctua NF-S12a fans for the 120mm fans + the 200mm Noctua NF-A20 crammed in the front). Adding to that, with only an 850w unit, I figured OCing was a no-go since it seems Ampere (regardless of the board partner you're buying from) seems to have pretty significant power spikes without a VC in place and I figured I'd trip OCP if I was in the 450w range with just the card.
The last GPU I truly dabbled in OCing or adjusting voltages on was with was the GTX 570 SC I had and that was because it was a beastly sample (932 Mhz rock solidly stable at stock vcore). Since then and up until now, I pretty much left GPU boost to do it for me on every card I've owned since (GTX 670, GTX 780, GTX 1070 BE, GTX 1080 Ti BE, RTX 2080 Ti BE).
I digress. I dunno if I have a problem free sample, or if the paranoia that it'll catastrophically fail at some point in the near future is warranted.
#89
AltherianPDX
Re: Fixing EVGA's 7 Figure Problem with FTW3 30 Series cards. 2021/02/22 23:19:41 (permalink)
3080ftw3 Ultra here...
Registered a new account here to report that I'm having the same frustrating issue.... Video card causes driver crashes, black screens that seem to reset themselves rather quickly.
However in my case I haven't really experienced in whilst gaming... Rather, I experience it while working and it's driving me crazy. I use Microsoft Teams all day and video chat with colleagues, and this crashing is causing me pain a couple times a day... Quite frustrating!
I'm at the mercy of EVGA and don't really know what to do.... I installed the Precision X1 software, there was a firmware upgrade, that helped a bit, but the crashes still do happen....
#90
